Then why bother running them all the time?
Bob
If it's for an additional source of lighting, I have to say that fogs don't add much illumination when it's not foggy out. If one wants more illumination, one should be running driving lights mounted in the same position and only when needed. Lastly, paisan noted that they're weak and don't add much light. To that comment is why I ask why bother.
The fogs add a bit of extra light to fill in where the OEM headlights leave off, that's why I usually run them, it also make me more visable to other drivers as well, similar to DRLs.
-mike
Where can I buy your box and instructions? I'm reasonably handy.
You might want to post over on ScoobyMods:
http://www.scoobymods.com/forums/forumdisplay.php?f=91 (Peaty will be impressed)
And perhaps over at:
http://www.sb9t.com/forums/index.php
I think you'll have yourself a nice little business.
-mike
email mike at iace.com
And why is that an issue? It doesn't bother me one bit as to whether people are using their fog lights properly or not. I just don't see this as a big deal. I'm much more concerned about being blinded by oncoming xenon headlights than I am by improperly used fog lights.
Bob
I was actually rather confused by your response. I still don't see how using foglamps keeps other drivers from flashing their brights. Does that have to do with Xenons?
Remember, Bob lives in a pretty rural area with more deer than pedestrians. The roads aren't lit at night so he needs the fogs. I use them whenever I drive to his house.
-juice
I drive in rural, dark, wooded areas in NH and ME all the time and know those conditions. Good driving lights (which I've had) or judicious use of high beams will out perform fog lights everytime.
I have no problem with people using fog lights, driving lights, or high beams - as long as they use them properly.
The lighting improves rather dramatically with them on. For slow speeds, on a curvy country road, they are excellent. In fact the lighting in general for this model and year are quite good.
My fogs are definitely not useless. They make a noticeable improvement. I can see the divider lines much better, and there's some overlap with the regular beams, maybe on the lower half of the light pattern, but it still helps.
Useless on a straight autobahn, sure, but on a twisty, dark road with deer, priceless.
-juice
Disclaimer: the headlights on Bob's wife's Forester (01 I think) just aren't nearly as good as my '98, nor are my wife's '02 Legacy headlights.
And that's when foglights should be used. If you're blazing up the highway at 75 mph, you are out driving your foglights.
Are yours aftermarket or OEM?
-mike
Who among us hasn't started looking for information on valve stems and not wound up reading the secret KFC recipe?
We heard you loud and clear, buddy.
At high speeds my fogs are off because they actually force you to focus too close in. You need to look farther ahead.
-juice
-mike
Again, for me driving with the fogs on has nothing to do with "looking cool." And the last point I want to make is I don't deliberately drive with my fogs on. Sometimes I do, and sometimes I don't. If Subaru had a dash light in the main instrument cluster (not down low on the dashboard), I would certainly pay more attention to it.
Bob
http://www.iihs.org/ratings/ratingsbyseries.aspx?id=579
Can you post it here?
Fantastic results. I e-mailed the link to my wife and she said that was the most compelling argument yet in favor of the Tribeca.
If you look closely, you'll see every single sub-category is rated Good, in every single test.
Straight As for safety. :shades:
-juice
http://www.youtube.com/watch?v=Q7dVFY5CxT0
As the tests show, this is a really, really solidly built car.
I'm not surprised it leaked. I'm also not surprised that SoA hasn't tried to stop that leak.
-juice
-Karen in AZ-
Umm.. the moderator deleted my message giving the URL of where to buy because we're not supposed to use this board for selling.
If you visit legacygt.com board, and search on RRAP you can learn a lot more about this topic.
Thanks for the interest!
Scott
s foglights. i think I asked this already but instead of an answer there was just a whole discussion about driving with your fog lights on or not.
I have 40,000 miles on my Tribeca as of this evening. My foglights both cracked within six weeks of when I bought the car and both were replaced under warranty about a month later. That tells me that I applied the X-pel film at about 5,000 miles.
The film is still as clear as the day I applied it and it has provided complete protection for the fog lights.
I do not drive with my lights on during the day - that's what DRLs are for - but I always have the fog lights on at night when the low beams are on.
The X-pel headlight protection film is 40 mils thick. I don't know how that compares to other products, but I can tell you it works as advertised. No cracking, no peeling, no yellowing and most importantly, no broken fog lights.
-mike
No big deal. You can only notice it at close distance..
Please don't infer that I doubt anything that's been said in this forum about the film. I don't. But, my experience is what it is.
There can be many reasons why it is different from others - fog lamp wattage, heat transmission through the lens, film composition or thickness, driving conditions, etc.
For me, the benefits of having the protective film far outweigh the risk of not having it.
When I got my windows tinted everyone told me SolarGard dyed film would go purple.
9 years later it hasn't. Looks perfect, actually.
-juice
-mike
The only think I can think of is maybe the film is not the 'thick' 3M film for lights? They do have the thinner ones for body panel, which is ALOT easier to work with being that the lights is so curvy and very hard to put on.
Any chance its because of the 1000 watt after-market fog lamps you bought? :P
Actually the fogs are stock. I rarely ever upgrade the stock bulbs as it's the reflectors you want to upgrade. As I said there are at least 3 others (Nissan Frontier, Dodge Durango, and my Nissan Armada) all had them burn on the fogs due to leaving the fogs on all the time.
My aftermarket Hella 4000s have plastic covers you leave on until you are ready to run the lights then you remove em, but I've never had those chip at all, even leaving the covers off.
-mike
There are other Subaru discussion groups out there and after 4 Subarus and many years on Edmunds I am ready to look for a new forum. :mad:
Jerry
The cars all have a lot in common (the H6 is shared with the Outback for instance), and so do the owners. We found a lot of pet owners, Mac users, educators, basically we have a lot in common.
So come here for the one catch-all topic for Subaru owners:
ateixeira, "Subaru Crew - Meet The Members II" #27758, 7 Dec 2006 7:09 am
-juice
Jerry
Oh, my gosh...you mean to tell me that on this forum I'm actually considered "normal"???
-Karen in AZ-
Mac user, teacher, former pet owner, and Subie nut
-juice
http://www.carmagazine.co.uk/first_drive.php?sid=334&page=1
Nothing really new here being said, but I suspect the Tribeca will be a much harder sell in Europe than here because of the lack of a diesel.
Bob
It is strange to see the steering wheel on the other side of the vehicle.
they do have yellow turn signals (which I prefer to all red). I was following a B9 the other day and its tough at first to tell when she was breaking and when she turned on her turnsignal. both being red in the USA models.
-Karen in AZ-
