Visitor Agreement.
( FORD )
First On Race Day
www.ford-diesel.com has had a number of discussions on dyno vs synthetic oil so I'd check it out. I would, however, recommend a bypass filter. From the information I've gathered, an oil bypass filter will definitely help extend the life of your engine. I think we'll go with synthetic but not until about 10K miles and let the engine get nicely broke in (the PSDs take longer to break in than the gassers).
f-d has also had a number of discussions on rear gear and ATF fluid as well.
If I had to guess MPG of a 4x2, auto, 5.4L CC, 4.10, I would expect it to be in the 13.x range with mixed city/highway, and 15.x to maybe a 16 on highway..
I too live where its relativly flat, Raleigh NC area..
Wburbank,
I really don't think you'll get a good return on investment by using synthetic motor oil in your PSD. Of course, this is my opinion.
Some things to remember are:
- It takes 15 quarts of oil per change.
- Diesels run at relatively low tempature, so a good diesel motor oil (eg. Shell Rotella-T) will have no problems performing..
- Diesel motors are known for their longevity naturally, without the need for synthetics.. This longevity is due to many factors including lower running rpms, lower tempatures, and the fuel itself being a lubricant.
Before ordering I had found my best price at
Darlings Ford in Bangor ME who agreed to 500 over Edmunds invoice. Im on the road for work, so I had opportunities to visit "all" the dealers (Ipswich Ford, Portsmouth Ford-incl Wiscassett ME, Danvers Ford, 128 Ford etc.) No one would touch 500 over. In the end, my deal was made right in my back door @ Walls Ford Old RT1 in Salisbury. I initially never visited because they are a small dealer. However, I told them the truck I wanted & if they could save me a 4 hr trip up to Maine to do business, I would leave a cash deposit. Simple as that, the deal was done. Jamie Eaton was my "Sales Girl" and Im happy to say, she proved she could handle herself just fine. Sorry for not replying back sooner but I havent been here in weeks. Just been hangin out with the Crew Cab formin the bond. Happy to say were gettin along real good.
What brand motor oil & weight, air filters, etc. do you recommend on the new SD and what interval changes? First at 1K then 3K after that?
Better question, what should I be doing with the new SD the first few hundred miles and thereafter?
I'm sure the dealer will go over many of those things with me and the manual will also have info. I'm interested in what the reality is and take excellent care of my SD.
Thanks again.
I'd recommend first oil change at 1K miles. Interval after that will depend on many things; engine use/abuse, oil type (dyno vs synthetic), bypass or no bypass filter, personal preference and beliefs.
Synthetic oils at dyno intervals are not cost effective. Synthetic oils at extended drain intervals can be cost effective. As I've said before, check out www.ford-diesel.com . This had been hashed over many times there... pro's and con's of extended drains, oil type, oil mfg. etc. Some folks are a big believer of synthetic oils with extended drains while others are not. There is no right answer except yours
We will most likely be going with a bypass filter (didn't get it ordered in time for the 4K change so it will probably go in at 7K) and synthetic at 10K miles (after Rotella at 1K, 4K and 7K).
We also are going to go for regular oil analysis from Blackstone (www.blackstone.com). I'd consider this as well. There are other companies that do oil analysis, we've decided to use Blackstone.
I changed my oil at 3k miles, and every 3k after that. I use motorcraft filters, avoid Fram as those oil filters dont have the anti-drain back valve on them, which keeps oil in the top end of the engine when its stopped.
I'm currently using Valvoline 5w-30 in my SD, but I'd really like to use Texaco Havoline instead, but I can't always find it in the 5w-30 weight which is what is recommended weight for the SD.
On my Ranger that has over 190K miles, I only used Texaco Havoline 10w-30, which is why I had a preference for this brand. However, I think all of the major brands are equally capabable if you change them at 3K intervals..
Check your tire wear often, and be sure to rotate them around every 5K miles or so. I'm rotating mine every 6K miles, or every other oil change.
For tire pressure, check the label on the door jamb for the recommended pressures NOT the label on the tires.. Also, the listed pressure (on the door jamb) for the rear tires is for when your fully loaded, you'll be able to run considerably less pressure when your empty..
I'm running 51 lbs in both front and rears.. The label called for 45 front/70 rear. At 45 in the fronts, I think I was seeing some slight wear on the edges so I upped the pressure a bit. This is probably due to the type of roads I travel on etc.
I'm still experiementing with pressures to see what gives me the best riding feel/best wear.. I might try the chalk-on-tire trick to check my contact patch..
Have fun! These are great trucks!
