Toyota Prius MPG-Real World Numbers
1568101120
  • pathstar1pathstar1 Member Posts: 1,015
    I don't think that. It doesn't seem to affect the "cold bladder effect" so whatever the gas does isn't affecting the problem. The gas will not be at 60 F BTW, it's closer to 50 F year round.
    You can come up with any explanation of why it shouldn't happen you like. It is a real thing. Denying it is silly. Just about every owner sees it and Toyota warns about it.
  • joe131joe131 Member Posts: 998
    I am not denying it.
  • kdhspyderkdhspyder Member Posts: 7,160
    That's precisely the point when you pump in the warmer gas in wintertime when the bladder is stiffer it doen't have the time to 'relax', expand and accept a full shot of fuel.
    In the summertime the bladder is already fully 'relaxed' and can take a full shot.
    The
    Too bad the manufacturer has not formulated the bladder material to soften up fast from the heat in the 50 degree gasoline that gets dumped into the tank during refueling. Then maybe the car owners would not get wildly optimistic fuel economy checks on their calculators as the weather changes from warm to cold. I suppose when spring and warm weather first begins to arrive then fuel economy takes a big dive by calculation too. If MPG figures are figured over an entire 12 month period I guess it would be accurate overall as an average, even with the few tanks that were wildly innacurate for MPG calculation purposes.
    The Prius uses the bladder to reduce evaporate losses and achieve its AT-PZEV rating. The HH and TCH don't have this bladder.
    Over the course of a year and keeping track tank by tank by tank manually it all evens out, miles driven/fuel purchased. I ignore the trip computer.
  • nalbandnalband Member Posts: 2
    If I refill my tank after using a quarter tank of gas I get much better mileage than if I run it down to 3/4 or near empty.
    1. Is this similiar to other's experiences?
    2. Does this argue for filling more often rather than less often?
  • mmpmd1mmpmd1 Member Posts: 2
    I've had a 2007 Touring Prius for 3 months. I've averaged 50-53 MPG the entire time. My drive is 20-25 minutes of stop and go, max speed 50 MPH, but I go on the highway once or twice a week, too. I pretty much stay with the traffic, and I've never been one to speed much, even before the Prius. (Prior to this, I had a Lexus RX300 and averaged 21 MPG on the same commute.) I don't use the AC very much (I never have) and I definitely see a difference when I put it on. Overall, I am very pleased with the fuel economy I am getting.
    Is this "better mileage" after averaging out over several tanks? Otherwise, it's "imagined mileage". You can't fill the Prius consistently each time.
    So far I'm getting 56 MPG imperial, 4.9 l/100 km, or 48 MPG US. This is fuel purchased and distance traveled since purchase of the car.
    But, what if you filled up after 150 miles every time over 10,000 miles total and you got 75 miles/gallon? If I "average out" over 10,000 miles, refilling every 150 miles and receiving 80 miles/gallon, haven't I averaged 80 miles pergallon? On the other hand, if I drive 10,000 miles and fill up after 400 miles each time and average 45 miles/gallon, it is a different overall average. Same car, but different miles/gallon depending upon when I fill up.
    whether you fill up after 150 miles or 400 your fuel economy would be about the same unless your driving speed, time and/or environment was different. The weight of the extra gas in the tank would not account for very much gas mileage difference at all. Just make sure you are not relying on a trip/mpg computer and/or dashboard gasoline gauge for your figures. Also, be sure to do the check on every fill-up; don't skip any.
  • harvey44harvey44 Member Posts: 178
    Depends on how you measure "COST."
    You're formula assumes there is no cost to polluting the air, and global warming.
  • larsblarsb Member Posts: 8,204
    You seem to be falling for the "my gas mileage on my computer shows higher numbers at the beginning of the tank and as the tank goes on it goes down" ILLUSION.
    First of all: you are not REALLY getting higher mileage on the "top 1/4" of your gasoline tanks.
    It just seems that way because of the way the computer in the Prius calculates mileage.
