Y2K Chevy S-10ZR2 vs. Y2K Ford Ranger XLT Off-Road
I am currently looking for a compact Pick-up that
does well both on-road and off. I have narrowed it
down between the Chevy and Ford. I would like to
know your opinions on which is a better vehicle
(price is not really an issue)...I am concerned
with the build quality of BOTH (heard both bad and
good about each)...which is more comfortable and
rides better and which is better off-road. I am
kinda partial to the Chevy, but I would still like
to know..Thanks for any help
Just remember to take EVERYONE'S opinion with a grain of salt. Or, you can do what I did. Test drive each truck. If the dealer will let you, drive them home for a day or 2. That way, you can really see what it'd be like to live with each one from day to day. I guess the dealer's think if you drive it for a couple of days, you'll just be overwhelmed with the "new truck fever" and be more likely to buy on the spot. (sales pressure)
Good luck! If the dealerships you go to are anything like the one's here in Arkansas, you'll need it!!
keith24
ps. thank god my dad didnt disinherit me
Thanks in advance!
Would like to see your guys rangers post online sites or e-mail me Rwhit829@aol.com
If you go to a larger tire, you're going further for every revolution of the wheel compared to the stock tire. Your odometer will thus understate the actual distance travelled. In my own case, I figure about 9%. So you'll need to adjust the odometer reading when calculating mpg.
Large tires will also increase rolling resistance and wind resistance and thus decrease real mpg. I'd estimate only about 1 mpg for my old Ranger since I didn't get too "radical" with my tires. Others on edmunds.com have reported about 2 mpg less.
Since my 4x4 Ranger is so old (1985), I won't participate in the Chevy-vs.-Ford debate. But I hope this helps!
Dan
Yes, MPG is decreased about 1-2mpg, and ride is a bit rougher now. The Firestones are NOT offroad tires. YOu take the chance with the 4ply of easily tearing or puncturing your tire when your out in the middle of nowhere. Some tire stores will take your Firestones in as a trade or credit towards a larger tire if the Firestones are virtually new. This is how I did and and it only cost me $275 for a set of 4 Goodyear 8ply all terrains. The tread pattern is much more aggressive. Believe me the Ranger looks 10x better with a set of 265's or 31" tires on it. This one reason why Toyota's looks so good and seem to stand taller than the Ranger. But after you put the larger tires on the Ranger it all comes out in the wash.
What performance numbers are we talking about? 0-60? gearing? Don't forget a ZR2 will also cost about 3K more than a comparably equipped Ranger. And the Ranger has a better reliability rating than the S-10 period. This is no secret either. Check Edmunds, Consumer reports, carpoint, JD powers.
Toyota is overpriced, overrated, over the hill, and most of all finishes LAST in the crash test at www.crashtest.com, and carpoint.
From what I have seen with my Ranger with 265's the Tacoma with 31" tires has probably a 1/2" advantage. I do have to say, I sure wish Ford would stop putting those damn Firejunkers on the Ranger and offer some real all terrains like Toyota/Nissan/Chevy
By the way my Ranger is a 91 XLT Supercab 2wd, just a couple hundred shy of 200,000 miles. Still Mechanically sound
Total miles 160K. Frequent oil changes with only Valvoline. Ok, as far as 4x4 capability the truck was champ even at 160K. Went through mud, snow, ice, etc...without much trouble at all. Drawback was that the Rangers had (still have?) a little more ground clearance than the S-10's. Plus side is that I never experienced tranny problems like some of my Ranger buddies. I personally enjoyed the S-10, but most friends that had similarly equipped Rangers were pleased with their trucks too. Get the truck you want, at the proce you want, with the options you want. I'd just be a little leary of Ford's tranny problems from what I know.
http://good-morning.com/wwwboard/messages/1304.html
http://good-morning.com/wwwboard/messages/1456.html
http://good-morning.com/wwwboard/messages/96.html
http://good-morning.com/wwwboard/messages/595.html
http://good-morning.com/wwwboard/messages/550.html
hope this helps
road test review:
Satisfaction: Remains high in spite of owners' complaints about reliability problems.
That sure says Ford is reliable. Seen too many unhappy people with Fords, including myself, to ever own one again. Chevy, Dodge, Toyo, Nissan - anything but a pushrod Ford truck.
My brother-in-law had his tranny on his '87 Ranger start slipping out of gear at 145K miles. I might attribute more of this to his never changing the tranny fluid and driving the truck like a bonehead, though.
The S10 seemed a bit cheesy and cheap-looking. That handle in front of the passenger? What's that? Big turn-off to look at that thing. I can't say how well the interior would hold up, though. S10 owners? Any squeaks and rattles or breaking, substandard parts?
But a pushrod Chevy truck would be...OK? Please explain.
