Sports Cars - The Definitive Discussion
Driving fast at the track on the other hand involves flaggers who watch out for what is over the blind turn entry as well at what info you already have to process about the cars you last saw on the straight, etc. They have radios to alert flaggers who are not seeing an event unfold but can get you info well ahead of the incident.
Well, off to Buttonwillow at the end of the month and Sears Point in early Oct. Good luck with the new Porsche's and hope to see some out at the track one day.
Randy
However, I do differ about one thing if I understand you correctly: Sharp turns during acceleration are actually more planted in the 911; it's understeer that you're more likely to encounter. Going into a corner a bit hot while braking would produce that effect, though.
I had an '84 Targa.... I'm sure I never would have been able to get even 80% of its performance at a track (never tried it), but for public roads? Anything that I was stupid enough to try, it could handle....
But, once you commit to a turn, lifting or braking is not really an option... you are better off adding throttle to get out of trouble...
I miss it dearly...
regards,
kyfdx
Hmmm...I hope it takes me less time to learn this then it did to develop an adequate golf swing.*LOL*
Piscean
I found the suspension forgiving enough on the car to make the switch to lightweight wheels with a harder compound tire. This switch alone has dramatically improved the steering feel to telepathic proportions. In addition, the inevitable rear breakaway one experiences from lifting early or mid-corner (letting physics work its magic) is now very catchable, and the breakaway is nice and progressive though still inevitable.
The engine has had a few modifications by a little company called Ruf, so I'm unable to give an accurate description of power or response differences (because my throttle system is very altered from stock). However it is surprising how differently this vehicle behaves in comparison to the newer models. The suspension was left alone, but the rebound damping on the 993 seems to be more forgiving than the 996. The 997's compression damping seems to be a lot more stiff the my car's.
I drove a 6 speed S with the PASM and Sport Chrono option in case anyone wants to know. The active dampers are truly amazing. The sport option firms things up noticeably, however if you drive the car with some aggression, the dampers automatically switch to a different rate. I still prefer a stationary setup, but if one can get used to the changes the suspension makes, the level of confidence is thus increased.
It's got more than enough power for whatever the owner may want to do and the throttle response is indeed sharper in sport mode, though one can get used to it eventually. The 997 takes advantage of the awesome dynamic weight distribution of its rear engine design and loads the rear with horsepower upon launch. I guess that's why it can reach 60 in less than 4 seconds with only 355 horses.
I'm not sure how long I'll want to hang on to my Turbo. Probably until I'm able to test drive the new ZO6. Until then, it's on to the 'Ring.
Well you make a strong case on the logical for getting the Boxster S, but neither of these cars are "needed" or very pratical imo. I personally wouldn't desire the extra razor like handling of the Boxster compared to the more comfortable and faster 911, which is still far from being a slouch in the handling department.
There is also something about the Boxster's look that, while better then the previous Boxster, isn't as balanced as the latest 911. The 911 just screams classic to me, even more so in Cabrio form.
Think about this, you daughters can ride in the 911S too from time to time.
Now if you're going to get another sporty car for the family duties that is roomier and more comfortable than the 911, then by all means get the Boxster for contrast, but my heart (and I'd make the logic fit ) would pine away for the 911.
M
Wow, there's a lot of concession made to Boxster in that statement. Although they handle differently, "razor-like" is never to be taken away from the 911. I think the 911 is more razor like, cat like due to its shorter wheelbase and rear weight bias which really come into play at high speed.
As far as comfort, I don't know what you mean by that. If being able to utilize the rear cargo area is considered comfort then I'll agree, but as far as the cockpit they are virtually identical. I THINK the 911 has a little more seat travel. The 911 comes across bigger than it actually is.
Can't wait to drive Cayman. I think this one is going to be pure driving nirvana. I'd get it but really need the drop top.
Thanks for your comments and insights. I feel that this was a well thought out decision, thank to folks like you and others here at Edmunds that aided the process immensely.
On the handling issue (maybe I didn't word it right) I would most likely agree when I'm able to drive the new 997 and Boxster. I haven't driven the new 997 or Boxster, only the "old" 996 in Coupe form. I agree they both handle exceptionally, but the Boxster seems to have an edge this time around no?
