Acura RDX
1363739414255
    Actually, I think BMW has been denying press requests for an X3. At least until they have the new engines available.
    Porsche did the same thing with the Boxster back when the S2000 came out. They held out until the Boxter S became available. (Instead one of the mags used their own long-term test car for a comparo.)
    Can't blame them in either case. I'm sure all manufacturers do this.
    C&D already did a comparo with the CX-7 and RAV4, which the RDX won. Edmunds did a comparo with the CX-7 and RAV4 (but not the RDX). Readers don't like to see the same vehicles featured month after month, so I think it may be a while before we see a head to head.
    On the subject of reviews, R&T got a 0-60 time of 6.3 seconds which is about a half second faster than anybody else. On another board, posters are trying to figure out how they got that.
  • c_hunterc_hunter Member Posts: 4,487
    What C&D issue had the CX-7, RAV-4, and RD-X comparo? I don't remember seeing that, but it would be a good read.
  • robertsmxrobertsmx Member Posts: 5,525
    Speaking of reviews, just noticed that Motorweek reviewed RDX and got 0-60 of 7.1s which sounds possible. They also recorded an average fuel economy of 21 mpg (mixed driving).
  • carlitos92carlitos92 Member Posts: 458
    I thought that was Motor Trend, October 2006. The CX-7 came last. :cry:
    "I thought that was Motor Trend, October 2006."
    You may be right. They all arrive at my house within a span of a few days. I can never keep track of which one wrote what.
  • rickgarrickgar Member Posts: 8
    Road and Track had a review this month with the following comment on gas mileage:
    "In all, the RDX is an impressive ball of technology, function and performance. (That performance, by the way, comes at a fuelmileage price — our best two tankfuls of admittedly brisk urban driving didn’t crack 14 mpg"
    Saw that too, but MotorWeek often records relatively slow acceleration numbers. Maybe they run uphill? :D
    Their CX7 took 7.7 seconds and only got 20mpg.
    The Forester XT managed a quick 6.2 seconds and got an impressive 22mpg.
    Saturn Vue Redline comes in last as 7.8s with no mileage report.
    Correction, BMW X3 3.0i was the slowest at 7.9s and a relative guzzler at 18mpg, but that was the 225 hp version.
    Rank for speed: Forester, RDX, CX7, Vue, X3
    Rank for economy: Forester, RDX, CX7, X3 (all require premium fuel)
    Too bad they didn't measure the Vue's fuel economy, it's the only one that can take regular fuel.
    -juice
  • hklhkl Member Posts: 9
    The RDX is obviously not targeted to sell a lot of units, because most car buyers are not that well-informed. They feel good on "catchy" phrases that other un-informed car buyers talk about. SH-AWD, I am afraid is above most people's heads.
    A lot people on this site worship BMW (including X5 and X3). I drove BMW X5 (my in laws) for an extended period of time and don't like it. It is certainly German wouldn't -care-less attitude in its design. For those who like it, good for them. I guess I don't have kow-tau to things I consider inferior, regardless what brand it is.
    Back to Acura RDX, I think the mileage is bit disappointing. For that reason alone, it won't sell well. But I know, it is a heavy car and the turbo gives a lot of torque and good acceleration. But the mileage will suffer. Too bad for Acura. Yes, it doesn't have so called brand name such as AUDI or BMW attached to it. Otherwise, everyone will be praising it - as if the best thing since slice bread. Such is human bias and stupidity.
    Try a Forester XT, 21/26 mpg with the automatic. Quick, too. You give up a lot of gadgets, though.
    No one vehicle has it all.
    -juice
    I wonder how much the FE would improve if both turbocharger's "blow-off" valves were rigged to always remain open, or at least remain open unless the accelerator pedal is depressed aggressively/quickly.
    Well, that would be the wrong way to go after economy -- it would just be releasing high pressure air before it goes into the throttle, but you'd still be spinning up the turbo (and you'd have to cut back the fuel rate otherwise the engine would run rich and still burn the same amount of fuel -- this happens to unaware street tuners all the time, when they replace a factory bypass BOV with an atmospheric one to get the cool sound). A better way would be to bypass the turbo and cut back the fuel. But I think the best way would be to use the turbo for added efficiency rather than added power. That would involve mild boost, and allow the same power to be produced at a lower RPM and with less fuel.
