Chevrolet Malibu: Problems & Solutions
Discuss any Malibu problems and possible solutions here.
Now: any suggestions why my 02 Malibu handles so badly. Hard to hold a straight line, terrible in cross winds, twitchy. Alignment good, tires are OEM Firestone Firehawks(26K and look new) at door frame recommended pressure. Pretty much been like this from day one. No history of curb climbing, off roading, or road killing. Suggestions:
I might be going in on Tuesday, rather than Monday. We're in for a cooler snap, so I doubt I'll need the A/C on Monday. Sounds like it best not to use the A/C until it's fixed.
Your problem sounds eerily familiar to a shot battery. If that proves to be the case, they will try to sell you a GM/Delco "Professional" battery, which isn't worth dirt. That one lasted 6 mos. Go to Sears and buy a "Gold" battery.
Mine doesn't always start willingly lately, either. I mentioned it to the dealer last month when I was in for a major brake re-do and they "couldn't duplicate the problem".
My neighborhood Chevron station switched to Sunoco recently, and I've come to the conclusion that that's the problem. Have driven the extra mile lately to get Amoco, and it seems better.
Also, the car often smells like rotten eggs, which suggests, on top of all else, my cat conv is probably shot, or headed there.
You might have fouled your spark plugs, which would then lead to a full tune-up, which Chevy doesn't require until 100K miles. Uh huh.
I've now determined that, believe it or not, my A/C problem is lizard-related. I ran a few errands yesterday, A/C was fine. Same today.
Not to be gross, but I'm thinking that the racket was the fan chewing up a lizard carcass. Thank goodness it didn't spit into the interior of the car. Now THAT would've been GROSS!
I'll wait for a spell to see if the problem recurs.
original post:
When I tried to start my new (used)2001 Malibu, I turned the key past the "on" position and all I heard was a rapid clicking noise. Lights and radio worked so I assume my battery is not dead. I think I turned the steering wheel and "locked" it, then the car started right up. Later the same day this same thing happened again (after I had stopped and started several times). I never could get the car to start, and turning the steering wheel I could never get it to "lock". Now I get no interior lights, headlights, or radio, absolutely nothing, even when trying jumper cables. I'm guessing I have confused the security system and it's locked up tight, but I have no if this is correct or WHAT I did. The car was towed to my gm dealer, but I haven't heard the diagnosis yet. Does anyone have any ideas or similar experience?????
Hopefully my action will prevent warped rotors. I'll keep you posted on this.
I have a 98 Malibu with a little over 146000 miles on it.
I have a very strange problem with my Malibu. My "brake" warning light in the instrument panel is on, and thinks that the parking brake is engaged. For example, after I fully release the brake and then try to drive, the "brake" warning light is on and it dings for a couple of seconds attempting to remind me to check the park brake. Also, my ALC is inoperable with the "brake" warning light on. Accustomed to five years of using the ALC system, I keep leaving the headlights on at night (I'm afraid that I'll eventually forget to turn them off, and drain my battery.)
So, I was wondering if this happened to anyone else before? If it has, is there a way that I can fix it myself without having to take in to the dealer. I consider taking it to the dealer the last resort.
Jeremy
1. Disconnect the negative battery cable.
2. Detach the electrical connector from the fluid level switch.
3. Using needle-nose pliers, compress the switch locking tabs at the inboard side of the master cylinder reservoir and remove the switch.
To install:
1. Press the fluid level switch into the master cylinder reservoir until the switch snaps into place.
2. Connect the negative battery cable.
Hope that helps!
Jeremy
However, looking at my owner’s manual it is not clear. It says "You can use wired headphones (not included) or the wireless headphones." Not a very clear statement and different from the 2004 manual. I would not put it past my "dealer" to snag them and sell them on ebay
Has anyone tried this?
This is NOT a safety issue. it is a damage/cost issue and besides the fact that this test does not predict real world crash damage, a consumer is only going to be responsible for the deductible amount, so the issue of $1,500 damage or $5,000 damage is moot.
Maybe I'm just venting... but I got a brand new Chevy Malibu LT back at the end of December and already it's been in the shop three times, and I'm about to take it back for a fourth.
First time: During the bitter cold we get here in Toronto, I had problems closing the door and trunk; the little plastic latches froze and the doors just bounced back open. My wife had to sit in the back seat holding the door closed as we drove home. Also, the cables in the trunk that power the lights in the trunk lid were binding against the weatherstripping around the trunk, and would have eventually split it.
