Odds are excellent that you've the '04 Mailbu " bad steering columm " problem, and eventually your car will loose power steering altogether or possibly veer in one direction or another due to an unbalanced servo system.
Your problem is in the early stage and the dealer should replace the columm and recalibrate the steering under warranty. This is not trivial and many dealers get it wrong (you can see earlier posts about that here).
In my case it took two visits to the dealer to fix this - first one installed columm and calibrated ok, but forgot to lube it so it started grinding after a short time. The second dealer lubed the columm properly and so far it seems ok.
The sunshade problem seems to crop up in really hot climates or rough roads or both - which is true in my location. I almost never use the shades anymore (their black color only serves to heat the car up, making the problem worse).
Might indicate a loose power or ground connection somewhere (like battery cable).
Radio stations stay in "non-volatile" memory so that is why they might not be lost but time is.
I have a 1999 malibu which has developed a similar problem. When the needle hits 1/4 tank, a turn or a bump sends the needle to empty and light comes on! And I do not think it is consistent
Cannot figure out what the problem is.
I hope that the dealer will fix the steering problem the first time I go there and will not make the interior dirty like it was the last time. But, who knows?
I also plan to replace the headrests.
Being a flight attendant, my schedule is hectic. I called the dealer and they said that unless it was blinking, it wasn't a big deal. Well, guess what? I came home Friday and today, Sunday, I ran a few errands. After finishing the last errand, I came out to my car to find it dead. It won't turn over! Now what?!
I've been reading these posts and my conclusion is that I have an ignition module problem. Since I need to fly again tomorrow, my dad will be dealing with this issue. I told him to make sure and mention the ignition module, as I doubt it's a fuel tank problem after reading so many posts here. I don't want to spend that much money fixing it, either, as I am trying to locate a new car. That takes time, though, and I'm in serious short supply.
That brings my next question, do I buy another Malibu? I heard the 04 and 05 models are a vast improvement. Can anyone attest to this? I'd like to go foreign but I live in the Midwest and there aren't too many dealers (or service stations) in my area. Also, my dad is heavily against foreign cars (Not that his opinion matters much in this area, as he has chosen all of my cars to date and they have all been evil!) I really don't want to buy another junker! Please give me your honest opinions and if not a Malibu then what???
Thank you SO much!
Keep in mind that the 04 was the first year of a brand new design, so some bugs would be expected. Presumably the 05 models are better. Also, choose your dealer carefully -- mine has a super service department and believe me, that makes all the difference!
I compared the Malibu closely with the 04 Honda Accord and although I think the Accord is just a little more nicely finished, I really don't think there is enough difference in the overall driving performance to justify the extra cost. In my case, with the GM Card rebates, it would have amounted to over $2000.
I think the 04/05 Malibu offeres a lot of bang for the buck: Smooth, quiet, solid feeling, decent performance and great gas mileage (25-26 MPG in suburban stop and go). Good luck with your decision!
I haven't been able to reproduce it reliably and the dealer thinks I'm crazy. As long as it doesn't shorten the life of the starter or some other component, it's not a big problem. But not having an explanation is rather annoying.
Are your steering columms factory issue, or have they been replaced?
One thing you may end up with when the steer columm is replaced are rattles in the dash. My Maxx gained several after that swap, but the dealers I have would probably destroy the dash fixing the rattles, so I live with them.
And incidently, t's not just the General's fault. Every first year car I have seen posted here is having more than its share of problems. Unfortunately there aren't enough changes in the newer Maxxes to make "trading" to a new one (in the hopes the bugs have been banished) cost effective.
Still very happy with the car and would recommend it to anyone.
"Because a couple of you mentioned Temp gauge I will do some more research (will take a while)."
For the third time my temp gauge is reading full cold and the engine cooling fans are running constantly. Check Engine light is not on. At the first occurrence the condition self-corrected and the second time the dealer replaced some relays.
Any lasting remedy?
THe nfew Malibu scores highest in its class when it came to intitial quaility. The old version the last couple years had taken that place too. But the are two enirely diffferent machines. the new one feel so solid and maintains its composure even on rough roads.
do you research than look me up if you want more insights.
Bruce
Could this be the sound?
So far seems to occur in hot weather.
However, since I don't always remember to shut down, that could explain the intermittent nature of the noise. I will have to pay more attention. Thanks for the info, I don't think I would have ever thought of it myself. It's good to have a little peace of mind.
