Honda Civic Hybrid Owners: Problems & Solutions
You can research official recalls of any vehicle here at the National Highway Traffic Safety Administration website:
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/recallsearch.cfm
As you will see, there have been NO RECALLS of any Honda Civic sedan since the 2002 model. At that time 295 vehicles were recalled due to a minor piece of plastic in the air cleaner box and 440,000 were recalled due to a headlight switch concern.
There have been absolutely NO recalls having to do with hybrid systems. Obviously, whomever told you about 102 recalls had no idea of what they were talking about.
To clarify, from the problem I have (in posting #264), my 2003 HCH is automatic, and it's 2003, not 2004. Sorry.
I have always taken the car to the same Honda dealership for routine maintenance (following the "NORMAL" maintenance schedule in the owner's manual). I don't actually know if I should call this a slip, but more a low frequency (deep sound) "ggggrrrrrrruumm" noise under my seat or shift gear. Again, only happens when re-accelerate after a complete stop. And after the "ggggrrrrrruum" noise for about 1/2 to 1 second, it will never happen again until I re-accelerate AFTER a complete stop again. Doesn't matter if the "idle" feature comes on or not. If I go VERY easy on the initial acceleration, the "ggggrrrrrrum" noise is not as pronounce, but seem to last longer (~1 or 1.5 seconds). The harder I press the re-acceleration, the heavier, louder AND SHORTER the noise is (~ 0.5 second).
Very strange... Well, after reading all the previous posting, I actually change my mind. Instead of taking it to AMMCO and MAIDAS, I am going to try to dealership again, this time... EGR valve, like some of you suggested. Will see.
ca_trojanboy (Go SC!)
Have you checked the rest of your exhaust system for pinholes, larger holes or loose fittings that can cause vibrations and noises?
BTW: Got the recall maintenance done on the ECU. It did change how the IMA behaves when engine braking down a hill... the charge gauge goes all the way up and does it more smoothly than before. Before the ECU update the gauge wouldnt go all the way up (minus 2-3 bars) until I tapped the brakes. It seems to ease into the electric motor engine braking a lot more smoothly without the annoying sudden decelleration.
Also, that annoying "lurching" at 3K RPM is gone as well.
So far so good. 35,400 miles and rapidly approaching end of warranty. Oh joy.
I gave in and did the Transmission Fluid flush, at the Honda Dealership. The techician replaced the tranny fluid and burnished start clutch, then redrained and filled it with new fluid again. The shudder nose at initial acceleration has been fixed for now. Just did this today. If it comes back, I will make a post here again. But it's fixed now.
I remember having a major tune up at 50k. The problem was at 67k. Oh well. Costed $100 to flush the tranny. I have never had any other problem so I am still happy about my Hybrid. Plus, I should be getting my single occupancy carpool lane sticker in two weeks (in California). Can't wait.
I am just reading through the posts one at a time and do not know if someone else has answered your post, but here goes: there is NOT 102 RECALLS on the HCH or anywhere near there. On the 2005 HCH there is a grand total of 5 and one of those great big problems was someone bitching that the rear turn indicators were changed to red instead of yellow.... When you do YOUR research start here http://www-odi.nhtsa.dot.gov/cars/problems/recalls/recallsearch.cfm
Mark
The 0-20 seems a bit extreme to me.
Seems like it would make sense, especially in warmer climates or in the summer.
All you would lose is a bit of mpg when your engine is warming up.
I just bought an '04. It runs beautifully, but as I was investigating the setting of the odometer and related displays, I turned off the Fuel Milage Display. I'd like to turn it back on again, but it just doesn't happen. When I turned it off, it took a few attemps... Nothing else is wrong; I can reset the A and B Trip displays very easily and flip between the displays. I know you're supposed to press the button for 10-15 seconds, but I do that and nothing happens.
Any suggestions?
Cheers
Mikael
I had this problem w/ a old Civic HB and a newer Civic 4d the shield are made of aluminum and they attach them w/ steel bolts the different metals cause corrosion (there is scientific term for the problem but I cannot remember it right now.) and if one of the attachment points breaks the heat shield rattles.
I just had the local oil change place remove the H/S no more noise......
http://www.corrosion-doctors.org/Aircraft/galvdefi.htm
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
As far as what to expect, you can expect this FOR SURE: if you are willing to play the game with the available instruments and tools, your MPG will definitely get better !!