Second time: The "1-6" button on the steering wheel radio controls did not work for switching between the CDs in the 6 CD changer. A new radio had to be ordered and changed out.
Third time: I noticed that the steering was a bit off centre and the car was pulling to the left a little bit, so that had to be adjusted. The car only had 2800km (1750mi) on it, so it was just about halfway to its first oil change.
AND NOW... as I was driving home, the "check engine" light came on, and the message, "POWER STEERING" came on my D.I.C. -- that's right, my power steering system failed. I turned the car off and on again, and it worked for a bit, and then failed again! I thought this was supposed to be a brand new electrical power steering system that was going to be so much better than the old hydraulic type.
In conclusion, I've always had GM vehcles, and this time I almost waited for the '05 Nissan Altima. People generally bash GM, saying that their cars are unreliable, and of poor quality, fit and finish. The new Malibu was supposed to be the car that lured Camry/Accord drivers back to GM... and I know the first run of any new generation of car is bound to have its problems, but you never want it to happen to you. All I can say is that the service at my dealer is excellent, and they've kept me happy by supplying a free rental car without me even having to ask, for as long as I need it. When everything is working on my Malibu, it's great. But I would suggest that anyone who is looking at the 2004 Chevrolet Malibu wait until they work some of the bugs out for 2005.
At the very least, I would begin to make contact with the local GM district offices for your region, just to protect yourself.
One of my daughters bought a Chrysler Sebring a few years ago that was about the same as what you are describing. She had it in for substantial repairs 6 times in the first 4 months..different problems each time. She raised enough cain that Chrysler took it back and gave her another one which did just fine for the 3 years she kept it. Maybe your car was built on a Friday afternoon when the plant guys all had a hot date waiting for them.
I took my Malibu in to the dealer to get that power steering problem fixed. They had to replace the entire steering column and the electric steering motor. Everything seems fine now... but I'm skeptical. My wife thinks I'm a bit obsessed, listening for noises, making sure the steering is straight and the doors all close properly.
On the up side, nobody changed my radio station presets in the Grand Am rental car I had since the last time my poor Malibu was in the shop.
Cheers!
I just got the car in the middle of January, and knowing my luck, I got in an accident in February which required a wheel, ball joint, and other assorted parts to be replaced, along with some minor body work. I was concerned that maybe this problem was related to all that, but I guess it's not. Now if they give me any trouble I can say "I know this guy in Toronto..."
Now for the new problem, as of today. Let's hope you don't get this one next. I was driving along uneventfully once again, and when I went to accelerate, there was no power. Then the car surged ahead. From that point, there was intermittent acceleration and lack of power. Then the car stalled out, and I had a hard time getting it started again. Since then, it hasn't stalled again, but still the same acceleration problem. When I take off from a stoplight, it feels like I'm in a car with someone trying to drive a stick for the first time. So now the car is officially out of commission until my service appointment.
Good thing I have my Alero to drive, which I also have to take in for a broken power seat, faulty climate control knob, and clattering noise under acceleration. It also suffered the frozen door that won't close this past winter. I'm starting to wonder if my GM loyalty is misplaced...
Sorry to hear about your problems so far. Hope you like your Malibu in general. Is it a Sedan or Maxx? 6 cylinder or 4 cylinder? Definitely have dealer take a look at the steering problem. Even if isn't happening when they see it there will be diagnostic information stored which will give them enough info to figure out what happened. On your other complaint, it is new one to me. Did you ever see a Check Engine Light or ENG REDUCED PWR message in your radio Driver Info Center? Keep us posted !
I called up the dealer this morning, and told the service manager about the new problem. He had me bring the car right down and gave me a loaner... an exciting white Lumina. I also asked if he'd seen any other cars with the power steering problem, and he said he's had one other one, the solution to which was the same as tim described above. No other ones with the acceleration problem, though. And the check engine light did come on, but there was no warning on the DIC.
I didn't mean to seem too disillusioned with the Malibu, or GM cars in general. It's just so many things were going wrong at once, but I don't think it's necessarily going to be a trend. This is only the second time I've had to take the Alero in for a problem in over 3 years, and the first time was something very minor. Overall, I've had good luck with GM products, especially considering some of the horror stories I've heard about other cars.
And I'm glad to hear the Check Engine Light came on, it may help them with figuring out that issue.
The steering problem will likely require replacement of steering column but I am sure that will address the problem you were experiencing.
If any more questions/observations on operation of your Malibu LS come up please post them.
Ken
Thanks for the reply
