Visitor Agreement.
Starting to sound like my used car lot.
Mike L
These trucks have been built for years, so it's a matter of how long do you want to look for one and how much do you want to spend.
IMO: Whatever you choose, make sure you get at least a 3/4 ton chassis. Whether it is a Chevy 2500 or an F-250, an Excursion or a 2500 Suburban. Very few folks ever regret having too much truck, but most regret having too little truck.
My dad pulled a 25' trailer with a 1/2 ton mid 80s Blazer and he was happy enough with it. But I sold it for him and had to take a lower price because of the transmission condition. According to the buyer GM put the 4-speed car transmission in that truck and it just isn't up to towing like the older 3-speed was. Anyway I bet that isn't true today as I've never heard anything bad about the GM 1/2 ton units. But your trailer plus cargo is near the limit for a 1/2 ton truck and it's always good to have some margin.
You should go try out a GM extended cab truck. The current body style (year 2000 an up) have the most rear seat room of all the brands. See how it works with your passengers. If acceptable, those are abundant in the used market, even 3/4 ton.
The tongue weight is only 600-900#, no problem for a 1/2 ton. The trailer weight is well within the truck's ratings. A weight distributing hitch is mandatory (according to him). Properly set up trailer brakes mean you don't overload the truck brakes.
I have both a 1/2ton and a 3/4 ton Silverado. I like both. The 3/4 ton is more like a truck, the 1/2 ton is more like a car with a big, open trunk.
Drive both, see what you think. Talk to people with similar sized trailers. Find out how they drive and what they drive. Either one may work for you.
Mike L
I pull a 28', 6600# trailer with a 3/4 ton extended cab Silverado with no problems.
Ray T.
Last time I used the truck was in Death Valley and since then the truck sat for about 5-6 weeks. When I got back in it, the clutch was worse - 3-4" free play and releasing right on the floor.
Since I still thought it had to be air in the concentric slave cylinder (aka the throwout bearing), I wanted to try again to get the air out. Since bleeding still didn't help, I decided to try a different method. I made a dummy clutch master cylinder cap with a seal and a port in the middle. I hooked up a vacuum pump to the port a put 30" of vacuum on the master cylinder. I was hoping the vacuum would make the bubbles much larger, and then they would come out. After a couple of minutes of vacuum, I pulled the cap off - I could actullay see some small bubbles coming up!
And now the clutch is perfect!!! About 1" free play and the release point is about 1/2 way down. Better then when it was new.
The vacuum worked so well that I'm going to try it on a motorcycle brake system that has always been difficult to bleed.
I'm not sure the bleed port for the concentric slave cylinder is all the way at the top of the cylinder.
Mike L
Thanks, Ross
Only after sitting for several weeks did the pedal change for the worse. It is possible that I could have bled the extra air out of the system and gotten back to where it was. But, I tried the vacuum instead and it worked.
Putting a vacuum on the master cylinder was easy enough to do, I'd certainly do it before replacing anything.
Of course, my reasoning may be wrong. Maybe the master cylinder wasn't able to fully retract, and the vacuum pulled it hard enough to clear the obstruction - or???
The only way I can think of air getting into the system is with the brake fluid. If the fluid got low and air got in; or maybe really rough roads got enough air into the fluid. Then using the clutch distributed the air to the slave cylinder where the air came out of the fluid (temperature or air pressure changes?) and caused the clutch to suddenly get worse.
I can tell you that the two motorcycle brake system that I tried this on - one is now working great, and the other needs a master cylinder!
Mike L
Don't forget trivia night on Wednesday, February 19, 9-10pm ET/6-7pm PT. Join other members for some trivia and member-to-member chat!
http://www.edmunds.com/townhall/chat/townhallchat.html
MODERATOR /ADMINISTRATOR
Review your vehicle
Now we need to try some of these roads.
Tom S's book gives remote campsite, and this shows campsites that are on the roads, but you still need Tom's book for a description of the camps.
Next time you're nearby, stop in and check out the new reference.
Mike L
I'll take a look at the book on Amazon. I need to order Tom's anyway as mine is old and in two pieces now.
Ross
I'm trying to figure when we can go camping. Not this month - a wedding next weekend, April is probable, but because Dorothy put in for some camping time at Little Basin. Probably the 11th (my Friday off), only one day so we can check out the place and decide which campsites are good, and how the hiking is, etc.
May we are going to Hawaii for a couple of weeks. So, how does June sound? I have the 6th and 20th off for three day weekends.
Mike L
We are going to check it out for the first time. Later, we could go and have the family group camping in a fairly close location. Will know better next month.
