Visitor Agreement.
There should be a metal tag on the diff that has this info.
Go to f150online.com and search for "axle codes"
Greg
Wichita
Axle Code is
3 S-923 A
L73 9759 A25
Steve
http://www.f150online.com/f150board/Forum1/HTML/000334.html
Greg
Wichita
Steve
Thanks in advance for any advice.
Joe
I don't think there is a down side to a limited slip axle (other than cost) and it is a good investment for safety reasons. It takes time to get into 4 wheel drive and there are driving situations in which a limited slip axle may prevent loss of control. In 4 wheel drive, the drive system is slightly more efficient in terms of traction.
I have the truck you are ordering (1999 Model) but have the Off Road Package and the 17 in. tires. It is a great truck and would never order another one without these 2 options. The heavy duty suspension that comes with the ORP is definitely worth it. Recently, I was on a very washboard dirt road that went through a dune field. I was cruising comfortably at 50 down this straight but hilly road and I did not louse traction once, could hardly feel the washboard, and the CD player did not skip once. If you are going to do any backcountry driving definitely get the ORP. The 17 in. wheels give you more clearance and look really sharp.
Regards, Steve
The “Off-Road” option includes heavier shocks (also available with the tow package), skid plates (available separately), decals and cast aluminum wheels like on the “Off-Road” equipped trucks. I can live without the decals, but I want the wheels. However, the dealer tells me there is no way he can substitute the cast aluminum wheels for the chromed steel wheels standard on the Lariat 4WD. Is this true, and also, does anyone know when the “Off-Road” package will be available?
Any info will be greatly appreciated.
michaelam@excite.com
Anyones and Everyones advice would be greatly appreciated.
roob880@hotmail.com
Thanks for posting the information. Now I will know what to look for but I doubt I will need to.
This past weekend a super crew (4x4) came in to where i work (a lumber yard) and hauled 3 pallets (3 trips) of 325 bricks (7lbs each). Truck sagged alot but it held up very well. The truck was 3 months old. After each time he came back we measured the rear end height. It seemed that the last time he came in the rear end had dropped (truck unloaded) about an inch. What i am trying to say is this truck is capable of doing heavy (pallet sized) loads. Just wanted to give an actual realworld experience. Unlike gmsucks i am not biased. My truck is shake and ping free. 6500 mls and its great.
Ryan
I have a Slapper, certified by my selling dealer. Their fix is to replace the "long block" with a rebuilt one.
30,000 miles.
I have door cracks also.
Call me, and I can set you up to see and hear these two problems.
I still am happy with my truck, and the service I get from Lubbers in Cheney Kansas.
I just can't decide if I want them to rebuild my motor, or believe Ford when they say "it's not a reliability issue."
Greg
'00 Lincoln LS8
'99 F150 2X4 SC 5.4 "Slapper"
'96 Triumph Thunderbird triple
'92 Ford Tempo
Last year's models get FQR's
I know what the F stands for.
Greg
Later the dealer asked if I qualified for the A or X plan. Yes for X. He proceeded to tell me that I could order the vehicle at "$300 - $500" below invoice. Two days ago the dealer called to tell me the Offroad package could now be had on the SC. I went in to draw up the order and took it home to look over before ordering. To my surprise, the price was actually about $200 OVER invoice - NOT the $300 - $500 below as he'd previously told me. When I called to question him, he claimed that the price is below invoice, but includes the Ford Dealer Advertising Fee, AND THAT MY EDMUNDS NUMBERS MUST BE WRONG!
I know the #s aren't wrong - I bought a 99 Dodge Ram Quad Cab over the 'net two years ago using their data. Is this guy attempting to take me for a ride? Seems to me the X plan is no better than just walking in off the street armed with the knowledge of what the vehicle should cost.
Comments appreciated.
Ryan
So hope this helps.
I'm really considering if my 99 F150 5.4 SC is my last Ford.
Buying vehicles these days is like voting for the next president. Choices are bad and worse.
Greg
Wichita
My '94 Lincoln Mk 8 fried the trannie at 60K miles, but all else was fine.
My '00 Lincoln LS has lots of fit and finish problems, but runs and handles great.
My '99 F150 5.4 SC is a slapper, and has door cracks and rear leaf springs out of whack. So far, dealer agrees and will fix, except door cracks have no fix right now.
Not sure what they will do after 36K miles.
Ford or Chevy or Dodge is like Bush or Gore or Nader - all have their up- and down-side.