M
M
I’ve heard tall people say they fit better in a 911 but as I mentioned the 911 may have a little more seat travel because the Boxster seats are limited by the engine cover. Also, the seatback angle is limited in the Boxster so if you use all of the available seat travel you are screwed with seatback angle. At 6’ 0” I find my height the limit for total seat comfort in a Box. As far as the seats themselves, the Boxster and 911 have the same seats in addition to the same cockpit, the only differences are the instrument cluster and shape of the vents.
On the handling issue the Boxster seems to have an edge this time around no?
I was kind of teasing you because if I recall correctly you never really cared for the Boxster. Anyway, many people have said that the Boxster always handled better than the 911. Both have evolved but I think the lesser disparity in power between the two today is allowing the Boxster to be more noticed and come into its own.
Despite power I think we have to concede an edge to the mid-engine design. And if anyone wants to argue this they should pick on the super cars obviously. But the 911 is more of a live wire and people love its hallmark handling like cowboys love to ride bulls, so that was also the basis of my response to you. Which do I like? Both, it’s that simple. But they are inherently different even though you know who the manufacturer is.
I guess I have a small issue with “this time around” because the Boxster S has been getting rave reviews ever since it came out. The incremental improvements in 987 are not groundbreaking, just the slow evolution that is part of the Porsche MO. If anything, maybe the power threshold has been reached that the press is starting to find acceptable vs the 911. Boxster press has been extremely positive and Cayman is irrigating perception with all of this talk about it outperforming the C2. There has even been speculation that Cayman is the first step in retiring the 911. I wouldn’t hold my breath on that but there was talk two years ago about 997 being an “interim” design. Will be interesting to see what transpires with them over the next several years especially now with the hybrid venture.
Well you got me there! I thought I had said something wrong on a Porsche board, and that is a huge no-no.
I've always liked the way the Boxster drove, but I couldn't stand the first-gen design. The front overhang seemed too long, like a lip being poked out or something.
I can't imagine Porsche getting rid of the 911. I don't think they can make it without it. Problem is at some point they're going to have to take the 911 to the next level like they did with the 996 compared to the 993, and the purists are going to groan big time. I too remember reading that an "all-new" 911 was due in 2007-08, but I don't see that happening now. The 997 is perfect imo. Hell by the time Porsche finishes rolling out all the 997's variants it may well be time for a facelift or redesign.
M
Let's just wait and see how the new aluminum Corvette Z06 competes against a 997 S on a race track...
I will likely put 12k-15k+ miles a year on my 997. If I couldn't have comfortably afforded it, I would have gone for a $58k Boxster S. If I couldn't have comfortably afforded that, I would have gone for a $32k Honda S2000. Whether or not the 500+ horsepower Corvette can beat the 355 hp 997 S on a racetrack is irrelevent to me. It's a car, like the Viper, that was never on my shopping list. For those that understand why, great; for those that don't, that's O.K. too.
On an intellectual and business level, however, don't you find it a bit disconcerting that it takes Chevy 500 hp, 7+/- liters and tires as wide as a professional wrestlers butt to essentially match the "race track" performance of Porsches 355 hp, 3.8 liter, sophisticated chassis/suspension approach. American companies are leaders in many areas of engineering prowess - aircraft design, medical instruments, nuclear power,..the list goes on. But in terms of automobiles, the Chevy Corvette (and Dodge Viper) sledgehammer approach is, at least to me, as unattractive as the oversized tract house in the suburbs with a brick front and vinyl sides. Thankfully, I don't have to move to Germany or Japan to get good architecture.
I am not tring to incite a domestic vs. import battle here. For those that find the Chevy Corvette their cup of tea, good for you. But with GM, Ford and Chrysler all struggling for survival while Honda, Toyota and, especially, Porsche, thriving, I think my sentiments are not inconsistent with a lot of other consumers and driving enthusiasts. And offering us "employee pricing" isn't going to fix the underlying problem.