My current lifetime MPG is 48.2 for my 2004 HCH, but my first tank was only 38.4 MPG.
Here are some basic tips for you: ( please just balance all these tips with common sense and drive with the flow of traffic when safety requires it - keep Bubba SUV off your tailgate !! )
Getting max MPG from a Hybrid takes a "re-learning" process in your driving style, for most people. You can't "just get in and drive" and expect EPA numbers or higher. But with a little re-training of yourself, you CAN do just that.
Everyone's MPGs starts out low till they get the hang of it. There are a million gas savings tips here just search around.
If you have nice, generally flat roads, use cruise control every chance you get, because it can balance speed more expertly than even the most trained foot.
In the city I accelerate very slowly, and if I'm alone in the car and nobody is behind me I accelerate as slowly as is reasonable.
I'll pop it into neutral and coast to the red light 3 to 4 blocks ahead - usually it turns green before I get to it.
Leave plenty of space in front of your car when traffic allows it. If someone pulls in front, remain safely back. You can reasonable expect your brakes to last 100K if you take it easy like this.
Pretend you have no brakes as you drive and that will help too.
The MPG you get will be limited by the changes you make to your driving style.
Coast, Coast, Coast. I have a manual tranny, so it is Oh So very easy for me to just pop the tranny into neutral when I have some speed built up and see that I have an open space in front of me an no one behind me to slow down. I usually coast in neutral when I need to keep my speed up because the car rolls much better out of gear. If I need to boost the battery or if I know I am going to be coasting only for a block or so, I leave it in gear to get the charge boost, because the charge increases when you coast in gear.
If you can drive as slow as 30 mph, do so and put on the cruise. In my manual tranny, I put it in fourth gear at 30 mph instead of 5th and it gets better mileage on the real-time meter. If I get up to 36 mph, I put it in 5th gear. Both 30 mph in 4th and 36-42 mph in 5th are the best for high MPG readings on the real-time meter. Yesterday in only a span of less than two miles at 30 mph I saw the real-time meter stay mostly 65-85 mpg on a flat road. I am always careful to avoid slowing anyone down who is zooming up behind me. I usually have three lanes to choose from so thus far I have avoided any Road Rage incidents !!
At your first oil change (I would do it around 5000) change to synthetic oil if you can. It allows for less friction in the engine and in THEORY you can get a 1-3 mpg boost from the added efficiency of the reduced friction. In a 1997 Suburban, I went from 17 mpg to 19 mpg just from the oil change alone.
Drive like there is an egg between your foot and the gas pedal and never accellerate harshly unless it is required for safety purposes.
Learn how to use Auto-Stop and milk it for every stop it's got !! It's easier in the manual tranny, because I can stop behind someone and take it out of gear and if I have to creep up a car length or so, the Auto Stop will kick in again after I creep up when I put it back in neutral. I don't know how the CVT handles that sort of thing. If all else fails and Auto Stop fails to engage if you have to creep up, TURN OFF THE IGNITION while you wait for the light to finish. These cars do not have traditional starters, they are started by a "starter generator" powered by the electric battery system, so it's OK to start it a few extra times a month in the effort to save fuel and reduce idling emissions, right? Right.
Avoid A/C usage when you can, as it KILLS the MPG. I had a tank at the end of the summer and I was at 650 miles and 55.6 MPG because I managed to avoid the A/C the whole time on that tank.
Keep your windows rolled UP when you can to avoid extra wind drag.
Try at all costs to avoid getting into a situation where you must drive faster than 60-65 MPH. These speeds will MURDER your MPG.
To improve mileage, you may want to run your tires at 40 PSI or higher when cold. This is a philosophy which is hotly debated around the web, so do your research before this tweak - there are pluses and minuses for this modification.
The combination of your car breaking in and your driving education will lead to increased MPG and fewer stops at the gas pump FOR CERTAIN !!!
Barb - They are the same seats. Honda does not have special 'hybrid' seats.
Her ICE Civic might be a different model year...
Obviously. But it makes no difference. There is no such thing as a Honda Civic Hybrid seat -- they are the same for all Honda Civic models for that year.
If she is going to complain then about those horrible Civic Hybrid seats, then how about complaining about:
- those horrible Honda Civic Hybrid headlights
- that horrible Honda Civic Hybrid glove compartment
- those horrible Honda Civic Hybrid windshield wipers
- that horrible Honda Civic rear legroom
- etc. etc. etc.
