Chevy Silverado - Continued X
Kevin
I asked my sales guy about this and he said that you can use whatever you want, but you have to keep records so that IF you have an engine problem later you can prove you were responsible and didn't cause the problem by not performing proper maintenance. Now, I know this is a Sales guy, not a Service guy, but I haven't seen anything indicating what I can and cannot use on my truck.
Also, did anyone get an actual form outlining the New Vehicle Limited Warranty at purchase? I didn't get anything. My sales guy said something should have been in the glove box, but there wasn't. I want an official document outlining the warranty so I know what's covered when. Anyone know where to obtain such a document?
Meredith
I asked my sales guy about the possibility of getting the GMC sun visors (that have the extenders, like in the photo) and he suggested I contact a GM parts place. What would a GM parts place be? Would I need to stop by the service department of a GM dealership?
Meredith
2. After driving my new 2500 LS, 6.0l for a little over a week, I now have a rattle / vibration / humming noise from the muffler or muffler heat shield when starting the engine cold. There's no sound at idle, but when accelerating up to about 35 MPH, there's a humming or ringing noise from what I believe is the heat shield. It quits after a few minutes when the exhaust gets hot. Took it to the dealer yesterday, and they said yes we hear the noise, and yes we've even heard it on a couple other 6 liters, and yes we even started up 2 2500's with 6 liters sitting on our lot, and they make the same noise.
But guess what the answer is? "Well, we don't see anything wrong and until we get a TSB or some info from GM about this problem, there's nothing we can do to fix this". I asked for a new muffler but was refused on the grounds that they have no info from GM about this problem.
Anybody else with a 2500 6 liter have this problem, and if so, how was it fixed?
I still use a Delco filter...even if I do it myself.
yes you could keep a record of buying other filters as such...
But IF you had a problem...and was able to produce all records....I would say they would then try to attack the filter not being GM.
I figure it's better this way so they have one less thing to throw at you....if the time ever comes...YOU will have to do the proving...they just make the accusations.
I have never had to use a warranty for major engine repair....but if I do...one of the vital components will be made by the company that I will be up against....not an aftermarket one.
Do whatever you want...but I see this as the best way.
Good Luck
- Tim
Since the dealer won't / can't fix it, I thought about just wrapping a piece of tie wire around the muffler and the shield, or jamming a bolt between the muffler and the shield to stop the vibration.
That is a HUGE muffler - I wonder what that mother is going to cost to replace?!
Richard
Who, by the way, IS using synthetic oil (Mobil One 10/30) with an AC/Delco oil filter.
The OnStar button, when equipped, is located on the "roof" portion of the overhead console.
and this one out for filters : http://minimopar.simplenet.com/oilfilterstudy.html
Should be more than enough information here to put this to rest.
rwagoner, I use Mobil 1 oil (10W-30)& Mobil 1 filter.
- Tim
cleaners and if so what are your reccomendations?
my salesman (Corian) had pinging problems when he
first aquired his '98 and now the pinging is
gone. his son put one of the fuel treatments
that's available that also reduces carbon build
up. he does'nt remember if he put valvoline or
chevron in there. it must have worked though
because it even idles smoother.
...RED
Ryan
Whipple - a brand of Supercharger
Quad,
6.75 quarts?....doesn't it call for 5?
6.0 calls for 6..and dealer says use 6.5..
What do you consider the full mark?...at the end of the checker pattern?
6.5 in the 6.0 makes it about 3/4 of the checker pattern filled when warm...
I have thought about putting in more....after warmed up...or when it's dead cold?
hmmmm
here goes another debate..
- Tim
2 DAYS TILL I GET MINE !!! WOOHOO
Ryan
Meredith, The following came in my 00 1500: Owner's Manual, Warranty and Owner Assistance Information booklet, Limited Warranty For Tires, and a folded brochure (part #15757348) titled Important Information About Your Truck. I trust that this is everything. If you are missing one or more items, you might want to request that your dealer get for you. Bob
I always thought that fill with recommended amount as indicated in owner's manual and as long as if falls within the grid marks...it's ok.
why, unless these sticks are made by different
vendors but, my stick and my friends are a 1/4"
different in length. mine is shorter but shows
within 3/16" from high mark with 6 qts. we also
use the AC oil filter vs. aftermarket brands.
tried mobil #206 and oil guage (i know it's only
good for general reading) showed almost 8 lbs.
less pressure. this is most likely because of
tighter paper mesh. my service guy at Michael
chevrolet in Fresno, CA also told me that GM
would probably use such a filter or any other
filter against a warranty claim. sorta of
confusing though especially when most aftermarket
items of good quality express "meets or exceeds
oem".
...RED
sorry it took so long to get back to you, but this board's moving pretty fast lately. reference your question in post #313 about carfax.com:
i don't know how deep these inquiries go, because i ordered my vehicle from the factory so no customer test drives were done with it before i got it and i didn't need to do a vin search on it. additionally, i know some, if not all, of the services listed are not free. lastly, the earlier post i made had an incorrect url. the correct one is:
http://wsf.carfax.com/
services provided:
salvage history
odometer fraud
multiple owners
flood damage
major accident damage
fire damage
good luck with your search, hope you never turn anything up like this on your dream vehicle.
kyle
Ryan
Engine cooling, instead of installing a lower thermostat, has anyone tried Water Wetter? Claims to lower tempeture by approx 30 degrees. Go to: http://www.redlineoil.com/prod_frameset.htm , then click on "cooling products. P.S. I have tried this product, I want to see what the comments are before disclosing my results.
Well, 2 more Austin, Tx folks have joined in!!! Meredith & dhharris! I believe this is the most representation from any 1 city!!!! Eat your hearts out!!!!
I don't need to keep up with the Jones, that doesn't do anything for me, I just think you've got a sharp truck and wish mine looked a little tougher - its hard with it sitting on the factory suspension.
Greg
1. What shocks did you go with and how is the ride.
2. Did you have to replace the driveshaft, and if so where did you get it from.
3. How loud is the 50 series inside the cab, i'm still not sure what muffler to go with, i want something that sounds good.
Again i have to say your truck looks great!
--Mike
Autotap diagnotics show absolutley no change in running coolant temperature when compared to straight water on my truck. I keep running it for my own sugar cube affect, but I don't think it has made any significant, if any difference at all.
Just my experience.
Has anyone had this problem and found a solution?
