We have. The verdict is that it's a great little car and a great value, despite your huffing and puffing to the contrary.
That's it. Case closed. No need for you to go on here.
http://www.topspeed.com/cars/toyota/toyota-aygo-ar34304.html
http://blogs.edmunds.com/Straightline/1493?@@
Another thing to keep in mind for any small car like the Yaris HB with little crash space between the rear bumper and the rear passengers is that it will not be as safe in a rear crash as a larger, heavier vehicle with a lot of rear crash space. That's not a dig on the Yaris, just the laws of physics.
If you are truly concerned aabout safety, get curtain airbags. The yaris with side airbags did fairly well.
But don't take any bad opinions. Watch for yourself.
http://www.youtube.com/watch?v=C1RCL2zCVmU&mode=related&search=
Peace!<-AladdinSane-- :shades:
I had one installed on my Honda CRX and it was approx. $300. in 2000. It never leaked, and it never gave me any problems.
http://www.autoblog.com/2007/08/21/decano-self-adhesive-sunroof-doesnt-let-the-s- un-shine-in/
As to the board you refer to, I was a member until I found it was mainly for 18 - 23 yr olds.
Hi-
That's kind of you...
I look forward to your conclusions with details, please!
Many thanx!!!
Peace<-AladdinSane-- :shades:
LOL
http://www.automotiveconcepts.net/install/sunroofs/index.htm
Inbuilt was expensive, like $1100+.
Top Slider was $630, and $730. for the larger.
Pop Top was not offered, so no price was given. This is the sunroof I had installed on my Honda CRX years ago.
That is in the top ten for all time dumb ideas. Wait until someone tries to sell the car and has issues with it:
A. bubbling/trapping moisture and rust/discoloring
B. ruining paint trying to get it off.
Upgraded from the 14" 175 tires to 14" 195 tires (Kumho KH16, a bargain from Tire Rack). No noticeable improvement in handling or braking - apparently the stock Bridgestone RE92's are pretty good, even if a little narrow by today's standards. However, the ride got a little smoother. Noise about the same - the stock tires were very quiet and although the Kumho's are rated extra quiet by Consumer Reports, they aren't any better than the Bridgestones they replaced. Thanks to the 14" wheel size, the replacement tires were dirt cheap - about $45 a tire plus $7 shipping and handling, $10 to install each tire.
Brake feel not so good initially, as they brake pads wore in they feel better - normal, now. If they come out with Hawk performance pads, I will upgrade, something I don't usually do with my econo-commuters.
The rear end always felt "hoppy" as though it wasn't well connected to the ground, even on freeway cruising. So I added a TRD rear sway bar, which has made a world of difference. It doesn't convert the car from understeer to neutral or even oversteer (one common problem with adding only a rear sway bar, as I found out with a 2004 VW Golf) but it does get rid of that hoppy feeling. Apparently the rear end needs a sway bar to tie it together, curiously the twist beam isn't enough. THIS modification is highly recommended to other enthusiasts, and even for parents who find this car a little squirrely at high speed (with the sway bar, it feels like a bigger car).
I got my sway bar online from Sparks Toyota for $152 with under $10 in shipping and handling charges and it only cost $60 to install (just a bolt on each side of the shock mount, not extra straps, drilling, or brackets required). Best painted finish I've seen yet on an aftermarket part like this, TRD (Toyota Racing Development) does a good job.
This is a very fun ride. Handles nimbly, more like a sports car than a "B" class car. I like it better than the Echo and Scion xA I owned before. Although horsepower actually got downgrade on the spec sheet from my Echo/Scion due to different test requirements, this version of Toyota's 1.5 feels zippier than my prior two versions.
The dashboard still picks up rub marks from finger nails and skin, but these disappear after wiping with a damp, lint free rag.
What I DON'T like about the car is it's size. It's one size down from the smallest cars we typically like in America. Although it has as much interior room as a Chevy Cobalt, it is much lighter and will likely fare less well in two car collisions. If it weren't as much fun, and cheap to buy and operate as it is, I'd recommend a Corolla, Caliber, etc. instead.
Toyota should make the anti-sway bar part of the new liftback "S" package for 2008.
What I don't agree with you about is the size. I think it's perfect: easy to maneuver, easy to park, and much bigger inside than it looks like from the outside.
The paradigm is shifting in terms of car size. In 10 years, we'll probably view the Chevy Cobalt as a mid-size.
bunch of cars that don't. Every manufacturer, even the
luxury ones, have them. You are one of the unlucky ones.
