Enjoy your Pilot; I tend to think your mileage is right where it should be, if not where you want it to be.
Most days the display for that 2 miles will show I've averaged about 14 mpg. If I get stopped for a minute or so at the light, the average may drop into the high 12 mpg range. I can sit there idling and watch the average mileage drop on the display.
Therefore if my trip was stopped at that point, my average mileage would be
12-13 mpg. Cold engine and short trips are not conducive to good mileage.
I expect that if I got stopped by all 8 lights on that route, my mileage for the 6 miles to work would be about like yours. Fortunately I get through most of the lights without stopping and the mileage goes up.
My normal commute is around 27 miles. It begins with picking up two co-workers who are a few miles away where I drive through suburbia. Then I drive along a rural road for around ten miles with 5 stops signs. Another 10 miles on the interstate with a speed limit of 65. I drive like a grampa through suburbia and everyone else seems like they're drag racing. I start very slowly and then I try to coast to the stop signs from 1/4 mile away. I do 65+ on the highway
When my wife drives only short trips in the Ody, she gets around 15-17 mpg but we get 24+ mpg on highway trips at 70 mph. So yeah, short trips kill mileage.
Denver, your dealer is on the right track with the lower octane. Less oxygen equals slower burn so you don’t need the benefits of high octane to control detonation. Your mileage should get better by a couple mpg after a couple oil changes.
I got the VSA light to come on in the display. Gotta have the engine running. Duhhh!
So if I'm understanding correctly I can choose to drive with the VSA "OFF" and the triangle will be lit. OR I can drive in normal mode and the triangle is off but will become lit if VSA is activated by road conditions. So in effect the lit triangle can indicate the VSA is on and active, and the lit triangle can indicate the VSA is off? Seems somewhat confusing. :confuse:
Yeah, I saw where the Pilot has 253 ft# of torque at 4800 rpm and the Ridgeline has a few less..and reaches its torque at 4300 RPM. Are the gear ratios for gears1-4 the same for Pilots and Ridgelines. Is the axle ration the same for both?
Did notice today that the RL is shifting around 2700 now instead of 3000. That's promising.
Kip
You are right with the VSA light. When I was testing it, when it activates, the VSA significantly cuts power! I think the exclamation point warning lets the driver know that the engine is still running. The light goes off immediately when it deactivates as soon as you lift your foot of the gas. With VSA, I could not get the Pilot to even come close to slipping out except when I had the front tires on pure ice. But that is the same as going real slow and breaking on ice. There isn't enough traction for the tires to grip even when the ABS reduces brake pressure.
I never did check my gas mileage when I was doing donuts at the ski resort, but I was probably getting 25 drifts per gallon.
Well, there ya go! :shades:
25 "Anything" per gallon is a pretty good number for a Pilot! Now we know the trick is to turn off the VSA and power slide through the turns !
Kip
My son has an 07 RL and hunts on a bunch of acreage with dirt roads going through it. Roads are rough and made up of lots of Georgia Red Clay. When the clay gets wet, it becomes very slick. He learned that with the wet steep hills and mud holes the VSA will get him through. Although he doesn't like the cut in power.
He has turned the VSA off, only to discover he was left with more power while not moving forward. :sick:
Kip
Seems about right to me, or maybe a bit high for 75 mph. A Pilot pushes a lot of air. Air resistance is a formula: Frontal area of the vehicle times the speed squared. At 65 mph the formula would look like Ax(65x65). Or Ax4225. At 75 mph the formula would be Ax5625. So at 75 the wind resistance alone is 33% higher than at 65. Other factors such as tire resistance, efficiency of the engine at different rpm, load,etc. would also figure in.
http://www.fueleconomy.gov/mpg/MPG.do?action=browseList2&make=Honda&model=Pilot 2WD
http://www.edmunds.com/advice/fueleconomy/articles/106842/article.html#test2
Drop your top speed to 70 and you might see an increase of 1-2 mpg.
Over a period of 7 years of recording every drop of gas, Our '03 Pilot would consistantly return freeway mileage of 18-19 mpg at 80 mph and 26-28 mpg at 60 mph. Your 2010 may or may not reflect the same mileage or mileage differences.
On the freeway, our '09 Ridgeline with 3100 miles on the clock is now getting 24+ mpg at 60 mph. At 70 mpg the mileage drops to 21 mpg. It may drop into the teens at 75 mph.