Went up to the Sierra's over the weekend. Had a wedding to attend on Sat, so we went up on Friday and camped out. The weather was perfect! Clear and 70 in the day, clear and 40 at night.
Mike L
We walked the Tanbark Trail twice, once all the way around and once taking the Pig Ridge cutoff. Easy trails mostly. Except for a section that is mostly washed out, we could drive the trail - it is that wide. Probably they were/are fire roads or maintainence roads. Pig Ridge cutoff had a section that was too steep for us to drive up, yet at the top we noticed 3-4 old car hoods, a couple of doors, a grill and a bumper (nice looking rear bumper with oval exhausts coming out both sides of the bumper). A mile or more of power line, intemittently down on the trail. Since the lines were wrapped around each other at one point, I decided they weren't live - then we found breaks in the lines. Want to salvage a couple of miles of 6 x 10ga aluminum wire? All you have to do is cut it and carry it out.
All in all, not the best camping experience, but it has a good price, and it is fairly close.
Mike L
My planned camper upgrades for this year include a 12v pump to replace the hand sink pump, a porch light, and a 200watt Pioneer sound sytem for the party events!
Mounted the compressor on a 1/4" aluminum plate the is sandwiched between the parking brake cable bracket and the frame, just behind the driver. No holes drilled in the truck.
Mounted the dual gauges at the bottom, middle of the dash. Right in front of the shifter. Used two existing screws, so no holes drilled.
Routed the wiring/plumbing into the cab through a drain plug at the driver's side back of the cab. Then down the wiring channel under the sill plate, across under the top of the carpet and to the gauges. Coiled the excess up behind the air ducting on the passenger side.
I still have to hook the airlines up to the airbags. I will run them inside the frame and tee into the existing lines and leave the fillers at the license plate bracket.
Vince, I'm not too interested in the trails at Little Basin, or to intested in Little Basin for that matter. I can see how it would get very noisy in the summer.
Mike L
I've been seriously considering switching from a motorhome to a pick-up camper. I like the Lance slideout models but I am concerned about the wieght. My truck is obviously a single rear wheel design. The load rating is about 3100 lbs in the bed. The camper would probably end up about 3500 lbs. I can get below the 3100 by opting for a non slideout model. I would definately prefer the extra room though and I have no desire to have a dually truck.
Has anybody hauled one of these around in a SRW truck? Did you add airbags? How did the truck handle it? I would like to be able to bring my boat and still have a truck to drive while camping. This seems like a great way to do it. The camper needs to sleep two big adults and my six year old twins.
Any ideas on what works and what doesn't?
You will be way over with the Lance slide out. I have a Lance 9.4 foot stickered at under 2500 lbs and with two large adults the total rig is 9100 lbs, 500 over the limit. This is due to cargo, tools, food, etc. I guess. The truck does fine with that load but it sounds like you would be even more over the limit.
The camper is great and fully meets my needs but it would be crowded with 4 people. You should look at the second bed in the slide out area. I've never seen one made up but I know the seating area is smaller than in the non-slide out models. If you can put the kids in a tent then the camper would be fine.
Easy is a relative word. I'm into my kit for about 8 hours with another 2 to go. I'm very fussy about how I install something. I must have 5-6 hours into making and fitting the bracket I mounted the compressor onto. But, I'm happy the way it worked out.
Mike L
By the way, I'm getting ready to go to Alaska; any tips on the trip and camper setup?
I think I've got mine mosquito proofed and have finally stopped the roof from leaking.
Jim
Do you have a route picked for Alaska? Or places to visit in Alaska? How much time do you have? We took 7 days to get to Alaska - 3500 miles.
I would recommend the Stewart-Cassiar Highway. It is well paved gravel and less traveled than the Alaska Highway - its also about 3-400 miles shorter and quite scenic.
If you are on the Alaska Highway, either way, stop at the Liard River Hot Springs and soak in the natural hot water for awhile. Enter the water more downstream and work your way up.
I would suggest you enter Alaska via the Top Of The World Highway. Takes you through Dawson City. We found the campground at Minto (on the Yukon River) quite nice. They open the campground about Jun 1, you can check in Whitehorse at the visitor center for information. It is a glorious drive up and over the pass entering Alaska.
In Alaska - If you can, take the drive up the Dalton Highway to Prudhoe Bay. Take the tour of the oilfields and Artic Ocean for $25. We were the only ones on the early morning tour and it was well worth it. If you go up the Dalton, there is a campground in Fox (just north of Fairbanks) and they have a sweet water spring just outside the campground. Fill your water tank with that wonderful water.