    If you are using the car computer's numbers and not the old-fashioned "miles driven divided by gallons pumped" calculation, then you are being fooled.
    The only correct way to properly calculate your MPG is to keep track of the miles driven between fill-ups and the gallons pumped at the fill-up and then divide the miles driven in that tank by the gallons pumped at that fill-up.
    Give it a try........and don't be fooled by the FCD........
  • sam2007sam2007 Member Posts: 1
    Less than a month back bought 2007 Prius with Pkg # 4 and I am very happy so far. Getting about 53-54 MPG with 60% city and 40% Hwy driving. I am not using any special techniques for coasting/hyperliling. My observation is that if you drive Prius like any other notmal car like Civic, Corolla, Accord etc., you should get at least 48-50 MPG.
    Got the car $1200 off sticker, bought Platinum extended warranty for $1,200 (Six years/ 100,000 miles bumper to bumper, $0 deductible)
    Hope this helps..Sam
  • mrmellmrmell Member Posts: 11
    Am picking up my wife's 2007 Pkge#6 Touring, next Monday, 6/25. May sound silly, and I will find out from the Dealer, but wanted input as to type of gasoline folks out there are using, AND, does it matter as to premium vs. regular gas, not just in terms of MPG, but minimum acceptable octane as well. Love to have some thoughts.
  • philmophilmo Member Posts: 77
    As you said, ask your dealer -- he's the one who's going to have to fix something if/when it goes wrong as a result of his advice. We drive all over the west where due to elevation changes "regular" may fluctuate between 85 and 87 octane. Our dealer said to "use 'regular' wherever you're at and don't worry about the octane. The octane will be fine for wherever that particular blend is sold and where you're driving".
    Separately, when we were having problems with our Volvo S60 which requires premium at sea level but are advised to use mid-grade where we live, that dealer recommended that we avoid non-branded fuels (Costco, Safeway Markets, etc.) as they tend to purchase inventory from whomever's around and has the best price. With a given brand (Sinclair, Shell, Bradley, etc.) you're going to get a more consistant product. Also, he said if you see the tanker-truck at your local station making a delivery to keep on driving by and go someplace else or come back when things "settle down" in the storage tank. Seems logical to me but I can't back that up with any facts or bad experience.
    You're correct that there's no benefit to using anything other than basic 87 unleaded. Just use a good quality one as noted.
  • mwbuenomwbueno Member Posts: 9
    Generally, any time a Prius is travelling @ 40 MPH or faster, the number 1 user of fuel or energy is aerodynamics. At these speeds the main users of fuel fall in this order:
    1) Aerodynamic Drag
    2) Mechanical Drag
    3) Tire Rolling Resistance
    4) Heating/Air Conditioning & Electronics
    5) Road Rolling Resistance
    Prius drivers have for years reported a perplexingly wide spectrum of mileage figures stating lifetime MPG figures all the way from the mid 30's clear up into the 60's.
