Chevrolet Malibu Accessories & Modifications
Accessories? Mods?
ventshade makes them for the 2004 classic sedan...but the maxx has a cruved side rear window and the drivers side window is about 1-2 inches longer than the sedan....
any help?
You might try searching the manufacturers web site...search using "ventshade" or "ventvisor" from either Yahoo or Google...there are several hits. If visors are commercially available for the Maxx, the web-site should also give you sites that sell them.
And while installing them sounds easy, to do it right normally requires the removal of at least two tires to get enough room to work (usually the rear tires, since the fronts can be turned left or right as needed to get clearance for the drill / screwdriver).
on another note..anyone consider a custom wheel...16X7.5 with a lower profile wider tire for their maxx? a 255/55/16 tire?
Anybody added a wind screen yet to the sunroof? Bene Vento has a nice clip no drill or tape application..the first Ive seen specifically for the 04 mailbu with the factory sunroof.
for the sunroof wind deflector you can order it here... www.protriminc.com click on the wind deflector...part number BV1213 they are slightly higher here..I got mine off ebay for $10 less from this same firm....easy installation and great looking..plenty of room for the XM and OnStar antennas as well.....I had the window deflectors and the sunroof deflector installed in 15 minutes..
http://home.att.net/~p.oswald
Please email me about the navigation system and the installation in your Maxx. I upgraded my OnStar service so that I can get road directions, reservation and such, but your navigation system sounds like the ultimate toy!
http://hitch-web.com/vhitch.asp?CLID=2&SM=LS+Maxx+Hatchback+5- - - +Door&DR=&MD=Malibu&C=Passenger+Car+or+Station+Wagon&- amp;- amp;- amp;MK=Chevrolet&Y=2004&SMBBID=1334-74&YID=86&CID- - - =3&MKID=12&DRID=5&MDID=795&OID=8&SMID=&cm- - - dNext=Next&BPID=6&VID=28121
there was a VERY small notch that the mechanic had to make so the metal would not hit a bolt. He also had to enlarge two holes with a drill. The website I am siting will tell you if there is a "no drill" policy for a hitch. In the case of the Maxx, I'm afraid a small bit of drilling is required. After watching him for 1.5 hours, I would seriously recommend a professional put it on when the car is on a lift. Also: Drawtite and Reese are the same company now. And pao: I don't think you and I live very far apart, should you want to get together to see my hitch and bike rack. I'm in Mt. Vernon.
My fiance's over on South Washington St...
We purchased our Maxx at Anderson Chevrolet in Baltimore, MD. It was the only blue Maxx 1sb (and nothing else) in Northern Virginia and Maryland, plus the best price--invoice minus the holdback ($675 under), with no doc fees.
60 months/100,000 miles
>$0 ded. $1570.00
>$100 ded. $1285.00
>$200 ded. $1070.00
>72 months/90,000 miles
>$0 ded. $1650.00
>$100 ded. $1350.00
>$200 ded. $1120.00
Otherwise, as modifications go, does anyone know how to disable the MPH yellow light on the speedometer? I already know my car is calculating MPH; I don't need a yellow light to tell me this 24 hours a day!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1- &item=7907347036&category=42612
this price is $10 cheaper than on their website
www.protiminc.com
I paid $2,300 for it with $100 deductible - the only consideration I could get from the dealer was for them to take another $300 off the internet price I was quoted. This was in January when the Maxx first made it to the dealer's showrooms.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1- &item=7912304219&category=42612&sspagename=WDVW
http://www.weathertech.com/store/vehsearch.asp?make_id=11&yea- r_no=2004&veh_id=1148&item_group_id=4&veh_opt_choice_- id=0#item_price