But no slur or fights intended; a Vette is what it is and Porsche is what it is and you pays your money and you buys the one you wants.
any one who would use that bit of bad driving to justify the Porsche, is really in need of some good lessons at Russell or another good driving school. If the driver feels that 400 hp is uncontrollable then they ought to drive something they can get comfortable in. Weight transfer without having an engine hanging out the back for a 33/67 distribution is what the rest of the world does every day, even on the race track. Where the Porsche does well is against itself, seems like most Porsche series don't attract competition, Go Panoz, but I don't think it's because a balanced weight to HP package can't beat a similar Porsche. Beating them dollar wise is a snap, after helping a GT3 driver at Laguna Seca he got his times close to my stock coupe on street tires. Next year if he is there I expect that he might even be doing better lap times, for what $? I'll take my under $50k sledgehammer.
Randy
Hp/liter is just a number. The new Z06's 505 hp LS7 weighs less than BMW's new 507 hp V-10.
Also, the new Z06 has more performance than the new 911 Carrera S.
The new Z06 doesn't have just a 427 cubic inch V-8. It has 6 piston front/four piston caliper brakes each with their own individual pads, a dry-sump lubrication system, an aluminum chassis, a magnesium roof and engine cradle, carbon fiber in the floor pan, and some other stuff.
link title.
Forbes picks the Carrera GT as top "exotic sports car", the 911 S as the top "high end sports car", the Corvette as the top "mid range sports car" and the Corvette again as the "best value". So both cars, albeit different, are winners in the eyes of Forbes.
And, as a result of some additional reading, I am going to make a point of checking out the new Corvette in person when I get a chance. I try to teach my kids to gather all of the facts before forming an opinion - perhaps I should do a better job of leading by example.
P.S. I do disagree with Forbes slightly on the Mazda RX8 as the top "family sports car". Rather, my daughters would disagree. Being in the back of a hard top RX-8 would get two thumbs down compared to being in the back of a 911 Cab with their hair blowing in the wind.
Now that opinion is purely from a driving standpoint. I applaud the reduced levels of NVH and increased levels of build quality in the new models. I just hope that the ZO6 has a bit more feeling than the stock C6.
I have a decent amount of stock in the company, and like any car enthusiast, I'm thinking "New Sports Car!" My 2001 Honda Prelude has served me well for the last 5 years, and while I have no complaints at all about the Prelude, it's time for something a little faster and a little sportier.
Suppose you were fortunate enough to be able to spend $40-50K on a new sports car. Which would you pick?
Ground Rules
- It's going to be a daily driver. I want something that puts a smile on my face during the daily commute -- not just a garage queen or a Sunday driver.
- I have a strong preference for new cars over used cars.
- Can be either a coupe or a convertible, with a slight preference for a coupe.
- Power/acceleration is important
- Handling/responsiveness is even more important
- Skidpad grip numbers matter less to me than the sense of being connected to the car
Currently on my list
- C6 Corvette (love the style, but haven't driven one yet)
- Base Boxster (drove one, absolutely loved the handling, but the acceleration seemed a little lacking)
- Base Cayman (maybe, though they're probably going to run well over $50K with options)
- Z4 Coupe (due next summer)
- M3 Coupe (haven't driven one yet, it's got power and handling, but the styling doesn't excite me as much as the others)
- Used Boxster S (haven't driven one yet, but it's the one car that might make me reconsider my preference for new cars)
Other cars I've considered
- S2000 (drove one, great handling, but a little too small for my taste)
- RX-8 (drove one, very nice car, but it just didn't thrill me)
- G35 Coupe (ditto)
- 350Z (haven't test driven it yet, but based on reviews, doesn't sound like what I'm looking for)
Is there anything else I should consider?
What's your favorite in this price range?
My preference would be to stretch your budget and negotiate hard on a new Boxster S. There are still a fair number of new 2005's around, that you should be able to get at slightly above invoice ($6k-$7k off MSRP for a loaded one). The one I was considering (before electing to go with a 911 Cab S) stickered at $63.8k and could have been bought for $57.5k. It included PASM, sport chrono, 19" wheels and a bunch of other goodies that make it the best handling roadster (and car) on the planet, according to Road and Track. Certainly not as massively powerful as a Corvette, but darn quick, much more nimble and fun to drive IMO, and a exceptionally refined interior cockpit.
