Visitor Agreement.
ignore this post if it shows up. I am having problems posting messages.
I have seen a lot of F-150 Supercrews on the road but not too many Quads. At a campground in Albuquerque the guy in the next cabin had a Supercrew so we swapped stories. He couldn't believe I got my 4x4 for what his two wheel drive cost.
themacguy (a little off topic) Next time you are in Sante Fe drive up to Chimayo and next to the old church there is a place that sell flavored tortillas and the best chilli relleno burritos in the state. The place is called Leona's.
Bookitty
I KNOW that "Consumer Digest" is in this category (As opposed to "Consumer Reports" that DOES NOT ACCEPT ANYTHING from the manufactures.)
Do you know where this JDPowers gets its income from?
As many engineers will tell you.... A given set of data can be made to show ANYTHING you wish. It is all in how you graph it.
I learned this lesson very well thru a popular TV-rating firm. They asked my family to participate in their rating system by keeping a log near the TV.... Once they learned that my family did not watch the shows they they wanted to 'promote' they simply stopped accepting our inputs every week.
When you hear an automobile is best 'in its class'...Who defines what the 'class' is?
Wait a minuite... lets pick one ourselves;
A- Size
B- Weight
C- Color
D- Wheelbase
E- Fuel-capacity
F- Brand
G- _______________(Fill in your own)
H- All of the above
I am finally happy (I think) with my 4WD Dakota Sport. Just wanted to give an update of my post outlining the problems and dealership [non-permissible content removed] I was going through. I drove my Dakota 400 miles to another state/dealership. On the way it developed a "howl" in the rearend above 50 mph to go along with the other problems described in post 576.
I took the Dakota to an independent shop in SE Idaho, (Steve's Repair Inc.) and had them do a diagnosis and estimate. While the rearend was still torn apart, the manager called the local Dodge dealer and had the Service Manager and the Shop Foreman come by during lunch to have a look at what they found. The Dodge Service Manager was very dismayed at the work that had been performed by the Colorado Dealership. Here is what was found and what the Ron Sayer Dealership fixed for me.....All of these guys were great. Keep in mind this rearend had been overhauled not even a month ago.
Rear Diff was set up incorrectly and had 18/1000 backlash. Should be 7/1000s.
Pinion Bearings preload was too tight.
Side Bearing Adjusters were cross threaded.
Side gears were loose on axle.
Fuel pump went out on them while they were testing it.
The whole rearend was replaced minus the axles. The new sidegears tightened up the fit just fine.
It was thier opinions (both Steve's Repair and Ron Sayer Dodge) that many of the parts that the Colorado Dealership said were replaced were never replaced at all, but just tweaked, and tweaked VERY incorrectly.
The differences:
The howling is gone.
The clunking in forward gears is gone.
The clunking in reverse is still present but very acceptable compared to what it was.
Gas mileage was improved by 3.5 mpg.
Whew, hope that is it and I can learn to trust my dakota now....gotta cancel that extended Chrysler service contract now. I was advised to never take a vehicle back to my local dealership given what they did the rearend of my Dakota.
Happy ending so far.
Hope someone can help. I am looking for a oil pan drain valve to fit my 4.7L. I have seen / gone to the fumoto site (www.fumotovalve.com) & they have a pretty good one (like their warranty also). However I am looking for other options / different types. Does anyone know where I can find them?
Also, does anyone know what size, pitch, etc. the drain plug in the 4.7 is? I could not find it in the Big Orange Book.
Thanx for the help
PDS
Disclaimer: Been wrong in the past, will be wrong again in the future, but I learn something everyday.
Evan
I work with data constantly; computer generated and paper. I could not for the life of me figure out how they put that on their order sheets. NO ONE to date at D/C has been able too either. BUT, I believe you'd have to physically write down that you DIDN'T want a/c to not get it. %-)
What happens is whenever there is a knock the timing will be retarded by a 2 degree interval. Basically you loose 3 to 5 HP per retard. So far, in one driving I have lost between 18 and 30 HP and boy can you tell a difference. I thought I was driving a 4 cylinder!!!!! And this is the only solution. Supposedly the timing gets reset back to the standard setting when you next turn over the engine. So basically, they are temporarily hiding the problem by taking away HP. If you are having this problem as well, start asking about the software upgrade released from National Customer Service. Also give serious consideration to Arbitration because the problem does not and will not go away!
I have 4.7 auto 4X4. I've got 12.500 miles on it and it makes 15 miles/gal. I've not have any serious problems so far, knock on wood, besides thinks we all know like ticking, hard shifting from time to time etc. I try to do all service by myself, because I believe cars/ trucks run well as long as they don't see mechanics. I change oil every 3000 miles. Now I would like to change transmission fluid. This fancy transmission has no drain plug, at least I can't find it. Does it mean that you have to get soaked in fluid by removing the whole pan. I've also checked the level of fluid and it's way too high. Maybe I don't know how to check fluid, but it shouldn't be a brain surgery. The stick is wet like an inch above upper hole. They say do not overfill. When I brought the truck home when it was new, the engine oil level was to high as well. I guess they simply don't care. If trucks leave factory like that how they supposed to run well. I would appreciate if someone could respond to my post, especially if someone knows how to change transmission fluid. By the way, why manual doesn't say capacities of transmission, brake system etc. They tell you what needs to be done and list all the steps, but they don't give you enough info so you can really do it. Maybe they assume nobody is doing those things anymore and we read manuals for fun. Thanks for attention!