    There are many reasons for this; a few of which I will list below. This list is niether exhaustive nor in order of importance:
    1) Tire pressure
    2) Engine Oil viscosity
    3) Engine Oil level
    4) Road Surfaces
    5) Winds
    6) Ambient Temperatures
    7) Elevation above sea level
    8) Operating Speeds
    9) Fuel Blends
    10) Humidity
    11) Barometric Pressure
    12) Heater or AC settings & use
    One item in the above list is 'Wind." Take for instance an 8 MPH Wind; which is almost impossible to discern when travelling down the highway. Let's see what an 8 MPH wind alone can do to Prius mileage. Putting the following variables into a Simulator :
    Temperature: 88 F
    Wind Dir: as per table below
    Wind Speed: 8 MPH
    Barometer: 30.03 inHg
    Humidity: 64% (Relative Humidity)
    Elevation: 410 ft. above sea level
    AutoAC: ON
    Climate Cntrl: 75 F
    Fuel: 115,400 BTU/Gal-US (RFG Reformulated Gasoline)
    Fuel kWh: 33,557
    Tire Rolling Resistance: 0.0077 (Prius OEM @ 38/36 psi front/rear)
    Road Rolling Resistance: 0.001144 (Smooth Dry Asphalt)
    Cd: 0.26 (Coefficient of Drag)
    FA: 2.16 m^2 (Frontal Area in meters squared)
    cwCd: 0.000014 (Crosswind Corrected Coeficient of Drag)
    cwFA: 0.000085 (Crosswind Corrected Frontal Area)
    After putting the above variables in the simulator and only changing the 8 MPH wind direction as per the table below, we get the following MPG Values at these different speeds:
    SPEED.....8 MPH-33° Crosswind......8 MPH-180° Tailwind
    20 MPH........85.50 MPG....................95.44 MPG
    30 MPH........76.58 MPG....................91.13 MPG
    40 MPH........68.35 MPG....................85.42 MPG
    50 MPH........55.24 MPG....................71.32 MPG
    60 MPH........49.29 MPG....................64.83 MPG
    70 MPH........42.71 MPG....................56.66 MPG
    80 MPH........37.39 MPG....................49.70 MPG
    90 MPH........32.54 MPG....................43.14 MPG
    100MPH........27.49 MPG....................36.27 MPG
    Winds can really make a big difference. Interestingly, the average wind speed across the USA is 8.5 MPH; with slightly higher speeds in the northern states vs. the southern states.
    Another very interesting 'Wind' fact is that winds are detrimental to mileage 70% of the time & only beneficial 30% of the time as illustrated in this image:
    It is not easy always knowing why your Prius is getting good mileage one day vs. another until all of the above variables are taken into consideration & MOST ESPECIALLY WINDS.
    My own results mirror this simulation.
    Can you simulate rain a) normal rain, b) downpour?
    My own estimation from the MFD is that the fuel economy reduction factor is about 15-25% of 'normal'.
    Hi kdhspyder,
    Very good point! Rain has a very big impact on mileage. Let's input the same variables into the simulator except for two items; let's change the Wind to NONE or 0 MPH & then we will change the RRR (Road Rolling Resistance) to show a Light Rain, Mild Rain, Heavy Rain & let's throw in Deep Gravel also:
    Temperature: 88 F
    Wind Dir: NONE
    Wind Speed: 0 MPH
    AutoAC: ON
    Climate Cntrl: 75 F
    Fuel kWh: 33,557
    Tire Rolling Resistance: 0.0077 (Prius OEM 38/36 psi front/rear)
    Road Rolling Resistance: As per table below
    MPH.....NoRain.....LightRain....MildRain.....HeavyRain.....DeepGravel
    20.........91.15..........77.80........72.33...........68.16...........55.79
    30.........84.35..........71.78........66.65...........62.76...........51.23
    40.........77.20..........66.35........61.86...........58.42...........48.13
    50.........63.49..........55.40........51.98...........49.33...........41.24
    60.........57.26..........50.79........47.99...........45.80...........38.94
    70.........49.93..........44.98........42.79...........41.05...........35.50
    80.........43.84..........40.05........38.34...........36.96...........32.48
    90.........38.18..........35.30........33.97...........32.90...........29.33
    So yes, your estimation of 15%-25% is right in the ballpark!
    Elevation & Temperature too have large impacts on mileage.
    Best Regards,
  • gizmo_454gizmo_454 Member Posts: 2
    I am NOT a Prius owner. I have been researching both the Prius and the Honda Insight, and have been seeing mixed results as far as mileage is concerned. I was initially excited about getting a car that gets 60mpg in the city. For that matter, even if I got the 40mpg that most are getting, I would be happy. I live in the "Great White North", a.k.a. Northern Michigan. Winters, from what I understand, kill the mileage of the Prius. Is there anyone from a place that sees 0-20 degrees F during the winter, and drives 2 to 4 miles to work that may shed a little light on what kind of mileage to expect?
