speaking of this, I took the air cleaner cover off last night and now I'm even more confused. It LOOKS like a regular carburetor ... but not quite. I dunno. Until I have some real time to take the whole aircleaner off and take a good look, I might not know the answer here.
SYMPTOMS: are you also stepping on the brake when you step on the clutch? I was thinking power brake booster leak.
hmmmm.... I'm not sure it HAS power brakes.
But, to answer your question, no, it happens when I just step on the clutch (parking brake engaged, of course).
I'll keep the grounding strap theory in mind. You never know.
so I took a good look at the exhaust last night. Seems like I need EVERYTHING behind the y-pipe, including the cat. damn!
I had a college buddy buy a new B2000 just before we graduated back in '85. He bought it in AZ but then moved to CO to take a job.
I caught up with him a couple of years later and he told me that he had to sell the truck since he could never get it to run right at altitude.
Q - I'm hoping my FIL's Legacy doesn't need that much work with the exhaust ... from what I can see, it's only one of the tailpipes that exits the muffler that is missing.
Still need to get the title transferred on it ...
In the 70s VW still sold quite a few cars without power brakes, but they were some of the last, I think.
http://cgi.ebay.com/ebaymotors/AUSTIN-HEALEY-1959-100-6-BARN-FIND-NO-RESERVE_W0Q- QitemZ280028845888QQihZ018QQcategoryZ6023QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This car looks mighty rough---and a 100-6 does not have the value of an AH 3000 and cannot be valued the same. Given what it needs, it is not worth restoring, not even close. Perhaps there are precious little bits and pieces one could salvage off of it (like speedometer gears or impossible to find little brackets or clamps--maybe even the brake drums are salvagable.
Even if it were a late version of the BJ8 (the best of the best Healeys) I'd have to wonder if it would be worth it.
Problem is, Healeys are not scarce. If it were say an Alfa Romeo Giullieta Sprint Veloce Coupe--they are so hard to find you sometimes have to work with what you get.
Another factor is that certain cars of a certain year are eligible for prestigious European re-creation events and for special vintage racing....so a 1957 model of a certain car might be worth way more than a 1958 model, for this very reason.
In the collector car world, you gotta know what you are doing, or you'll end up very short.
I don't think there has been anything posted in this thread with that much rust!
I forget now what the car itself was, but I do remember it being $22,389 out the door, with tax, tags, a $1200 extended warranty that I never had to use once, and all the other assorted bs they throw in. I do remember the window sticker being $20,950, including the $560 freight charge. I also got them to throw in a 12-disc CD changer, mounted in the trunk.
I just have the 2.7 V-6. Sometimes I wish I had splurged on the 3.2, because it's a lot more powerful, and torquier across the board. The 2.7 also has a reputation for sludging, although mine has about 122,000 miles on it, and I haven't been that religious about changing the oil or keeping it topped off, and it's never given me any problems.
And yeah, mine is like that one on eBay, minus the blingy wheels and the woodgrain interior. Wood/plood might dress up some cars, but IMO the Intrepid ain't one of them! :surprise:
I kinda like that Diamond-T truck. There used to be one abandoned in the woods not too far from my house. It was parked next to an old early 60's medium-duty Dodge truck. There was also a 1957 Ford back there, thrown upside down in a dumptruck bed. I remember a couple other fairly big trucks. One was an old 1947 or so International that said "Giant Foods" on the side, and another that was so stripped down I couldn't tell what it was. They used to be at the edge of a cornfield owned by a guy who also had a contracting company, but now there's a school on that piece of land, and that old junk is long gone.
I liked the Diamond-T though. It was a single-axle tractor rig. I thought it would've been cool to put a pickup truck bed on it and fix it up.
I went to a friend of a friend's old farmhouse a few weeks back that I had never been to before. Its a young fella who's uncle used to own the farm. Anyway, there are several barns around the property. The one that was in view held an AH. It was partially covered and obscured by old tractors, etc, and I didn't want to waltz over there and check it out, so I'm not sure of the year. I could see it was definitely rough, though.
Anyway, get to talking with the guy and he says there are cars all over the property. One barn holds a rotted out Woodie. There's also a 280z, but he says the engine is gone (the best part!).
