Thanks for any input offered.
Before that, I got just the connectors and had them spliced in, but after some mechanic did me the favor of cleaning my engine with that shiney stuff, it started missing in two cylinders after the engine warmed up, and I can't track it down. So I just decided to replace the whole harness.
Now, can anyone tell ME how to get it through the firewall WITHOUT pulling out my dashboard or AC unit (which I think also means pulling the dashboard.
HELP!
1 The washer fluid light on the dash will not go off? Is the sensor in the rear wash tank?
2 The Parking Brake light stays on?
3 Some a hole stole the original bose radio out of my car where can I get a new one. I know they suck I just like the OME look.
If you can help thanks in advance!
In there is a fuse marked "ign cont" on the box lid from memory a red 10 amp, this controls the alternator charge circuit which activates the alternator output, check this fuse, even if it looks ok replace it as have seen many that look ok but have gone high resistance either ay this will stop the alternator charging at the corrct 13.5 to 14 volts
Hope that helps
www.zedworld.co.uk
How do we decide what to do with it? It has been a fantastic car for all these years, low maintanence and made it to 230,000 miles! I hate to junk it but have no idea how to sell it, or for how much? Also I'm not sure if it can be smogged for sale in CA. Any ideas?
By the way, I have an '88 with 174,000 on it, but it still runs and looks okay. Not perfect, but quite okay; a 7 or 8 on a scale of 1-10. At some point, though, I'll have to decide what to do with it.
Which seals leak? Is this issue simply due to mileage, or did the car run low on oil or overheat?
Please let us know how you dispose of your Z.
Engine starts and run fine for about 30-45 minutes..when it's cold.
Once the car gets a little warm, it starts making sputtering sounds as if it's going to cut off. Sometimes it does cut off, and sometimes it doesn't.
One thing for sure is once you cut the car off, it will not crank back up for about an hour or two. When you turn the ignition it sounds like it wants to crank up, but it won't. It actually sounds like it's being flooded. I have spent $900 bucks taking it to a shop; yet they still cannot fix the problem.
Anyone has any ideas what it maybe?.
There are several 300zx forums on the web that might also help you get a feel of your cars value. Google "300zx forums" or "300zx clubs" and things like that to find them. People participating on boards like those are true fans of the car and would likely be the most knowledgeable about what a given car may be worth.
With an older specialty car in pristine condition like yours, pricing guides like KBB, NADA, etc. are worthless when trying to determine value. For that matter, they are really a joke with modern cars also.
Good luck with your decision. I wish I were able to seriously consider buying it --- it sounds like a real gem.
There are a few good dealers participating in the Real World Trade in Values thread here on Edmunds. They base their appraisals on auction data and are considered to be on spot with their assessments. I am not a dealer myself. If you need more clarification, you may want to direct a question to them in the appropriate forum.
Jack
Ghale
i stuck and dont know what to do!!