    If I am looking at 20-30 mpg, that is frustrating. My '91 Civic, with 271K+ miles on its 95hp, 1.5L, gets 32-34mpg during the winter or summer in the city. And last fall, I made a trip to Boise, Idaho in it and averaged better than 42mpg at 70-75 mph. What is wrong with this picture? A 16 going on 17 year old car, that burns a quart of oil every 1000 miles gets the mileage that these new hybrids get? Something sounds wrong to me. I am half tempted to just rebuild the motor in my Civic and get a good body from down south somewhere and laugh my butt off at these full-sized SUVs.
    I guess, for me, the $300 I bought the car for 4 years and 120K miles ago + the cost of rebuilding the motor is more cost justifiable than spending 25K+ for a car that might get less mileage than the one I have. LOL
    Anyway, if there is someone out there that lives somewhere in northern Michigan, Wisconsin, or Minnesota that can shed some light on their experiences, I would greatly appreciate it!!!
    Have fun all!!
    "Modern" cars will not get the mileage of previous high mileage cars. The reason is a little complex, but I'll tell you what I know.
    First, modern cars must get good crash ratings. To do this you will no longer see 2000 lb cars. Looks like 2800 lb and up is now the norm. Weight kills mileage.
    Second, modern cars must keep emissions very low. To do this they have to keep the cat. and engine warm. That requires extra fuel. Some even have to cool the cat. in certain circumstances, and they inject extra fuel with no oxygen to do that. This all results in more fuel burned, more CO2 produced, but less CO, NOx, and hydrocarbons emitted.
    Finally, we now drive at 70 - 75 MPH without thinking it's fast. Much higher speeds than even 10 years ago. Speed is a big mileage killer!
    The old high mileage cars such as the early Civic, Suzuki, and others that got 45-50 MPG wouldn't pass current emission standards for new cars, nor would they be as safe in an accident. I wouldn't want one. My Prius does just fine, thank you. Don't expect 60 MPG though. Use the new ratings, which indicate 48 MPG overall for a Prius. Which, coincidentally, is just what I'm averaging since I got my car. I expect it to improve a bit, but get a lot worse in winter.
    I haven't yet had the winter experience with my Prius, but I expect the engine will not want to shut down very often, based on other's experiences. This will result in poorer mileage, just like any other car in winter. I've seen most reports of 35 to 40 MPG in the northern US and southern Canada (the parts that get -real- winter). You do have to block the air intakes on the front of the car (many use the black foam plastic pipe insulation). Also, a block heater is a good thing (available from some US dealers, and most Canadian ones). Short trips will also yield poorer mileage in a Prius. In non-winter weather, mileage is lower for the first 5 min. of driving - around 35-40 MPG. In winter, it's more like the first 10-15 min. before the car warms up. Once warm, you can get 50 MPG and up, but the average will suffer due to the warmup losses.
    It's the regulators, not the car manufacturers that are driving all this. Last fall the US Supreme Court ruled that CO2 was a pollutant that the EPA could regulate. If the political will is there, that could result in a "remix" of the control factors that -could- result in better mileage and lower CO2 with only a slight increase in CO, NOx, and hydrocarbons. We shall see. I'm not holding my breath.
    "Finally, we now drive at 70 - 75 MPH without thinking it's fast. Much higher speeds than even 10 years ago. Speed is a big mileage killer!"
    Ummm, both old and new cars go the same (faster) speeds, so I don't see how this affects the modern designs more than the older vehicles...
    "It's the regulators, not the car manufacturers that are driving all this. Last fall the US Supreme Court ruled that CO2 was a pollutant that the EPA could regulate."
    No, not quite. They said that the EPA had to make a determination if CO2 was a pollutant, not that it is a pollutant subject to regulation. So the EPA has to weigh in on the subject - which it has yet to do.
    However, I disagree with the premise that modern small ICE-only cars cannot get good MPG. I think that the Honda Fit (for example) will do similar MPG in winter as summer, which is to say around 38 MPG highway - rather less than summer MPG for a hybrid (depends on the hybrid driving style), but possibly more than winter MPG for a hybrid. For someone who makes very short trips (at any time of the year), where the hybrid components don't function to their maximum, a small ICE-only vehicle may actually yield better MPG. And the Fit is a safe car. So is the Toyota Yaris, and any number of other small vehicles from several manufacturers.