Today, for the first time ever, my DIC told me "Diver Change" . No where in the manual does it mention this is something the DIC can say, so maybe it's personal......
Seriously, yesterday my CD player stopped working. I figured it was too hot and would be fine after I restarted the car. Sure enough, the next morning everything seemed fine, until I wanted to play CD #1. It said it was playing CD 1, but track 0, which I had never seen before. So, I was trying to get it to work and the "Driver Change" message appeared. I figured it had to something to do with my using the other key fob (which I've only used a few times ever) this morning. But, still, it was a weird message, don't you think?
By the way, i ejected CD1 and now everything is fine. Anyone ever gotten that message before? e2Helper, any ideas?
This was probably a store-bought CD, right? Any time someone mentions a home burned CD it is of course suspected
If you continue to have problems I would suggest you take it to dealer. I haven't heard of your specific complaint before. I believe you had your radio already serviced in vehicle a while back, right? But that was a long time ago and so updates are likely available for certain complaints
As far as the DIC message, do you remember which line of the display it was in (top or bottom)? And when it was displayed were you using the CD or AM or FM radio? I have never heard of a message like this but FM radio stations have the ability to transmit Radio Data System Messages to your radio and I have seen a few cases where some radio station in Canada was sending a cryptic message "Inovonics Model 711" which caused a few customers to take their vehicle to dealer for service :surprise: (I think it was 99.9 FM in Winnipeg)
It's good to know my Maxx isn't tired of me, cause I still love my Maxx! :shades:
I have a couple questions: does the trany on an 04 Maxx LS have a magnet in the transmission filter pan?
If not, could a person place one in the bottom of the filter without adhering it with a strap or glue?
Far less important is do you know if the oil drain plug is magnetized and would there be another good place to stick magnets on this car to aid in getting ferrous particles out of lubricating fluid?
crosby1
My husband took it to the local auto parts store & had them check the computer codes. Turns out that I had a spark plug misfiring, but that was all. He also had them check the alternator, but it's running fine. I am at my wits end. I would love any suggestions that anyone may have! Thanks!
Any help would be greatly appreciated. This has been going on for months nowl
Are you sure the radio changes to FM1 or does it change to AM? My experience has been that the radio will switch to AM but.........do you listen to XM1 or XM2 usually? If this transition occurs pretty much within a few seconds after starting vehicle I would suggest your dealer look at this document: #PIC3193D - don't tell them who told you . If it happens sometime after just when driving then this is probably not applicable.
As far as airbag warning light, has any of your repair orders ever mentioned what fault code they have read from vehicle?
Here's a thought. The dealer has experienced the air bag light coming on but never the radio switching bands. They've kept it for 2 and 3 days already testing and driving the car. They change some things and truly believe it's fixed. And I believe them. But as soon as I pick up the car, the problem occurs within a mile from the dealer. Now, I only leave the key with them, not the key fob. I always use the fob to unlock the car when I pick it up. Could the key fob be sending some "glitchy signal" to the radio that causes the problem?
A couple of days after the new tank was installed a fuel line came off and fuel gushed out under the car. The tow truck driver would not take the car until the fire department came and OKd the car to be moved. Towed in to dealer, line re-attached.
Now, a few months later, car stalled on freeway and there was fuel leaking out underneath. Towed in again. Now they say it's a problem with the fuel pump. Tomorrow will be the third day it's been in the shop since it stalled.
I don't know. It's a nice car when it's running, but it's by far the most unreliable car I've ever owned. Never been stranded before by a new car even once, let alone twice, during the first year. It's also been in the shop for steering clunking, radio replacement, window shade replacement, pulling to the left, tailgate rattle, misaimed headlights, etc. This is the car that carries my wife and daughters. I don't want them running around in something that might not get them home, or strand them in an unsafe place.
This car is a lemon under the legal definition in California. Don't know if I'll press it, but I could. I'd be a fool to buy an American car again.
Davismaxx
2004 Maxx LS
VIN 237245
built May '04
I will have to think a little more about it.
If you wouldn't mind if you would reply back with last 6 digits of your VIN (not the whole thing!) I might be able to help a little more.
The key fob signal (specifically UNLOCK) IS used to personalize radio settings to which key fob (fob #1 or fob #2) was last used but that would be evident immediately when the radio first turns on.
The dealer still has the car. they say they are trying to get an engineer on site to help out. The dealer even mentioned (before I brought it up) about "buying back the car". don't know if it will come to that or not
