And if you take it into a shop to get midnight's list done, I suggest you leave a couple of days between the service and the big trip. Just in case they leave any little surprises for you. Like the oil filler cap my dealer forgot to replace...
Our 2000 Ranger Supercab 3.0 A/T is as we expected-- the compact pickup of choice. In 14,000 miles, the only problem has been a severe juddering in the steering system (solved per #13440, which attributes the complaint to "air ingestion into the power steering system [if] the wheel is turned when the engine is not running...." Comment: Replacing the original Firestone Wilderness HT's with Michelin LTX M+S tires gave us a noticeable improvement in both ride and handling precision. Question: I would appreciate a shock absorber recommendation. I want improved control (the originals are beginning to allow too much heaving on bumnps) and an increase (or at least no significant decrease) in ride quality. Oops-- just noticed post 946... but further info./opinion would be welcome Thanks in advance for comments/suggestions.
At 74,000 miles on my original 1994 Ranger shocks, I just lately replaced them. Because.... well, just because they were old. I put bottom of the line Sears Monroe on, and I really think the new shocks are no better than the 8 year old ones I removed. It was a Sears half price sale and all 4 were $50+ tax.
Do you really need new shocks at 14,000 miles?
If so, most of the gung-ho Ranger addicts recommend Blienstin (sp). I bet one will cost what all 4 of my Monroe cost. Or, they also talk about the Ranchero 5000. Think that is the model number.
It's a 95 4x2 rear drive 4 cylinder 5 speed, 92 thousand miles. I changed the fuel filter approximately 1000 miles ago. Since then mileage has gone down. I checked and rechecked the fuel line connections when putting the new one in and made sure the arrow to indicate flow pointed the same way as the old one. However, I have lost what seems to be about 40-50 miles in range. Used to be able to get about 375 miles before the needle was burued to the bottum line of the E the few times when I felt adventurous. Now it's maybe 330-340.
Is it possible fuel filters are like what I've heard about new air filters in that it needs to get slightly clogged to be its most efficient? Can I expect maybe once the new Pep Boys filter is broken in that my mileage will go back up? OR should I take it out and get one from the dealer?
Bought this Ranger new in 1994, 4 banger 5 speed 2x4 Supercab. It turn 241,000 miles last week. It blew a timing belt so now I'm thinking it's a signal to go shopping. Thinking of maybe upsizing to a F150....however this Ranger has been so good hard to decide. Got 103,000 mi on the first set of Firestone tires (on the 3rd set now),still has the original everthing water pump,alternator,clutch etc. except of course, timing belt serpentine belt, plugs. Diff. bearings got noisy about 150,000 mi. so had all replaced, and changed the shocks to Monroe gas shocks....OK, but definitely a harder ride. Anyway that's a testimonial to the Ranger. I've had many new cars thru the years, this is the first new PU and it's been great. Surprising the durability of the 4 banger. 70% of the miles were Calif. mountains and freeway.
I got my 93 2.3l auto, reg cab, up to 142,000 miles. Totally reliable vehicle, no matter how much I beat on it.(Owned it while I was 17-25 years old) Anyway the engine is a non-interferance engine, where the cam and crank can spin freely and the valves should never contact the pistons. While there could be some combustion damage, there should not be any metal to metal damage. So just make sure no plugs foul or smoke in the tailpipe and you will know your pistons and rings are still holding down the oil. But it's such a reliable engine that it should be just fine...
But now I have a '03 3.0l regular cab with manaul. $2,000 dollar rebate off invoice was too much to resist, although I would love to see what the next remodel brings us.
Eharri--->Could be that, your intank filter, or maybe just a bad filter.
I got the regular cab Edge, 4x2, 5 speed manual, tilt and cruise, with Edge plus package (6 disc in dash, rims and goodyears) plus I added security, step bars, door locks and limited slip. All said and done I financed 14 grand. I started off the invoice pricing, and paid $100 over invoice in trade for extra goodies installed. Then the rebate.