    The comparison was -my Honda Civic CVSSC got 50 MPG in 1980, how come the Prius can only get in that range-. The reasons are as I stated.
    The Honda Fit gets much poorer mileage in winter than summer, just like any other vehicle. It also gets poorer mileage in EPA comparisons and the "real world" than the Prius. My Prius is so far at 48 MPG overall average (fuel used vs distance traveled since purchased), and does that even on the highway. Of course, if I drive at elevated speeds, the mileage drops. I see 6 l/100 km at 120 km/hr (that's around 40 MPG at around 80 MPH). The Fit and Yaris would get worse mileage at that speed.
    The Hybrid system is there to allow the small 1.5 l engine to operate in its' efficient range and to recover energy normally lost in city driving. It does have less effect on the highway, except it is used to give a boost to the ICE from time to time (quite a lot, actually), to help maintain speed without loosing ICE efficiency from throttle burping. The CVT also helps with this.
    I didn't say or imply that modern small cars were unsafe, in fact, I said/implied the opposite. They are safe cars because they have been designed to meet tougher crash standards. I said they are just heavier cars, and because of this and the tighter pollution standards, they don't get the mileage of previous generation "small cars", such as the 80s Civic.
    A couple of notes:
    1. My mother-in-law owns a Fit, and her mileage does not change significantly during winter. Maybe 1 MPG or so. The 38 MPG highway (at 80 MPH) I mentioned was real world, not EPA.
    2. I think my statement about very short trips in a small modern car vs. a hybrid are still valid. Under certain special circumstances the small car might be the better choice, especially when purchase price is considered.
    3. RE: Weight. The Fit weighs 2500 lbs with the AT (2300 with MT). That is still pretty light. My point about modern cars and safety is that the small cars I was mentioning (like the Fit) have both very good MPG and high safety - one does not have to accept increased weight in exchange for safety.
  • mr_hybridmr_hybrid Member Posts: 4
    Hello All,
    I am wondering, what is the actually gas tank size in the Prius? I know the specs say, 11.9 gallons, but I've yet to fill more than 10 gallons. Is there some reserve?
    There is a well in the bottom of the tank to catch contaminants and act as a reliable source of fuel for the fuel pump under extreme maneuvering. It holds around a gallon. You can't drain it. Several people have posted that when they ran out of gas they had to add 2-3 gal before the system would pick it up. Further, the bladder makes it hard to "fill" the tank, without the risk of damaging it. NEVER fill a Prius to the top of the filler (to the gas cap). The fuel will expand and force its' way into the small volume vapour recovery system, and can damage the tank if it overflows through that into the space between the bladder and the tank. The fuel tank will have to be replaced if that happens, and it costs over $1000 to have that done. Not warranty!
    On the mileage wagon, again...
    I guess I just don't understand. If they can make a 427 cu in small block Chevrolet get 28mpg on the highway, why can they not get a 1.0-1.5 Liter get 5-6 times that? Ok, so maybe 5-6 times that is not completely realistic, but how about maybe 3-4 times that? I don't see any reason why not.
    As for the supreme court's ruling that the EPA needs to take a look at whether CO2 is a polutant or not... You people need to call your congressman and have them put some pressure on the EPA. Every time you or anyone else on this planet exhales, you are sending out CO2. If they come out and say that it is polution, it won't be long before we as people will have to pass smog tests. "No more than X breaths per day, or you will get fined for poluting!"
    All jokes aside, every living organism generates CO2. Including plants after dark. If everyone is truly worried about CO2, get out and plant more trees. Better yet, stop mowing down an entire acre to build one house. Just take out the trees where the house will be and leave the rest. The more trees and vegetation we have, the less you have to worry about CO2.