On the other hand, here are some ideas about what she could validly complain about:
- trunk space
- dashboard with all those silly lights and "IMA" stuff
- antennae on the roof
- smaller wheels than the EX
- etc. etc. etc.
Those things are different on the Hybrid, and are candidates for discussion.
Sorry, that sounded kind of snarly. What I should have said was, "Yes, I thought of that. But it makes no difference..."
Sorry about that.
I think it does make a difference. She may have meant that the seats on a Civic she owns were more comfortable than the hybrid seats. If the seat design changed from the model year of her Civic to the model year of her HCH, the comment is completely understandable.
Or, maybe is is just a perception issue, difficult to say. Also, anyone know if there are any differences in the suspension of the HCH vs the normal ICE Civic. That may come into play here.
I have no doubt that's what she meant. That's not the point at all. The point is that this is not an issue related to the Honda Civic Hybrid. It is a point about the Honda Civic model styles for years 2002-2005. You might as well say: "I hate my Honda Civic Hybrid. The hybrid's vanity mirrors are no good. And the hybrid's glove compartment is too cramped. And why do the power windows on the hybrid work opposite from my Toyota?"
The last time I checked, the topic of this thread was related to "Problems and Solutions" concerning the Honda Civic Hybrid. Not non-hybrid, regular Honda Civic issues.
Yeesh. I think I now remember why I don't usually participate here.
"I have found the seats, on long trips, to be very uncomfortable in the Honda Hybrid."
That sure sounds like she got uncomfortable in a hybrid to me.
She then remarked that she"did NOT find this problem" in her regular Civic.
I take that to mean that she also owns a regular Civic and was bring that up for comparison purposes
She stated an opinion about the Civic hybrid seat comfort. Perfectly on topic.
The reaction to this is baffling.
I have a 2003 Civic Hybrid. My friend has a 2004 Civic Hybrid. We have different seats. Mine is more traditional, less bolstered and rounded at the edges. His has a sharper, tighter fit which holds you better but could be uncomfortable for some.
Even the headrests are different. My Hybrid has square holes in the headrest (which I don't find comfortable), and my friend has those solid headrests. His also has headrests in the back seats while mine don't (the rear seats curve up a bit where the headrests would be).
riley
Currently Hybird is operating mainly only as a gasoline engine motor without the assist of the battery for the IMA system.
The local service and National Honda Rep. indicated it could be due to customs problem, also mentioned a problem programing the computer and then have mentioned maybe redesign or refining the design of the part needed.
Have been told it is ok to still drive the car.
Other interesting thing is that no service order was written up.
Can not believe it takes 5 weeks and counting to get a part and repair. I wonder whether I should try going to media press or tv.
Are you trying to blame "hybrid technology" for your one isolated problem?
Sounds like that lady who drove her HCH through a 7-11 window and is trying to discredit the technology instead of saying to herself "I could have just turned off the ignition and this whole thing would not have happened."
If you have a Honda dealer who is having problems getting a particular replacement part, then you are certainly free to try other dealerships. You are also free to contact Honda Corporate and get someone working on the problem for you. You are also free to use your insurance to help pay for leasing another car while you wait on the repair.
Nothing about your problem would indicate that it is anything other than an unfortunate incident, and not indicative as a "defect" of any sort in the Civic Hybrid technology.
Welcome to the forum. I think it may be premature to shout your problem to the media quite yet. I do agree that 5 weeks is a long time to get a part. I would get them to open a service request that identifies the problem and an approximate time to get it repaired. If this is the dealer you bought the car from they should take care of your warranty issues. With gas topping 3 bucks a gallon I would be unhappy if I had a car that would not live up to the expectations of mileage because the dealer cannot get parts. I guess nothing has changed since the 1970s. I had problems getting warranty parts for my 1978 Honda Accord. My advice document, document, document!
Also twice I've turned off the alarm with remote, locked the doors, started the car (I think in that order), then a block down the road the blue light is flashing and the alarm is periodically doing these 5 quiet beeps in a row. I have to stop the car, turn it off, and restart it.
normal? I am admittedly inexperienced with car alarms, so it could be me. But how sensitive and quirky this seems!