I owe less on my 2003 Ranger than my girlfriend owe's on her 2001 accord.
and the limited slip, are you ever in snow? I am not in a bad snow area, but we do get some from time to time, and there are hills around. I want to be able to use my truck all year round.
I prefer to skip the 4x4 to keep things simple and cheaper. Also I have heard and read that steering and handling are not as good w/ 4x4. Thanks in advance.
So if I do see snow it's never around for more than a day or so. We might get one or two hard freezes throughout the year, but that is usually taken care of by the city sanding the bridges, etc.
I didn't have the need for a 4x4 as I am not an off-roading type of guy. The edge package does have a 4x4 suspension, so I don't imagine there is a whole lot of difference in handling in my 4x2. A 4x4 would probably only add a bit more weight up front, and would only really handle differently if the transfer case was engaged. Insurance is also much cheaper on a 4x2.
I got the limited slip so I would not have to worry when I do go on a few country dirt roads, or out camping. I have yet to experience any wheel slip, but it's good to know the limited slip is there in case I do hit some mud or ice that I wasn't expecting. For $295.00 dollar upgrade it should be well worth it. Just have it added to the bill of sale so you shouldn't have to pay for installation labor, etc.
Another advantage with the limited slip is that it is always "on", or ready to engage. No buttons to hit. It is also better than lockers or 4x4 systems in that a limited slip will have no affect on turning or cornering ability. Definitely worth the small price you pay for it.
One small note, I love my 3.0l stick in the regular cab 4x2. Plenty of power, however highway gas economy suffers a little with the 4.10's in the rear. I would go with 3.73's(or whatever equivalent there is) for a little lower rpm's while cruising. But if I had to tow, the 4.10's would definitely make it easy to get a load moving.
for your post. Appreciate your comments re/ limited slip. Also I hadn't thought about the insurance difference. I am looking at the automatic, 3.0l and regular cab.
As for the final drive ratio, I was under the impression that the edge only came with 4.10, vs 3.73 in the XLT. If I had my choice I would be inclined to go with the 3.73. I don't plan on towing and am looking for a relatively relaxed highway ride.
I prefer the higher stance of the edge along with the vinyl flooring.
I didn't look into gear ratios when purchasing, so it is all after the fact. I didn't know the 3.73's are only available on the XLT. I figured it would be little more than a speedocable gear change, and a new rear gears. I currently do 80mph at 3,000 RPM's, and with the horsepower peak over 5k, it has plenty of passing power when needed. Also my Edge has a governor at 92mph...
One item to note, my 2003 Edge is quieter on the highway than my girlfriends 2001 Accord EX. The wind and road noise is much better insulated in my truck. She gets better gas milage (4 cylinder Honda), but I can go places she can't... Had to get step bars so she could easily get in the cab, but when comparing the Rangers on the lot, I had to get the extra ride height. I love my truck, and will definitely enjoy it for a long while.
Anybody have any experience with a cat-back system for a Ford 3.0l? I am looking for 1st. Power increase and 2nd. A bit more sound and 3rd. A good deal.
How about any other performance parts? Chips, air intake, etc? My main goal is to increase power to help out gas economy. As much as a catch 22 that is, I do admit I enjoy a little lead foot action here and there.
Anyone hear about the new Thunderbolt? FORD SVT supposedly has put a supercharged 5.4 Triton in a Ranger with plans to market. GM, Dodge of Germany currently have no mini truck to meet challenge.
I just got a used '99 Ranger 4x4 Stepside. I would like to get people's opinions on hard and soft covers as well as pros/cons of the hook and loop versions of soft covers versus the snap versions. Any help is greatly appreciated. Thanks!!
I have a snap on Black Max Extang cover on my 95 Ranger. IT's been on the truck 3 years now and still doesnt let a drop of water into the bed. I like that you can roll it up easily and store it by the back of the cab to carry heavy cargo, and there's also the obvious fact that it was cheap. Dont like how much of a pain it can be to get on when it's cold outside and the canvas shrinks. Sometimes my fingers and palms will get blistered from the effort and I might only be able to manage a few every hours before I get tired from all that pulling and I have to take a rest. That's a problem youll have with pretty much any soft cover. Mine is a quality product, but I just dont like the general charactaristics of soft covers anymore other than low price.
