I have a 2005 Sunfire. Mileage is about 12,000 miles.
On my recent trip to Heath,Ohio, I was coming down a Hill at the posted speed of 50 mph. At the foot of the slope speed became 35 mph, and a sign was posted " BUMP 200 yds". I reduced my speed to 35, but did not see the BUMP sign. At end of 200 yds was a Railway Track, and I went over the track, and my Sunfire jumped.
I heard ckunk sound, and thought that maybe I will have a flat tire. As it was cold, dark and a lonely road, I continued to go further about 1 1/2 miles to the Motel on the main road. Halfway, Red Engine Light came. But, as I could see my Motel, I thought it would be better to go slowly into Motel's parking lot and then check. I was inthe Center Lane, to make a left turn, and the Engine stalled. I restarted the car and parked in the Motel.
I parked the car overnight, as it was too dark. Next morning I started the car, and it started, but showed the Red Light on the Dash Board Panel. I drove it slowly across the road to fill up Oil. The light disappeared, but came back after 5 minutes.
I realized that I was loosing Engine Oil. I called GM Roadside Assistance. They towed my car to a Pontiac Dealer. The dealer checked and said the Oil Pan was damaged and needed replacement. This will cost $ 500.
I agreed to have it done. However, when I went to pick up the car, i was told that the Engine was making noise and they cautioned me against driving on the Highway to Detroit and then to Toronto. They suggested to change the Engine- cost $ 5,200. My Insurance Company agreed to pay for this , and the Engine was changed this week on Dec 21st. I took possession of the car on the 22nd.
I have some questions that baffle me:
1. Why are the Struts/Shocks not strong enough to withstand the shock at 35 mph.
2. Many cars go thru Pot Holes on Roads, worse then this Railway Track Bump.
I hear other parts of the car getting damage, but not the Engine.
3. I drove about one mile after the Bump, when the Engine Light came on. Then I drove another 1/2 a mile. Is this distance sufficient to ruin an Engine ?
4. Could my Engine damage be due to :
a. Defective Struts ?
b. Defective Engine ?
I trust that someone who has experience such an incidence would answer me ?
May39
Damage such as you had could happen at any speed and under the right conditions to most any vehicle. If the road clearance was such that your oil pan could contact an obstruction it would not really matter how fast you were going or how well the struts reacted to the "bump" It could be very possible to knock a hole in the pan even at 5mph!
No way I can see that the engine was defective. You should have stopped IMMEDIATELY whan that red warning light came on. The engine was "oil starved" and probably came close to seizure and most likely scored some bearings and cylinder walls.
consider youself lucky that your insurance paid for a engine replacement.
Those engine warning lights are there for a reason and should not be ignored. had it been a coolant loss you probably would have gotten away with driving a mile or so more but no oil is a no-no.
good luck in the future, Believer
Now, my point is why is the suspension/or the struts not effective on such bumps ?
Are they too soft ?
may39
VW New Beetle, VW Golf and VW Jetta 1999-2005 are vehicles that have minimal ground clearance between oil pan and pavement and are known for frequent destroyed oil pans.
What I find most disturbing is the cost to replace the oil pan and the cost to replace the engine.
A new, complete 2.2L Ecotec crate engine may be purchased for less than $2000, a used less than 10K mile engine for $500, and oil pan is $100 or less and there is not $400 in labor to install it.
You are lucky that you had insurance.
I feel so stupid. Gosh...
It's already a salvage title...before I bought it someone totaled it and this guy fixed it.
Any help would be greatly appreciated. Gosh...I am soo stupid..I was trying to park..in a too small spot. GAH!
Manda
I have a Sunfire coupe 1995 and my horn does not work anymore. The fuse and the relay are fine. I cannot locate the horn !
Can you tell me where it is located and how to access it if possible. (I cannot lift the car though).
Many thanks
Chrisbe
Chris
Thanks guys!
Btw, Cool Forum!!
What about after market replacement parts ... any good words.....or bad ? Advise appreciated.
:sick:
Don
Thank you to all who can help.
(a) there was an alignment problem between the sheet metal on the door and the sheet metal on the front quarter-panel, and that caused chafing and led to the paint chip popping off; and/or
(b) the hinges are in some way, shape or form unfit for their intended use and have failed, causing the sheet metal on the door to chafe against the sheet metal on the front quarter-panel.
Has anyone reading this message experienced a similar problem with Pontiac Sunfire coupes? I searched the Internet earlier today, but didn't come across anyone who had a problem like this. It looks to me as if there is a tolerance problem caused by some defect in manufacture.
Thank you in advance for any suggestions that you have to offer.
No blown fuses Can anyone help?
What could the problwm be? Please help
thx
Any ideas...Any sugegstions would be greatly appreciated. This is the latest issue of many since she's had this turd. :lemon:
Now it seems like the trans wants to hesitate more often going from park into drive. It will take a moment to grab the gear (it's an automatic). There is some noise that seems to be louder recently, and the trans also feels like it has some trouble accelerating through lower gears. I have already set up an appt with a local Cottman Trans to check it out. Has anybody had a similar problem? I love this car, and it just started giving me any kind of trouble a few months ago, and I've owned it since last March. I don't know if it's worth it for me to keep fixing it, or to seriously consider trading it in while it's still running. :confuse:
Joanna
I just found out today that the blower fan only blows when the selector switch is on the third and forth speed. (We were running the AC). Not sure if it does the same thing when selecting for heat. Any ideas as to what the problem is. :confuse:
Thanks and have a blessed day.
Right now the only thing I have found is Raptor Open flow From Schucks. It's cheap, so I have no qualms pitching it if it sucks.
Any Suggestions would be appreciated.
I noticed there were a number of posts about these problems so I've made new discussions for them, and moved some of the posts here out into those new topics. Be sure to track the whole Sunfire group to make sure you see new posts.
Did you figure out the problem with the blower fan?
I have a 2001 Sunfire with a similar problem... the fan only works in the fourth position with the A/C running.
I have a 1997 sunfire, my cd player is going nuts on me. when i first start the car in the morning or after work it takes a cd and plays it no problem but if I want to put a new one in after that no way, it physically does not accept a cd, you try to push it in, feels very forced, then if you leave the player empty for a few minutes you here a sound like it is either trying to eject or it thinks you are giving it a cd, I get E20 and E20 messages all the time, sometimes it works sometimes it does not. Please help me. I cannot afford a new player right now. If I have to clean the lens how can I take out the cd player, I do not want to unhook anything because of the anti theft which was a major problem when I had to get a new key, the new key got stuck in the ignition and they had to put a brand new ignition in for me,
Also I get no AM reception on the radio, if I need traffic updates I cannot get them, any idea how I could fix these things.
thanks so much.