I have to add that my salesman was superb from start to finish. When I started this process back in January, I wasn't able to find a local dealer that would even talk to me for less than $2000 over invoice. (I never checked with this dealer for no particular reason.) As a result, I took what I considered to be a risk and placed a bid using priceline.com. My salesman, who is the dealership's internet sales rep, responded favorably to my offer and the rest is history. My original price was $400 over invoice and of course I had to order. During the course of the wait, Ford made the sliding rear window and privacy glass standard features on the Lariat package vice options. These happened to be about the only options I had elected not to get. Additionally, the destination charge increased. I was expecting the dealer to pass on the price increase when we signed all the final papers, but I was simply told that my original price agreement was "price protected". Result: I paid not a penny more than my original price. Further, the salesman briefly mentioned an extended warranty but quickly moved on when I declined the offer. No pressure, no gimmicks, no surprises. I actually ended up paying around $150 over invoice. The truck was in perfect condition (no dents, dings, scratches) and not missing any ordered options. I couldn't be happier with the experience.
Sorry for the long post but wanted to share my experience. There are good dealers and salesmen out there. Not all are snakes looking to make a quick buck at your expense. Oh yeah, dealer was Duval Ford in Jacksonville, FL and salesman's name is Mike Tudor.
For those still waiting, hang in there. When you finally get your rig, the agony of the wait melts away with the satisfaction of having the best looking, best equipped, and best built truck on the road.
Sorry for the looonnnggg post but wanted to share my experience. There are good dealers and salesmen out there. Not all are snakes looking to make a quick buck at your expense. Oh yeah, dealer was Duval Ford in Jacksonville, FL and salesman's name is Mike Tudor.
FoMoCo invoices the dealer based on price at shipment. When the dealer submits the buyer info to Ford and the name of the buyer matches the same of the orderer, the dealer gets a credit for the difference (at least that's how I understand it works).
Since FoMoCo has taken the stand that what you are seeing is 'normal', your options are limited.
Be sure to state that you are not satisfied as most modern new vehicles do not have this trait of using a quart of oil per 1000 miles..
Either, this particular engine isn't up to typcial Ford quality standards, in which case they should attempt to diag the problem and solve it.
Or, Fords quality standards are far too low, and you will discourage other individuals and business to not buy Ford products because of low quality standards..
Their response could be: Big whoop.. or possibly they will ask, what they can do to remedy the situation..
Your response will be based on how far you want to take it. Pick one of the following.
a. Ask them to fix the problem
b. replace the engine
c. would you settle for an extended warranty? You believe this problem is an indication of a problem, and you would like assurances that this is normal.. They can show their commitment to you by granting you an extended engine warranty.. It costs them nothing if the engine doesn't fail.
d. Start the work through Ford arbitration, (ie, lemon law).. although this might be tough as Ford has documented that this is normal.. So you could end up with nothing.. Ask your dealer for the Ford Arbitration Packet to start this process..
e. try your own remedys. What happens if you run 10w-30 oil?
f. Since the truck is an early 99, convince the dealer that it has the rare but infamous piston-slap problem, in which case the engine gets replaced..
To be honest, I'm not sure what I'd do in your case.. Good Luck..
The bad news was that another week was added on to the Estimated Week of Delivery from 6/12 to 6/19 and it's status also does not indicate it's been released to convoy/rail.
I'm hopeful that it is standard for them to say 3 weeks (since it's later in the build week anyway) and it might get in sooner, say 2 weeks. They probably have to fill the rail cars I suppose.
It would be a great Fathers Day present!!
I'll check status next week to see if it's on rail.
Anybody know if tracking rail by www.BNSF.com applies to SD's from Mexico ?????
Have a nice Memorial weekend everyone! Be safe, have fun, but remember what Memorial Day is.
Any info anyone has on this would be greatly appreciated.
It only occurs under acceleration, and disappears when you reach a constant speed. I think for different folks in different trucks the sound has different intensity.
Other ways this sound has been described:
- light knocking or pinging
- like a sewing machine
- air pulsing or air escaping
- noisy lifters
- absolutely annoying..
The cause is something to do with the air flow through Y pipe at the exaust causing a standing wave.. It is not harmful to the engine in any way..
Is it possible that this is what your hearing?
My dealer has replaced some idle valve, warmed it up and loosened the transmission bolts to let it equalize and then retighten, and most recently adjusted the idle position sensor and tried to tell me it was some flashing material on the plastic air intake.
I do hear other air and exhaust noises, but I do realize with a truck that big and an engine that large, you will have these noises. It is only when there is a definite metallic noise to it that I become worried.
Thanks for the input.
2000 F-250 XLT, PSD, auto, Super cab, 3.73ls white
It will tough to get to sleep tonight.
Also, Those of you with 350 DRW. Is there a fair amount of suspension noise? Hard to explain but it kind of sounds like something loose, a rattle on minor road surface inperfections. Dealer said, you guessed it...it's normal.
One last comment. There has been alot of discussion about rail dust here and on Forddiesel.com. My truck had it and after discovering the dealer was going to "remove" it with a clay bar (which the TSB states never to do) I purchased the chemicals and did it myself. Rail dust is a serious problem if left unattended. I have a 89 Thunderbird that never had it removed (because no one knew what it was). In about 1 year little holes began to appear in the paint. It is so bad now that if I try to wax it all the little holes fill with wax and I end up with a red car covered with little white specks. This is not what you want to see on your SD...check for it and, if you have it, do something about it before it is too late.
