Any clues?
Steve
any help would be appreciated!
I also believe it can be disabled through the information console where the radio is, but I don't have my car or manual handy. I will check after work and post later, if no one else has replied by then.
If you are hearing the chirp on the first button press then you can turn this off using the Driver Information Center in radio. Just turn on the vehicle and press the MENU button until a menu item comes up which says LOCK HORN (I think this is 3rd or 4th one depending on vehicle). With that displayed just press and hold the ENTER button until the display changes from LOCK HORN ON ---> LOCK HORN OFF.
You can do similar stuff for UNLOCK separately - along with other stuff as you can see.
If renter is just noticing that the horn chirps after the LOCK button is pressed a second time then that is BY DESIGN operation and cannot be disabled. It is actually considered a feature which you can use as a quick method for locating vehicle. The fob has an actual LOCATE feature but that does 3 horn chirps.
How do you activate this feature?
I would have tested this out to describe better but didn't want to annoy my wife
I had an intake manifold oil leak, trouble with the sunshades, the DVD player failed, a headlight assembly filled full of water and had to be replaced, the AC fan had to be replaced with only 845 miles on the car, window trim was replaced, and several other things all within 6 months. This car had about every problem conceiveable. I love the car and wanted a new one without all these problems.
I contacted New Motor Vehicle Board in Sacramento Ca and they helped me obtain a repurchase of that car. It took 8 months to complete. We have since purchased another Galaxy Silver MAXX LT fully loaded and so far so good. But it has only been a month.
We bought the first one off the local chevy dealers lot. It was our very first ever brand new car. What an experience.
See if you can get the dealer to order an 05 stereo not just a replacement and see if that works as well for you.
I have a 2001 malibu and am going through both of these things at the SAME TIME...only finding out that it's probably the ignition module and not the fuel pump a little too late --- having already bought the new replacement fuel pump...and chances are it's not even that problem. Oh well -- I guess we'll see tonight.... :sick:
My question is, do you think it would be worth getting the subwoofer installed, and possibly upgrading the speakers, if I'm going to leave the stock head unit in? Would the sound quality be improved significantly? Also, I've read that some of the newer stock head units GM is producing come with an 1/8 inch line-in jack. I was wondering if the 2005 or the soon to be released 2006 malibu comes with this feature on the stereo, or if there is some other GM vehicle that has this feature, so i could possibly install a stereo made for that vehicle in my car. Any information anyone can give me regarding modifying the stereo in a 2004 Malibu would be much appreciated. If anyone has any experience with this, or if you have any suggestions/ideas i haven't considered, please give me a shout. Thanks!
The ignition module , that one situade under the hod I've replaced already.
So should I replace the ignition switch, only the middle where I put the key or should I replaced the hole thing, that plastic cover that is around the cilinder?
Thanks for the help!!!!
There were quite a few nuances in operation of keyless entry and content theft that weren't really covered.
1) Have always had lead/left pull. They realigned at 9K (I paid), then again at 10K when drive link was replaced in trans to correct howling. Still had left pull. This time they realigned again and recalibrated the electric steering sensors. Car now drives straight for the first time.
2) Warped Rotors - They machined front rotors for 2nd time and back rotors for first time. Problem gone for now. If they warp again (and they probably will), I hope it happened before 36K warranty is up as they will probably have to replace the front rotors. All rotor problems are covered under new car warranty. They said they correctly torque the lug nuts, but who knows.
3) Checked A/C performance - on ride home from work in 90 degree weather, it takes a long time for outlet temp to get cold. They say it is fully charged, no codes set, outlet temp OK. I have to make sure I remember to set recirculate mode every time I use car and make sure compressor light is on.
4) Headrests and Sunroof wind deflector - they ordered the parts.
After 14 mo, I am still quite pleased with this car, and the service dept at my dealership.
My right front turn signal is interittent. Usually, the first few miles it will give the rapid clicking indicating that there's a burnt-out bulb on that side. Then, all will be normal.
I'm wondering if a bulb can be intermittent, or is this a problem somewhere else? If it's the bulb, I can handle that repair myself. OTOH, if this might be an electrical glitch elsewhere I might as well just take it into the dealer.
It seems weird that a bulb would burn out on a car that's only 10 months/10k miles old.
I have 04 Maxx 14mo/18Kmi & rotors have been turned twice already.
I went out and tried it: First, I had to empty my tool bench in order to find a socket wrench that would fit the (apparently) metric fasteners that hold the headlamp assembly in place. Then, I had to balance the thing so that it wouldn't "scratch the vehicle with the lamp or the lamp with the fender", as the manual says...while also trying not to drop the whole assembly (which would probably rip the wiring harness out).
And how, pray tell do you remove the covers that let you access the bulbs? The manual makes it sound so simple: "Remove the rubber covers from the individual sockets", they say. How? There's no diagram. (And I notice that the instructions for taillight replacement are only for the sedan...I presume the Maxx requires dealer service).
This headlight design has to be the dumbest thing about this car (with the exception of those rear sunshades).
Anyway, I have an appointment with the dealer for Friday...arghhh. I knew this car was too good to be true; I hope I don't have to go through this over a simple bulb replacement every 10 months. :mad:
Three years ago, I had the controller replaced, so this one has lasted that long. I remember using it this past May and it worked fine. Seems like the problem only crops up during warmer weather (it's 90 right now).
Also, I noticed (the first time I had the problem), that turning the defrost on would NOT fix the problem. I was thinking the A/C button itself was faulty, but that wasn't the case. I could still hear the compressor clicking on and off with defrost selected (and A/C not turned on). To me, that points to a more electronic problem, not a "dirty button" or "contact" problem.
Is this typical? Has anyone actually done the cleaning technique described in that PDF? Any help is appreciated! Thanks.
Globe199
What does it indicate? Is there a fix for it?
The car has 10,160 miles and was built in Jan.2004.
Other than that I have noticed a very light clunking noise while driving on uneven surface and break squeal at low speeds (15-30 mph.)
:confuse:
The sunshades don't give me any more problems and stay in place all the time.
My Maxx still running well....Feb 04 build....purchased in Mar 04...and about to roll over 31K ......still loving the car!
