The Honda weighs just over 2 tons, not "almost 3 tons." ~4,200 lbs doesn't come close to 3 tons, in my mind.
The RAV doesn't weigh 1,200 lbs less. The 2002 Odyssey weighs about 4,250 lbs. The 2008 RAV4 weighs about 3,500 lbs.
Whoa whoa whoa.... the Edmunds weight you are listing is the GVWR - the total weight of the car PLUS the total payload it can handle. That is NOT what you should be measuring. You should use curb weight as your guide.
A 2002 Odyssey weighs 4,250, a 2008 2WD RAV4 weighs just under 3,500 lbs.
You didn't have a current Odyssey (which weighs what you state here at 4,430), you should be using the weight of the previous model (2002 falls into this category).
Curb weight vs. actual weight loaded is a good question. Which should you use? I think most people drive around with people and object loaded in the vehicle.
I'm guessing you had a similar amount of extra weight in both (similar numbers of people), although you COULD carry more in the Honda.
Going back to my original point, you got similar relative mileage to EPA in the Odyssey as you do in your RAV (about 1 MPG less).
My 2002 Ody got 27 MPG @ 75 MPH on trips from CA to NM. Sometimes it got 26.5, but it was fairly consistent.
Later Caaz
Can anyone suggest a good Remote Starter and it's price and where can I get it.
I need it installed, so it will be really helpful to me during winters.
I am just looking for a Remote Starter, which can start my Van and I can use it to unlock doors. And ofcourse, I am looking for a cheaper one.
Thank you,
Sunil.
It does, absolutely. Your car uses extra fuel trying to get to optimum operating temperature (getting "warmed up, in other words"). That'll drop mileage by a noticeable margin.
Thanks for your consideration,
Jonathan Wahl
Corporate Communications
Edmunds Inc.
MODERATOR /ADMINISTRATOR
Review your vehicle
I ook mine in to Honda and they claimed to get 19.6. They must have been coasting down a 30 mile hill...... This is my only gripe w/ the Ody.
I'VE HEARD OTHERS SAY THE SAME THING ABOUT THE "BREAK-IN" PERIOD.
I WAS SORRY WE TURNED IN THE 2004 FOR THE 2007, BUT NOW WITH ABOUT 10,800 MILES, IT'S GETTING SUPERIOR MPG CITY AND HIGHWAY.
MAYBE 18 CITY AND 28 HIGHWAY WHICH IS GREAT FOR THIS FINE RUNNING VEHICLE....BUT IT TOOK A LOT OF GAS DOLLARS IN THE BEGINNING.ESPECIALLY SINCE THE PRICE OF GAS WENT UP RIGHT AFTER WE LEASED IT...SO HOPEFULLY YOURS WILL DO THE SAME...GOOD LUCK, AND DON'T COUNT THE ODYSSEY OUT YET...I THINK THEY ARE AWARE OF THIS, AND ARE MAKING IMPROVEMENTS TO THE GRADE-LOGIC DRIVE-TRAIN...WE ONLY PUT ABOUT 7500 MILES A YEAR ON OURS...MOSTLEY CITY DRIVING, SO THID WAS A REAL "GUZZLER FOR THE FIRST YEAR OF USE..IT PROBABLY SUCKED UP ABOUT $1500 IN REGULAR IN 12 MONTHS.
BEST REGARDS,
LOU :shades:
Thanks in advance
here is my stupid question:
The mechanic where I set the tire pressure told me to set 39 psi ( front) and 42(back) , and I thought this was way too high for the van. He even showed me 42psi on the sidewall of the tires. Is this true? Should the pressure be set to 39 front/42 back? or what should I set it to during winter vs. summer?
Many thanks for helping me out!
zaki
I have had service people tell me not to use the oil recommended in my manual and to me that is always a red flag and an indication that I need to begin looking for a new place to get my car serviced.
The engineers that write the specs for your manual are professional people that know their products. I trust them more than individual mechanics who come and go from various dealerships.
Second tank, very little freeway or stop and go driving and got 25.7 MPG.
Third tank was 24.8 MPG with about 25% freeway miles. So last 2 tanks averaging 25.2 MPG.
2,150 miles so far and averaging 24.88 MPG. Terrain around here is almost table-top flat. Had a day with wind and another with some heavy rain.
Tires were under inflated by 2-3 PSI til I put 36 PSI in all 4 of them yesterday. That may help the MPG a bit.
GOOD LUCK AND ENJOY THE RIDE.IT'S WORTH IT!
Just filled up and got 26.8 MPG, with about 50% metro freeway driving at 55 - 70 MPH. I know 1 tank does not mean much by itself, so will continue to keep checking it tank by tank.
I still wonder why some of these vehicles get mileage in the teens. Something must be amiss somewhere as I don't think I could get that if I tried.