    Right now, they clearly have designed the engine/turbo to extract more power at a given RPM. You can go after the flip side of the problem to get the same power at lower RPMs.
    The fuel economy is disappointing for an Acura. But that's only because we've come to expect remarkable things from the company.
    Anyone shopping similar vehicles is going to be equally depressed by what the competition offers. Both the X3 and FX get 2 or 3 mpg less than the RDX. They make the RDX look downright efficient.
    If a buyer decides to move downmarket to something like the CX-7, they don't fare much better with only a 1 mpg advantage. Now you're giving up luxury features, refinement, and performance. That's a lot to sacrifice for a couple gallons of gas.
    And real-world numbers for the CX7 have been actually worse than the RDX. Look at Edmunds' and Motorweek's tests.
    -juice
  • kyfdxkyfdx Moderator Posts: 276,248
    Anyone else think that turbo 4-cylinders aren't particularly well-suited to heavier vehicles?
    That's usually the case.
    But less weight would mean they'd have to take out all the things that make this an Acura.
    So instead, my suggestion would be to give it a manual transmission. That would transform the car. The TSX is a lot more lively with the 6 speed than it is with the auto, and I bet the RDX would be the same way.
    Maybe a Type S later on? Who knows.
    -juice
    We're not likely to ever again see the introduction of a new or derivative vehicle model with front wheel drive capability and a manual transmission/axle.
    The hazardous are just too great.
    Sorry, my mistake, I should have said wastegate, not blow-off valve, I know the difference, just a senior moment.
    Ah I have those moments too, and I'm still in my 30s! You're correct about the wastegate, and my other comments would still apply about the engine tuning....
    Being fair, it really depends on how MUCH of each you're really giving up. A Mazda may never have the cache or intangibles of an Acura, but the CX-7 is not THAT far downmarket or down on performance from the RDX. The Mazda IS, however, less expensive to the tune of 10% or more, and that will buy a lot of gas.
    Assuming you're not expecting 30 mpg, you can't go wrong with either choice. Just my $0.02.
    With Acura, you get better leather, nicer interior, and more importantly, a better AWD system. That is until you throw in tech package (on both), then the gap widens even more (the NAV and ELS sound systems in Acura are fantastic). With Acura, your $$$ do indeed go somewhere, and most of it is visible.
    Has anyone purchased those, salesman says they are available.
    I still diasgree that most of the money is visible, but I'm just a dumb little guy fighting against what every premium auto maker wants the world to believe. SOME of it is visible, but if all the extra money was going towards better leather and plastics in their cars, the Acura dealerships would look and behave like lesser brands'. Leave out the NAV/DVD-Audio for a moment, and all of the features are comparable to the CX-7's except maybe the DUAL-zone climate control as opposed to single-zone. The Acura's AWD being "better" has been argued before, and it comes down to what you want it for. When the snow falls, the Mazda is more than adequate. On the Nurburgring, the RDX might out-drive a CX-7, but there's a lot more than SH-AWD to credit for that. In the end, like I said, neither car is perfect, and neither is a bad choice. It's just nice to be able to have two good vehicles to debate about! :shades:
    There is no argument that SH-AWD is better system. It IS! The problem with SH-AWD is that its potential can be harnessed only by the willing and the educated. For a typical driver, the strengths may never show up. The only real advantage to them is that SH-AWD is proactive and sends power to all wheels at all times. SH-AWD is certainly not about being just "adequate". CR-V's RT4WD system fits that bill.
    And yes, better leather, better interior in general, refinement, are all part of the cost that premium badges are supposed to provide, and Acura does that. As for dealership experience, I have been to both ends of the spectrum, a dealership that I wouldn't visit a second time. And another where I have had wonderful experience (and picking up my TL from them tomorrow).
    If you can't see those differences, the "premium" is definitely not worth it for you.
