Did you fix yours and if so how?
Thanks for the info.
Once when starting the car it sounded as if it was only firing on 2 cylinders - I have the 4cyl. Ecotec - this went on for at least 30 seconds. Switched off and re started and the engine was fine again. This and other random events convinces me that some computer is hanging up or is unstable. I just hope a fix is on the way because I find it very annoying. I don't know what to expect next.
The radio with Six-Disc CD changer is another radio version which also has 2 lines of display and 4 buttons although they have different functions.
Do you know approx build date of your vehicle?
It also makes the steering feel lifeless and numb, and may cause it to "pulse" in the center position.
I'll have it checked again at the 30K checkup and see if it can be backed off a little. No fun having lifeless steering.
at a parking lot(moderate slope, car head down hill) I failed. The engine sound like there is no gas(I have such experience on my old car). The engine started when I tried the second time. However the sound is still abnormal. I don't know what's wrong. Does anybody have similar experience? Thanks in advance for your advice.
I think we have mentioned this before but if just one external lamp was not flashing you will likely see the remaining lamp and instrument cluster indicator flashing at a double rate indicating a bulb outtage condition.
Actually no light flashing and no turning arrow on the panel for both light and right turn. I pulled over because it was too horrible and I was really scared to death.
However, it was back to normal again when I started to drive.
This is so wierd.
Just came back from another business trip. This time got a rental Cobalt. Same rattling and clunking in the steering, and it has the electric steering like the Maxx. I wonder if GM has a bad supplier for steering components these days.
BTW other than that the Cobalt seemed like a nice little car.
DavisMaxx
2004 Maxx LS Gold
21K
5/04 build
I got under the hood and found a harness connector at what appeared to be possibly a temp sending unit on the manifold. I checked to see if the connection was good and actually it was not fully attached. I clicked the connector together and it has been fine ever since.
If the radio was on when you last drove the car, it should have turned off when you opened the door. If it didn't it could be something as simple as a sticking or shorted door switch.
DavisMaxx
04 Maxx LS Gold
21K
5/04 build
I also have problems with the idle, remote start (for about 2 weeks it refused to start every morning and it now works fine), radio (seems to like the Jazz EQ preset and won't stay on custom between starts, randomly doesn't let me adjust the Auto Vol settings) and seat heater that comes on by itself. I haven't had any trouble with the temp gauge though.
Lately the steering also seems to be difficult to operate for the first turn or two after sitting for a while. I don't think its the pavement, since I can turn it several times in place and it becomes normal.
2004 Maxx LT
15.6K
2/04 build (but came with the new column from the factory)
2005 Maxx LT
5.4K
1/05 build
Today AM: I parked the car & turned off. When I re-started it, the clock radio said ERROR? The radio didnt work at all.
Today Lunch: Car started right up, radio worked fine? While I was sitting in traffic, idiling, my car turned off (no warning, no lights came on, it just went dead) It started after two tries? I took it to a gas station & put some premium gas in it (just thought it might help)
What could be the problem?
Stalling can be caused a number of things. Based on the info you have given, things like:
Spark plugs
Fuel Filter
Air filter
Fuel Injectors
Fuel Pressure Regulator
Could all be causing the problem.
Car has 119,000+ miles. It was my husbands company car for 3 years (he had regular maintainance done) then we bought it for a great price!
Service done recently: Coolant flush (July 2005) - we put wrong antifreeze in it & had to flush the whole system to avoid corrosion.............Oil Change (July 2005)..........Breaks & rotors (July 2005)...........
Back in July our auto mechanic told me one of the belts would need changed before winter / cant remember which one?
1. Turn the key to off
2. Turn the key to run (one position before start) and let sit for several seconds.
3. Repeat 1 and 2 two or three times.
4. Attempt to start the car.
If it starts flawlessly then you may have a clogged fuel filter or bad fuel pump.
But I doubt the fuel filter is the problem or the sole problem here. But I would change it or have it changed when other things are done. It's time.
So, what's cooking here? Has this got anything to do with the endless random weird events that are taking place in my 2004 Malibu?
What do you think e2helper?
The dealer put in a new radio, but the same thing is happening, so it's probably not the radio. The service tech said it could be the programming or power source to that portion of the radio's controls. Previously, someone said the keys and/or keyfob need to be set for the car, but I don't understand that because we don't have the "personalization" option.
The car goes into the shop again next week. If anyone has any ideas, let's hear 'em.
My point is this - simply changing the radio may or may not solve the problem in your case.
I believe the erratic behavior of my radio points to a far deeper problem than the radio itself. I believe the problem is in the Body Control Module which in my humble opinion is unstable for one reason or another. Whether it is glitchy software or low voltage or voltage spikes I don't know. But something is causing these cars to suffer from erratic symptoms that clear up the next time around.
Hopefully, the fix will be as simple as hooking up a capacitor or diode somewhere to catch voltage spikes or whatever is causing the problem.
But there hasn't been an update for some time.
The 2001 had a 50 litre gas tank and I drove it approx 450 km with mix highway and city driving.
This 2005 with a 60 litre tank is empty at approx 325-375km.
When I bought it, the sticker on the window claimed:
City: 9.8ltrs/100km
Highway: 6.6ltrs/100 km
As well, the following website states I should be getting approx :
City: 24 miles per gallon
Highway: 34 miles per gallon
http://autos.msn.com/research/vip/Spec_Glance.aspx?year=2005&make=Chevrolet&model=Malibu&t- rimid=-1&src=vip
I'm not getting anywhere near that.
When I brought the car back in the first week, I was told that the car has to be worked in and it should improve after the first oil change. It has not improved.
I brought the car in last week and was told that their test showed nothing wrong with the car.
I asked them to check the brakes as well to see if they may be sticking since they were already squealing after only 8000km. The brakes are still squealing at stops.
The service technician said the stats in their promo ads were based on perfect temperatures and conditions and that the 4 cylinder works harder to carry the car and that is why I am burning so much fuel. The service guy actually said he wishes his car got that mileage.
My 6 cylinder Malibu, or even my Chevy Blazer and Ford explorer got better mileage than I'm getting with this 4 cylinder with 60 litre gas tank.
I'm waiting for a response from GM on the issue.
I think you might have a problem with yours.
Here is what GM Calibration Website says about latest version: "New calibration with diagnostic enhancements for DTC P0340. Also improvements for starting, idle quality, and shift stabilization affecting 3-4 upshift."
It supposedly is up to date wrt PCM cals, etc.
Also, for first time, just after starting and when the auto headlights came on while car was parked, all the gauges went to the minumum values (fuel, temp, etc) for about 2 seconds and then came alive again.
Is there a fuse or connection I can check for possible corrosion or looseness?
Dealer ofcourse says this is normal---BS.
