ford 4.2 v-6 is junk
had a problem with my 97 f-150 smoking on
start-up. took it to the dealer and after 7 days,
they decided it was valve seals. got the truck
back and still had the problem. went back to the
dealer and they gave up and replaced the engine
with a rebuild. got it home and it also started
smoking and the "check engine" was on. after
another 200 bucks, they "solved" this problem. the
original engine had 59000 miles when it gave out.
i just got rid of a 79 chevy with 320,000 miles on
it and the engine had never been touched, what an
idiot!!!!!!
idiot!!!!!!
Harry
It does sound like my buisness. Somehow my Fords are holding up....
Sounds alot like your biz...someone else driving your truck and not caring about it...
Currently best friend has '95 302 Bronco with 180,000+ miles. Starts and runs perfect!!! Other friend has '93 Bronco 302 with 120,000( I had to do fuel injectors recently, $99 over the net) My Father does 40,000 a year X 4 years with nary a problem on his 302's. This will be the last year of the 302 Explorer so we'll wait on the high mileage verdict on the 4.6's. I don't put the miles on that these family members and friends do but my Ford motors have NEVER broke on me.
If you want info on my old '87 454 turbo 400 GMC I'll be happy to expound.
The TBI on my 454 was junk!! Air leaks, throttle shaft holes worn etc...this was under 60,000.
To each his or her own.
4L series is bulletproof.
I actually traded for an '85 F-250 460, C6 that NEVER faltered.
I too would be GM loyal if I had your luck but as fate would have it it just worked out the other way.
I am interested in the 8.1 Allison combo when it comes out. If it is significantly more powerful then my 310 HP 425 lbs torque 5 speed super duty, who knows?
The next personal area is styling. LOL!!
GM 8.1 340 hp/455 ftlb
Fd 6.8 310 / 425
both obviously have a very flat torque curve. Unless you are pulling 18,000 lbs all the time, you miss the 8.1s power over the 6.8 too much--both engines way more capable than most apps need...but the Allison is far above anything Ford and Dodge has. Not only in durability, but in performance and towing features.
Swift....
I agree on the Allison issue.
All engine and tranny combos are offered in the 2500 HD.
But they will.
leapfrog.
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