    Well, you are right about that, at least. Enjoy your "downmarket" X3. ;)
    -c92
    I don't think Acura's premium features are that good on vehicles under the RL in their model lineup. We have a Honda, an Acura, and a Subaru. I don't see much, if anything, about the Acura that is significantly better than the other two. They all have very good interiors and the quality of the leather, plastics, etc is quite good. They all have great fit and finish. I would actually say the Subaru is best by a slight margin.
    If you want to see premium, and pay for it, step up to Lexus. The interior on the RX, for example, puts the RDX and MDX to shame. On the RX, I can definitely see where the extra $$ goes to (and it's a lot of extra $$). Acura has never really gone toe to toe with Lexus in my opinion, except maybe on the RL and then just barely. The rest of the model lineup is a very small increment above other non-luxury makes in my opinion, and below the full-luxury makes.
    Yes, if you want to experience a really poor, horrible, example of AWD, then by all means buy an RX. Even Lexus can't figure out how to build one with good AWD capability.
    Initially, for the RX300, the system including a VC, Viscous Clutch/coupling, mounted across the otherwise open center differential. In 2001 the rear LSD was dropped and VSC/Trac was added wherein the brakes were used along with engine dethrottling to simulate center and rear LSDs.
    For the RX330 the VC was dropped entirely.
    Now I see with the introduction of the RX350 the VC is back in use again.
    Maybe this "new" VC will not remain "flaccid" when needed like the earlier one does.
    If you should purchase an RX then get the FWD version w/VSC/Trac as it is just as (in)adequate on adverse roadbed conditions as the AWD version.
    IMMHO it would be nice, really nice, if Lexus were to license the SH-AWD system for use on the RX series.
    Well if you ask me, any FWD vehicle adapted for AWD is already a kludge! That includes all of Honda/Acura/Lexus models based on a car platform.... They could all shave hundreds of pounds, lower the CG, get better packaging efficiency, and overall better handling from a true AWD platform. But that's another example of automotive engineering that the mass market doesn't care about. People assume AWD is AWD, whether it's an impotent system from Lexus, a sophisticated (but still imperfect) system from Acura, a purely reactive system from Honda, or a full AWD system from Audi/Subaru.
    Anyway, given that neither Lexus or Acura has a perfect AWD system, I would focus on other "premium" features when trying to differentiate them from the crowd. I see a lot of differentiation with Lexus, but not much from Acura.
    RDX does not cost $50K like the RL. I don't expect it to match it in quality of materials used. By same measure, For the price of tech loaded RDX, you get base FWD cloth interior RX350. Is that a valid comparison. This, before I venture into the AWD system. The Lexus system doesn't compare!
    MDX is in its seventh year in the market, fortunately, it won't be seven years before we see the new model. And before you pass your judgement on that vehicle, at least see the quality and features that is being offered for its price. Sorry, your arguments don't hold a candle.
    There is no need to be mad or sarcastic when someone points out the facts to you. I'm not a fan of vehicles like RDX, or SUV/CUV in general anyway. X3? I couldn't care less about it. It isn't worth my money either.
    Not mad at all, nor did I mean to come across that way. But I don't consider everything you've stated is a "fact," either. Nothing personal. We're not gonna convince each other, so in the interest of good will, let's move on. Have a good one.
    -c92
    http://www.edmunds.com/insideline/do/Drives/FullTests/articleId=116773?tid=edmun- ds.il.home.photopanel..3.*
    ... the CX-7 (while plenty good for the dollar) does not match up against the RDX. Spec racing is all fine and dandy. But even though you can check the same boxes with the CX-7, the quality and function of the items in those boxes are not the same.
    While I certainly agree that many buyers will not value the difference in performance between Acura's 2.3L turbo and the unit in the CX-7, that does not mean the difference should not be considered. The same can be said of the ELS stereo, the NAV, the interior styling, and extra features. If someone falls into the category which does not value such things, it simply means that person is not part of the target market.
    Frankly, I expect the only reason why a CX-7 (or RAV4 or Forester XT) buyer would've cross-shopped the RDX is because they were mislead by a box-checking comparison.