Denali National Park is a must see. Sometimes the easiest way to get into the park is to agree to camp for 3 days at the furthest in campground. Otherwise, you may have to wait a day or two to get a campsite.
Seward was just too crowded for our tastes. Spend some time in Homer - camp at the end of the spit, on the water. We took a ferry ride from Whittier to Valdez. You have to get reservations for the train ride (with camper) to Whittier and for the ferry to Valdez. One phone call got both reservations.
We found gas and supplies easy to come by. If there is something special, a certain brand you want, you may want to stock of on that - otherwise, it is available as you go.
We found the portions served in restaurants to be huge! More so in less populated areas. And the costs were about the same as here.
Seward was as close as we came to a 'bad' time. And it was worth seeing the Aquarium (or whatever it is called). Just the miles of RV's parked along the water was depressing. We stayed out of town at a small campground.
A lot of the roads are gravel. And the gravel roads have soft spots from melting ice and snow. Watch for 'wet' spots or holes and slow way down and go around them. On any gravel road, slow down and pull over when approaching traffic. The traffic throws up rocks, and you hit them at the speed you are traveling. By slowing down and pulling over, you can save your windshield.
Good, fairly new tires are advised. As is a good spare. We didn't have any flats (on new LT tires) while others did.
Take your time and take lots of pictures - you will have a great time!
You can send me an email if you want to come down to Santa Clara and see our Alaska trip photo album. But, I'm out of town from the 6th to the 21st.
Mike L
I'd take it apart and try to lubricate both support bearings. Then test it before you put it back together.
Mike L
You can see it at www.aliner.com. It's called the Truck Cabin Freedom. Be prepared for an extremely slow web site.
Mike - Thanks for the info. We haven't decided on a definite route as yet, we were thinking of driving northbound and taking the Alaskan Marine Highway southbound for part of the way. It sounds like a lot of fun to be able to ride one of those ferries. My wife and I collect ferry rides anyway and this seems like an excellent chance to ride one more.
My job deteriorated into a 100% travel position, so last Nov. I decided enough was enough and retired. I said that to say that I have no timetable - I was just going to wing it as far as the time was concerned. We're going to take it easy and just enjoy the trip.
I have been to Alaska a couple of other times (on work contracts) and I was able to do some sightseeing on those trips, but I do want to travel the Haul Road to Prudhoe Bay.
Where did you stay in Deadhorse? Interesting name: Deadhorse. The name conjures up some unpleasant images although the real explanation for the name is certainly mundane. The Milepost says that the area has been overrun with grizzly bears the past few years - I'm not telling my wife that part until we get there. If I told her before hand she would say 'I'm staying in Anchorage, pick me up on the way back'.
I sat in one of the trailer versions at an RV show. It's small inside because the A-frame design is inefficient but I liked it anyway. One thing I noticed is you really need the skylights in the roof because that is where your head goes when sitting on the seats!
I added the site to the camper list.
HARDSIDE:
http://www.bigfootrv.com/
http://www.lancecamper.com/
http://www.fleetwoodrv.com/truck_campers.html
http://www.skylinerv.com/2weekender.htm
http://www.wrv.com/products/index_atc_ltd.html (Alpenlite)
http://www.starcraftrv.com/hardsidetc.html
http://www.northern-lite.com/
http://www.nashtraveltrailers.com/campers.html (Arctic Fox)
http://northlandcampers.com/index.shtml
http://www.summerwindcampers.com/
http://www.hallmarkrv.com/
http://www.okanaganrv.com/camper.htm
http://www.shadowcruiser.com/
http://www.kz-rv.com/truck_camper/truck_campers_index.htm (Sportsman)
http://www.s-scamper.com/
http://www.wcrv.net (Adventurer)
http://www.six-pac.com/
http://www.camperking.com/ (2 bedrooms!)
http://www.roamercorp.com/
http://www.thorindustries.com (use pulldown) (Corsair, Citation)
POPUP:
http://www.fourwheelcampers.com/
http://www.palominorv.com/
http://www.phoenixcampers.com/index.html
http://sunliteinc.com/
http://www.northstarcampers.com/ (RC Willet)
http://www.alaskancamper.com
http://www.lite-craftcampers.com
http://outfittermfg.com/
ALTERNATIVE:
http://www.rockytoppers.com/truckcampers.htm
http://www.sportmasters.com/tonneau.htm#campalong
http://www.outbackproducts.net/index.html
http://www.aliner.com/page37.html (popup hardside A-frame st
We stayed at the 'Prudhoe Bay Hotel' or some name like that. There are two places to stay in Deadhorse. One is used by the tour buses, the other was used by us. It was $190/night, which sounds high and I'm known to be cheap. But, it wasn't that bad. The room included meals and snacks. Which would have run over $60/person/day. So, the room was only about $70 and had a private shower. The food was very good - isolated people need good food or there will be big problems. The night we were there, they had prime rib or baked salmon. Of course, you can order cold sandwiches or hot, made to order off the grill. Fresh fruit, cakes, pies, cookies, chips, salads and more.