Plain and simple: Speed kills mileage. :sick:
Read your window sticker and you will find that the estimated MPG for your Pilot is something like 17-23 in big black letters. Now read the small print beside the large numbers and you will see how much they expect it could vary. Variance will be caused by speed, driving conditions, weather and so forth.
A 500 mile trip at a constant 75 MPH will take 6.7 hours. At 65 mph it will take 7.7 hours. If mileage at 65 was 2-3 mpg better than at 75, the savings would be 2-3 gallons of fuel. That is $5-$8 more or less fuel and an hour more or less time on the road. Priorities depend on needs and wants.
Kip
Kip
After the car has been sitting on level ground with the engine "OFF" for a few minutes or longer, pull the dipstick out and wipe clean it with a clean cloth or paper towel.
Note: if you use a paper towel, be sure no pieces of the towel stick to the dip stick.
Re-insert the dip stick completely, then remove it again. Near the bottom there is a "Grid" . The grid has an upper and a lower "Mark". The oil should be on the grid between the 2 marks. If it is toward the bottom of the grid I would add a bit of Honda Approved oil, a little at a time until the upper mark is reached. Don't go over the upper mark . Sometimes "clean oil can be hard to see on the stick but if you rotate it while holding it horizontal you can usually see the oil mark on the back of the stick.
Kip
I received a letter from Honda, 5,000 mile service is due, service recommended.. The car is not even 1 year old yet, and 6500 miles..
Do I follow the letter or MM ???
When a car is running, there is oil circulating throughout the engine.
After the engine is turned off, it takes a few minutes for the oil to drain back into the crank case (oil pan).
The dip stick has a sealing gasket built into the very top ,just under the handle.
This gasket makes the stick a bit harder to push the last bit into the engine, but it should be done.
So if the car is sitting flat, oil has had a few minutes to drain back into the crank case, and the stick is being fully seated when checking; you will get an accurate reading.
If the oil level is showing real close to the bottom line on the "grid", but still within the grid, you should be OK. If it is below the bottom line on the grid, the car needs oil to be added or changed.
Personally, if the oil level is more than half way down the grid I will add enough oil to bring the level back to the top, if I'm not planning to change the oil any time soon. I'm not sure if the distance between the bottom and top lines of the grid represent a quart, a half quart or what amount. If half way down I would add 1/4 quart of oil, give that a chance to settle into the oil pan and re-check the level.
If that brought the level up pretty close to the top line I would stop. If not, add some more.
If unsure what oil to use, get a quart of "Honda" oil from the dealer. You can be pretty sure that "Honda" BRAND IS WHAT CAME IN THE ENGINE FROM THE FACTORY.
There are all kinds of opinions as to when the oil should be changed.
Many say the cars computer keeps track of the type of driving that is being done and the "Maintenance Minder" will let us know when the oil needs changing. Others believe the oil builds acid over a period of time and should be changed at least every 6 months just to get rid of the acid ladened oil. Even though the driven mileage and "maintenance minder" (MM) don't indicate it.
I personally change the oil every 5K miles or every 6 months, whichever comes first. Sometimes the oil may have only 3K or so at the 6 month mark But it still gets changed. I also use car brand oil filters. Example: in my Honda I use Honda Brand filters, In the Toyota I use Toyota brand filters. In the Chevy I use Delco (GM BRAND) filters. There may be other filters just as good for a dollar less. But when I use the "manufactures brand" filters I feel relatively sure it is doing the job it is supposed to do.
FWIW: I got the Ridgeline the first of November 2009. (6 months) It now has 3000+ miles on it. I will be changing the oil in the next week or so. even though the MM says I still have 60%. Left. I will use "HONDA" brand oil and filter from the dealer, because the engine is still breaking in. Same thing the next couple of times. When 12K or so is reached, and I feel pretty sure the engine is broken in as much as it is going to be, I will start using synthetic oil.
I may be wasting money, but peace of mind is worth something. $25 worth of oil and filter seems pretty cheap compared to the cost of a new engine.
If I were driving 12K+ a year, I would likely use the MM after the first change. But as I only drive 6K+ per year, I will stick to every 6 months.
Different strokes for different folks!
Kip
I have been using shell 87, 89, 91 on my 2006 camry V6.. Same route, used cruise.. mpg came out very similiar using shell 87, 89, 91.. So all shell octane are very good.. I will be using shell 87 on the pilot.
here is the fuelly site to see it.
http://www.fuelly.com/driver/hondavtec/camry
information from the website.
because the dipstick goes through the cylinder head, oil draining back into the oil pan can wet the dipstick and give deceptive readings. so when checking the engine oil level, make sure you look at both sides of the dipstick, and use the lowest reading.
