Visitor Agreement.
I can't imaging a $50,000 car with no headlight adjustment. My $25,000 Subaru has adjustments, why can't M-B do it?? :confuse:
Also, my rear view driver's mirror seems distorted. Is this "normal"?
Performamce is better than expected given the weight of the vehile and the fit and finish are up to MB standards...
In the end the decision to buy a classy automobile vs. a run of mill minivan has proven to be well worth it. We have the space when needed and the ride and craftsmanship of a MB all the time. Great car...
If you are a member, I would try AAA. They will plan itineraries, maybe they have locations for ULSD.
You can also call MB. The dealerships that are on your route have to fill up somewhere.
As for the garage remote, you know it works. It just doesn't work well. I have a 20 year old unit that works fine with my 2006 R (Panoramic roof). The fact that the handheld remote does not work in the car leads me to believe that much of your problem may be the reception in the garage. Either have your repair man extend/repair the antenna or replace the unit.
Before doing that, you can run a test at a friend's or neighbor's house. Take their remote into your car and see if it opens their garage.
greasekid1, i understand that you are incorrect in the first sentence your REPEATED statement, and correct in the 2nd sentence.
wopel, i think your statements & concern are exactly correct and i sympathize - your concern is why i opted to stock up on 06 VW TDIs for my family "fleet", instead of looking at any rare 07 diesel models.
as for it being "illegal" to refuel an 07 diesel with non-ULSD, that seems absurd and totally unenforcable. i figure there MUST be folks out there who have done that, and i wonder if anything bad actually happened to their vehicle as a result - i think it's *doubtful* that anything bad would happen, but if i had an 07 diesel i would surely go out of my way to find ULSD if at all possible/convenient.
All this is one reason that I bought CDI which can use either type of diesel.
Reason that Bluetec cannot use old diesel is because it will not meet the new emmision regs and may also damage the Bluetec filtering system itself. Aside from all that it will probably work----at least for a while.
I use Shell.
Generally, stations will only put out the ULSD emblems once they are certain their co-mingled fuel is at or close to 15 PPM. All refineries in the US are actually making all new ULSD at 8 PPM because they know the co-mingled fuel will pick-up old sulfur contaminants. ULSD is also being imported in addition to being refined in the USA since Canada started their conversion somewhat sooner and ULSD has been refined for Europe and elsewhere for sometime now.
The one observation you received from a station sounds about right in that they have to go through at least 3 refills of their tanks (if not 5 or more) before enough of the old 500 PPM fuel is flushed as it is co-mingled with the new 8 PPM fuel.
I believe that most high volume retailers are going to have to be producing the ULSD by January 2008 and it therefore will be available in most of the US the way it is in California right now. However, the US Energy Department and EPA actually are allowing that "up to 5 percent of the market could delay making the transition to ULSD until 2010".
The good news is that in population centers and on major roadways the availability should be quickly getting better as stations continue to get better. The misconception arises with the significant difference between what can legally be refined versus what is available in retail outlets. Where as about 90% or more of the diesel being currently refined and imported is ULSD, the gas station that sells very little diesel fuel could take a year or even more to adequately flush out their old diesel. This is why the process is so slow at some stations. I also believe that many small ownership stations will wait to put out their ULSD emblems until they are absolutely convinced they have had adequate time for the natural flushing.
BTY, the MB R-Class and ML are not Bluetec diesels only the E-Class is currently. Since the R-Class and ML are classified as trucks for fuel economy ratings they do not have to employ the Bluetec engines for emission purposes until 2010.
I know you must love the mileage of your new R-Class diesel but I am really curious about the adequacy of the power given its weight. Does the diesel engine really have the power to smartly move the R? And what about when it is really loaded with passengers and/or cargo?
I guess I am skeptical given the size of the R-Class.
J
I sweated it out with the ULSD fuel. Some stations had no idea what I was even asking for. I filled up at every possible chance, and usually didn't need too much, but the fear of not finding it was quite high!
Now that the cargo top is off and the stuff out of the car I'm getting about 23.5 +/- mpg. Not bad for it's size. I still have no idea where the front of the car is!
I'm getting to love the nav system.
There's still a lot to get used to. I've been driving in the comfort mode and it ain't bad!
The only answer I have received so far, is that they are the SAME (although HP specs are different?). I've been told that the NAME "Bluetec" is only a marketing device which is applied to the E-class alone. In Europe it means the use of the urea additive. That urea additive (adblue?) will supposedly be used on future E-class models in the US to make them viable in all states.
So, I don't actually KNOW the difference between CDI and Bluetec but have been told repeatedly that they are the same.... FWIW.
http://www.mbusa.com/tracking/whatsnew/redirect.jsp?redirectUrl=/locator/jsp/ind- ex.jsp?locatorversion=ulsd
I asked one dealer to adjust the low beam a litle higher, but he said that there is no adjustment possible.
Another dealer said that he could adjust the low beams higher, for a price.
So, which dealer is correct? Is it possible to adjust? Or is the second dealer wanting to scam me?
I would think that an over $50,000 auto should have adjustable low beams, don't you?
This might sound like a stupid question but where is the battery located, i can't find it anywhere!!
HELP PLEASE.
it can turn a little knob in the console next to trans shifter - behind a little door. manual control of electronic trans. in the e320 it allowed manual selection of one forward gear (2) and one of the two reverse gears.
mbenz-rescue-dude showed me this odd technique after the failure stranded us in a boston parking garage.
a meilleur chance!
my R350 did not come with the plug in piece for the phone - it supports bluetooth but the salesman told me I have to spend another $400 for the piece that plugs into the arm reast. does anyone know if i need to but one matched for a specific phone (kinda makes the use of bluetooth pointless but i googled for them and http://www.wireless4mb.com sold ones for specific phones) and is there anywhere i can buy one cheaper than $400, maybe a compatible cheaper one or even a used one?
Many thanks.
I also read that MB has admitted they didn't think the R through enough - really?
I know this is an old post but was hoping you can tell me what the outcome was of this issue.
My 2006 R Class is stuck in park now and after three days in the shop, no fix.
Sam
Took it to a dealer and I have to get an INLET PORT SHUT-OFF VALVE FOR THE TURBO CHARGER. Has any one else had this problem?
