Ford Ranger III
The pinging noise doesn't seem to be coming from the engine compartment. It's coming from beneath the cab, leading me to believe that it could be the transfer case or transmission. Not like I know much about engines/transmissions, but that's my best non-educated guess. I'll take it in one more time and see if they can spot something and get back to you. Thanks for the info.
Actually, I think a big problem may be the seal around the rear doors/front doors interface, which may be letting in a lot of the noise. Not gonna mess with that, though. Was the model you drove the supercab?
Honestly you could operate a F-150 with a 5.4 liter engine cheaper, since they run fine on 87 octane.
Sold my Ranger with 8500 miles for $11K and glad to be rid of it. I suggest you do the same.
BTW, I am a lifetime Ford man. I feel though that the Rangers, for the most part, are false economy. The cost of admission is low, but the cost of operation is high. More for high octane gas, poor fuel economy, same insurance cost as a big truck, and the agravation of all the problems. And the large depreciation, oh boy! (There is a reason for the $1000-$2000 or more rebates they're offering. I found out the hard way).
Rangers are a great value. I don't see how you can compare a F150 to a Ranger?? Tell me where you can get an F150 absolutley loaded for 18,888??
You may not get great resale but you also don't pay a whole bunch at sale if you know how to deal.
And F150 sure doesn't fit too good on the trails where I go. I have seen many large trucks stuck because they couldn't turn around or were just too large to fit between trees or rocks..
BUT, for most people who purchase small trucks, the driving factor in the purchase is price. But the initial cost is only an advantage if you end up satisfied with the vehicle in the short term.
Buy a Ranger and need or want to dump it a year or two later, you pay a big depreciation.
Buy a full size US Truck or a Toyota, they hold their value. For instance, a Tundra 4WD Access Cab limited can be purchased for between $26-$28K, before taxes. (OK, no leather) BUT, you'll probably be satisfied for the extra $8K and you can just about ask your original sales price a year later, if you want to sell. The difference in cost of operation over the long term is negligable, probably less for the big truck since it will probably more reliable.
Is it worth the extra $8-10K to get the bigger truck? It is to me, now. This may not apply to you. Only relating my experience so as to let the community get one more opinion.
In the end, it's your money.
Rangerless in GA.
(Now driving my old '66 Mustang - Forgot how much power a properly massaged 289 had!)
I've had several 5 speeds with manual trans/transfer cases. They tow fine. Am looking at a newish truck, but need to be able to tow it on occassion
can one of you guys recommend a replacement 15 inch tire to exchange for the stock Firestones on my Ranger, which i cannot seem to get balanced ? [ironically, they want to shake the most at about 60 to 66, right where i do most of my driving]. i am thinking of a Michelin product: any suggestions here ??
i am looking at 225 x 75 x 15.
Steve.
I've got an old V6 Ranger 4x4 that I'd like to trade in this spring for a new 4cyl. I'm just tired of getting 15MPG around town and I don't do a whole lot of off-roading. So I'm looking at getting a 4cyl 4x2.
Dakota Ex Cab because you can put a seat in the back.
TD
Bill
I have an ancient V6 Ranger 4x4 that keeps going and going and going...
I would offer about 16K and see what they say if you really like the truck. The 3.0 may lack power but it is a very reliable engine overall.
I know once you get behind the wheel of the new SOHC 4.0 in the Mazda you won't want the 3.0..
Thank You JP122985@aol.com
Schaffs3
Schaffs3
http://media.ford.com/products/make.cfm?make_id=92
The bumper capacity is probably stamped somewhere on the bumper itself--it is often 2000lb irrespective of the towing capacity of the vehicle. When in doubt, get a hitch.
My ancient 5sp 2.8L V6 4x4 Ranger gets about 19-20MPG on the highway, so I would expect a modern 4x2 5sp would get the rated 22MPG. However, someone else with a more recent 3.0L Ranger might be able to answer that question.
Note that the MPG of pickups is very much affected by speed since pickups are not very aerodynamic (to put it mildly). Today's cars are pretty aerodynamic so going fast won't affect the MPG that much. Not so with pickups. Also, make sure to get a tonneau or cap if MPG is a concern.
Also, the truck has 245/75R16 tires on it. Can you install bigger tires on stock rims? What is a bigger (taller) size for these? How big before needing a lift? What is a good lift kit for these for under $500-600?
Thanks in advance.
4.0 litre engine, auto transmission.
Have there been any problems with this truck?
Anything I should look for/at on this vehicle?
Well, it came on after about 25 miles. We replaced the gas cap and brought it back in. It was the same code, so the mechanic turned it off and drove it to see if it would light up again. Of course it didn't until the next day. Anyone else have a similar problem or any suggestions as to what it might be?
Any suggestions would be appreciated.
Enjoying that open axle?
