Visitor Agreement.
GM customer service has offered 100,000 miles and I asked for 150k. I didn't think about the 6 years. I'll ask next time I call. Thanks again.
Actually, the service manager is just doing his job, but I'm convinced this noise is not normal and will not rest until it is either fixed or a 2001 5.3 motor is under the hood.
Quad, yes, the logic is obvious. How can anyone be 100% certain of anything, when questions remain to be answered. GM needs to disclose what this "harmless noise" is. To the dealers credit, they are still investigating and I am keeping on top of them via email and cust service. When I get the TSB I'll pass it on. R
P.S. Can a 6.0L be dropped in a 2k 1500 Z71? heh heh
I don't believe GM offers any kind of 150k warranty. Don't know for sure.
By-the-way, I go in Monday for my ping/knock/chatter/slapping, etc. (whatever it is). I'll post the results. However, I don't think the soaking will change anything. If not, I'm going after another (free) extended warranty and/or new engine (if they can't fix the one I have). Based on previous problems, this little knock is not that big of a deal unless it develops into a blown motor.
Good luck......
John
The reason I asked for a 150k extension is, I paid $1300 for an extended 5/75. GM offers the 6/100 to customers with the standard 3/36 warranty. I just thought I should be getting a proportional extension. However I'll take them up on their offer tomorrow and take it from there. Thanks!
Oby, the HPIII is on hold for me right now, but I'll definitely ask those questions to the tuner. Thanks again! Roger
I know this is off topic, but has anyone experienced feathering in their front tires? Mine had to be rotated at 6000 miles....I'm putting on Bilstiens this week. R
Also got the tranny reflashed and selt belts replaced, if any cares.
I got a question if you guys can help.
1. Is there a need to change the oil immediately now since the blow-out? If the carbon went out the exhaust I shouldn't have a problem right?
Thanks....John
Ryan
Also, the rpms at speed (75 mph) is about 100 less now.
John
Mine used to come on at about 35 mph. Now it comes on 50-55mph.
It seems to shift at higher rpms.
I had it updated due to shift lagging. And also i didnt like the OD coming on so soon.
Also in the morning it idles at about 750 rpm until it warms up anyone elses does that??? Its cold here (20 degrees in morning)
Ryan
Are you sure it's not just pinging less because the weather is cooler now?
I think I'm confusing myself here. My truck now shifts to a higher gear at a lower speed. The shifting before was fine for me, but now it seems to shift (2nd I think) quicker. It seems to drag or bogg a little now at lower speeds. I hope this all makes sense.
Quad:
I agree with you. I'm going to change the oil this weekend, or sooner. No, I'm not sure about the pinging/knocking. I'm going to test tonight, now that the truck has cooled and back at home (I didn't drive today). I'll be able to test it tonight and post a follow-up. I also agree with the cold weather change. Temp. here has dropped 20 deg. in last couple of days.
Thanks for response.......John
After testing at home under my own conditions, the knock is still there--no change. So much for the carbon build-up theory. I guess I was optimistic yesterday and did not test long enough.
I beginning to think this knock/chatter is going to be classified as normal under GM specs. I predict that's the next thing I'm told when I tell them it's still knocking.
Top it all off: I have to change my oil now (only had about 1000 miles on old Syn. oil); the tranny is not shifting as good as it was; and I wasted two days. I should have left it alone.....
John
According to the service manager (ding dong), he updated the system with the latest stuff, etc....What you think went wrong?
JOhn
Thanks.....John
To check if your truck has all the updates, the dealer will connect the tech2 unit which will tell him what's been programmed and what's not.
Something has definitely changed in the way the truck shifts. It really doesn't bother me and I'm hoping for better gas mileage. If so, I'll leave it like it is. Unless it's causing unreasonable lugging, etc.
I'll post the numbers if they're on the order.
One more thing......I'll probably post this on the Silverado topic too, but what do you think of the K&N air filter. I got the hard sell today at an auto parts store. If what he said was true, I may try one......what you think?
John
My '00 Silverado 5.3 Ext cab has gone through the full gammit of problems. It shakes at 70 mph (got the fix, but it still shakes) And the knocking problem. I've posted many times about this knock problem and have talked at length with the service department where I bought the truck about it.
I believe it was Oby who suggested new spark plugs. I tried the 4 post ones, and that seemed to help the knocking sound. But, the sound persisted. (this actually made it more difficult to convince the service guys there was a problem! figures)
Then after not reading the messages here for over a month, I came back to find the info about carbon build up. 3 days ago I went and bought some of the Techron addititive and the knock is about 95% gone!! I noticed an improvement in the knock and in power from the engine by the end of the first day. I'll return in a week and let you know what the fuel milage is doing (the truck seems to have gotten about 1.5 mpg less than 5000 miles ago, currently at 8000 miles, so we'll see if the cleaner helps that problem too)
While there are a ton of different fuel system additive cleaners available, I only tried the Chevron Techron and it worked. Along with cooler spark plugs. I can still get a very faint knock from the engine under load at 1500 rpm, but it's gone from normal driving.
Thanks a million guys!!!
Here's a link to the air filter:
http://www.amsoil.com/products/ts.html
Their online catalog and price list doesn't list a filter for the new style Silverado, however, they do make one. Just drop them an email and they will get back to you with a product number. Hope this helps.
Thanks again....
John
What you think?
JOhn
From what you've posted, it looks like it hasn't been done. The test I mentioned will confirm it. Shifting into OD at 40 is a little too early. My opinion.
Ryan
Here's what it's doing now.
Tranny:
1. Shifts are screwed up.
2.Another big concern now is when it shifts it clanks. There's not a jerk and if it were not for the clank sound at the shifts, it would probably be okay. I think I could live with the early OD shift.
3. Also, when I'm slowing down and the shifts are reversing, it feels like someone is bumping me in the rear. That make sense? Kinda like the tranny is catching up.
Engine:
1. The knock is now a constant ticking sound. Before I had the "soak" it only knocked when cold...never when hot. Now it knocks/pings/ticks all the time. I took a 6 hour trip last night and when I stopped it was ticking.
Not only did I waste two days of shop time, I now have to change the oil because of the soaking 2000 miles early. I also use Mobil 1 and you guys know how much that stuff cost. Plus it's about 35 deg. outside.
By-the-way......Ryan, you asked about gas mileage. I got about 18.5 last night running between 65 and 85. That's the first time I had the truck on the open road so I don't know what it would have been before the tranny reflash.
What a DUMBA#@ I am!....just when I was happy with my GM truck I have to go and screw it up!
Any help is appreciated.....especially the correct service numbers for the tranny reflash. So I can tell the idiot how to do his job!.............Thanks again....
JOhn
JOhn
If you guys post the correct reflash coordinates, I'm taking the truck to another dealer. But this time I'm going to watch. I'm also going to test drive before I leave the business.
Thanks....John
Did you check the GM vehicle calibration information site and input your VIN? It will give you an idea of what the program updates are/were available.
I tried the test you suggested. It does lug when I decel. to 38-40 and slightly accel. However, if I get into the gas, it will shift to lower gear.
I'll keep trying....
Thanks...John
Thanks again....JOhn
I'll probably let another dealer take a stab at it next week. Hopefully I can get it worked out. If not, will be good excuss to buy that 01 Z71. Hehe....
Thanks again for information.....
JOhn
Pocahontas,
Edmunds.com/Roving Host
