The site isn't smart enough to report what your vehicle was built with so I believe it provides entire history back to earliest production to latest available.
I am now waiting for someone to ask "what site"?
However I would prefer it if someone else posted web address if Edmunds OK with it
Regards
Where do you live? My Maxx suffered a lot of hail damage last week also in Colorado. I also didn't get any glass breakage. I'm curious how much your estimate was to repair.
If there is no pull (lead) at lower speeds, but it pulls at higher speeds, suspect a bad tire. If you swap the left and right front tires and the pull changes to a right pull, it's definitely a tire.
I have a 2000 Chevy Malibu, 6 cylinder and I love my car! I bought it at 40k miles and I now have 95k miles on it..pretty much all highway miles with no problems..until now.
Well, a few months ago, I did have a intake manifold leak and I got it fixed, no problem. I have noticed, even before I got the manifold fixed, that my car tends to scoot when I am stopped at a red light. It only does it every now and then, but when it does, it's extremely annoying as my car literally moves...almost feels like it's trying to take off when I'm stopped but it only does it when it's in Drive, at a red light, on occasion. *shrugs* This has got me thinking that it may be the fuel injecters..as well as what happens with my car, down below.
Also, when I go to accelerate, say, on the highway..going from 35 on the onramp to 55 to keep up with the flow of traffic, my car will scoot back and forth, back and forth as I'm pushing on the peddle to go faster, and then it will finally go faster after about 10 seconds of doing this back and forth thing. What is up with that? My father seems to think it's the fuel injecters? If it is the fuel injecters, about how much do think it would cost to repair this?
I do know that it's time for a tune up, spark plugs and all, and I'm planning on doing this tomorrow (Monday) and my husband is also replacing my water pump this weekend. Do you think it could need a tune up and not an injecter problem?
Thanks so much for any help you can give me, I truly appreciate it!
I suspect either the morons who rotated the tires tightened them so much they warped the rotors, or else the rotors have begun wearing badly.
I have read Mailbu brakes are prone to trouble. Looks like it's comming true for me.
thanks, e2, for notes on trans. I'll have to find a service station that will lift my car up so I can read the date stamped on the transmission.
And at this point I'm about ready to give up on Chevy dealer service in S.Calif.
This concerns me, as the overstated mileage on the odometer would make the actual mpg calculation appear to be higher than it actually is. Is also means the warranty will run out before the actual miles are driven.
"Even though there is not a federal regulation pertaining to odometer accuracy, some states do have specific laws. Generally, a tolerance of plus or minus 4% is allowed, ..."
Any thoughts are welcome.
PS. The only other fix, per the TSB, is to over correct the cross camber. This involves removing the bolt that connects the strut to the frame, and filing the hole. I have until 7,500 miles (currently at 6000) to see if the pull comes back, and I want to do this. That is their window for alignment work under warranty.
Do an Internet search for 'GSP 9700' or 'StraightTrak' for more on this subject. It would be senseless to modify the car to suit the tires, then have the problem recur after a tire rotation or replacement.
It makes you wonder how often this grief could be avoided just by swapping tires left-to-right.
The build date on my Maxx is March 2004. How do I know if my vehicle has the upgraded door trim to protect in side impact. Would my VIN number hold the key to the answer?
"#1762 of 1928 airbags by kurtamaxxguy Apr 03, 2005
very true on mailbus with airbags. But Even with, torso protection is only marginal (in march '04, door trim was apparently changed to improve this - I learned about it at the GM clinic, and was told, sadly, no retrofit is avaiiable for older '04 malibus)."
Thanks :confuse:
This brings to mind the recent issues many have reported with the black wearing off of steering wheel controls in the trucks or off of the stereo buttons themselves.
The car only has about 15k miles on it, and is about 18 months old. So it's still under warranty. I'm going to have the wife take it in for service, but I'm dreading a "normal wear and tear" response. I had that same response with the 1997 Malibu when it was 6 months old and the carpet fibers started coming out. That one nearly took an act of Congress to get GM / the VA dealership to fix it at their cost. This despite my pointing out that the vehicle I had traded for the Malibu was 4 years old at the time and had perfect carpet in it, showing how well I take care of my vehicles. If the trade had good carpet after four years, surely that Malibu should last at least six months before looking worse.. (the trade in was a 1994 Geo Tracker, ironically enough bought at the SAME dealership.)
Wish me luck..
As far as the buttons go- I didn't realize that the HVAC control panel faces were made the same way as the buttons seem to be: basically some sort of white material that lets light pass through with a black opaque coating over the top leaving white exposed for lettering / symbols to show through at night. If it would be more durable I guess this wouldn't bother me so much, but when it starts wearing off in under a year GM might want to have a chat with their supplier (or if it's because of a GM design spec, maybe rethink the design itself). This just looks bad on a relatively new car.
I really recommend you take to dealer to have them update your PCM calibration. Your vehicle is early 2004 build so you are likely 2 versions out of date and last version (per GM Calibration site) did this:
New calibration.....improvements for starting, idle quality, and shift stabilization affecting 3-4 upshift.
I just don't put the windows down more than a quarter of the way.
The other problem I'm having is the fuel economy function on the DIC is overstating my mpg by 1.5 to 2.5 miles per gallon. Anybody think that these two problems could be connected?
As always,
So it has the last major update that has been talked about in forum. It doesn't have the VERY last one which was only related to fuel gage operation. I think you already had work done in that area on your vehicle to address that, however
Anyone have leaking experience with a low mileage engine? Sometimes Wal-Mart techs get carried away with their own importance, although the dealers don't use the sharpest tacks for oil changes and at least WM doesn't pull the battery out of your car like some quick change places.
If you have any advice please let me know.
Unfortunately I don't know enough about the system to give you any suggestions on what type of issue you may be having though.
I.e., what kind of metal (tin, phosphor bronze, etc) ? also, are the exterior molex connectors sealed?
Connector terminal plating varies. There are a lot of connectors in the vehicle, as you know.. Standard fare is for terminals to be tin-plated but quite a few connectors have gold-plated terminals. I am not familiar with anything that has phosphor bronze and probably my description of stuff as simply "tin" or "gold" is really not technicially correct.
Almost all of the connections you find underhood, inside door or on front/rear lighting are sealed.
when I worked at GM, we once had an area for the smokers who used computers, the latter of which used tin plated connectors for memory and other innards. All the computers failed within a year, due to terminal corrosion due to the garbage from the cigs. The smoking policy was changed (outside only) and we no longer had computer corrision problems.
Other than that, the car is doing great. We keep discovering neat features. Did you know that the wipers revert to intermittent when stopped, then return to the set speed when you get going?
Davismaxx
I don't recognize that number as a valid TSB# but guess I could be wrong. Typically the format of a number would be xx-xx-xx-xxx (9 digits). I think the first 2 digits are for year. I am not sure about the rest. Closest I could come to your complaint would be TSB#04-02-35-009 but I don't know if it really applies but a better number than the one you have
The windshield wipers do have a feature where the intermittent delay varies by vehicle speed (increasing speed reduces time between wipe cycles).
davismaxx
Not sure why they would do that but the number I gave you would be more recognizable by a dealer. The date on that bulletin is May 24, 2004.
good luck :shades:
