Good luck with getting your Z back on the road.
thanks,
Chuck
Yes I have tried what you have suggested except testing the computer. I was told that if you turn car (not start) and disconnect the neg terminal turn car off and reconnect it will reset alarm. didn't work. Called Nissan dealer and he suggested that I touch pos terminal to neg (pos off battery that will reset alarm. I will try the computer idea. are u talking about the ECU? Is it under the floor board on passenger side? Thanks for your reply and help I will let you know what happens.
www.xenonz31.com/files/fuel.injector.service.campaign.pdf
what do i need to do to give it more pep and how much would it cost
Thanks - Cody
what else can i do to prevent this problem.
please help
and how hard is it to change the lifters in this car 1985 3.0l non turbo 300zx there are 12 lifters i know a little about cars but maybe not enough once again
PLEASE HELP
The real problem is that upon starting it, it sounds like one or 2 cylinders are not firing at all. The owner jockeys cars, and I think he is trying to dump this one. He bought it this way. I suspect he knows it's not a simple problem as he has been through an auto tech course. Claims he put Seafoam through it and it helped. Also says it smoothes out when you drive it. I didn't drive it as I didn't believe him. There are no unusual noises. Could it just be injectors or electronics? Exhausts are both burning black. Clutch is solid.
Is this a common problem? Anyone have any ideas what the problem is? He just put $600 worth of new BFG tires on it. Any idea what this car would be worth considering it's problems? Could be a money pit.
Thank you,
Is it tail lights or brake lights? Are the front parking lights on? Do the tail lights get brighter when you apply the brake? If no, maybe it is the brake light switch.
Although this car has always been very well maintained and never abused, age and mileage have conspired to end its useful life. If I can't sell it as a project or parts car, I'll donate or scrap it.
I was glad to sell it to someone who will drive it.
Please let us know what you find.