I've been thinking about giving him a buzz to talk more about the AH and maybe get a look at the Woodie. I think you guys have talked me down from the AH. I wasn't sure of its real value, but if this one is worth so little, I'm sure that one is worth even less (since I'm pretty sure its not as old).
Ok, according to Mazdatruckin.com, I either have a 2-bbl Makuni carb or PFI (port fuel injection).
Now... would PFI include a component that LOOKS like a carburetor? I'm thinking no, right? I mean, if its REALLY port injection, that's happening right at the head, correct?
That is what I would think but ehh who knows with old import trucks.
What exactly is a "big healey"?
This thing was about the size of an MGB. maybe a bit smaller.
Throttle Body Injection, or TBI, is the one that's essentially a carburetor body with a fuel injector nozzle in it. Or, two fo them I guess. I guess jokingly you could call it Two Barrel Injection? :P
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320027135289&fromM- akeTrack=true
basically, the top picture of this is what I see when I look inside. I thought maybe it was electronically controlled, but I assume not.
mazda carb on ebay
i'll tell ya one thing, I'm surprised. I mean, it has started every time now without having to touch the gas at all. I've never had a carbureted vehicle do that (unless it was after the vehicle was all warmed up and only sat for a few minutes).
I'm hitting it a bit lower, though. The ill-fitting trunklid, what looks like an ill-fitting driver's door, along with those rotting floors, cracked dash, etc, make me feel like its less than a $5k car. $5k would be tops in my book.
BUT, you may be right. could get the bidding to $6k-$6500 ... its then just a matter of actually SELLING it for that.
I agree though, if you want to come out whole, you shouldn't offer more than $4,500 for it. The rusty floors will bedevil any seller until someone goes for it and gets it done.
If I had young kids and a summer place, this would be a great car to leave there and store in winter.
But Ford and Chrysler are definitely second-runners in this category. GM just has such a better aftermarket for parts and restoration.
I've seen this car pop up on eBay from time to time, but this is the first time I've seen it with those awful wheels. I think in the past it just had Rally II's. I also don't think there was a GT model offered in 1976, so this is most likely something that someone just made up. The interior is definitely not stock.
Now the LeMans did offer something called the Sport Coupe, which was separate from the base LeMans coupe. I can't figure out exactly the point of it though. It didn't have a bigger, stronger engine. And all the stuff that made it look sporty, like the Rally II wheels, bucket seats, console shifter, full gauges, louvered quarter windows, etc, were still extra-cost options. So the only thing I can see that it added was a few badges and the set of dummy lights on the trunk.
I've seen this 1976 Grand LeMans on eBay before, too. I like this one better than that pimped-up thing, although I think the first thing I'd do if I had this one was lose the skirts.
"For less than the cost of a new Buick."
http://cgi.ebay.com/ebaymotors/Rare-LWB-W-Division-Only-24K-Gorgeous-NO-RESERVE-- 40-Pix_W0QQitemZ250027507466QQihZ015QQcategoryZ6384QQrdZ1QQcmdZViewItem
Andre: Sounds like you got a good deal on the Intrepid. And it's certainly provided you with good service. Do you use regular oil or synthetic? I'm thinking of switching. The studies I looked up on the web seem to show longer oil change intervals, possibly longer engine life, and slightly increased power and mpg.
It's hard to believe that British sports cars were once so common that you could stash them in the barn and forget them. It was a summer car, and so I suppose one winter he put it in there and said to himself that he'd drive it next summer. Then, when that rolled around, he didn't get to it (and maybe the battery was dead), and that started its journey into a pile of scrap metal. It's a small automotive tragedy.
I've thought about going the synthetic route on my Intrepid, but at almost 7 years old and 122K+ miles, I wonder if it would be worth it? The car did seem like a good deal at the time, especially with the 0.9% financing they offered me. I remember I put $2000 down and the payments were $347.66 per month for 60 months. In later years though, they were discounting them so much that I could've probably gotten a 2004 Intrepid ES or SXT for not much more than what I paid for my base model.