    The winter/summer mileage difference is not much, by my account. Maybe, at most, 1 mpg for my civic. Nothing for me to worry about. I do not have a block heater installed, and I drive 2 miles to work, and still consistently get 34-35 mpg in the city, and 42+ on the highway(70-75 mph), even in the winter. If I do 80, it drops to about 38mpg, and if I hold it to 62 mph, it will get 47.5 mpg. My '91 Civic weighs about 2400 pounds. And like I mentioned in my previous post, it has 270K+ miles on it and burns more than a quart of oil every 1000 miles. Not bad for a wasted motor.
    As for the "safety" issue. I don't know about you, but I don't get on the road saying to myself, "Oh I think I am want to have an accident today." I have no tickets, and no accidents. Period. Not bad for a 28 year old living in a place where more accidents are caused by excessive speed, drinking, or hitting deer, than anything else. Basically, mostly stupid people doing stupid things. There should be no reason for a rearend collision. If you weren't following too close, and doing 15-20 mph over the speed limit, you would have plenty of time to see the person in front of you stopped. To cut this short, I think that if people, in general, would use a little more common sense, and good judgement while driving, there would be no reason for "side curtain air bags" or "crumple zones".
    If I had it my way, if I were to buy a brand new car, I wouldn't take it until all the ABS, Air bags, traction control, backup cameras, DVD players, TVs of any kind, and anything else that takes the drivers attention off the road, or takes control of the vehicle away from the driver, were removed from the vehicle. So I may be a dummy to say they least.
    Enough of my ranting. Someone do something about the mileage on these new vehicles!! The more I read, the more I am disgusted!!! :mad:
    Welcome to the Forum and have a wonderful safe 4th of July!!!
  • caazcaaz Member Posts: 209
    I ALWAYS top mine off...completly...if your at a gas station, which most of us are when we fill up, unless the gas station is right next to your house, you will have used up the required fuel to give you expansion room
    Awesome...thank you for the info. I won't make the mistake of damaging the fuel tank...
    Do what you like to -your- car, but I wouldn't. I add a little after the nossle shuts off. But if I hear the fuel at the filler tube I stop.
    The fuel will expand roughly 0.5 to 1 litre, based on roughly .1%/deg C, underground tank at 15 C, air at 30 C. One litre will be burned in about 20 km in my Prius. You'd better fill up at a station a long way away from home or work, or wherever you plan to stop, and drive fast as the expansion will occur in 20-30 min. This does not account for the higher temp reached by the car sitting in the sun. This also does not account for the air trapped in the tank. There will be some. It will quickly cool to the fuel temp as you fill up from evaporation and splashing. It will expand more than the fuel, giving extra pressure to force the fuel through the evaporative canister (if it isn't at the vent - and it appearantly isn't, as this has happened to a few unlucky owners).
    I have overfilled my car twice due to nossles that didn't shut off. I noticed an extra 80-100 km on the tank. So I surmise the amount of fuel from "normal" nossle shutoff to filling to the top of the filler tube is 4-5 litres.
    "I guess I just don't understand. If they can make a 427 cu in small block Chevrolet get 28mpg on the highway, why can they not get a 1.0-1.5 Liter get 5-6 times that?"
    I guess I don't understand. What 7 Liter displacement engine gets 28 MPG on the highway? ( 427 cu in = 6997.27 cc, i.e. just about 7L).
    Are you talking about a 1960s or 1970's car without modern smog controls?
    Corvette highway miles is about that. Some owners report low 30s on the highway.
    EPA 18/28 with more horsepower than any of the old 427s.
    (16/26 for the 427 cubic inch Z06)
    2006/2007 models. The 60s and 70s models got worse mileage.
    By your logic, why not just make a one cubic inch motor and get 12,000 miles per gallon?
  • graphikzkinggraphikzking Member Posts: 3
    The Z06 will NOT get into the 30's in MPG.
    One of my closest friends has a C6 and we go to corvette shows very often. He can occasionally get 28-32 mpg in his corvette and all the Z06 owners report that if they do 70mph highway they can get like 27-29 but almost never see 30 or higher unless they are traveling downhill for a long period OR have a strong tailwind.
