Lots of options that do not show on Toyota site. And I noticed one car listed as BASE V6 has "leather surface seats". I had thought leather was only a Limited option. Some of the cars have 3rd row seats.
So I guess the Toyota RAV4 saga continues.
I second that and on both engines.
So far we haven't seen any decent mpg's yet.
I know they need to break in 1st, but hoping people will be posting some decent numbers.
And if you look at SET that's a 'nother whole world.... entirely different accessories, Toyoguard, etc. I live in SET but work in CAT so we see these difference often.
How often in the previous gen Camry did you see two=toned Camry's? All the time in SET.
I am wondering about getting the 2006 Rav4. It's the first year, and I thought that most people advise NOT to get the first version of a new redesigned model.
What do you guyz think?
pogs
4dr SUV 4WD (3.5L 6cyl 5A) .Can you tell me difference between 4 dr SUV and 4 dr SUV 4 WD. I live in miami ,can someone tell me good dealer in miami to fortlauderdale area.Also what I should ask dealer before buying RAV 4.
I want to buy a RAV4 base model. but I don't like Camry. do they share same chassis? anybody can give me a response?
I've gone through about 20 new car product launches and there really hasnt been anything 'major' in any vehicle.
same as Jim
For those in Dallas, Tx. you might want to try Metroplex Toyota. I am working with them now for an 06 Rav4. I have dealt with them before on other cars. They are very upfront with no hassle prices.
Jeff Heiss
Dallas, TX
http://www.scangauge.com/
Exactly the rpm's I had. They only trend higher when going
up a hill. The 3300 @ 77mph was up a steep incline.
So we need a V6 RAV4 owner out there to check that for us. There must be at least one V6 on a US hwy now.
WE HAVE THE ALL NEW, 2006 TOYOTA RAV4 6 CYLINDER AVAILABLE!!!
WHO WILL BE THE FIRST TO OWN IT???
INCOMING STRAIGHT FROM THE FACTORY!!!
COLOR = SILVER
2006 Toyota Rav4 Sport Model V6, Model #4443
MECHANICAL & PERFORMANCE
3.5 Liter DOHC V6 w/Dual VVT-i Engine, 5 Speed ECT Automatic Transmission
Elec On-Demand 4WD/4WD Man. Lock, Electronic Power Steering/4-Whl Ind Susp
Sport Tuned Suspension, Fr&Rr Stabilizer Bars/4-Whl Disc Brakes
Hill-Start Assist Ctl/Dwnhill Assist Ctl, 18" 5-Spke Alloy Whls w/P235/55R18 Tires
& Full Size Spare Tire on 18" Alloy Whl
SAFETY
Star Safety System Includes: Vehicle Stability Ctrl w/Traction Ctrl
Anti-Lock Brakes w/Brake Assist & EBD, Dr & Fr Pass Advanced Fr Airbags (SRS)
3Pt Seat Belts in All Locations, 2nd Row CRS Lower & Top Tether Anchors
Rear Door Child Safety Locks, Direct Tire Pressure Monitoring System
EXTERIOR
UV Reduction Glass Wndshld/Rr Priv Glass, Clr-Kyd Bmprs,Rr Spoiler,Dr Handles,Pwr
Heated O/S Mirrors,Spare Tire Cover, Fender Flares / Black Grille & Roof Rack
Mlti-Rflctr Halogn Auto-Off Headlmps/Smk, Headlmp Bezels/LED Tail Lmps / Fog Lmps
Frt Var & Rr Int Wipers / Mast Antenna
COMFORT AND CONVENIENCE
Air Conditioner w/Clean Air Filtration, AM/FM CD w/6 Spks / Aux. Mini-Plug
Man Tilt/Telescopic Adj. Steering Wheel, Cloth Int,Mlti-Adj Fr Chairs w/Dr Ht Adj
2nd Rw 60/40 Splt,Reclne,Fld Flt w/Slide, Fwrd Cpblty w/Ctr Armrst, 2 Cup Holders
Dual Glove Box/Digital Clock/Cruise Ctrl, Power Windows/Door Locks/Keyless Entry
Optitron IP Gauges / Gated Shifter, 2 Fr/1 Cargo Auxiliary 12V Power Outlets
Ctr Cnsl w/2-Illum Cup Hldrs, Cell Phone, Storage,Upper Storage Tray, & Cnsole Box
Crg Area 2nd Rw Seat 1 Tch Fld Flt Lever, Sunvisor w/ Ext & Illum Vanity Mirror
Illuminated Entry System/Silver Int Trim
FE-Federal Emissions
DJ-AM/FM 6-Disc In-Dash CD Changer w/ 6 Speakers, and MP3 / WMA Playback Capability
RL-Daytime Running Lights
SR-Power Tilt/Slide Moonroof w/Sunshade
TO-Towing Prep Package - V6 3,500lb. Towing Capacity - Includes Upgrade Radiator, Fan Coupling, Alternator, and Pre-Wiring
C4-Carpeted Floor Mats
SELLING PRICE ON THIS GORGEOUS VEHICLE IS $27,214
PLUS ONLY SALES TAX AND DMV FEES!!
-juice
But it's a myth that you need a full-size truck, SUV, or van to haul plywood home. I've had 5 sheets up there and you couldn't feel it.
-juice
You can down load the instructions from the net at scangauge
-juice
I imagine it might take a few weeks, so what I'd do is schedule the repair, but don't drop it off until they get all the parts in stock.
-juice
Frank
If you can wait till mid summer you may be able to save a few dollars too.
On the other hand Consumer reports shows that Toyota and Honda are pretty low in problems there 1st year and go down just a little their second year.
This past weekend we had some pretty bad weather in northern Ohio - I was really impressed with the whole package of traction/stability control and 4wd - I had absolutely no trouble maintaining complete control in conditions where other vehicles were struggling to keep their wheels from spinning or from sliding all over. I know I've read alot on these forums about it being a reactive system, but in actual real-life useage, it seems to me to be fairly seemless. If it's a slight tradeoff for price then it's well worth it.
Absolutely no problems so far with any aspect of the vehicle - the 4cyl idles a bit unevenly for the first few minutes but it clears up quickly and it's more than enough engine for this vehicle.
Good luck with your RAV$
However, I did follow the 34453 zip code link, and it is awesome.
Looks like it definitely jumps over to a regional site.
Found it interesting that the Everglade Metallic is indeed available on the Limited V6. I had seen other information that showed that only Black and Blue were available.
This regional site shows that Black isn't available on Limited V6.
Unless it only shows which ones are out there in that region.
I will be test driving a Honda Pilot this week, since I have no idea when the Rav4 V6 will be coming into the Chicago Region.
I feel the same way about Toyota's in general. Also, the fact that they will be made in Japan for the first two years is a positive. The cars seem to be better built over there for some reason. That is why I am almost leaning towards bending the rules when it comes to buying a first year re-design. I'm sure there will be kinks to be worked out, but I'm afraid of finding out in a few months that I should have been more careful.
pogs
