I agree with most of your argument for 4wd being better than 2wd in winter driving but there is one thing I think has been overlooked and that is tires. Most all-weather tires are especially poor for traction in snow or on ice. I have a 93 club cab 5.2, auto and lsd. I found going up even the slightest icy incline virtually impossible at times with my Yokahama A78 all weather tread. I got another set of rims for my Dak and put the new this year Bridgestone Dueler Blizzak snow tires on all four corners. What a difference it made, with cautious driving I could go anywhere (within reason) including a fresh 11" snowfall.
My company vehicle is a 4wd Suburban which is great in snow, ice and mud. It is even more enjoyable because the company pays for the gas and broken parts. I find that I take more chances using 4 wheel drive than I do driving my Dak. I would also guess that there are also many other 4wd users which get overconfident and forget they can't stop any better than the 2wd drivers. I too see many crunched and overturned 4wd vehicles in the ditch during our mid-west winters. I have a new Quad on order and really could not justify spending another $3000 for the aggressive looks and the occasional use of 4wd. Do you have any idea if the 93 Dakota factory mags (15x6)and snowtires could be used on a 00 Dak with the tire/handling package (15x8) other than probably looking strange. Best price I've found for factory takeoff 15x8 rims is $399 plus shipping.
You are right about tires making a big difference - all season tires are a compromise - they are designed to be adequate at everything, which almost by definition means that they are good at nothing. This becomes evident in extremes - and for most people that means bad weather.
Blizzaks or the Michelin equivalent (SureGrip??) are a big seller up here for winter, but I don't see them as a replacement for 4wd. They are not great on dry pavement and they usually require an investment in steel rims as well as the need to change wheels twice a year (not such a big deal). The benefit 4wd has is that you can engage it when needed in most applications - even in bad weather the major routes are likely to be clear - with snow tires you are really stuck with them for four months of the year.
Chains and / or studs are a better bet - but obviously only where they are allowed.
As far as your 15x6 on the Dakota - check the overall tire / wheel size, any difference will need the computer to be reprogrammed. I would also be concerned about the brakes / ABS - definitely research before you try it.
Is a 4wd better than a 2wd? Not always: If you are not in foul weather, or you commute over long distance, and you would like to keep maintenance and repair cost down, then your best choice would be a 2wd truck. It's not as costly to maintain or repair and has better fuel economy. Since 4x4s usually are taller they also create more drag and resistance. The up-front cost is also lower as are insurance premiums for a 2wd. To say 2wd trucks "just sux" is silly. Are there advantages to a 4wd? YES. Are there advantages of 2wd? YES. If a 4wd suits you needs-great, but that still does not make it better--just different.
Is 4wd appropriate all the time - no, that is why my trucks always have shift on the fly 4wd.
2wd has better fueld economy than 4wd - well, yes, when you are using 4wd, but in 2wd mode the difference is hardly measurable - maybe a little more drag and a little more weight. When I need 4wd I'll take its safety over fuel economy any day of the week.
Insurance lower for a 2wd - not always - there are companies in some parts of North America who seem to think that there is a lot less risk in a 4wd than a 2wd and insurance premiums reflect that.
My 4wd has the ability to drive in 2wd or 4wd modes and I like it that way - my and my family's safety comes above a few bucks for gas or a little additional maintenance - I want to be as safe as I can be, and 2wd is not as safe as 4wd in marginal conditions.
I really fail to see how a 4wd cannot be 'better' than a 2wd. It has both 4wd and 2wd options - effectively everything that a 2wd has and more - so by definition it MUST be better. That logic doesn't hold true for full time 4wd, but I have spoken out against them many times on various topics here.
Whether the trade-off of more functionality vs. more cost is worth it is where the debate starts - I am just amazed that people put their families at risk by buying 2wd when 4wd would help - even only occasionally.
i have a few questions and try and understand that i know we're talking about trucks. i also am not trying to be a smart [non-permissible content removed]. 1. based on your last post are you saying that people with 2wd, whether it be truck or car, are putting their families at risk?