Cygnusx1, you may be able to convince us that you,
as an individual, had a problem or problems with Ford products. However, you will never convince us that all Ford products are as bad as you seem to think they are. Vince8, Scottsss, Cthompson21, and myself are all satisfied owners of Rangers or B-Series trucks. There are thousands more like us. If you believe that we all made a mistake in our purchases, then you are very naive, my friend. Oh well, battle on Don Quixote. And good luck, you're going to need it...
I'd love to have this vehicle. Yessirree.
Question: I recently bought a 1990 F-250 SuperCab XLT Lariat Centurion 4x4. It has the 7.3l diesel and the E4OD transmission. Up till this truck I have never owned a truck with an automatic transmission, can anyone tell me any does and don'ts? Also I have heard rumour that this transmission is prone to failure. Is there any sustinance to this?
REPLY: I owned a 95 f-350 crew cab 4x4 with the auto and the 460 gas.I used this truck for work both on and off road. My average G.V.W. averaged about 9000 to 9500 lbs. The tranny went at 56,000.Fortunately I purchased the extended warranty and Ford repaired it no questions asked. The service writer did inform that there were some problems with that tranny.On a better note I am now driving a 96' ,same package,same workload, 72,000 mi. no problems.
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC
Manufacturer: FORD MOTOR COMPANY
Mfg. Campaign #: 99V204000
Year: 1999
Make: FORD TRUCK
Model: RANGER
Potential Number of Units Affected: 322
Manufactured From: DEC 1997 To: DEC 1998
Year of Recall: '99
Type of Report: Vehicle
Summary:
Vehicle Description: Electric vehicles. The transaxle may have been manufactured with the park detent spring misaligned. If the spring is misaligned, the park mechanism may not engage when the shift lever is placed in the park position.
If the park mechanism does not engage and the vehicle operator has not applied the parking brake, the vehicle could roll free as if in neutral.
Dealers will inspect the transaxle and any with misaligned park detent springs will be replaced. Owner notification began July 28, 1999
By your ridiculous logic, I could say that:
I had a Olds Cutlass Supreme Int'l with a HO Quad-4. The head gasket blew and cracked the head at 75K miles (this is true). This makes a Chevy S10 a terrible truck because the head gasket will blow and crack the head.
It doesn't actually state how many rangers were affected by the throttle cable recall.
Why don't you post the recalls that affect the S10?
Hey spoog jr. we get it, Nissan's are the best LOL!!! and Ford sucks. Now run along little boy.
NISSAN!!!!! HAHAHA what a joke.
good. The latest 2000 Consumer Reports Reliability
Ranking ranks the Ranger (and I quote) "Worse Than
Average". In fact, only two trucks ranked in the
"Above Average" category for reliability. Tacoma
and Frontier!! And before you go spouting off about how it's a biased ranking you'd better think
again. The results are taken from surveys by actual owners. That's right - Ranger owners ranked their own trucks "WORSE THAN AVERAGE" LOL! What a hunk of junk. Where are all the satisfied owners??? Oh, that's right, they're all at the repair shop because their Fords won't run. LOL! Hava nice day......worse than average...
And..."A4LD - Premature Converter Bushing Failure & Seal Blowout."
And for the manual tranny we have - "The hydraulic clutch, slave cylinder/throwout bearing is another item you should pay close attention to. After time, the slave cylinder fails to release the clutch completely. If you are having trouble shifting into 1st and reverse while stationary or if your truck creeps forward with the clutch pedal depressed the slave cylinder/throwout bearing is probably at fault. Unfortunately there is no easy fix here as the transmission must be removed to replace the combination slave cylinder and throwout bearing."
YIKES!!
Thanks Rangerstation, for clearing that up. More proof the Ranger is just a top notch vehicle. Gosh, scratch the surface and in minutes you can really find a lot of great info on Ford and their wonderful Ranger. LOL.
But I'd buy one way before I Ford Ranger. Also
Dan Hareud's Review of the Ranger at MSN Carpoint says the following
(there's that nagging reliability problem again, darn it)
HANDLING The base Ranger has a soft suspension and
undersize tires, while 4WD Rangers have the
opposite handicap; its suspension is too hard and
tires are too big. In either case, handling leavesmuch to be desired.
STEERING Much too slow. The wide turning radiusreally hampers maneuverability.
4-WHEEL DRIVE It's rather crude
FUEL CONSUMPTION The V6s burn a lot of gas.
This truck is notorious for problems. Further voiced by the latest survey results. It doesn't get much simpler than that.
Hmmm... I think we have the definition of "Trolling" demonstrated to us, fellas.
Oh wait! You owned some "lemon" Ford umpteen years ago. And, you can read magazines and websites! I guess that just makes you a great source of information! All of that experience and wisdom!
If you actually have something useful to contribute or debate, please do. If not and just want to post garbage, please don't.