The Caymen S, by the way, is roughly $7k more than a Boxster S, so if you were thinking of that one in a $50k budget, forget it. More like $65k-$70k with little discounting. The base Cayman won't be available for another year or so.
P.S. On your slight preference for a coupe, as a former S2000 owner I can say that both the Boxster S and 911 Cab are considerably quieter inside with the top up at post-legal highway speeds. I have 3,400 miles on my 8 week old 911 Cab, so daily driving is not an issue.
As to performance for the dollar, and I note your skid pad comment, the Corvette is the bang for the buck leader. Just back from two days on Sears Point Raceway with a basically stock C5 Coupe, slower than a Z06 or C6 with similar drivers. For a day and a half I passed a succession of Porsche 911's and Boxster S's and one track set up S with race tires came closest to staying with me but I was pulling about a second per lap faster when we had clear running.
As to test drives, good luck, my experience is that you drive used ones and then buy new ones with 5 miles on the odometer. Buying performance cars with a couple hundred miles on the odo just doesn't seem to work for the dealers much so they try to keep them as delivered. The best deals for a Vette are on the internet through the outfits that get the largest allocations based on prior sales.
Randy
I just got rid of a used 911 Turbo that I happened to steal for just under 59 and change. The previous owner had taken very good care of it and was a true Porsche aficionado. He had all the records meticulously kept and didn't slack once on the service. It was one of the most reliable super cars I'd ever driven and I don't regret driving it one bit.
habitat: Yeah, it's been a rollercoaster ride the last seven years -- lots of work, but fun too.
I am starting to think that the base Boxster won't be fast enough to satisfy me. I'm currently leaning toward the Corvette, but if our stock does particularly well, I'd certainly consider the Boxster S as well.
starrow: Test driving a used Vette sounds like a reasonable option. I might even rent one for a day to see if the Corvette experience is what I'm looking for...
The combination of power, handling, and refinement is starting to grow on me. So is the fact that it would probably be much better (with 4 good snow tires, of course) in Boston's winter, which runs from November until April.
I'm curious how people would compare it's fun-to-drive factor with the Vette and the Boxster...
Same goes for the M5. The M3/M5 are both the absolute tops in their respective categories. But don't confuse a sports coupe or performance sedan with a roadster or sports car. Completely different driving experience, at least for me.
Our 911 is a third car, and I wanted to go the pure sports car route. The M3 is definitely more versitile, but not by the margin you might think. Even with snow tires, it doesn't have the ground clearance to tackle serious snow. Nor would you necessarily want to try. If I had an M3 in Boston, I'd still be looking to have a back up beater for the worst days.
I'm sure any Porsche dealer will be happy to sell a PORSCHE Boxster to anyone who wants a new Porsche.
Kids these days. :mad:
(1) I don't know "where (you) come from" that a "Boxter is not a porsche" (sic), but where I come from it's a safe assumption that a real Porsche owner would not consistently misspell Boxster five times in two posts.
(2) As a real and very happy 2005 911S owner, I have no ego impediment to acknowledging that the Boxster S is the best handling Porsche on the market. Road and Track came to the same consclusion when it broke the slalom record previously held by the Enzo (a "real" Ferrari). And the Cayman S is indeed based directly on the Boxster S - which is a good thing.
(3) I see from your posts in the Corvette C6 forum that you are looking for recommendations as to what options on a new Corvette will enable you to "turn heads". Apparantly you are obsessed with this objective? And you think that the Boxster defames Porsches "all arounf (sic) the world"? :mad:
I think if you try connecting the above dots, you will reach a different conclusion as to what is real and what is fake here. I have.
Wonder if it is too long?
Ultimately the Cayman S is probably going to emerge as the best of the lot due its mid-engined design - there simply are no engineers left who defend rear-engined cars as the way to go. Credit marketing and tradition with perpetuating this configuration.