    My arguments will never hold a candle to anyone intent on defending Honda/Acura to the end. There are some really passionate Subaru enthusiasts on the forums here, but they will glady complain about Subaru and cede that there are better vehicles out there. I wish more Honda/Acura enthusiasts were the same way. Subaru actually listens to owners/enthusiasts when we complain, and the cars have gotten better because of it.
    Other than Varmint, I haven't seen very many other level-headed Honda/Acura enthusiasts here, and that's unfortunate. I think the zealous enthusiasts would be doing themselves and Honda/Acura a favor by toning down the attitude. I have a Honda and an Acura now, and will gladly tell you about the things that are wrong with the vehicles and what could be better -- I like them, but they are not perfect by a long shot. I really questions someone's credibility when they may act otherwise about the cars.
    Going back to my main point -- when I compare the Hondas that I have owned (currently one now), and the one Acura that I own now, and the one Subaru I own now, nothing about the Acura stands out as being premium or better than the other two by a significant amount. I think we can say that about most of Acura's vehicles when compared to other similar makes. Acura has never really played with the big boys in the luxury field, except maybe on the high end (RL) and then just barely. What they have done is offered some great cars at a good value that are more luxury minded and more sporting than their Honda stablemates. But not by a huge amount. I think the Acura name appeals to a lot of people, but it doesn't automatically make the car better.
    Has Acura's leather improved that much? I used to think BMW's leatherette was better.
    Sorry, that was sprinkled in somewhere in this debate, so I forget who said it.
    Also, the pre-production model on the NAIAS floor was all scratched up, and both the dash and the plastics around the door sill would scratch if you ran your nails over it.
    I have yet to test drive a production model (please, tell me they're much better), but even the pre-production Hyundai Accent didn't have those issues.
    -juice
    I didn't expect you to accept that better interior quality, features, and a superior AWD system are packaged in RDX compared to CX-7. The link provided by Varmint only agrees with my point. Whether you agree with those as "facts" or not, is simply a matter of choice on your part. Its definitely not fiction to me.
    You shouldn't expect everybody to agree with you. If you look a few posts above yours, I'm not an immense fan of RDX, but I will voice my opinion when things are undeservingly misrepresented. I will also say that I couldn't less about being seen as a blind supporter of a particular brand. I know where my money belongs! That should be least of your concerns.
    Am I surprised that a $46K RX350 feels more upscale on the inside than a $38K RDX? Nope. It should! And for the same reason RDX feels more upscale, has more features and superior AWD system than CX-7. It comes with a price. If you disagree with me, let me know, instead of getting bogged down with unnecessary rhetoric about Honda/Acura enthusiasts.
    I don't completely accept your position because "better" and "superior" are blanket subjective statements that marketers use and are oftentimes in the eye of the beholder. The more staunchly people use terms like that, the sillier it sounds. I've already agreed that the Acura may be more "luxurious" inside and can out-drive a CX-7 at 9/10ths. But for the money, and the enjoyment requirements of most drivers, there are alternatives to the RDX that might be a better value. The target markets of the two CUVs are VERY close, but having driven both now, I don't feel Acura is offering ME any compelling reason to pay 10-15% more. Believe me, I don't want you or anybody else to buy a CX-7. The less of them on the road, the more mine stands out.
    And yes, I read the Edmund's review, and I trust their opinions. But if we shouldn't strictly compare vehicle specs, let's not swap links either. For every review like Edmund's I can find another review or poster that supports my viewpoint. Live with it.
    -c92
    Again, if you're strictly looking from "value" point of view, RDX is NOT for you. And if you could say something like "the Acura may be more "luxurious" inside and can out-drive a CX-7 at 9/10ths" suggesting that things are better or superior is far from being blanket statements. They are based on experience, and feel not spec sheet. Unless you disagree that there are such things like "feel" or "experience".
    I'm glad CX-7 works for you. It probably would work better for me too, however I would take CR-V above both of them. But this thread is neither about CR-V nor CX-7.
  • bodble2bodble2 Member Posts: 4,514
    "..if you're strictly looking from "value" point of view, RDX is NOT for you"
    You're right.
    carlitos92, robertsmx is right. ;)
    Oh, okay...since you put it THAT way... :blush:
    I guess I'll have to go my fallback argument, which was "the RDX is just FUGLY and has the wheels of a base model RAV4." :D
    Seriously, it's been fun. Cheers.
