I always liked the taillight treatment of the 1973 Monte Carlo. The way the taillights are recessed a bit, and with the more form-fitting bumper, the rear almost looks a bit custom/exotic. For '74 i was a bit more formal/frumpy looking.
That Mark IV actually looks nice in the pictures, but I'd be curious to see how bad the rust really is, up close. And I can handle no working a/c, but a non-working heater bothers me. Heater cores can be a real pain, depending on the car. And if the problem is in the control unit inside, I imagine that could be pretty hard to find replacement parts for.
I thought the same thing. I wonder why he doesn't elaborate about the heat and A/C. Does it blow any air at all? Is the heater core bypassed? Is the compressor there? I'll never understand these ads where people put so little info. In reality it would certainly save a lot of emailing/phone calls back and forth.
This looks nice, but are they the right carbs?
A classic or a fake?
Andre truck
"has the muscle to back it up"....mhmm
VW's worst
Pricier personal battleship cruiser
Last of the old school...these were sold alongside W116 for a short time
"Needs Battery and Fuel Pump"....uuh I think it needs a little more than that
Survivor
'73 H/O, oh, yeah, that's not even a good clone. Interior is wrong. Shifter is wrong, steering wheel wrong. Note that the serial number is not listed? Also that "11000" all that were made? Try 1097. Also note no mention of the special engine that was used, the W30 modified 455ci?
H/O stripe kit for cloning
I wonder if any of those later Hursts used the more formal Cutlass Supreme roofline...the one that was shared with the Monte, Grand Prix, and Regal?
I've never, not once, known anyone to have a heated garage here in Denver, and it gets WAAAAYYYY colder here than in does in the Pacific NW.
I've heard that a heated garage can be bad if you take your car out in the snow and get ice and rock salt all over it. The rock salt isn't TOO brutal on the car when the temps are cold, but warm it up, plus the melting of the ice, and it goes to work on your car.
I guess if heating a garage adds to the humidity somehow, that could be bad. But maybe if you heated it with a fairly dry source, such as a heat pump, it might not be too bad.
By saying "heated", they mean attached, rather than detached.
I can't see anyone on the west side of the mountains needing one of those gas heaters - it doesn't get that cold here. In eastern areas though...it could be handy.
1. Throw away 2 SU carbs with 3 moving parts
2. Write a check for $750 + labor
3. Install 2 Weber carbs with 100,485 moving parts and enough volume to run a Ferrari V-12
4. Lose 5-8 mpg
5. Gain 3 HP at extreme RPM
6. Tune for low speed or high speed--you can't have both.
Up here, vehicles that are garage-kept suffer quite a bit less wear-and-tear during the winter months than those that live outdoors year-round. Snow and ice build up, both inside and outside the car, is the primary culprit as it does not fall/melt off regularly as it does any/everywhere in the lower 48. Other than an occasional Chinook, the weather is well below freezing for at least four months straight (November through February) and often longer.
In addition, very little salting of roads is done. My preference would be none, but I have noticed early (October) and late (April) snowfalls receiving salt rather than sand/gravel in recent years at intersections.
Here, we either get chemicals that are hard to clean off a dark colored car, or we get "sand" the diameter of a dime that makes windshields and front bumpers look awesome after a long winter :sick:
Yeah, that's what I've always heard too. You keep things frozen most of the time and there's less of a problem with corrosion from road salt than if the ice/snow melts and mixes with the salt.
I have no idea why garages would be needed in Seattle. Hardly ever gets cold enough there to snow anyway.
My son lives in Rochester, MN, which I think gets a lot colder than Denver, and for longer. His garage, while attached, is not heated. I don't think may of them are actually heated. Neither is mine, which is not a problem unless I have to do some work in the middle of January :P .
Ditto for here in Colorado. In the winter, it just s**ks to have to remove the snow from your car; in the summer, the occasional hailstorm will blow through, wreaking havoc with cars that are outside.
Even though our house doesn't have a basement (a rarity around here), we have always kept enough room in our garage to store both our cars. The daughter's car, sadly, has to live outside - perhaps the next house will have a 3 car garage.
the plate says joy
too new?
more my style
gotta throw one in for lemko
not andre, but am i reading this right?
are they throwing in the cider block?
worth more in ct?
but my god, why use a '77 with the awful bumpers? Probably a better engine to ditch, but the rest of the car sucks.
If you are spending that much coin, how hard is it to ditch the rubber snout and loer the suspension?
The MGB/RX-7 conversion is a great combination, but not with a rubber snout car.
1975 Buick Regal with a V-8 350hp Engine - 350 horse... really?
power window on both doors - You guys have seen a lot more oddball cars than me, but has anyone ever seen a car with only one power window from the factory?
The front seats consist of the driver seat and a two thirds seat for the middle and right side passenger. - Split bench, enough said
seats are extremely comfturable from years of seating. - Thanks for breaking them in
When driving down the street, you will get the "whip lash" glare - Does this car somehow anger people when they see it?
needs to get it's timing realigned - What?????
comfturable
carborator
its' self
An ad for a car is like a resume. You should write it and let it sit for a day and then proofread it and then have someone else look it over.