    That said.. the prius is known to have seen 80-90 mpg on some highway stints.. downhill and with tailwind..
    SO lets go by the AVERAGE:
    Corvette (from our experience) ; 25-27 MPG
    Corvette ZO6 (from other drivers); 23-26 MPG
    Prius Owners (highway) ; 46-49 MPG
    So just under double..
    now also consider that the prius holds 5 people.. if we were to schrink the car to hold just 2 people.. (ie Insight) I'm sure we could increase gas mileage by about 7-9 mpg.
    LASTLY - the whole 7 liters getting that much why cant a 1.5 liter get x amount of miles:
    You can't just shrink the engine size and expect to double.. in that case why does the 7 liter corvette "Only" have 80 more HP than the 4.2 liter Audi RS4 engine? Liter for liter it should be 700hp.
    Also, just because the engine is cut in size.. the CAR weight is still the same.
    Sorry about my rant.. BTW - my corvette buddy makes fun of me and my wife's prius.. but whenever we all go out.. guess who's driving..
    AND he plays with all the gadgets and gizmos in the car.. and we average about 48-50 mpg summer and 43-46 mpg winter. We will be getting an engine block heater soon - $29 and it supposedly helps winter mileage by about 1-2 mpg.
    Overall we are very happy with the car and love how there are no pollutants.. if you ever flew into LA you would understand the impact we have! (I live in Philly though and hope that it never looks like LA).
    I honestly don't want to get into a 'Vette/Prius", "Mac/PC", "Salma/Penelope" thing here but observe the following:
    YES, on the 80-90 mpg numbers. I posted some time back about a 50+ mile return run from a ski area on I-70 that put me in the driveway at 87 mpg.
    DOUBTFUL, on maintaining your 46-49 highway with 5 people. Is that how many folks you had in the car when your arrived at the number? My experience is that, on highway trips, each person "costs" about 2mpg.
    Rockies to Bend, Oregon with wife in the car, 51 mpg. Bend to Rockies after wife had flown home, 53 mpg. (Figure into this a 5,000 ft net gain on the return trip.) Scientific? By no means, but it's something I'll be keeping my eye on.
  • nypriusnyprius Member Posts: 8
    Just maked one month today. Have a little over 1000 miles on the car. My AVG MPG has been 52. My bast tank was 54.7 my worst was 50.1 That was my first tank.
    Hope This Helps
    We must all do what we can to cut down on oil. A lot of the money going to the Middle East Helps Fund Terror.
    If we value our country, our Troops and our way of life, we must do all we can to get more MPG.
    Slow Down, Drive Less, Buy a fuel efficient car. United We Stand Divided We Fall. We Must All Pull Together To Become Free Of This Oil Habit. Our Country Comes First Not Our Comfort.
  • crazedcommutercrazedcommuter Member Posts: 281
    Hello Prius owners. I'm researching the Prius as a possible replacement for my 2005 Scion XB that I plan to give to my 16 yr. old daughter soon. I travel 80% highway, 112 miles round trip from Winchester, Va. to the Dulles Airport area and roll up about 32k per year on the odometer. Is the Prius the type of car that I would want for extended highway travel, or should I be looking at a conventional 4cyl.? My 2005 XB auto has been a great car and gets consistant 33-34 mpg at 65-75 mph, but it's a little "tinny" and I wanted more comfort with better mpg if possible. Thanks to all.
    Rob
    You should average 48 (winter)-54 (summer) mpg quite easily. For more feedback on owning the car check out the new owners forum at...
    http://townhall-talk.edmunds.com/WebX/.f0db6d9/359
    Specifically, notes about seats, driver height, non-telescoping steering wheel, etc.
    Philmo,
    Thanks for the link to that excellent report. It appears that the Prius is a capable highway cruiser. I'm going to take a test drive very soon. Do you know of any rebates or incentives on the Prius?
    They tend to vary by region. But really, I'm trying to get you to migrate over there where you'll likely find what you're looking for other than mileage reports, which is the specific subject of this forum.