2. if someone buys a 2wd, whether it be truck or car, they're going to pay higher insurance rates?
3. based on question #2 should'nt auto manfactures offer a choice of 2wd or 4wd for the full line of their product?
I actually said where 4wd would help - meaning if you lived in a part of the country where road conditions are bad at certain times of the year. I also think the vehicle comes into play here - FWD wouldn't give me as much concern as RWD and a fairly evenly balanced weight distribution wouldn't give me as much concern as a weight distribution that has little weight over the driving wheels.
The problem with 2wd trucks is that both of these occur - RWD with very little wieght over the driving wheels. If I could put 4wd on just one vehicle type it would be on a truck for that reason - give me a 2wd SUV before you give me a 2wd truck.
Point 2:
No, in fact generally speaking the opposite is true - but in some areas where the weather is regularly bad it is cheaper with some companies to insure a 4wd than a 2wd.
Point 3:
Well, no not really - there is limited benefit to adding 4wd to something like a Ford Taurus - it has a fairly even weight distribution, with the weight bias in favour of the driving axle, and it is FWD.
Subaru has proved that 4wd (or AWD in their case) can be marketed effectively, and as AWD / 4wd systems develop I wouldn't be surprised to see more computer controlled systems that have the capability of diverting traction to all four wheels. I don't think we will ever see a shift on the fly system in a sedan.
idrive a two wheel drive ranger and have learned that where i live...south texas...it sucks when it rains...no matter what i do my little truck gets no traction. I've seen 4 wheel drive trucks zoom right past me. They are not getting good traction either but 1 wheel in front and opposite wheel in back (ordinary 4x4 setup) spinning sure does help the weight distrobution in the big or little trucks. Butmost people will find that locking or limited slip rear differintials in a 2 wheel drive truck will get you just about anywhere you wanna go, if you know how to drive them. ive seen 4x2's posi's mud better than 4x4's.......alot of times it just depends on the driver. so the point is if you dont need 4x4 but you need that extra security, and dont wanna spent the extra money, spend the extra $200 and get the limited slip rear differential for your beloved 4x2.
I've always said a 2WD should have a Posi rear...but a 4WD doesn't need it if you know how to "pick lines"..so to speak. Mudding is more than just hitting the gas and brakes....
remember - I drive a Dodge, so I need all the help I can get :-)
Incidentally - saw an article on the new heavy duty GMC / Chevy - coming this fall to a dealer near you!!!
Looks like a nice truck.
Also heard rumours that Dodge's Ram makeover is going to include a distinct styling differential between full size and heavy duty - I even hear that the heavy duty may not be that dissimilar to the Power Wagon concept.
trucks I have seen of the powerwagon are cool looking...as is the Post '94 Ram...since 94 is the only time Dodge has sold trucks! Let's hope they have something other than an engine made by someone else (cummins) that makes any good power. Wether it's a Ram..a PT cruiser..or a Stealth...they seem to only sell on looks....but hey..it seems to be working right?......Gives my wife a good job...so you go Dodge buyers!!
You wouldn't be a Ford man would you? Last I knew Ford was using a Navistar diesel and calling it a Ford. At least Dodge has the honesty to call theirs a Cummins, but why wouldn't they when it's the best engine anyone puts in a pickup truck? Ken
I be a Chevy man.....which I know their 6.5 Diesel sucks....but no where have I said ever that it was a good diesel....now the new Duramax/Allison Combo coming out.....there is an engine...(even though it's an Isuzu!)
You have my deepest apologies for even thinking you could be a Ford man. I have great hopes for the Duramax myself. Isuzu has been building heavy duty diesels for a long time and from what I've read Chevy may have it right this time. I sure hope so, If I hadn't needed my new truck now I may have waited but Chevy has been very strange about delivering 3/4 ton trucks. Deep down I've always been a GM guy and if the Duramax is equal to it's press releases we will all be winners because the competition will have to keep up. --Ken
Pay attention now. I've been writing about the Ram diesel I ordered on March 21 and took delivery on May 5, so I think that qualifies me as a Dodge man. Anyway, Ford does call the Powerchoke a Ford engine, although if you read carefully they will tell you otherwise. However they don't make it obvious the way Dodge does with the Cummins.