If I had it to do again, I'd buy a hard cover. Reason 1: They lock. Reason 2: They lock. and Reason 3: Did I mention they provide locking storage? It may seem like a pain to part with the extra cash for a hard cover. But believe me, on those long trips where you can stop over in a motel without having to lug all luggage in your truck bed into your room and then load it back in the next morning, you will most certainly thank yourself for having bought something that provides a secure bed.
IF the Ranger is your primary means of transportation, you will thank yourself later for getting the hard cover.
Short bed ARE hard tonneau go for about 750-850, and fits your Ranger XLT or Edge body moldings. I will hopefully get one after my spray in bedliner, sometime this summer...
1)Do all the 2003 ranger 4x4s have the new 4" alum driveshafts that are replacing the vibrating steel ones? 2)what kind of gas mileage does the 4.0L 4x4, 4.10 rear get? I do alot of highway driving at 70-80 mph. Overall is everyone happy with their Rangers I had a lemon 1999 and swore off fords forever but 0% and a friend in the biz is luring me back. Thanks
I will add my 2 cents to your second question. I have an '01 4.0, 4x4, automatic, 4.10 rear and have made several round-trips on the Interstate between Minneapolis and Des Moines. The typical cruising speed is in the 70-80 range.
I have found the EPA estimates to be pretty accurate on this truck, but wind makes a big difference. The best I ever got was a tad over 20 MPG but I only got that on one round-trip. Going into a stiff headwind, I have gotten as low as 16.5 on the same trip. Around 18 or 19 is about what I average for highway driving. It goes down if I spend much time in stop and go traffic.
I concur. I own an 00 pushrod 4.0 vibrator V6 (with an ARE cap). I average about 18 on the highway (using cruise) at an indicated 70 to maybe 72. When ratcheting up to 80, mileage drops fast as drags increase. I get about 16 to 16.5 at 80. Around town about 14.5 to 15 in summer, about 13 to 13.5 in winter. I have the 3.73 rearend with 5 speed auto, and 15 inch stock Ford alloys with Michelins. Ranger mileage sucks pretty bad on 4x4 V6's, no matter which truck you get. Just simply too much drag (high ground clearance) and weight and friction in the drive train. Physics is at work here. If one wants mileage from a Ranger he needs to get a 4 banger and 2 x 4; he can then expect maybe close to 23-25 mpg under ideal conditions. Trucks SUCK for MPG, period. That is what Honda Civics are built for. If MPG is what one nedds, AVOID a truck altogether.
I bought a 2003 Supercab with 3.0L engine and A/T. It now has 2000 miles on it and I got 21.9 mpg on a 300-mile trip that was 90% highway driving. How much better will this get when the truck is fully broken in? Also, the engine seems kind of noisy to me, especially when accelerating fairly hard or pulling up hills. Is this normal or a cause for concern? Finally, is this engine pretty reliable and how long can I expect it to last with proper maintenance?
That engine noise is very likely detonation (pinging) from that 3.0 motor (it is infamous for that symptom). I wouldn't worry about it. They will ping their way to 250 000 miles. Also, some of these motors will get a "marbling" sound, especially at idle when cold, that is most likely carbon buildup around the piston skirt area (so the theory goes). My 4.0 does it, and has for a long while. It goes away when hot. I don't worry about it anymore. I am just thankful that it runs ! ;-)
I've noticed that the torque peak on the stock 4 cyl. is lower than that on the 3.0 six. This is very odd tuning. The peak on the 3.0 seems too high, also, unless this truck runs at an unusually high RPM. This tuning could result in the 4 cyl making more power at normal cruising speeds than the 6. Is this, in fact, the case? Why would Ford tune their engines so oddly? Would a more aggressive spark advance lower the torque peak on this engine? This works great on Harleys and is cheaper than re camming.