The tour of the facility was $25/person and worth it. There is no other way to touch the Artic Ocean. Take the early tour (7am?) to avoid crowds from the our buses. We were the only two on our tour.
You can stop many places along the way and camp, but we chose to drive straight through from the campground in Fox (just north of Fairbanks - fill up with sweet spring water) to Deadhorse. It is a long day, but do-able. To do it again, we would take more time and camp along the way.
Good luck and have fun -
Mike L
How is everything in the town of my birth? You didn't know I was born in M-town? Deaconess Hospital (gone I believe).
Here in California we are still waiting for the summer weather to show up. Mostly low 70's day and hi 50's at night. No more real news here. Still trying to schedule some summer vacation. Enough work that they don't want me to take off, and I have enough vacation that I don't want to work. And they are changing the rules, so any vacation not used by the end of the year will be cashed out on Dec 31. I hate changing rules.
Dorothy is off work, she doesn't know if they will ask her back in August or not. Maybe she will have a long vacation.
My dad bought a new Airstream 25' and he seems to like it. He claims he gets 2mpg better (12 vs 10mpg) than with his old square trailer. And it tows better in the wind than the square ones did in the calm.
Is your Chevy still running? And your trailer still getting used? And your plane still flying? How many hours do you get to use it annually?
Do you still have the same email address? I'll let you know if/when we are coming out this summer (hopefully mid July or August).
Later,
Mike
The HD is great. Have a 30ft w/3 slide Excel by Peterson industries. Don't remember if we still had the Old Hitchiker when you were out.
Traveled down to Smith Center KS for Factory Customer appreciation get together along with 600 ohters first part of June. Planning AZ for March.
Teaching 12yr old grandson to fly the Skyhawk these days. Lots of fun for grandpa. Our youngest Daughter was back from Mission work in Jan so lot of flying with her. In an out of St. Louis IFR couple times etc -- about 50hr a year.
Same home e-mail. We'll be at Oshkosh last week July/first week of Aug. Yeah-let me know when your back.
Loren / 75V
Several of us had them years ago--we used them on our pop up campers. Sears had really nice 10'x16' & 10'x20' (Not just the ones that came out 6' or so) that came with aluminum support poles that were extendable (up&down) and looped over the top and connected to the other side. You could use them as free standing with two or three sets of pole supports or connect one end into the camper awning rail and extend the rest out and over the other sets of poles. The 16' or 20' really gave a lot of coverage area.
I've been searching the net everywhere but can't run accross anything but the short ones that can't be free standing when wanted.
Anyone know what I'm talking about??
I've checked camper world type places with no luck.
HELP
75v
http://www.fiamma.it/usa/index_usa.html
Checkout the website and see if it meets your needs.
Mike L
However I'm just looking for the plain ol 10'x16' 0r 20' flat piece of awning with one end such that it can be pulled into an Awning Rail Slot then removed and folded back up for next year so to speak when I would use it again. The Sears one I mentioned had real nice set of poles that came apart for easy carring.
Loren/75v
We are planning on being in Iowa about the 23rd-28th of July.
Are you up to a Maid-Rite?
Mike L
I am more concerned with overall length, sway on the highway, weight distribution, etc.
BTW, my truck is a 96 Chev 1ton xcab 4wd dually with 7.4L and auto tranny. Thanks in advance for any input.
Meeting for M/R would be great again. Would have to be the 23rd as I have to pick up the GKids on the 24th and we'll leave for OSH either Thru. Nite or Early (5am) Friday the 25th.
Or how 'bout getting them to Go and Meeting at the Hangar. That way I could have Katchup on mine. Maybe a short ride or something again. If you get this before you have leave let me know.
I carry Wk Cell 641-485-2122 nearly all the time so call me on that.
loren / N1575V
I couldn't get my vacation approved until the last minute - too much work - then I got laid off. Go figure! $45K severance takes some of the sting out of it - I wonder how much of that my good ole' uncle will want?
We got to Iowa on the 24th, and made a family reunion on the 27th. Then off to KC so my wife could fly home (she made plans before my vacation finally got approved). I got home yesterday.
I've got a couple of leads on jobs, but I kinda like the idea of staying home - at least for awhile.
Later,
Mike L
Any immediate job opportunities?
Loren
What do you think?