On the oil level, if you do not follow all the instructions, it will read high. Make sure you are on level ground with the engine warmed up, parking brake on and the transmission in neutral. If all that is in effect when you checked, then take it back to the dealer and have them siphon the excess out or give you a good explaination for the situation. I would also have them check the dipstick PN. It is not unheard of, when several different models go by,that someone accidently grabs the wrong dipstick from the bin.
There rolling off the assembly line but have not seen any pictures yet.
Surely there must be some pictures out there.
chad
When I took delivery of my 4.7L Dakota, the Oil level seemed WAY too high on the dipstick when measured using 'normal' methods.... (Let sit for a while to allow oil to collect in pan)
However
When I checked the oil level immediately after driving, it was spot-on where expected on the dipstick.
Another complication came at my 1'st oil change when after putting 5 quarts in the crankcase, the level on the dipstick seemed just fine. The dealer REFUSED to put the 6'th quart into the engine and declared that the owners-manual and service-manual (BOB) were both WRONG These documents indicate that the 4.7L holds 6quarts of motor oil)
FOr those of you that have changed their own oil int the 4.7L....How many quarts do you use?
I've been adding Marvel Mystery Oil during break in, and will continue to do so until the oil is gone (another two tanks or so). For those who have used M.M.O. during break in, did you notice any difference in mileage after you switched back to straight gasoline?
You both mention somthing I had not considerd. The fancy oiling system with the hollow camshafts and all must hold some amount of oil. This accounts for the apparent 5-quart capacity.
It would be a poor design indeed if this was allowed to drain into the pan while not running.Repeated dry start-up conditions for several seconds means early death to an engine.
Studies have shown that most engine wear occours during cold startup/warmup.... engines that run for long periods at a time have very little wear. IE....Crude-oil pumping stations, Ships, taxiis, ...etc
You might be able to sell the 5x7 on ebay or other web sites to recoup some of the cost.
Allen-
Thanks for any info/advice.
Mailman
I have the power bucket seats. I find that I have to recline the back of the seat with the power seat in the full down position to keep off the headliner. The headrest is definitely not. The top of the head rest comes to the base of my skull. Perfect position to snap my neck in a wreck.
Plenty of length for the legroom. Thigh room is a little tight. I think the thigh room is mostly the design of the bucket seat since the sides come up high on the seat portion.
I have taken my Quad on 3 road trips since July 4.
1000 mile round trip, 1800 mile round trip, and 500 miles Saturday. I begin to feel achy between my shoulder blades after about 250 miles. This is problably due to the reclining of the bucket seat and holding the wheel with one hand.
Like the vehicle for round town. Family enjoys the vehicle. I really love the four doors.
One interesting note, When I was researching extended warranties the main reason I did not select the DC extended warranty was it specifically excluded injectors on the gas engines. Rick
As far as the computer goes - so go the high end chips, as well - it/they require premium due to their remapped torque/hp curve & advanced ignition settings. Keep up with your expenses, monitor your daily mpg & watch your temperature readings. All may be of some importance sooner than you think.
Getting them to pony up their Holy Grail - a replacement PCM - is going to take some doing. ALL of the auto manufacturers use them and ALL of the snobs think theirs NEVER fail. Porsche started using them in the 83 944 and 84 911 models & up (I've had several of each) and I never met a mechanic who saw an ECM (their PCM) fail that could easily get the manager to replace it, under warranty or not. They would do everything short of rebuilding the block to avoid replacing one. I just started buying them from a 'parter' out in Arizona - to heck with Porsche and their sanctimonious crap - and fixed every computer problem I ever had from the start for a couple of hundred bucks in an hour or so. So stay on em!
Mark
Oh, I was originally thinking split rear, but seeing that Gibson doesn't recommend towing with it, I'll probably go with the swept side.
GOOD to be back on a forum that's more hands-on/technically oriented!!! After a lapse in time, I went to the owners club only to find lot's of good stuff about '01 styling changes, etc., but very little about the mechanics of these unique trucks.
For what it's worth... My '00 Quad 4X4 has the 5.9 and 3.55 RA. After much research, pricing, etc., I ordered the Borla cat-back "package," which includes a K&N air filter... Should be here by the weekend, and I plan to do the install myself.
Chose Borla partly because of reputation, partly because of anticipated performance/fuel economy gains and partly because of stainless steel construction (versus "aluminized" steel).
The Quad Cab package was $425 plus shipping ($460 at the doorstep in Michigan), and was back-ordered from CA for about a week.
I've been keeping a close eye on mileage, and will be anxious to note any gains once the new system is installed. However, I understand that the computer requires approx. 100-200 miles to "adapt" to the free-breathing intake/exhaust.
Will keep any & all posted on the install and results if there's an interest.
HEY!!! Anyone install a roof rack on their Quad yet!!?? I'm desparately seeking experiences/insights!!!
If you haven't already, you might want to check out Borla's website... If you're interested in the sound, there are some sample audios.
