2000 Dodge Ram 1500- Rough Idling Problems
I have a 2000 Ram 1500 Quad Cab (3000 miles) with
the 5.9 V-8 (Gas). I have had it in the shop twice
the dealer agrees that it is idling rough but
showed me to other new trucks on the lot that had
the same miss while idling is this normal ???? Also
a noise with the Air condition compressor while at
very slow speeds... Any help with be appreciated
Oh by the way, the whining going on under the hood, after some study, is only happening during cool/cold days. The truck sat on a warm day for 8 hours once but upon starting it and driving off I never heard the noise. But again the next cool morning it was back. ??
The mechanic who looked at my truck supposedly talked to a Tech. Rep. at Chrysler whose response was that the emissions had been tightened up for the '98 trucks and that was probably the reason for it. The Tech. Rep. said that if they received enough complaints, a service bulletin might be issued on it. So, my only advice to anyone who has this same problem is to keep complaining to your dealer as I have, and maybe enough voices will get the problem fixed, if a fix is possible.
My idle problem is when I let off the gas and it is cold and/or damp. The engine almost dies (sometimes it has) I tuned up the truck (it only has 22,500 miles) and this took most of the flat spot out, but not all. Next time I am buying a Toyota or Nissan crew cab.
If anyone else has the Ram 1500 with the V-6 please post a reply to this or e-mail me at Klassicone@AOL.com
Anyone worked out lease and lemon law together?
Just bought this truck in March, with a 3yr lease.
Highly disappointed!
KLM1962-As far as the 3.9 goes.It's a "crude" V6,just a 318 with 2 cylinders whacked off.Just like the 4.3 Chevy V6.It's NOT GOING TO IDLE SMOOTHLY.My 88 S10 Blazer shook at idle,like they all did.The GM engine has balance shafts now,and it's a lot smoother than it was.The Dodge 3.9 doesn't have balance shafts,and has the old shake common to ALL these "designs".The original Buick 3.8 V6 was the first of the hacked V8's and it shook until they redid the crank(offset journals),and put in balance shafts.ALL these engine were was just a really CHEAP way to make a "V6" from the tooling they had for smaller V8's.The Buick 3800 is by far the most advanced of these designs,the Dodge is the least.
I have to ask,what wee you thinking when you bought a 3.9 Ram?I don't know how anyone could actually buy one.I couldn't take a 3.9 in a Dakota,let alone a Ram!I'm not trying to get you angry,I just don't understand it.I've had a couple of "lesser" powered vehicles in the past,and after a few years,I really hated them,and was happy to see them go...
I've said this other places but, to point, I have a hard time believing GM or anybody can 'fake' horsepower ratings.
Please show us these 'numerous' dyno tests. The only tests I've seen is the Truck trend Chassis Dyno, which shows rear wheel hp, not actual engine.
And the interesting thing about that test was it showed the Chevrolet about 40 hp behind the Ford--a lot. But then Motortrend took the same engines and loaded up with 800 lbs and the Chevy outran the Ford. How can an engine with 40 less hp outrun another?
There are no 'facts' in this arguement.
The ford was 3.55 rear end and I believe that the chevy was 4.10. That is how 40 HP less can accelerate faster. For some raeson the mags never get comparable trucks to test.
The Chevrolet was a 3.73 gear and the Ford was a 3.55.
Even if it was a 4.10, it would not make up a 40 hp delta. horsepower is speed rating--which is why acceleration tests like that are good proving grounds for. that tests shows engine performance thru the entire rpm range, which kinda equals out ESPECIALLY with the flat torque curves of today's chevy and ford engines.
I have had uncorrected vibrations since day one on 70 mph highway driving. The brakes are undersized and in the winter the windows will not go down with the slightest moisture on them. Also at 100,001 miles ( policy I bought was for 100,000) the air conditioning died. $1,200 to fix. Plenty of rattles to keep you company.
David
Also, can anyone recommend a good dealer in San Diego? How much over invoice should I expect to pay?
RT
I am fully satisfied with the way it rides , except on cement freeways.
It has terrible fry hop.
Does anybody know any cures ? I have tried 200#
of sand without results. any suggestions??
tires? ,springs , shocks????
Maybe the reason that the trucks are never the same, there's a hidden (a.k.a. payola) agenda?
Also, was one vehicle 'shifted' for power while the other left in over drive?
budsiler,
Your tires require a different air pressure depending upon the load on the tire. The Dodge specified pressures assume a truck loaded to the GVRW. (For legal reasons.) Get your truck weighed and adjust the tire pressures accordingly.
Rich
There has to be a 'stone joke in there somewhere; but I'm not going to go there.
Rich
If this started happening suddenly I would check the PCV valve.
Rich
