-June 2024 Special Lease Deals-
Only problem is it is very difficult to shift. Problem started a few hundred miles ago. Any clues?
Thank you for your reply and thank you everyone for helping me.
I need to know if anyone has the vacuum tube diagram. I've been going by
Online Nissan 300ZX service manual but the picture is way to small.
I just need something better to go by. Can anybody help me on this?
Do you need? eng-pass comp-? trbo/non-trbo?
It will take a day or two to get the info to you.
you can also E-mail me at flh94_black@yahoo.com.
I have owned six z`s myself (2 now)-85 2s & 85 2+2)
Talk to you later.
Mattloid
new drive line from nissan.(ack) I was checking for one a few years ago..
The only thing I could find is..a good driveline shop in your town can build you one
for way less then a new one. Nissan QT me over 600.oo for one.(85-2+2).
Sorry..
I have two z`s now myself.
you can also e-mail me at flh94_black@yahoo.com
mattloid
you can`t or it`s verry hard to get all the traped air out of the line.
You have to use a vacuum bleeder(""NOT A POWER BLEEDER")
What happens is air gets traped in the curv-of-lines, pistons..
As you maul or powr bleed the fluid and air turn to fom (it`s in side the systom
were you can`t see it. I will look it up to nite ,
hit me back (ok) e-mail flh94_black@yahoo.com
mattloid
carpet-headliners---UHUHUUUUU.
It`s in my notes (i`ll have to find it) But it is out there.
I need carpet for mine too.
Mattloid
Ummmmm, whats a distributor cap? :confuse:
ARE YOU THINKING CHEVY? :P
Also my AM/FM radio is AM only. Is there supposed to be a ground on the aerial??
1. What viscosity oil, and regular or synthetic?
2. The transmission shifts nicely, but the fluid looks dirty. SHould I change it or leave it alone?
3. ANy way to check the timing belt? I don't know when it has been replaced.
ANy other tips will be appreciated. Thanks Tim
im not sure about my injectors, never checked them. i was thinking along the line of fuel pump or fuel pressure regulator.
if i were to have to order the engine about how much do they run, and what website would i need to go to for a good one.
Get some wrenches, get some advice, and fix the dam thing!!!!