Up to now truck has been great. Driver side rear door window leaks but the dealer is supposed to fix that. Around town 11 MPG. (Y2k Black 350 SC DRW 4X4 Lariat V10 Auto 4.30 limited slip trailer tow).
Cab DRW Short 6 3/4' Box. Is Ford going to offer
this truck is any colors other than white or the
Black LE. Also, I have been told I can order
sometime in late June. Any info on the new 2001
model changes would be great!! Thanks, Kevin
http://forums.ford-diesel.com:8080/ubb/Forum18/HTML/000425.html
for some information on the 2001s. You can order them (or should be able to) but the dealer won't have pricing or color chips for a while yet.
As for the SD CC DRW shortbed any color as long as it's white, that is the case for the 2Ks and haven't seen any indication that that will change for the 2001. This also has been discussed at www.ford-diesel.com.
As of last Friday, I only knew that it was built on a Wednesday 5/24 and not on rail yet. Today, I've learned that it is on rail and assigned to a rail car. I was able to get all the important info from the dealer. (SD was built in Hermosillo, (Sonora), Mexico. Now on rail (Union Pacific Railroad (rail car # TTGX969357) trace by entering the rail car # in the Equipment ID field at this link www.uprr.com/pub/pet/
I am able to trace the rail as it moves along and it gets updated very frequently. It's been past several cities across Arizona just today. It's close to the California border now. I was also able to search the cities and map the locations using www.msn.maps.expedia.com/QuickMaps.asp
I also know from the dealer that the estimated week of delivery is now 6/18. When it gets to the destination (ramp ??) I think it comes the rest of the way by car-hauler (truck). Hope to know that next Friday.
As you can tell, I'm getting very excited !!!!
Let's hope it gets to me by Fathers Day !!
Hot tar and cloth seats don`t seem to fit! So far I am able to cover them, but could use a few good hints.(Calling all tradesmen!) $1.59/gal in NY
Ouch!
My one concern at this time is I got the the trailer tow package but did not get the hitch. I ASSUMEd for a $150 bucks you would get more than the wires. The dealer said (when I was picking the truck up, not when I ordered) the hitch was a separate item. Is it raining or is my leg wet from something else? Other wise real happy. Time to go driving again.
Dave
I filled the truck up for the first time took 26 gallons and I had driven 434 miles, looks like 16.69 mpg mainly running around the back roads, it should only go up from here.(2000 white, xlt,PSD, auto, manual transfer case, stock 235 tires for now)
Now that the temps in the day are in the mid 90's, I re-confirmed the reason I like white trucks..
The latest 'nit-pick' I have:
When turning at low speeds (like in a parking lot), sometimes there's a slight popping sound comming from what sounds like the floor of the cab.
I've heard of a TSB for CrewCabs about this, but nothing for SuperCabs.
I'm wondering if its occuring now that the temp's are getting fairly high, thus the rubber cab mounts might have a bit of extra flex in them? I'm just guessing here.. Anyone else have any ideas..
covers which i'm planning on getting myself:
some info:
- Completely 100% waterproof and fit your seats like a glove
- Made of high-quality nylon-laminated neoprene wetsuit material
- 1/2" foam padding
available at http://www.caraccessories.com and
http://www.performanceproducts.com (although I
didn't see on perf prod's online catalog, but it's
in the print catalog)
Hope you see it by Father's Day
When I get in the truck dripping wet, the seat cover gets wet, but when I get home I wipe it down with a towel and leave the window open overnight and tomorrow the seat is dry and clean. (I do this about 3 times a week now that boating/canoeing season is upon us.) The factory seat underneath is still dry and clean. (I pull the covers about once/month to wash them and let them hang to dry.
So far my 5 year old nephew hasn't managed to stain the back seat - but I haven't let any juice sit for more than a few minutes.
Biggest caveat would be the price. $500+ for both seats (crewcab), but I guess that's cheaper than replacing the seat itself.
Now on to the important stuff - Just got the truck back from the dealership for looking into the Sputter/Flutter noise that we've all heard about. Well, according to FORD, this is normal! Bull!@#$ !! The noise that mine makes is NOT normal and if it is normal, I'm switching back to GM! Here are the details:
Sounds like an exhaust leak with a broken-up catalytic converter."SputterSputterRattleRattleCrackleCrackleBang"
Only does it after the truck is good and hot. Once it starts, it is consistent.
The sound is most pronounced when gently accelerating up a hill at low speed.
According to Ford, and the dealer, this is not the same problem as described in Service Letter #13519 ( See http://forums.ford-diesel.com:8080/ubb/Forum20/HTML/000089.html )
Sound familiar to anyone? If so, I'd like to hear any details you may have.
Later..
I'm just guessing.. I've never heard of anyone else with this type of issue.
