Need Help in finding Aftermarket Parts
borkmanborkman Member Posts: 2
edited April 2014 in Mitsubishi
Please help me in finding aftermarket parts for my '03 Mitsubishi Galant. I have been searching High and low on the internet for parts and nothing fits. Is the maybe a custom shop I can go to on the internet to help me out?
  • driftracerdriftracer Member Posts: 2,448
    This place is connected to a Mitsubishi dealer:
    http://www.srmperformancecenter.com/index.html
  • borkmanborkman Member Posts: 2
    Thanks for the website...very helpfull...I can start on the engine of my car now...Thanks
  • tom41tom41 Member Posts: 3
    need to know who makes mud flaps for 2005 impala. the 2005 has flared rocker panes and rear quarter so previous years wont fit.
  • wale_bate1wale_bate1 Member Posts: 1,982
    OK, whose got links to substantial Audi tuners? I mean aside from Abt...
  • another_personanother_person Member Posts: 93
    It's so hard to find anything for this car. Does anyone know where I can find some bolt on upgrades?
    I don't think you are going to find very much in catalogs from one single source for this car but I'm sure with some homework you can scrounge a bit here and a bit there. Certainly you should be able to find free-flow air filters, a decent exhaust system, and better handling components and tires. Probably the hardest thing would be to find any serious engine modifications -- I'd bet anyone who's made an early Camry go faster has adapted parts from later cars or done a lot of custom installations.
  • manyfordsmanyfords Member Posts: 3
    Anyone know how to convert an 86 T-bird to 5 lug?? Also, I have a 94 mustang that had an engine fire and needs a new front clip, I figured that I would put a body kit on it instead of going back stock. Any opinions on who makes the best fitting aftermarket body kits?? How about the lambo door kits?(Who's is best??)
  • danf1danf1 Member Posts: 897
    Are you sure you don't need a new engine too? ;)
    Oh, yeah, forgot to mention. My T-bird has a very low milage Jasper rebuilt 5.0 in it '86 block, I was planning to put that in the mustang and put a stroker kit in the '94 5.0 block and put it into the 'Bird.
  • 67fastback67fastback Member Posts: 2
    I have a 67 fastback and i was wondering if they even make any kind of aftermarket engine upgrade to increase horsepower. I can't seem to find anything online. Please tell me if you know anything or know of websites talking about/selling. Thanks.
    Oh, the aftermarket for the 289 is enormous!
    Here's a book to get you started:
    http://www.themotorbookstore.com/ford-289-302-engine-manual.html
    However, if you have a numbers correct '67 Fastback that's in nice condition, this car could be worth $15K-$20K (if it's really nice) and you should think twice about modifying it, as you will seriously decrease its value.
    What I'd do in that case is take out the correct engine and store it, and if you put in a more powerful engine, don't cut or weld anything.
    If the car is not correct, well then, have at it, it doesn't matter anymore....
    You can easily (but not cheaply necessarily) build your 289 up to 350HP no problem and probably still run on regular gas and not need a turbocharger or supercharger at all.
    Of course at 350HP you had better be upgrading suspension and brakes as well, and probably strengthening the chassis too a bit.
    Also you might google HotRod magazine and do a search for back articles.
  • oc4oc4 Member Posts: 4
    Hey Folks- I'm currently in southern california specifically in the orange county area and i'm sick of the brakes on my 2001 galant...i've replaced the rotors once and resurfaced them about 2 other times- anyone out there know if slotted or drilled rotors make any difference or at least if it will help or where i can find a shop that will do it at a decent price??how much would i be looking at or does anyone know what the best solution to this problem would be? please help!!
    You might want to try the Stop here! Let's talk about brakes discussion instead.
  • mixinmixin Member Posts: 1
    Hi just wandering if any1 knew if escorts rs2000 skirts would fit a mk3 5 door fiesta si,
  • yotaracer7yotaracer7 Member Posts: 1
    I have been browsing the internet for 3 months trying to find Performace upgrades as well at Exterior & Interior (custom). I have had no luck does anyone know of a site that I can get these parts. Thanks
  • tlarocktlarock Member Posts: 1
    I'm thinking about buying a used Lancer Rally.
    Is it worth it, and if so what can I do to the engine to hop up the performance?
    The car I'm thinking about is a 2005, with a auto trans.
  • dreamingofmoredreamingofmore Member Posts: 4
    you want to see if bosch makes rotors for your application. they come with a 5 year warranty and run 50-60 a rotor, also go with bosch premium pads either semi metallic (oem)or upgrade to a ceramic pad about 10 dollars more than oem pads. make sure you get your brake fluid changed and go to a dot 4 fluid it will be ok to use it has a higher boiling point which means it can handle more heat from your brakes.
  • ramswellramswell Member Posts: 1
    i was looking for the same info on my 04 3.4L impala that you were in october. i can find air intakes and grills and body kits however i was wondering if there were any superchargers or chips that you have found that you may recomend. thank you
  • drgadedipedrgadedipe Member Posts: 8
    the engine is a Chevrolet V8. if ne1 knows any modification i could to the engine i will be very thankfull.
  • mk259mk259 Member Posts: 1
    so i just got a 2001 protege, and i'm wondering if there are any online sites that anyone KNOWS and TRUSTS to order parts from such as body kits, intakes, etc. i live in Hawaii so it's not like i can just drive to a parts dealer and find what i'm looking for,(its a rock and there ain't to many on it).
  • liquidousliquidous Member Posts: 3
    Hey , it was coincidence i saw this post, but make sure you check out the post i just posted about MQVP Parts. make sure you either get the MQVP parts or OEM parts.
    theres a lot of hokey pokey going on out there.
    i think we the consumers ought to start sounding out about it. we're being ripped off left and right.
    good luck finding those parts
  • gojeffiegojeffie Member Posts: 3
    I need to find weather stripping for my rear hatchback and wiper strips for both doors for 1981 Ford Escort SS. Everywhere I looked on line for parts did not even have windows listed much less the strips needed around them. Can anybody give me some ideas on where to look? Thanks. Vicki
  • marcinasmarcinas Member Posts: 1
    :shades: Does anyone know where I can get replacement visors? I have a 1995 Mitsubishi Galant s and can't find anything on the net. Please help!!!
  • the_big_althe_big_al Member Posts: 1,079
    Okay - This is probably a lost cause question, but..... Are there any performance mods that I can do to the 3.4 in an 04 Impala? It does all right and it gets fairly good gas mileage, but it only produces 180 hp and 180 ft lbs of torque. I am fairly certain the 3.4 is a punched out version of the 3.1 so maybe there isn't much more that can be done to the motor?
  • millerlite4443millerlite4443 Member Posts: 2
    will a walboro 255 fuel pump for a 1999 eclipse fit a 2000 mitsubishi galant ive got a turbo kit on it and i need a high flow fuel pump. if it wont does anyone no of one that will.
    u could try ebay thats bout the only place i no of