Heck, with discounting, I guess I could get a base Charger these days for about that price! I think I'm going to just keep it and see how long it lasts. I did an Edmund's TMV on it, and it looks like tradein on it is only around $1800-1900 for an exceptional example, so at this point I might as well just keep it until the transmission or engine or something major goes.
Brakes? $6,000.
Engine? Priceless....
But you could just park it and sit in it and have lunch---very pleasant!
What should you pay? Should be around $12,000 to a smart buyer to come out whole. You have to anticipate a quick $5,000 on these cars as soon as you buy them. Immediate karate chop guaranteed.
This puts you at about $17,000, which is actual fair market.
It's probably running so rich that it doesn't need to set the choke to start. I bet it doesn't even have a computer anywhere.
Good luck on that one... :P Replacing their clunky V8 would be a good idea, though. It wasn't a very good engine back then---lotsa ghastly problems. Not sure if they were solved by 1969 or not.
The GM trasmission is in a Rolls case, so it won't match up.
Well then see if you can go find my old '69 Bonneville and just yank out the whole drivetrain...400 4-bbl, THM400, rear end, and all! That would also take care of the rear brakes, although you'd still have to find a way to work them in with the front brakes. I wonder how hard it would've been to work a GM full-sized disc brake setup onto something like that Rolls?
This one too--probably...
We've been thinking of getting a new Accord in the next year or two to replace our 1988 Olds. But, this would be a lot cheaper. Seems like it's been taken care of, but they don't actually say it's a one owner car. If it were a manual I'd be really tempted. On the other hand, my wife perfers autos anyway. We have two kids.
I always loved these wagons (and the 740s before them) for the same reason Andre hates them--they are so squared off that they have great cargo room and headroom.
All right, all of those who hate old Volvos tell me that even thinking about it is a bad idea. I live in Louisville, and so this a local car. In any case, I didn't see a place in the listing where you can contact them to ask questions. It's probably in the local paper.
http://cgi.ebay.com/ebaymotors/Nice-1997-volvo-850-wagon-tinted-windows-third-se- - at_W0QQitemZ190032453711QQihZ009QQcategoryZ31878QQrdZ1QQcmdZViewItem
I don't know if this is any indication of how they age, but my neighbors had a 1989 Volvo 740 wagon. Dark metallic gray, charcoal/black leather interior. They bought it used in 1991. By 1998 they were getting sick of it, and traded it for a new Legacy Outback, which they still have. I remember them saying that the Volvo was getting to the point that every time something would break it would have to go back to the dealer in Virginia, because the local mechanics wouldn't touch it. And they could be guaranteed at least $1000 in bills every time it went back to the dealer.
But then I've heard other people swear by these cars, so the simple answer I guess, is your mileage may vary! If nothing else though, the price seems decent, so even if you end up with a total turd, you wouldn't be out too much money.
Looks decent to me. Minor cosmetic damage to the exterior of the car, but solid.
Oh, there we go. Had to insult it first.
Impala SS
That Impala seems indicative of the typical old car gone to neglect...not enough money to restore her, but not needy enough to be forced to sell her, so the car rots.
Mine was a '98 S70, but most of it is the same as the 850. Mine was a turbo, so you don't need to worry about that added complexity with this ebay wagon.
The buy it now is not that cheap. Mine was only worth about $4k to a dealer and it was a loaded up T5 with 115k miles. And that was maybe 6 months ago (i wound up selling it for $5500 through ebay). SO, I'm thinking he's about right on this car. The old wagons seem to command a bit more than the sedans ... EXCEPT for the T5 models.
Ask if the following have been replaced and when: ABS module, timing belt, wheel hubs (bearings ... but you can't replace JUST the bearings in these), swaybar endlinks, spring mounts, and rotors.
If all have been done recently, you are in good shape. The timing belt technically should have been done around 70-80k, so it is needed again at 140k, but ask anyway so you know where you stand. OH, and ask if the tensioner was replaced along with the belt.
Its a great car when you aren't spending money on maintenance. Between 100k-115k miles, I spent around $2k-$2500 on mine. I probably had it pretty well sorted out by then and it may have been good to me for quite a while afterwards, but it was time to let it go (I do miss it, though).
But for some reason I like that Grand Ville. Even in that Mr. Hankey edition shade of brown.