Yes, the 2.3l reaches it's peak of 154ft/lbs at 3750 RPM, while the 3.0l it's 180 ft/lsb at 3900. I don't have the complete curve available or infront of me, but I would bet that at 2000 RPM the 3.0l is around 150 ft/lbs.
I own a 2003 3.0l reg cab 4x2, and when I drive I rarely have to go past 3000 rpm.(and usually only in first gear). I am not a slowpoke either! Best thing to do is test drive both, and I am sure you will see what I mean. In a regular cab, the 3.0l rocks!
Also, the 3.0l don't ping anymore for 2003 and maybe even 2002.
Midnight. Thanks for replying to my inquiry about The torque peaks of the 4 banger vs the six. I'm planning to buy a long bed standard cab and I don't believe the smaller engine is even offered in this configuration. Anyway. What would be the cheapest way of lowering the torque peak of the 3.0? Engineering it significantly higher than normal driving RPM is just, well, bad engineering! A waste of engine potential! It would even cut into gas mileage as people rev higher to reach peak power. What were these engine designers smoking? On another subject, I've seen several comments about Installing K&N (read "less restrictive") air filters on these trucks. All well and good, but if you're going to open up the intake end of your engine, ideally, you should balance it with a less restrictive exhaust as well. And, most important, keep in mind that these changes will lean out your engine. You'll need to adjust your mixture to keep engine temps down and achieve good power/efficiency. Easy with a carburetor but somewhat problematic with fuel injection.
Trying to get into the heads of the Ford engineers might proove to be an effort in futility.
I do know that at highway speeds (75mph) with a 4.10 rear gear,the 4th manual gear will put you right around 3900 RPM. Which would be perfect for towing. It does seem a little high, but the vulcan 3.0 is a stout little motor. I used to own a 93 2.3l, and never had the valve cover off in over 140,000 miles.Never got below 20mpg. My current 3.0l has much improved power, even compared to the current day 4v 2.3l, but my MPG is currently aroung 17mpg in the city. But that could be because the engine still has 2,100 miles on it, and hasn't broken in yet.
End result, it really depends on your application. A daily commuter behind a 2.3l would be perfect for economy. Those who would could use a little more towing capability, the 3.0l. Then the 4.0l is a big increase to power for a small option price. If you want a reg cab, long bed, you should be able to order that truck with a 4.0l from any dealership fleet salesman.
I bought a used 99 Ranger Extended Cap 3.0 XLT I Have had problems with the shifting since I got it with it being hard to go into gear. I was told to pump the clutch if this helped it was the master cylinder. It did help so I took it in to have the MC replaced they did I was driving the same day and the clutch went all the way to the floor and was engaged in gear. Had it towed they said a locking ring had come off that they hadnt gotten it on right. They put it back together same day it doesnt it again. The tech says there is no retaining clip just the ring that locks into place this doesnt seem right anyone know what might be the problem??? Thanks in Advance.
My 01 supercab 4x4 has the 4.0 sohc w/5 spd auto and 4.10 gears. Crusing between 70 and 80 I average 18 to 20 mpg. I have to agree with brucellinc in #987 wind can really kill gas mileage. Once on the way to Portland, OR from the SF Bay Area I only got 15 mpg. This was in real heavy wind and I just about had my foot to the floor. Driving back and forth to work (60 miles a day) which is about 70% freeway I average 17.5 mpg.
since I have visited this room. Back in 1998 I purchased a Ford Ranger XLT stepside kingcab 4x4 with a 4.0. Truck was pretty much loaded with every option. I bought the truck for $19,600 dollars. I put on some better and larger tires, an air intake system, step bars, rock guards, spray in liner, and a flowmaster exhaust system. After 97,000 miles the truck has performed wonderfully. I have had a brake job done, transmission fluid changed, along with all other maintenance performed. I also did a timing belt at about 70,000 to be safe. These are great trucks. But, my wife is wanting to sell it since we have a car, an SUV and a truck. I am going to try to hold her off as long as I can. The truck looks new, runs great and is very reliable. I have waxed it and washed it kept it looking great..