    Here's a list...vaya!
    http://townhall-talk.edmunds.com/WebX/.ef28f8b/
  • If you are a long-term hybrid owner, our Senior Editor, John O'Dell, would love to hear from you! A short email with your maintenance experiences and concerns would be great. Please send to John at jodell@edmunds.com by close of business Wednesday, August 22, 2007. Be sure and include your Forums username.
  • carbotcarbot Member Posts: 14
    I had an '03 Prius which I put 37,000+ miles on in 10 months. I had no problems or maintenance issues. I sold it to a friend who now has 150,000+ miles on it. He has replaced the 12 volt battery and a catalytic converter. It was a business car for each of us.
    I now own an '04 with 160,000+ miles. I have the oil changed every 5000 miles. At each 50,000 miles I have other routine service done. I replaced the 12 volt battery at 130,000 miles. I replaced the plugs, serpentine belt and water pump at 155,000 miles. The belt was not worn out, just frayed. The water pump was "weeping", so I replaced it while the belt was off. This is the best car I've ever owned. I recommend it to anyone who asks about it. I now have 9 friends who own Priuses and as far as I know there have been no major problems of any kind with any of them.
  • Drop an email to John O'Dell. He'd love to hear about your experiences!
  • downeaster1959downeaster1959 Member Posts: 7
    Here's a question for those of you who love to speculate! I had a 2005 Civic Hybrid with manual transmission. On my very first fill up, I only got 34 mpg. The second was around 44. Soon, I was getting the hang of it and was able to break 50 pretty consistently. My overall average ended up being just under 52, and my best trip of decent length (80 miles on rural roads) was 59.9. I am now thinking of a Prius, mainly because of its larger cargo area. If I could average around 52 with my Civic Hybrid (living in Maine, with winter, etc.), how well do you think I'd do in a Prius? Thanks for any intelligent guesses you'd like to offer!
    The average difference between the "new" Civic hybird and the Prius is about 5%. That is, the Prius does about 5% better than the Civic. You can see the graphs at greenhybrid.com.
  • edwardfedwardf Member Posts: 2
    Rob,
    I li ve in CT in a hilly region of the state. I often commute into NYC and drive to Rhode Island. I do a lot of highway driving as well as short up and down hill trips. I tend to average 46 MPG overall. I drive the car around 75 MPH on the highway (if I go slower, I'll be run off of Interstate 684 by everyone going 85 MPH). I consider my mileage to be real world because I don't really attempt to do all the "hyper miler" techniques to squeeze gas mileage out of the car.
    Hope that gives some information to mix into others opinions.
    Good Luck!
  • south4south4 Member Posts: 32
    I have a question of you as host and to anyone else who has information about this.
    I recently received an email from J. D. Powers and Associates saying they were doing a survey of Prius owners who have the navigation system to see how effective it was for us. I do have the nav system and would love to give feedback BUT it required opening an attachment so I deleted it-I won't take a chance on phishing.
    Do you know if this is a legitimate survey or a scam?
    I have found the Nav system to be horribly incorrect and a waste of money so if it is not a scam, I would like to participate! Thanks for any info you may have.
    I just saw your note and wondered what part of the country you are in. My nav system has been incorrect so many times that I've stopped using it. It became a joke with my children who would suggest plugging in the address of our destination and leaving early enough to be taken completely out of our way.It really has been terrible.I use mapquest again to get directions.
    I am in the southeast and wonder if it's only bad in my region.
    I use my Nav. System every day, all day. I drive and look up addresses for a living. There is an occasional incorrect detail on the DVD, but these are the exception, by no means the rule. My DVD is almost 4 years old, so most of the few problems that I encounter would probably be corrected with a new issue. The problems are so few that I don't even consider a new DVD. I find the controls are very easy to use, and the voice activated controls make it unnecessary to stop, a lot of times to find restaurants, gas stations, etc. I live in southeastern Virginia, but have driven to PA, NC and OH with no problems.