I definitely love Porsches (though not so much the 996), but the idea of drawing a line between "real" and "not real" Porsches is pretty suspect.
It's funny though - after I sold the Porsche and bought a Ferrari I had to deal with the "it's not a 12 cylinder so it's a not a real Ferrari" crowd.
You decide. Whatever you call it, awesome it is.
M
Thanks for the highly entertaining link. Doesn't tempt me to trade in the 911 (where would the little ones sit?), but certainly has me thinking that I need to take one of those performance driving courses.
Did anyone notice the high rank of the Ariel Atom in the track times at the end of that clip?
It's different kind of sports car>>
Ariel Atom story
I won't count the sport coupes, but the line's sometimes unclear. Among what I think are sports cars... the Miata, MR2, MR-S, and Solstice seem to be all there is on the bottom rung. The 350z and RX-8 start in that price range too, and used ones are as affordable as a new Accord.
Do any of them manage to be sports cars, despite the cost-related compromises? How low can a "real" sports car go?
(And why does that Dodge Caravan in the parking lot outside have a "Sport" badge on it? Makes me wonder if there's any point to the "sports car" label at all.)
You could buy lots of go fast stuff from the aftermarket (Weber carbs). The Sprite Mk I was a pure blast to drive with all of 75 horses under the hood.
IMO the Miata, MR2 and Solstice are not only real sports cars but offer a more pure sports car experience than many more expensive and powerful cars.
Case in point, the 350Z. I guess I'll reluctantly agree that it's a sports car, since what else would you call it? But it weighs several hundred pounds more than my 1995 Maxima and shares an updated version of the same engine that is tweaked to power everything from a current Maxima to a Pathfinder. Sports car, I guess. "REAL" sports car, not in my book. The old 240Z was truer to the term.
Back to your question. While I fully agree that a real sports car doesn't necessarily need to be "real fast", when I was shopping back in 2001, I wanted something that was at least fairly competent in all performance categories. The $32k Honda S2000 was my ultimate pick. Not as inexpensive as a Miata or some of the other cars you mentioned, but performance that could match or beat the base Boxster, Z4, SLK and other more expensive cars. Even today, you would need to spend nearly $60k for a Boxster S to have a better performing sports car, IMO. And the S2000 was designed from the ground up and hand built. The build quality, paint finish, etc. were right up there with my current 911.
I drove my S2000 for 2.5 years, 19,000 miles and got over $23k on a trade-in. Had I wanted to go through the hassle of selling it privately, I probably could have gotten close to $25k for it. In the 2.5 years the grand total maintenance on the car was under $320, including 4 Mobil 1 oil changes. The tires were on there last legs. My point is that the least expensive car to own isn't necessarily the cheapest to buy up front. Anything American is not going to come close to matching Honda resale value.
The problem with all of these and the more expensive competition noted is that what fits when you are 20/30 seems very tight when you arrive at 50 and more than 1/2 the baby boom is there. I loved my MGB from 1972 to 1984 when I was about 180 lbs but at 198 all those tight fits just don't work any more. I'll take the compromise and have space for the wife and a couple bags when I'm on track with the 350hp in the Corvette, sportscar enough for me!
Randy
As far as the S2000 goes, it did take me on my annual golf outing for 3 years with a set of clubs, large duffle bag and various other items in the trunk. The mandatory beer cooler went in the passenger seat. I had a friend that had an MGB from 1975-1978 +/- and that was indeed a tiny tiny car in comparison to the 2,800 lb S2000.
Enjoy the New Year.
(And the Elise is 500lbs lighter than a Miata. 900lbs less than a Solstice, probably more in the GXP's case.)
Now, think about this: extra HP will help you in acceleration and can help overcome the additional weight. But when braking (and turning), what does the Solstice GXP have that can make up for that 900 (that's NINE HUNDRED) pounds of additional mass?
For perspective, imagine putting a 300 lb offensive lineman in the passenger seat of the solstice and then strapping a fully stocked refrigerator to the deck lid. Now imagine what that does to the handling/braking on a track......
ps - according to the specs, you also get 0.2 cf more storage space in the Elise... :P