Pay attention to what? Navistar is a separate company and nowhere did I ever get the impression that Ford makes the diesel. Are people that dense? Dodge man? Ohh....now you're qualified to call the Navistar a "powerchoke"? Did they give you that great material at the Dodge dealership?
The point is that not everyone knows what you and I know, and that is why I say Ford does not make it well known that their diesel is not a Ford product. That doesn't make it a bad engine, in fact that's probably why it has been a success. I have been told by someone who thinks he is a lot smarter than me that the engine in his Ford is the same as the engine in my Dodge because (he thinks) Cummins is owned by Ford. He also said I was full of crap for suggesting Ford did not make his engine.
Of course there are just as many GM and Dodge guys out there with bricks missing as there are Ford guys, but whatever they drive they make life interesting. I meet with a bunch for coffee almost every afternoon and there is always an expert in attendance on whatever the subject of the day is. I have to admit sometimes I may be it that day, but it's all in fun. I hope you understand that's what this is all about for me too. If we all liked the same things this would be a boring life. Have fun. Ken
Never realized what brand of truck you drive determines if you need a two or four wheel drive.You guys are just too much,but at least your entertaining.
I live in B.C. Canada, and 4 wheel drive trucks are common. I still think they are a luxury unless you go off-roading. Over here, I use my 4x2 for everything. In the winter, there are only about 2 days where you need a 4x4 to get around. Yes, it snows, but diving slow and careful with a loaded bed and an LSD does wonders (Plus our snow crews are really good here) I originally wanted to get a 4x4 for off-roading purposes and made an excuse that it would be better in bad weather. However, I could not justify the extra price in paying for a 4x4. So far, I have owned my 4x2 for 3 years, and have only had one problem. I wish I had 4x4 then. I tried to climb a mud hill and it didn't work. I got winched out for 35 bucks. That still does not justify the 7 grand I would have paid extra for the 4x4 (I got a real good dea on the 4x2). Just about all my friends have 4x4's. We go off-roading with them. However, when the real badass hauling come around, or heavy driving rolls to come, It's always me on the block. Due to their configuration, their trucks dont' handle as well as mine does, espcially on windy highways, or hauling things around even. With LSD, you'd be surprised how much this truck can do, but don't mistake it for a 4x4, because it defenitely does not haev the capabilities of a 4x4. It however poses other advantages over a 4x4
Ok, time for my 2 cents......I currently have a ford ranger ext cab 4x2. It's a great truck....except when it rains, or snows. I carry 300 lbs. of sand in the winter just to help with traction and 150 lbs in summer - YES, summer due to rain. I love my truck but more than a few times in the last 4 years have I been on a slight incline (going uphill) and it's just rained or is raining, I'm like the little engine that could. I sit there and sit there and try to get going and no traction. (And my tires are GOOD ONES), the 2 wd just won't go.
I vowed my next truck would be 4wd even though I'll only need it a few times a year (I live in IL) it's well worth the few extra $$.
When I bought the Ranger, I said, No way, I'm not spending extra for something Ill only use once and a while, but I was wrong. Now, I'm upgrading from the ranger 4x2 to a GMC 4x4!
Good luck in your research. My vote is for the 4WD.
It's too bad about your Ranger, but don't judge all 4x2s by your experience. The Ranger is a good enough truck for what it was built for, but they are extemely light in the rear. A full sized truck is another matter. mgdvhman: You have your beliefs and I have mine. A 4x4 is great if you go off road but only a small percentage of us ever do. For the rare occasion when 4 wheel drive is helpful it's not worth it to me. It seems like these days either people don't know how to drive when it gets slick or they just think it's cool to have a 4x4. I'm too old to be impressed by that kind of thing so I'll stay with a 4x2 with antispin and I've never been stuck or had to turn around and go home because of weather and I live in the heart of the snow belt.
