Visitor Agreement.
I just finally got my 2001 Ranger 2wd 4.0L x-cab. My question is this: you carry 600 lbs of sand in the bed for winter driving, while all I've put in there are (2) 70lb bags. Is 600 lbs really necessary? We got a big snowfall just after I picked the truck up last week, and the Limited Slip worked pretty well, but I was still sliding around a good bit, so I guess I may need more!
As it is I appear to be getting around 15 mpg on the little driving I've done - I knew that the combination of the 4.0L and my heavy foot would hurt me there, but I hate to weigh it down TOO much with sand. So, I should get more, huh?
David (also)
ed
My truck has 165,000 miles, lucky me with no major problems. My engine is a 2.3 inline 4.
Do they need to have the valves adjusted at all ? I can not find any information regarding this.
Has anybody experience this problem?
I have a somewhat heavy foot, but I think these numbers are going to be pretty representative of what other Rangers equipped the same will get. I'm hoping that the numbers will improve somewhat as the engine breaks in and I put a cap on it.
It's a 2wd, so they are the Wilderness HT type, all-season, so not the same design, etc., as the A/T with tread seperation feature. If I'd have gotten a 4x4 with the A/T's I'd probably have gotten rid of them immediately.
The HT's are performing well, in fact. Maybe it's just because they have new tread. But, even with new tread, when you have all-season tires on packed snow, there will be SOME loss of traction, especially in the conditions I was in.
I'm not going to waste money replacing something that is working fine. Your arguements for getting rid of A/T's make some sense, but these HT's don't need to go. (I should say, though, that when they wear out I won't automatically replace them with the same thing) Next winter, when there is less tread on them, I may buy snow tires, but I'm not even sure I need to do that.
Yup, it moves pretty well.
My exact setup is: '01 Ranger 2wd extended cab 4.0L SOHC automatic with Limited Slip. Interestingly, in this configuration Ford expects me to haul extra weight, and gave me the 1600# payload package, so I have a somewhat bouncy ride and a higher ride height. Neither are quite to the level of the 4x4, but are just right for my off-road needs.
I haven't gone to a drag strip yet, but the package definitely moves very fast and has lots of power! It's no Light'ning, but coming from a sporty Integra I'm very satisfied and my wife hates it (I continue to drive *just slightly* in excess of speed limits and beating others from stop lights)! Not to mention how great it handles muddy, rutted roads through new developments (up and down hills, through drainage ditches, to Grandmother's new building site we go). Very happy I avoided the 4x4.
In fact, I had to call a dealer I wasn't working with to confirm that I could get this package with the LSD option! I had an order on a 4x4, since Ford wasn't accepting the order for the setup above, then the next day I checked Edmunds (considering adding an option to the 4x4) and found that the LSD was now listed as an option on the 2wd! My salesman didn't want to lose the sale on the higher priced 4x4 and claimed ignorance of the new situation, so I had to prove it to him by going to the salesman who will probably get my business next time.
It was all worth it. I love my set-up, very versatile and speedy, very nice fit-and-finish, and at a great price. Just a couple of disconcerting noises from the engine and the driver's side door which I think I can get resolved.
Can anyone recommend a good storage compartment for the flair sided bed? Are there some nice "designer" side opening compartments that compliment the curves? Delta dosen't seem to have what I want.
reliability problems. However, when I look at the sister 1996 Ranger it shows this
car has potential problems: "Occasional problems on this vehicle are failures of the
Canister Purge Valve/Sensor Assembly and the Mass Air Flow (MAF) Sensor."
Should I consider the same problem for the Mazda?
If they're the same truck why does Carpoint rate Mazda higher on Reliability?
Please help.
Accord99
I also have a stepside Ranger and get favorable comments from strangers. I have a 1998 XLT 4x4 SC in light blue. I have nerf bars, bug sheild, and a Lund grill insert on my truck. I have also put a K&N aircharger kit on, have a chip and P265x75R16 all terrains. Great little truck.
Good luck!
z
Does anyone know how to solve this problem?
It's also linked to the top of this discussion, right underneath the title. Thanks for your participation. ;-)
Pocahontas
Pickups Message Board
Good luck!
Email:hciaffaglione@caanberra.com
Phone#: 1-203-639-2406
I've got a 2000 XLT 3.0 4x4 automatic extended cab with the off-road package and about 9k miles, purchased new. I've got two problems, possibly related to each other.
First of all, there is a constant pinging noise above about 30 mph. It sounds similar to a washer being spun on a bolt. Seems as though it's coming from under the vehicle as opposed to the engine compartment.
Second problem is mileage. I just filled up tonight and got around 13.5 mpg, which is about what I normally get. I know, 13.5 is hard to believe, but I generally get about 230 miles to the tank if lucky. Pitiful. I don't have a lead foot and most miles are highway.
My question is this: What should the dealer be checking that they possibly are overlooking? I took it in around 3k and they didn't do a very thorough inspection, only took about 10 minutes before saying they "fixed it", which I discovered wasn't true as soon as I hit the highway. Could these two problems be related?
I'd really appreciate any suggestions from all of you. I know this is a great resource for these sorts of things, I just haven't been able to find an answer yet and I'm at wit's end. Thanks in advance!
The engine is very noisy. No doubt about that. I would also point out that with my set-up the ride is very hard, somewhat worse than an S-10 3.4L V6 I've driven periodically. Try to test drive the exact package you want and make sure you like it. I'm okay with mine, but I doubt I'll ever haul a big enough load for it to be worth it (at that point I have a 1-ton dump available). I got the 4.0L 2wd more for speed than payload.
Of course, thinking about it, I've gone over curbs and driven through rutted, messed-up building sites and was very happy to have the tough suspension then, not bottoming out.
Aside from the noise (there's plenty of wind noise, too, and some creaking in the doors that I hope to fix) and the occasionaly gripes about the ride, I'm very happy with the truck overall. I've shot across busy roads enough times to make any gas penalty of the 4.0L worth it.