(I love the car though, my first tank I got 37.4mpg and from what I've read, I'll get better as I learn more how to drive it)
Same thing happens to me. If you lock the car with the keyfob, you must UNLOCK the car with the keyfob. If you lock it with the key, you must unlock it with the key.
Locking the doors with the autolock button inside the car is the same as locking the key with the keyfob OR with the key outside the car - it turns the alarm ON.
I'm not sure how you can LOCK the car doors while driving it WITHOUT engaging the alarm - does anyone with more experience with Civic alarms know the answer to that?
I just experimented with this. If you lock the door before you start the car, you are setting the alarm. The doors lock automatically when the car starts, so usually you wouldn't do this. But since they unlock automatically when the car is off, if you are sitting in your car anywhere with the car OFF, and you lock the doors with the auto-lock button, you set the alarm. So if you start the car after that, the alarm is on and it makes the 5 beeps while driving. Or if I stop the car and open the door to get out, the alarm goes off loudly. The remote will not turn off the alarm when the key is in the ignition, only way to disengage the alarm is by taking the key OUT of the ignition.
It's definitely quirky, I can't say I like this part, but luckily something that does not come up too often (the need to sit in a locked car that is not running). Just have to know to turn off the alarm with the remote before starting back up the car. Quirky.
The computer diagnostic showed the EGR valve was bad. A visual inspection of the CVT fluid showed it was indeed dirty and although I had not received the letter, my car did need the ECM upgrade. All work was done, most under warranty, which also paid for my 2 days of rental car.
Knowledge is power. Thank you for sharing yours. :-)
Why do I feel as though HCH drivers are being punished for having a car that does not look obviously hybrid? (I know that's not true, lol, Prius drivers have to use the same ugly stickers even though Priuses are visibly recognizable!)
Has anyone actually stuck those ugly things on their car yet?!!
"Same thing happens to me. If you lock the car with the keyfob, you must UNLOCK the car with the keyfob. If you lock it with the key, you must unlock it with the key."
Are you sure it isn't just a little different from what you have stated. Actually my experience is : "If you lock car with either the key, door lock button or key fob, it arms( activates) the car alarm. In order to disarm ( unactivate, deactivate) an active car alarm you must either use the key fob or the car key."
Lock-on,
MidCow
It was shrill and pronounced. We would not consider buying that car because of the whine.
the a/c runs to take moisture out of the air and lower the humidity inside the car so the defroster will work better. if you don't want the a/c to run - just make sure the heater is set on "fresh air" (as opposed to recirc) - the normal floor setting and turn the heat up and fan high. usually there is some hot air bleed to the windshield which may be enough to clear it w/o running the a/c. The fresh air coming in helps blow out the humidity (your breath, coffee steam etc.) and will keep the windshield clean - hopefully. If you must keep the system on re-circ for allergy or pollution reasons - then resign yourself to running the a/c to reject the humidity.
i let a friend TRY to connect the stereo and clipped some wires and then connected them back, but my keeyless entry doesnt work, IMA light is on, i wanna cry... please help..
My 2003 manual Hybrid has averaged 39.7 mpg on Trip B. I have not reset trip B since a week after purchasing it,so if accurate, that is 40 mpg over 35+k. I think this is great! Most of my driving, over 50% of the mileage, has been in city. I'd say I drive a little faster and more aggressively than the average driver. When my wife takes the car for extended periods I notice a jump in average mpg on Trip A to around 43 mph. When I drive exclusively in city it averages around 37 mpg.
I'm really satisfied other than the minor inconvenience from the recall and a rattle or two here and there. I've had the catalytic converter and a front strut replaced under warranty.
My wife found that she could reach underneath somewhere and stop it.
We took it to the dealer and they removed the top panel and installed some sticky foam.
That worked for a while.
Then the passenger side door began rattling. I could push on the interior panel and get it to stop. The dealer put some padding on the internal rods (etc) but it didn't do any good.
I gave them a 2nd chance on the passenger door and now the center pillar rattles at times along with the door.
Then the rattle next to the air bag began again.
I took it to the dealer again and they put in more sticky foam.
As soon as I got it back the Left side began to rattle.
At that point, every time I brought it in for a rattle I'd leave with two.
The various rattles in my car is not really that loud and rarely happen simutaniously, but the car is so quiet otherwise it's just a pet peeve at this point.
I suspect that this is something that's true of all Civics, not just Hybrids. Does anybody know?