The 4.0 Ranger V6 uses a timing CHAIN, not a belt. You have done the IMPOSSIBLE...replacing a timing belt that the motor does not have. Congratulations ! ;-)
Here's equipment and what I paid: Auto, AC, Power equip group, Appearance pkg, Tilt w/cruise & leather, vinyl jump seats, class III trailer hitch receiver, Slide rear window, privacy glass, full size spare.
Price 18,442 NY tax 1521 (8 1/4%) Reg/Title 125 (2 yr registration) doc fee 148 20,236 rebate 2,500 TOTAL 17,736
timing chain... Fact still stands that my Ranger has been trouble free with normal maintenance. I notice the Ranger vs Tacoma room is gone?? I am a Tacoma owners worst nightmare..
I got 2000, but 2500 now? I missed out... Anyway, I owe less on my 2003 Ranger than my girlfriend does on her 2001 Honda Accord. And I have only made 4 payments so far... LOL. I also pay 135 bucks less per month...
scape, I tried to re-open the Ranger vs Tacoma thread 2 additional times, but it always gets closed due to certain known instigators. It was a good place for two camps of truck fans to get together, but certain "planets" seemed it was a mountain that needed to be battled over.
I'm trying to find sources for ladder racks. I hope I can find one that is relatively inexpensive and easier to remove. Does anyone know of Internet resources or the type of local shops that carry this item?
I've been in the market for a commuter/light duty truck and had pretty much settled on a regular cab XLT Ranger 4cyl 5spd for the economy (29mpg hwy). I felt kind of cramped in the cab though and really wanted the dry storage and grand kid seating of the extra cab. On a whim I looked at the new Mazda trucks on this site and found that they listed a 4cyl X cab not offered by Ford. I've looked through most of the postings here and didn't notice any information on this vehicle. Has anyone had any experience with this unit? I'm told Mazda currently has a $3500 rebate which makes this unit pretty attractive. I'm not concerned with tow/hauling as I also have a V-10 Superduty. Are the mileage figures given fairly achievable? Thanks, Ron
the 2.5 is the 2.3l with a longer stroke. The 2.3l has a timing belt, and so should the 2.5l. The 2.3l Is a non-interferance motor, as should the 2.5l, but I cannot say for sure. That extra stroke might be just enough to cause valve-piston contact.
I would really sit in the regular cab for a while. Me? I own and like it, it's got plenty of room for me, but I have the back of the seat all the way back (I'm 6'1" with long legs). It fits me well, but not much room to spare. My girlfriend really wanted me to get a extended cab so she could recline during longer trips. It's just very useful space. My next ranger will probably be extended cab...
Things to watch out for? Well the best bet is to take the vehicle to a mechanic for a full point inspection. DIYers will need to check belts, vacuum hoses, condition of liquids, a few spark plugs, especially brakes, and definitely take any used vehicle for a good test drive. Hope that helps
Couple of questions on the Ranger. I am looking at getting a new work truck for my companies lab to use. The primary driver is about 5'9. How much room is there behind the seats in the regular cab model. I don't want the v-6, so I need to get the regular cab. Is there enough room to cram a couple of duffle bags if the seat isn't scooted back all the way?
Also how is the 2.3 4-cyl for towing. I don't need to break any speed records while towing, just don't want to hurt anything. The vehicle would never tow more than 1,500 lbs.That shouldn't be a problem should it? I notice the 4-cyl is rated to tow 1,600 lbs.
Hope things work out with the Ranger because the price is right with the $3,000 rebate. $11,900 for an XLT w/ a/c and block heater. List price is $15,825.
I've never been in a standard cab Ranger. I'm 5'7". I had a 1966 full size Ford, standard cab. I kept the seat all the way back and there was no room behind the seat. Nothing. Course, there was a fuel tank back there in those days.