But I've pulled people out of ditches who tried it - no big deal right, that's there fault.
Let me tell you a story.
I know someone who had a 4x4 (hey this is Canada), but didn't think they needed 4x4 engaged because it was only raining, not snowing. They were coming down a hill which curved. In 2 wheel drive the back end started sliding and the truck ended up going into a ditch where it promptly rolled. The other side of the ditch was someone's garden and the truck landed on the family dog - killing it. Now this time it was a dog, but the family had two small children.
Would 4wd have prevented the accident, who knows, would it have given better traction - absolutely. I agree that the driver plays a large part - but why wouldn't you give yourself as much of a chance as possible?
That's fine, Tim, you have your needs and I have mine. Just don't tell me my truck is useless or that no truck is worth having unless it has 4 wheel drive because that's just dumb. I suppose because I drive a diesel I could say anyone who buys a small v8 or a v6 is wrong, but I don't say that because we all have different needs. The fact that most truck buyers don't even need a truck doesn't matter to me either, buy what you want and let the rest of us buy what we like.
..I understand your points about most don't need it....If I really stretched....maybe even I could suffice?....but it comes in too handy for the do it your selfer and adventurer that I am...
If i encounter a very bad situation....as I have before...and it could remotely save my life....it's worth all the extra it costs 100 times over.......to me at least
"It seems like these days either people don't know how to drive when it gets slick or they just think it's cool to have a 4x4."
Heck most people cant drive period. 4x4 or whatever.
Ever see these idiots making a left turn and cross well over the dividing line and leave no room for you to turn into your lane when you are making a left?
Throw any kind of weather into the equasion and look out.
I know I got off the subject there but in general there are alot of idiots on the road.
Ok Gentlemen! CHILL.... Remember this all personal OPINIONS. Just like someone saying I'm a ford fan, I'm a dodge fan, I'm a chevy fan, toyota fan, etc.....everyone has their own opinions and own experiences....but that's why were here - to find out about them!
Let's keep it kind - save the bickering and nasty stuff for the dealership negotiations!
By the way....I want to thank everyone on the forum who has helped answer ALLLLL my questions I've posted lately......I'm not a fan of shopping for new trucks, and I'm getting ready to buy one so I needed allllll the OPINIONS/ADVISE I could find! Thanks again Truckchick
Sierra or Sonoma? I have the Sonoma twin the S10 2wd and replaced the factory tires at 5,000 with Michelins, what a difference!
Anyway if you're going Sierra look at the '01 C3, its all wheel drive-all 4 engaged all the time, (not meant for serious off road) sounds like what youre looking for.
I'm in IL also and with the Michelins I can go anywhere even when it snows and my braking is much better also.
Hi...I'm actually looking at full size......to be exact: 2000 GMC Sierra 4WD SLE 4 door. Didn't think about the 2001...I'll look at the dealer when I'm there this weekend. Thanks
Haven't seen alot of GMC's on the road nor alot talked about....Maybe everyone just goes towards the chevy...who know?
2wd with high clearance, high height, big tires, good suspension will do just fine in prerunner type offroad situations, e.g. anyone been to death valley?
for mud, slick, rock crawling situations, 4wd is definitely needed, most likely with at least a good lsd or locker.
but.. been in offroad situation before where we got stuck being high centered on a hump.. another almost in mud.. another where the truck just slid downhill .. all with 4wd. so imho, i agree that driver skill is a major factor being at least 50%.
and with good skill (not me, i'll admit) some can go in some serious off road situations in 4wd with just open diffs that normally require lockers (albeit with all other hardware being heavily modded so that there's a wheel that'll always provide traction).
if you can get 4wd with the works, i think you should just get it, even if you don't think you may need it because you never know when you will. (for me, it's anything that'll help out, skill or no skill
it isn't that much more ($2000 for a super duty) plus you'll get a higher resale value.
