Honda Accord Future Models
http://automobiles.honda.com/models/model_overview.asp?ModelName=Accord+Sedan
The Coupe and Hybrid pages are not yet updated, just the sedan. Note some accessories changes, like the DVD-based i-VES (in-Vehicle Entertainment System) for the rear passengers. I don't recall seeing that on the former '05 model page.
With those new stubby tail-lights I'm even gladder that I got an '05 two months ago.
My local dealer hasn't had too many '05's recently since they've practically been giving them away under the Clearance lease program. If someone wants an '05, they won't have much selection to choose from ...personally, I'm glad I waited.
It looks like the "wood grain" trim package upgrade isn't available anymore. Just a metal trim package?
I'm pretty sure wood grain trim is still available. It will probably still only come with the ivory color interior, which is available with the exterior colors: desert mist metallic, taffeta white, carbon bronze pearl (new '06 color), and nighthawk black pearl.
Here's why I'm confident wood grain is still around: go to the Accord Sedan page on Honda's site, and click on What's New on the right side. Scroll to the very bottom, and in the section Sportier Styling note the last bullet point on the left: New wood grain trim
As for a wood grain accessory "trim kit" that extends the trim up the sides of the center stack and up over the glove box and under the driver's legs, they may not have it quite ready. Just as it seems they didn't have the base wood grain interior quite ready for their brochure and web site picture photo shoot, since there don't seem to be any pictures of it.
If it's "new" then I guess they think it looks better than the '05 wood grain, which kinda looked a little artificial to me.
IMO my 05 does look better. But what i hate is it looks bad from certain angles.
Honda should consider it... the tan does look really sharp.
I feel like Honda's finally built an Accord for me. Now if I were just looking for a new car....
~alpha
The 2005 may depreciate slightly more since its already a year old when you drive it off the lot, so keep that in mind. This is the "2005 Honda Clearance".
I'm actually attracted to the Special Edition, but it doesn't offer a moonroof. Guess that's an EX thing nowadays. (I had a moonroof in my 1997)
Too bad its not new car time yet.
They do usually give a rough ride but not necesarrily for the reasons you think. They offer stiffer sidewalls and any cushioning that was achieved via sidewall flex goes away; this improves handling. The reason the rider is rough is because the suspension is usually associated with sportier models, i.e. better handling, etc.
I am not sure i would use the word FAD. It is more like keeping up with the Jones. They offer it so we need to offer it to be competative. A FAD goes away after time; we won't see sammler wheels in the future.
As far as tire wear, many larger tires are assocaited with sports and performance and use a softter compound and yes softer trie compounds are stickerier, handle better, have beetter traction, BUT THEY ALSO WEAR FASTER!
Bigger turning radius wider tires can only turn so far in the wheel well space. Yes the truning radius is usually larger because of the width of the tire. However, these cars can still turn around and don't seem to bother a majority of those drivers.
YTCMV,
MidCow
Nevertheless, this thread has got me investigating and discovering a thing or two: only the Accord 6-speed has had a 3-foot wider turning diameter since the generation's intro.
The 6-speed has 17" wheels and a manual tranny, so it begs the question: is it the larger wheels or the tranny packaging that increases turning diameter ?
I fitted my V6-auto with 17" wheels which have the 6-speed's exact wheel specs, and the tires don't rub against any part of the wheel well. Makes me think it's not the larger wheels per se that made Honda increase turning diameter but rather the manual tranny.
Since the 06 4-door sedan will come with a V6 & stick option, my guess is that the V6s - even the automatic only LX - will have the wider turning diameter because of tranny packaging and production line mandates .
And so - the theory goes - it's not the wheels but the tranny.
As to the larger wheels, while ride cushiness is diminished, a larger and lighter wheel delivers drivetrain longevity and handling benefits due to lower unsprung weight. The tires themselves are almost as long-wearing (up to 360 treadwear) and affordable (as low as $65/tire for Falken/Kumho) as the 16s.
That the 2006 LX-V6, which won't have the 6-speed, will also have a wider turning diameter suggests that production efficiency is a factor.
The turning diameter has nothing to do with the transmission. It has to do with the increased tire width. So that the wheels don't scrape the wheel well area the limits of the left maximum and right maximum were limited; if you can't turn a wheel as far left or right the turning radius is increased. Sometimes to make larger wheels more sporty the stering wheeel turns lock-to-lock are decreased.
If you have the standard 17 inch wheel on your 05 great; this means Honda probably could have left the turning ing diameter the same.
And I agree you can get tires with high treadwear which will wear longer. The downside is that there is reduced traction, so even with traction control on and high acceleration you will probably spin your tires.
Motor On,
MidCow
P>S> I can report already the 17inches ride and handle better
"by-wire" means that there is not a direct, physical cable link between the accelerator pedal that your foot controls and the fuel injection throttle that controls the gasoline flow into the engine. Instead, it is now an electrical signal over a "wire" between the accelerator and the throttle. Honda states that this "improves drivability". The term "by wire" is kind of misleading because you may interpret "wire" to be "cable" or some other direct linkage. But "by wire" really means electronically controlled.
the 06 honda looks way better than the 2005 one
Main features DRL ,VSC, LED taillights, heated mirrors, more HP, better mileage.
If you really want to know what's new on the 06s, then go to the Accord website and click on "what's new" and it will tell you.
kath3: Honda's sales were at a record high (in August) Accords Sales rose I belive around 20%. I'll try to find the article and post it.
Honda Canada's also posted a record high.
Anyone know?
Offering an AUX jack would definitely make me more likely to buy a 2006.
It looks very nice IMO.
Looks a lot like Mercedes CLK.
Can't say I was really impressed. The color looks like mud and the new EX alloy wheels are about as bland as the 16s on the Hyundai Sonata.
The front looks a bit better with the chrome grille.
The rear, however, doesn't seem to match up well with the front. From the earlier pics, the rear end looked sportier, now I'm not sure if I like the 06 rear better than the 03-04. I definitely DON'T like the 05s.
Most of the European models and all the Lexus models have red and amber.
One rainy night, a car front of me was M-B E class sedan that shows its presence
in clear and simple manner. I mean, separate bright red led when brakes( not the usual dimmer red becaome brighter ) and nice and solid amber when turning.
I think red and amber combination is much safer than all red.
Think about sunny mid day or rainy evening.
06 Accord has now LED , I hope they put back amber turn lites in 07.
Anyway new rear does not go well with sleek front, it is trying to be sexy but just dull, fat and need of refinement.
Honda,Please go check rear of M-B C and E class or VW Jetta(not the new ones)
they are , to me, simple and funtional and in harmony.
" Most of the European models and all the Lexus models have red and amber. "
No longer true, since they went to true LED lights only red. Recheck the models. Yellow LEDs don't show up and are not used.
Acurs, Infiniti, Cadalac, Lexus, MB, BMW all use red only!. The new Jetta does not use LEDs. The rear of the MB does not show amber. http://www.mbusa.com/brand/container.jsp?/models/gallery/photo_gallery/index.jsp&mcode=E35- - 0W&modelCode=E350W&menu=4 If that is amber in the slices then it is not LED.
I agree with you though Amber and Red are more distinct and show up better, but I don't think we will see thatcombination anymore.
Cheers,
MidCow
The weird thing is I have an Acura that has red and clear lens covers in the rear, yet it has amber turn signals because of the bulb color. So you can have the red and clear look with amber signals.