Greg
If your primarily goint to pull a trailer, you might want the F250. The F150 with the trailer tow package and 5.4 motor will probably fit your needs if you will ocasionally pull a 24'.
I drive an empty F150 5.4 SC mostly in town, and I get about 15MPG on average. Have seen as high as 18 at 65MPH for a whole tank on the hiway (with a tailwind), and as low as 13.7 for a busy weekend of running all over town doing chores and errands.
The big motor really has spunk, with a 3:73 Limited Slip, gets out of it's own way pretty quick.
On the noise, I had to leave my truck at the dealer overnight so they could start it cold to hear my piston slap. Check www.f150.com for similar complaints....might be a bottem-end bearing problem.
Piston slap is usually most noticeable on cool (less than 65 degrees) mornings, during warm up, at 1200-1500 rpm. Usually goes away when you put it in gear, but some folks report it sounds like a deseal truck as they drive away in the morning.
Ford is replacing engines (new motor in some cases, remanufactured long block in some like mine) on trucks because customers don't like the noise. Ford says it will not affect performance or life of the truck. Yea. Right.
Greg
Wichita
'99 F150 5.4 Slapper, door cracks, springs out of whack.
www.f150online.com, but you knew that!
Greg
Ryan
Greg
Wichita
We've had our 01 F150 XLT supercab 4X4 5.4 for about 2 weeks. We looked at used ones and thought maybe we'd buy one a year or 2 old. Most had the door crack. Quite a few of the trucks had the 4.6. My husband was adament about the 5.4. The recommendation by Wards Automotive was enough for him.
I very much hope we don't experience any problems. I'm not sure which other truck we would have purchased if not the F150. We owned a Dodge....not buying another! which eliminated the Ram. My dad owns the Silverado and he's had zero problems with 3 trucks in 9 years (drives them 60-70k in 3 years then gets a new one). We just didn't like how the Chevy handled. I drove it for 4 weeks once and couldn't get used to the handling. That leaves the Toyota Tundra which I'm sure will be bullet proof, but doesn't give us a powerful enough engine or quite enough room. You also have to pay quite a premium for that truck.
All in all, we're very happy with the F150...of course we'll see how I feel after many more miles!
Again, you made a good choice. I have a 1999 5.4 Triton V-8 and really love this engine. It has been properly maintained, at the dealer, and so far - the engine just gets better all the time. I think it took 20,000 miles to really break it in properly. I suspect this engine is good for 200,000 miles plus based on the driving experience/feel and mileage I have gotten from preivous Ford powerplants. Plus, this 5.4 gets what I consider very good gas mileage for its horses/torque ratings plus it is a 4X4.
Like I said - good luck and enjoy. By the way, if you want an active site - start reading about all the buy-backs from GM on their trucks!
People who are going the buyback route on the silverados are mainly for 1 reason. Vibrations. This is normally on happening on the 2wd trucks.
I have a 4x4 silverado ext cab 7600 mls and its great. Please dont get the idea that "all" silverado owners are unhappy. Trust me ford has its problems too
Ryan
Ryan
Better check the doors for cracks....look at the door frame above the handle near the bottom right of the drivers windos, or bottom left of the pass window. Looking for a 1/8 to 1/4 inch crack from window out.
If 5.4 motor, or Romeo MI built 4.6, have motor checkled for improper pistons, called variously piston slap or ps, sounds like a rattle when cold, mistaken for knock(ping). Fix is to replace motor if still under warranty.
Some 5.4's having many oil leaks, and head gasket concerns. Look for seeps/weeps along front of motor.
Some 97-00 F150's rear leaf springs are not banded so they can shift, or come apart. Look bad, but many not affect performance/safety.
Rough idle: certain 5.4's exibit a rough idle that cannot be fixed. Others have a bad "lifter" that causes a rough idle and is repairable with a replacement.
Better sleep with that truck for a few days and really check it out good.
Greg
Wichita
IMHO, I'd say the 4.6 v-8 is the minimum in this truck. It has a good track record, many millions of Crown Vic's. I had one in my 94 Crown, and a DOHC version in my '94 Mk8.
I test drove a v-6, and really felt that it did not have enough ooomph when needed for pulling into speed limit 45-50 wide streets where you need to "make way" or you'll be sitting there all day.
Can't imageine filling up the bed and going somewhere. Just not enough HP down in the normal RPM range.
Greg
'99 F150 SC 5.4 slapper with door cracks
Wichita