I've seen that abbreviation before. I think he meant to say "350 high performance", which could mean the engine's been built up or, more likely, it has a 4-bbl carb. If it's stock, I doubt if it's very "high performance". Probably no more than 170-180 hp I'm guessing.
For the most part, GM used a tall 2.56:1 axle ratio in cars like this, so unless that's been changed, the car isn't going to be a screamer, no matter what's been done to the engine. But it would only get worse for 1976, when they went to a 2.41:1 axle in an attempt to improve fuel economy. I dunno if that worked, but I did see about 17.5 mpg out of my '76 LeMans. Once.
Still, kind of a cool car...except for being brown. I think it's kind of bad luck to have a 1970's car in brown or yellow. Because then when it breaks down, it sort of leaves itself way too open to the turd or lemon references. :P
I think for the most part, I preferred the style of the '76-77 version of all of GM's intermediates to the '73-75 models. I know many people don't like the big, bulky bumpers, but I prefer the quad headlights of the later models to the single headlights of the earlier models. I think these cars were just too big for single headlights. Plus, I guess I looked at quads as a bit of a status thing, since among the domestics at least, it was mainly smaller, cheaper cars that had singles, at least from 1958 on.
My Mom had a 1975 LeMans coupe, and at the time I thought that was a hideous looking thing, with its big single headlights and garish eggcrate grille with rounded corners and the beak. But then I thought the '76-77, with its quad headlights and squared-off grille, and just the slightest hint of a beak, was simply gorgeous.
I kept the car for about two years before I sold it, we had our first child on the way and I was not going to be able to keep up with the note.
Years later I had a 1975 Buick Electra 225 Limited that was great a great car lots of room for anything you wanted, very comfortable lots of torque. My last Buick was a 1986 Grand National another great car the quickest car I have ever owned.
Yeah, they weren't the most space-efficient cars in the world. My '76 LeMans has a power seat, so it can get into some pretty obscene positions, and I actually find it roomier up front than most cars made today! And with the small transmission hump, fairly high seating position, and dash that's fairly out of the way, you could actually get a third person up front...although I don't like driving like that. The back seat is horrible when it comes to legroom, but I'm surprised that I have decent headroom back there. And footroom under the seat is good, once you figure a way to contort your body to get your foot under there. And then, just don't expect to hop out in a hurry.
And trunk space is downright embarrassing for a midsized car, but I think it was about the norm for the time. I've taken my LeMans to the GM show in Carlisle a few times and I have to position my beverage cooler at just the right spot in the trunk, and just the right angle, in order for the trunk to close. And i have to put a towel over the top to keep it from rubbing on the trunk lid!
I've thought about getting a compact spare tire for it, because I swear the full-sized spare seems to take up half the trunk.
The '75-76 Electra and LeSabre is another car I've long admired. I guess the one to have would be a '75 LeSabre convertible, but I also like the 4-door hardtops, and the LeSabre hardtop coupe that had the odd roofline with the small roll-down window in front of the stationary rear window. Like this...
Shifty
That Bonneville is in the worst color for that car. That body style looks good in dark, green, blue or black but horrible in most lighter colors. Might be ok in white.
The SSEI was the supercharged model not the SSE. Its an easy thing to screw up and an even easier thing to check but no way I would buy any SSEI no matter how nice in that gold ughh.
IIRC the SSE/SSEi iin white came with painted white alloy wheels. A bit much IMO.
EDIT: heres a pic (a '92 Model)
12 vents on dash = luxury
Especially when the AC went right after the end of the 36 month warranty
An old co-worker of mine had a 91 SSE, the old style - burgundy with gold lacy wheels, of course. It was in pretty immaculate shape, but the interior was just weird, and the leather reminded me of football leather...same color too.
fintail,
i don't mean to nag but i have to take issue with your spelling.
when it's a car it's "burgandy."
you can easily check this at craigslist, or anywhere fine automobiles are sold.
cheers -Mathias
Regarding lacy alloy wheels, I had them back in the day on my Sable. They looked nice but were a real pain to keep clean. I do not miss them.
Has a salvage title and needs airbag reset but wasn't in an accident
Professional stereo installation
Looks cleaner than most I see That dash layout looks weird
Outside looks ratty but inside looks nice
Anyone making a mob movie?
Half the size of a new Civic
If it looks good in person, this could be good
That '66 Impala does look nice, and I guess the price ain't bad, if it looks really good in person. I have a feeling that having just the 283 might hurt its value, compared to a 327 or, even better, a 396. Also, I don't think it's an SS, just a plain Impala. I dunno if being an SS really means much though, if doesn't have a high-performance engine to go with it.
Eldo is at least 200% higher than it should be...and I only like those if they lack the vinyl top and other destructive addons.
The old 5er "may" need a window relay? Isn't it kind of a yes or no problem?
