Visitor Agreement.
Won't guarantee you won't have problems.
Mike L
You can see some pics of his camper at http://members.home.net/vofm
Erik
Thanks in advance Ronnie
With my 1400lb popup camper, I didn't find the bar was needed on my K2500.
You must have a full size camper or heavy 5th wheel to need the Hellwig bar.
Mike L
Thanks for the info
Ronnie
You can see some pictures of my installation on my web page. Hellwig has changed the bar and mounting system so don't worry about my whining.
http://members.home.net/vofm/bar/bar.html
We used to use BB's to communicate before we had discussion groups like this one. Some folks use the terms interchangably.
Mike L
Has anyone spotted a place where RVs go when have been in accidents and are "totaled" - a used RV parts source. For instance, when my brother was riding in the Baja in a new rented Class C (seat belted in the dinette, fortunately) an oncoming truck forced the driver into a concrete encased culvert that projected to within inches of the right of way. My brother suddenly had a view through the floor to where the propane tanks and the right rear wheels had been. No fire. No serious injuries. Lots of trouble, for instance a wrecker had to be requested by a guy who hand-tapped out a telegraph message to the nearest garage. The insurance company tried to get out of paying for loss because the policy "didn't cover tires", etc. Eventually it was declared totaled and everyone came out OK but it took a good lawyer.
For a project I will be working on beginning next fall, I would like to find an equivalent wreck and get some of the surviving fixtures from it. Has anyone spotted one in New England or eastern U.S.?
I'm not interested in those covered with mildew and with weed trees growing through the vents that are behind unpainted houses.
Thanks for any ideas/help.
Ronnie
We (Mike L & gang) recently spent a long weekend roaming around the Stanislaus National Forest. We didn't run into much 4x4 terrain so it wasn't really a problem but I'd like to find some more challenging areas which rules out the Lance.
Here's a picture of our rigs. If you want to see more of our trip, I posted some pics at
http://members.home.net/vofm/stanislaus/stan.htm
"http://www.renoclassifieds.com/"
2. '98 northstar Pop Up Camper, shortbed, stove, sink, furnace, 3-way fridge, many option, just like new, $5900. Call 775-358-6747
The Reno Gazette-Journal Subclassification: Campers/Shells 5/27/2001
You shouldn't put it under the sink because batteries give off a nasty and potentially flammable gas. If you want it near the camper, a good place is in a plastic battery box in the bed of the truck in front of the wheel well. Then just run the wires into the battery box via a connector. Still involves some wiring though. Actually you could just run the wires through the battery compartment door only when you are in the campsite. That would be easy but it wouldn't charge while driving.
If you don't think you'll use the 4wd then don't buy it. It costs more, weighs more, reduces mpg, and increases possible repair costs. On the other hand, I wouldn't be without it. But I like to go places where I need it, or MIGHT need it and it gives me peace of mind.
I doubt you will towing a 26' trailer in the off-road wilderness. Go for the 2wd with the limited slip rear end.
Jim
"Funny, I don't remember being absent minded...."
Problem is that those few inches can make big difference sometimes. So for now I'll stick with the 4Wheel idea and see what happens.
I did a quick run down part of the Ultimate Camper Web Site List and noted some sizes.
4Wheel......80" wide.....56" high incl. vent
Northstar...84"..........66"
SunLite.....84"..........67" incl. vent
Phoenix.....84"..........57"
Palomino....??...........64"
The Phoenix Sasquatch would be my choice of all of them. It is small enough but has a holding tank and toilet.
Mike, I know you had your Phoenix made smaller than standard to be the same as the 4Wheel. But they say it's only an inch taller to start. I suspect this doesn't include the vent as 4W does. Is that how much they shortened yours?
I think the 4" narrower makes a big difference in the outside, but not too much inside. All the loss of width came out of the 'hallway' in the living space. And, I'm only 5'10" so the bed has plenty of width for us.
When I get home tonight, I'll measure the camper height (assuming this feeble old mind remembers) let you know what I come up with.
At any rate, if it was a question of 1-2", I think we could let all the air out of the airlifts and squeeze by.
Mike L
Really happy with performance about 18 months later....
Otherwise people will load a camper that takes the entire payload and then fill it with the above stuff and wind up overloaded......'But the manual says I can put that size camper on it!!!'
Mike L
