Dodge Ram - III
the Ram. Anyone had similar experience?
Q: Does the air stop flowing through the
ventilation system when heavy load is placed on
the engine (i.e. the engine is pulling a large
vacuum due to the heavy loading)?
Background: '98 Ram Quad 1500, 5.9L, Auto
Last trip we took to Wyoming I had
the cab full of people and the bed full of gear,
so about 1000 lbs of payload, no trailer. Just
about every time the truck was going up a steep
grade at speed (~70mph) the air (A/C or vent)
would stop flowing out the vents. This would
occur no matter what speed the fan was set at.
Once the truck crested the top of the grade and
the engine was no longer laboring I would hear a
flapper valve slap open or closed and the air
flow would immediately return to normal.
I just had the truck in for routine service and
the Dodge dealer said this is normal behavior
for this vehicle. Is this true?
Any responses appreciated.
Garrick
I would be very wary if the dealer told me not to take off hard.
I have also looked for a good Dodge web site to ask questions and technical advice, opinions, etc. The best site I have found is www.moparchat.com This site is clearly the best in quality, with over 60,000 posts! Good luck either way Trevor!
Transmission problems: Check the throttle position sensor first ($30 item) on gas engines. If this is faulty, it can cause all kinds of trans problems, down shifts at steady speeds, dropping out of lock, ect.
Good luck
Wildman
Wildman
I have a 2001 2500 quad Cummins with auto and 3.54 gears with 5000 miles on the clock. I get 19 to 20 mpg running like you said, pushing the limits. Every time I take a trip it gets a little better. When I run 75 mph I'm turning just over 2k on the tach. Ken
My mileage on the interstate isn't much better, especially around here, hilly in Alabama, Tennessee, and Kentucky. I think for the most part we are driving the heaviest 1/2 ton pickup and there isn't much that make up for that especially with a 4x4 with a solid axle.
I get a little of ping with my 5.9L but haven't noticed any with the 5.2L Durango. Both have about 15000 miles.
The ping was the one thing about the Dodge that I worried about, haven't had too much to complain about. The Silverado/Sierra seems to have a shaking problem, especially in 2wd that can't seem to be fixed. Drove a couple of 2wd 2001 Silverados last week. One was real smooth and rode great, the other had a shimmy in the steering wheel at several speeds. Pretty dissappointing for a $30k truck. Didn't look too much at ford.
Hope my rambling helped a little.
Paul
2500 ram, changed fuel filter, pumped fuel in
system, but still wont start....air in lines?
how do i bleed the air out of the lines do i
take the lines loose at the injection pump or
at the head? is there a site i can go to to pull
down a service bulliten on how to bleed air out
of system. thanks for any help i can get.....
I got a 97 Ram 1500 5.9, Auto. Over the last months Its been slipping out of second gear;now almost completely. At about 10 MPH and if I give it very little load, I can feel and hear it go in, and then at 30 MPH it goes into third. Is there any kind of adjustment I could look at? Could the TPS do this? Or do you think a major O/H is warranted?
Thanks for your participation. ;-)
Pocahontas
Pickups Message Board
from AUTO MATH HANDBOOK by John Lawlor table 13, pg 93
AMORA
Design engineer class of 1984
http://www.car-truck.com/chryed/buzz/b080100.htm
The 5.9 was pinging but I found a TSB that corrects it and all is good. I beleive it had the ignition wires moved.
I got about 17mpg on the old truck and 14-15mpg on the new.
I looked at fords and chevys but their seats stink. I am a big person (>300lbs) and both ford and chevy seats are not adequate. I have driven the dodge all day and feel great when I park it at night. The infinity sound sytem is superb. The truck handles so well it is easy to forget you are in a large heavy vehicle.
The front end is just starting to bounce a little so it is past the time to replace the shocks. (22k). Tire wear is normal and even. The old truck got to 75k but the shocks were heavy-duty and of a higher quality.
I have had excellent results with Bell Dodge (Phoenix, Az) service. There are always having specials on maintenance items and they are cheaper then QLube. Pluse, they can't BS me about not performing the service because they are the ones doing it and I keep a set of the records.
So far the pluses far outweigh the minuses but we'll see as time goes on.
Bob C
You did it, U Won ! Worldwide consumers have paid there hard earned money and you provided worldwide consumers with the worst Engineered vehicles on Earth...
Got to hand it to Chrysler, Dodge, Jeep, Plymouth you have Won beaten all your consumers.
Wise old saying you can't read a book by its cover :O)
Chrysler, Dodge, Jeep, Plymouth great looking vehicle unfortunately for the unsuspecting consumer even to date Transmission failure, head gasket failure , too many more serious problems Etc...
Just read this Newsgroup 2% Satisfied , 98% Unsatisfied . Surf the internet U will find 100s of thousands of Chrysler, Dodge, Jeep, Plymouth vehicle owners that are Big Losers. Telling there Chrysler, Dodge, Jeep, Plymouth vehicle Horror stories.
Now that Chrysler, Dodge, Jeep, Plymouth consumers have read the book by owning one of the worst Engineered vehicles on Earth. Consumers worldwide learned a costly but valuable lesson.
Now we have come to realize. Yes Chrysler, Dodge, Jeep, Plymouth they are the Winners.
Yep we the "Consumers of Chrysler, Dodge, Jeep, Plymouth vehicles are the BIG LOSERS" !
Were losing vehicle trade in, Value its Awful.
Quality Automobile Dealers don't want your Chrysler, Dodge, Jeep, Plymouth vehicle offering 50% of Galves Trade in if in Mint Condition.
Even Chrysler, Dodge, Jeep, Plymouth Dealers are offering 50% of Galves. Now we are driving around in a nearly worthless Chrysler, Dodge, Jeep, Plymouth vehicle and paying for Major repairs :O(
Its not going to get any better cause Smart Consumers are not Buying a New or even thinking of buying a used Chrysler, Dodge, Jeep, Plymouth vehicle.
We sure learned a Valuable Lesson > Never again buy Chrysler, Dodge, Jeep, Plymouth vehicles. For those few Die Hards remember( Only a Fool Loses Twice )
Rejoice fellow Chrysler, Dodge, Jeep, Plymouth vehicle consumers now it is our turn to Win.
Chrysler, Dodge, Jeep, Plymouth your profits are gone, Stocks are dropping to an all time low Chrysler, Dodge, Jeep, Plymouth is just hanging on by a thread bankruptcy is near Hooray - Yeah !
Now how does it feel to be a LOSER ! Chrysler, Dodge, Jeep, Plymouth :O)
Worldwide automotive consumers buy smart be a Winner don't become a Loser like the rest of us who owned or still own the worst engineered vehicles on Earth.
Let Chrysler, Dodge, Jeep, Plymouth become the final Loser.
By the way the saying is "You can't jugde a book by it's cover".
Also a set of plug wires to go with Anyone now of a good aftermarket source and opinions? Thanks
I will now be towing an 8500 lbs trailer with my truck (instead of 6000 lbs) and was looking to increase the engines torque. But I'm concerned with the Auto transmission! I was looking at TST's "Valve Body Kit" for increasing the transmissions line pressure. Has anyone had any experience with this product? If so, did you change torque converter's too? Does it shift harder now? Any help/comments would be appreciated. Thanks!
I too am interested in hearing what you might find out. I am looking to increase the durability of the auto in my 99 Ram 4x4 Quad. Is this kit the answer? Keep us posted.