The 4 cylinder's power has been upgraded in last couple of years, but I did drive test drive one of the previous ones. Can you say 'weak'?
I would not get a 4 cylinder to drive, much less to tow. I would not get a standard cab. And also, if you do any towing, get an automatic, it will be rated for more towing than a manual. And although the automatic is not a strong transmission, the manual is worse if you try to tow with it.
P.S. I have a 1994 4L V6 Extended Cab automatic. P.P.S. Don't expect any decent gas milage either. It's a truck.
I have some pictures here that may give you a good idea of the room behind the seats... http://www.cardomain.com/id/2k3edge It's just enough to fit a subwoofer box, amplifier, and the tire jack kit. There is roughly 4-6 inches of space at the bottom, and it tapes down to 1-2 inches at shoulder level. Not much room, but my seat is all the way back (just barely not touching the rear wall or window). I think it may work for you, granted that the primary driver may not need as much legroom to drive comfortably. If that is not enough room, perhaps a cheap toolbox for the bed?
Also I would think about the towing and engine choices again. If the truck will be hauling some weight regularly, and that weight is near the limit, I would definitely step up. You don't want to always be near your limit, you want to be comfortable while hauling/towing. I think the 3.0l may be a good compromise, and it should not cost that much as an option. Of course you will not see 20mpg in the city with a v6, but you will with a 4 cylinder. So depends on what the truck will be doing mostly. But the 2.3l is a very healthy engine. I had a 2valve version of it in a 93 ranger, and it lasted over 140,000 with nothing but maintenance.
Dudleyr, I had the same questions as you and did a bit of research. I ended up getting the B2300 Mazda Extra cab last weekend. It's basically a Ranger (same engine & drivetrain) with different trim. It only comes with the 5spd manual which was fine for me as I'm looking towards fuel economy. I've only a couple of hundred miles on it but am quite satisfied so far with the way it drives and there is more than enough room behind the seats for duffels or small passengers. I got it fully loaded with the power and convenience packages for $15k with the $3500 rebate but before tax & lic here in California. Also the warranty on the Mazda is 4yr 50,000 mile. If you need the 4cyl and extra cab I'd consider this as an option. Hope this helps, Ron
I am aware that the 1,500 lbs that may be towed are near the limit of 1,650 lbs, but the Toyota and Nissan both tow 3,500 lbs with their 4-cyl engines that have a smilar hp and torque rating. I am just wondering if Ford underates the 4-cyl so more people will buy the 6. Even my little Integra can tow 1,500 lbs.
Also the 3.0 v-6 only has about 8% more power and 17% more torque than the 4 at a huge penalty in fuel mileage (22 vs. 29 highway). This vehicle will be driven at about 70 mph on the highway about 4-5,000 miles a month during the construction season. No real big hills (SD), and not much starting and stopping (the hardest part on a vehicle that is towing).
This is not a pleasure vehicle - it is all about getting the job done efficiently.
Has anybody had problems towing with the new 2.3 liter engine (I know the old one wasn't as good).
Also how did people manage just a few years ago when the 3.0 V-6 only had 130 hp - 13 less than the 4 now has (I know the torque was about the same)
DC
Your comments on highway ride quality are greatly appreciated. I need to check out the rpm vs mph numbers on the automatic.
http://www.rangerpowersports.com/features/svt/2.shtml
Regards to all truck loving perple,
Andy
midnight_stang Jan 29, 2003 9:26am
380hp/450lb.ft should be pretty mean in a regular cab ranger!
Price 18,442
doc fee 148
20,236
rebate 2,500
TOTAL 17,736
1. Does the 2.5 use a timing belt or chain? Is it an interference engine?
2. Is the extra cab room noticable over the 96 model? I always needed a little more leg room.
3. Anything to watch out for before buying? it has 56k miles and is in excellent condition.
Thanks for any help!
Thanks, Ron
Ron