    -c92
    You may be right there. I'm kinda fence-sitting myself regarding the looks of the RDX and the new MDX, especially the rear roof-line and window treatment. Too much Infiniti FX resemblance for my taste.
    My main fence-sitting issue is gas mileage at the moment. For every positive report, there are at least as many dismal reports (really dismal, like under 15mpg combined).
    I suspect, and Edmunds also mentions it, that road tests (most of them) seem to have been very aggressive with the RDX. Leadfooted driving and being overly aggressive can lead to that kind of fuel economy. Motorweek is in fact the only source that has gotten 21 mpg in combined driving. They usually don't push the vehicles as much.
    I doubt many people will agree with your opinion on the styling. More people might agree with you if you were talking about the CR-V, but I believe you're in the minority about the RDX.
    -juice
    While the RDX is no CR-V in terms of styling, it also doesn't have love-at-first-sight styling like, say, the TL does. From certain angles, IMO, it looks over-styled and a bit bulbous. I also think that, for an SUV, it sits a bit too low.
    I agree that it sits low, but I like that, and I think that may actually help it stand out a bit against all the tall SUVs. It's more user friendly and handles better.
    OK, there are too many angles on some of the details, but I don't think that spoils the whole package. It still looks good.
    -juice
    It looked really good to me in photos, but in person it has a very short (length) tall (height) proportion and ends up looking stubby. Roof racks and running boards emphasize the look in an adverse way. I still like the look of the RDX, but it's definitely not very graceful like some of Acura's other designs.
    Something I don't like about RDX's (front end) styling is that it looks more like the outgoing MDX. Honda could have been more aggressive there. Rest of the styling is well within my tastes.
    And I like the fact that it looks low and planted, as opposed to appearing tall. That was, in fact, one of the pleasant surprises when I first saw it in person at an auto show.
    "I suspect, and Edmunds also mentions it, that road tests (most of them) seem to have been very aggressive with the RDX. Leadfooted driving and being overly aggressive can lead to that kind of fuel economy."
    A number of reviews have mentioned that the turbo is (to paraphrase) addictive. While it results in mileage that is rather abysmal, I do think it tells us something about the nature of the vehicle. Obviously, they enjoy pushing it. Isn't that the way a sporty vehicle should be?
    We'll have to see how owners do with mileage. I expect that once a driver gets past the honeymoon period, fuel economy will improve. The magazine don't have the cars long enough for that to happen.
    The Acura team who developed the RDX wanted it to look like a running back. So they certainly weren't going for sleek. If the vehicle were a mid-size, the proportions would be too much, but as a relatively small vehicle it works.
    I do think they could have simplified the front clip. The lights are great. The grill is typical, but at least the strakes leading into the air ram give it more character than the same grill on other Acuras. I think it's a wee bit cheesy, but if they had simply used a traditional Acura pentagon, it would have been boring. So, I think it's better than nothing.
    The real problem comes with the number of creases and openings in the nose. This has been commented on many times before. I also think the front bumper could be thicker/taller to take up some of the space below the lights.
    Conversely, I think they could have done something more with the profile. I'm glad they didn't put a bump in the belt line like the CX-7 (that looks silly), but it could have used a more aggressive line around the door handles, or even well below that above the rocker panels.
    Overall, it's a nice-looking vehicle with a few minor flaws. There isn't another vehicle like it which cannot be picked apart the same way.
    I know what you mean about "addictive", but I still think 12-14mpg is even too low for agressive street driving (track is different). My 05 Outback XT has a turbo-4, is similar in power (250HP) and MPG (19/24) ratings, and will do 0-60 in the low 7 sec range. Even back when I was having nothing but fun with it, I was still getting 18-20 mpg. It is very hard to ever get 24MPG in that vehicle, which is my gripe, but I have never seen averages dip really low with agressive driving. Now, the RDX does have 300+ pounds on the OB XT, so that doesn't help -- it would be like carrying around two extra passengers. Not sure if that is worth 4-5 MPG though...