In Texas, most trucks are 2wd. So if you lived in Dallas Ft.Worth, or Houston, and went shopping for 4x4, they are all going to want to know what you are doing.
In Colorado, that's very different. Most everything you shop for in the way of suvs and trucks are 4x4. Autos get by fine with front wheel drive. But rwd only vehicles, work fine too but are the first to have problems if something does happen with the weather. Many, many work trucks never see off road duty, but are 4x4 nonetheless. So no one here thinks twice.
I think the particular circumstances of the area where you drive is what determines how appropriate 4x4 is. If it's not, then it probably does seem like a luxury to others.
Since GMC will have the C3, I wonder if Chevy will offer AWD as an option. It would definately get me into a full size truck. I dont want or need 4wd, but AWD is a diferent animal, meant for on road use. Guess we'll have to wait til September.
Now is there anyone out there that has driven in a Minnesota (or comparable state) winter in a 2wd? I am curious to know how different it is for the ones that live life on the edge....*L* I personally have a 4x4, am trying to sell it, and am still wanting a truck, but can't afford much....what do you all think?
I currently have a 95 ford ranger 2WD ext. cab; I live in Far Western suburbs of Chicago. I've have the truck for 5 years. In the winter, I put 300 lbs. of tube sand inthe back which is very much needed. If the sand is not in the back, there is no traction. I have the same problem in rain on a hill, but in the summer, I just have 150 in the back.
My advise, stick to 4wd for the winters. I'm upgrading to a full size 4wd to make it easier.
Woody, although I live in Eastern, PA I worked for a company located in St. Paul, MN (Eagan) and previous to that for a company with plant locations in the UP of Michigan as well as Superior, WI and Duluth, MN. There is such a vast difference in operating a 4WD, that it is a wonder, that everyone living in an area where weather and/or terrain affects driving, does not opt for it. When I began driving 4WD vehicles back in the late 60's (precluding my 4WD experience in the 50's with the military) it was rare indeed to see civilian types owning and operating a 4WD. Today, there are very many to choose from, and they are actually commonplace. The 4WD today is much more user friendly as well as socially acceptable. One of the problems that emerges from that, is that people have the idea that 4WD makes one more or less invincible. Believe me, that is not true. Prudent driving accounts more for safe driving than the mechanism of 4WD. Stopping is still an obstacle, sometimes manifested by going too fast in the first place, because one has 4WD. The limited slip differential also increases the odds in one's favor by increasing tractive effort in both 2WD as well as 4WD. As the LSD feature engages automatically, it is a "no brainer" for the general population. This option as well has plus and minus benefits that should be learned. I would not be without our 4WD vehicles (3) but it is a decision that only you can make. They are more expensive and require a bit more to maintain. Hope this helps.
Thanks, I think that I am going to stay with the 4x4 and lease. I think that (an obviously you do too) that in MN in the wintertime, there is just pretty much no way that you can get away with anything less, especially if you have a profession that REALLY needs you (Emergency Medicine). By doing the lease option, I can still keep the payments low, and get what I want/need. At least it looks good on paper....*L* Thanks again!!
I live in Mpls, MN and you can get by very easily with 2WD. Lots of people have done so in the past and lots of people continue to do so. But...I have a 4WD Ranger...so make of that what you will :-)
thanx,
RED
Point 2:
Point 3:
- Tim
I also think it helps in a 4wd, but Tim and I have had that debate before.
You also need to realise (or realize) that mudding requires a totally different skill set to other forms of off roading.
- Tim
LOL
- Tim
Ken
- Tim
--Ken
best damn truck I have had yet!
(Click for bigger pic)
- Tim
Ken
Gotta have fun!
Truckchic
- Tim
You keep telling yourself you don't need one.
I'll take one......you know.....to be impressed..
- Tim
- Tim
Thanks again
Truckchick
Thanks again
- Tim
death valley?
but..
no skill
Hope this helps.
Bookitty
Woody