If you switch cars at a great expense, you may or may not
get lucky. Rattles are easy to fix if the dealer is willing. It's usually just a bad clip. My Yaris is good so far. Elantras and Versas get lower gas mileage. If you're
fine with that, go for it.
bunch of Hyundai people have been attacking Honda and
Toyota forums. I wonder why? Desperation?
And yourself?
racing. I have a Yaris Hatch. I test drove the
Fit, Versa, and ran away from Hyundais. So you still
believe a Yaris is made of plastic? You must not
be very smart.
Take notice Korean vehicles are almost always compared to the Japanese. That's because it's a known fact the Japanese build the most reliable vehilces on the planet. The Koreans and their supporters can make all the claims they want, but until they can support their claims with facts, the fact remains that the Japanese still build the best vehicles. Unsubstantiated claims are nothing but poppycock.
http://video.google.com/videoplay?docid=-1897765951498046612&hl=en
Ladies and Gentlemen on this forum, I've been a "gear head" for almost 40 years, and one would have to be to own the British iron I previously owned. I learned to "turn wrenches" with the best of them - by necessity. All of the aforementioned brands and vehicles were purchased new, never used.
You can say what you will about the Korean cars, but I must say our overall ownership experience with the Hyundai has been exemplary, equal to or better than both the Honda and Toyota we currently own. The Hyundai has 152,000 miles on the clock, and with the exception of normal routine maintenance (3,000 miles or 3 month oil changes, 24,000 miles or 2 year ATF changes), the only non-routine maintenance has been the replacement of the alternator at 103,000 miles at a cost of $79 - I bought it online and replaced it myself. Of course, the engine's timing belt was replaced at 60,000 and 120,000 miles, but this is standard routine preventive maintenance as per the book. I'm not talking tires, brakes, hoses, etc. here, as all of these are normal wear and tear items. That's it, after 5+ years, and 152,000 miles. No engine problems, no automatic transmission problems, no suspension or steering problems, etc. It had one warranty issue within the first 6 months of ownership - an 02 sensor. Pretty darn good I would say!
The Accord has been the equal, but it's had 5 warranty-related service issues, 2 within the first year of ownership. The Camry, unfortunately, that's another story. We've had it in the shop several times during 2007, not only for the drive-by-wire throttle problems so well known on Edmunds.com, but for an automatic transmission shift flare problem. And, the dash has several squeaks and rattles already. The verdict is still out on this one.
That's one person's direct experience on Korean vehicles vs. the competition. And, it's a substantiated claim, unlike perhaps others. The overall quality of build of "this" Hyundai is equal to either our Ohio-built Honda or Kentucky-built Toyota, including panel gaps, seam matching, etc. Of course, this is just one sample, and I must admit that I take excellent care of all of our cars. The Hyundai is just as solid today, with no squeaks, rattles, or rust, as the day my wife drove it off of the Hyundai dealer's lot. I understand everyone's misgivings, but many statements on these forums are made without ANY ownership experience with a brand of car - rather only hearsay evidence or supposition.
The initial Japanese cars we owned were no Rock of Gibraltar examples of quality and reliability. The Datsun and Mazda, and our earliest Toyota Corolla, had their share of significant mechanical and body problems. Over time, these companies improved their products immensely. In my opinion, based upon being a past or present owner of many of these brands, Hyundai is mirroring the same exponential improvement as the Japanese brands that came before it. Think about it folks: The Asian mentality in building cars, attention to detail, and concern for quality is different than most other cultures, and the last time I checked, Koreans are Asians too.
PS I drove a 1966 Toyota Corona off the showroom floor in Phoenix and never had a problem with it.
I don't have to justify my purchases of anything, and was not doing so here. I offered the information based on experience, and thus, thought some folks might actually be interested - apparently not. It was not marketing or sales hyperbola, simply life experience, which is more endemic than many of the uninformed opinions that are written about many brands of cars here on Edmunds.com.
Some people take things entirely too seriously!
And in the interests of full disclosure... did you buy your Yaris before or after the IIHS crash tests came out on the Yaris? And your Yaris has or does not have the side air bags and curtains?
So, anyway, when you bought your Yaris, were the IIHS crash test scores out yet, and did you get one with the optional side bags/curtains that allow the Yaris to get a Good vs. Poor score on the IIHS side crash test? I figure the answer to both questions must be "yes" based on your earlier post.
