Has anyone else had this problem? Any suggestions?It makes me angry to have this kind of a problem after only 4 years in a $50,000.00 car.
Ask around and get several referrals and then check them out and get a WRITTEN estimate from each.
Good luck to you and to all others and stay safe.
jensad
I have a 2005 RL with about 90k miles on it right now. The back of passenger seat does not recline. The back goes up but not down when someone wants to sit back and relax. Is this common? Does anyone have a solution for it? Thanks
Recently, the driver's seat (not the seat back)has stopped going up and down so now I will have to have that fixed at my own expense-very annoying in an allegedly reliable 5 year old car.
I guess it could be worse; it could be a Toyota.
08-022 Outside Rearview Mirror Is Loose (2005-2006 RL)
http://www.in.honda.com/rjanisis/pubs/SB/B08-022.pdf
SYMPTOM
The driver’s side or passenger’s side outside rearview
mirror shakes or is loose.
PROBABLE CAUSE
The bolts fastening the mirror housing to the mirror
base were not properly torqued.
CORRECTIVE ACTION
Replace the outside rearview mirror(s).
Also from the TSB:
Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
-TR
2005 RL
.......EVERYTHING WENT DEAD! Electrical system off, engine dead, no power steering, no power brakes, driver apprehensive! I was able to get to the right lane & about to pull off while still going 50mph downhill when the electrical juice came back on & the car "jump started" itself!
Dealer seems to think it was a battery problem with a bad cell, but is the WHOLE car subject to a complete shutdown? Has anyone else out there had this problem with an Acura? I'm a first (and definitely a LAST) time owner of an Acura & considering reporting this to the Dept of Transportation, but I sure would like to know if this is something that has occurred before???
I've owned Dodge, Plymouth, Olds, Ford Lincoln/Merc, Nissan, Toyota, all new like the Acura but never had this kind of problem.
Thanks. :confuse: :lemon:
Jim
The mechanic is attempting to claim innocence as his job was to just swap the engines which he did by dropping the engine and transmission out of the bottom of the car. The only thing that seemed strange to me was that he used the original old splined right side axil instead of using the axil that came with the new used engine. My thinking is that why wouldn’t he use the splined axil shaft that was already “worn in” with the replacement engine drive differential it came with? I’m wondering if the noise I was hearing was the meshing of the two dissimilar gears from two different engines and most likely from two different year cars.
My concern now is what froze up that caused the car to lock up the front wheels and what needs to be done to rectify the situation. The gearing I am talking about is located in the oil pan of the engine. Is that engine oil or are those gears in a separate compartment that is fed transmission oil? How about any metal filings that may have been created as a result of improper gear mesh? Ouch! I could be way off on my diagnosis what else could it be? Your advice or a post on the Acura forum is welcome.
JoeSax
Has the link changed?
Mark
Dealers can easily lookup RADIO CODES and can find Navigation codes after opening a few parts of the Navigation system.
Did you ever find out what the problem was?
I am unable to open the rear windows from the driver's door though and the auto up/down on the rear windows no longer works. Rear windows open when using the local switch but you must hold the button to open or close. Front windows are fine.
Are there other resets I must perform after battery change?
have had this car for several years without any water (from outside) leak in. in the last couple of months when the car was in moderate rain, i noticed water under the glove cmp.
took the glove comp out, found water underside of the blower.
took a/c pollen filter out and the filter was wet.
so it appear rain water is getting into the air intake for the heat-ac system..
cannot find any obvious breaches of gaskets. the plastic shroud at the lower edge of the windshield and associated rubber parts are intact.
any clues??
Transmission 30K,
Rear and Front Differential 30K,
Brake Fluid Every 3 year,
Power Steeting Fluid 5 years
Coolant Every 5 Yrs (Part of Timing Belt Change @ 105K)