That is a neat web site.
Kip
I always consider synthetic oil, until I see the price at the parts store. What change interval are you planning on using with synthetic? It will be interesting to see if MPG is affected.
Joe
My real purpose of the synthetic is to reduce wear on the engine internal parts.
Better mileage would also be a good thing, IF it should happen.
My understanding is that synthetic is slicker, than "Dino" oil and produces less sludge and carbon that can stick to internal parts. Many moons ago I raced 2 stroke motorcycles in cross country enduros, A friend that raced motorcycles was experimenting with a synthetic before most of us had heard about it. Seems it was called "Ameroil" or something like that.
He heated a piece of 1/4 inch steal with a torch until it was really hot. Then put a couple drops of Dino and a couple of drops of synthetic oil on the hot metal. The synthetic vanished, but the dino left a very small but visible ash.
I was impressed by his demonstration but still not convinced that oil from plants could lubricate as well as oil from petroleum. I didn't like the idea of an engine seizing up in the middle of nowhere, so I stuck with dino and just removed built up carbon from the top of the piston as I had always done, at the end of each season.
When my family came along, I stopped racing and lost touch with my racing friends.
Then around 2003 I purchased my first lawn mower with overhead valves and an oil pump. The guy at the store told me I would get a longer life from the engine if I would change to synthetic when I got about 15 hours on the engine. He said to not do it any earlier than that, because the synthetic is super slick and the engine would never "Wear In" properly and would always "use" oil. He also said that synthetic would stick to parts better, lubricate better, and flow better with a cold engine.
My Generac Generator owners manual said to use synthetic oil after the break in period. Ridgeline owners manual said synthetic is Okay as long as it meets specifications. So I'm going to put it in the Ridgeline at 12K or so.
I will probably change it according to the Maintenance Monitor because my understanding is that synthetic doesn't build acid like dino does. Right now the RL is at 3400+ miles and the MM says I still have 60% oil life left . So my type of driving would likely go to 7K+ before the MM gets too excited. Because I have been changing it every 6 months which is around 3K miles, I will likely be changing it only half as much using the MM and synthetic oil.
In my case the cost per year for oil would likely be a wash as I will be changing oil only half as often, but it cost nearly twice as much. Will save a little bit on only buying one filter yearly.
And yes, it would seem that a slicker oil would allow the engine parts to move more freely and possibly reflect that in better mileage.
One last thing. I have always thought that Gas is Gas. But when I switched from our local "Flash Foods" and "QT" brands to Shell 87 octane, I saw an increase of 8%-12% across the board with the Pilot. Shell is usually $.05- $.10 per gallon more costly. That equates to 2%-4% more per gallon to get 8%-!2% better mileage. It may also contain better engine cleaners, I won't even pretend to understand how the Shell gets better mileage, but it sure does in both our vehicles. And that is a good thing !
Kip
09 honda pilot 4wd. 1/4 mile. 16.1 @ 86 mph , o to 60 7.7 seconds
10 acura mdx. 1/4 mile. 15.1 @ 93 mph. 0 to 60 6.6 seconds..
I don't know what articles you have been read, getting 8.6 to 9.1... wow. honda pilot is as good as mdx... I also think Ridgeline 1/4 mile will be very similar to pilot..
I know most honda dealer use honda oil ( mobil 1 )..
I really like castrol brand.. I used it in my camry.
so I like to know what u guys using on their honda.. and tell how they perform.
thank
My current mileage on the odometer is reading just shy of 57k and this is a combination of both highway, city and off-road driving (and when I say off-road I mean fire trails, driving through streams, 3 wheel angled turns, mud, sand and rocks, etc etc etc.) I have kept a small notebook listing every fill-up and my mileage. The lowest I have ever had during a one tank trip was 11.5 (lots of off-roading and idling) and the highest I've had on one tank is 27.4 (all highway with big rig traffic). On average I'm getting 20.3 MPG. Would I like better mileage? Sure I would. Am I happy with what I'm getting now? Yeah, considering what I put "The Beast" through.
I'm lookinging forward to a nice drive from Hershey, PA out to Chicago, IL and back coming up at the end of Sept. which will be mostly 90% highway driving.
That is all for now.
Odie
JJ
my 2010 pilot ex-l 4wd average 20.2. my best was 21.3. I always warm up my car in winter time, and drive in snow. I am happy with mpg on the pilot.
I now have 106,000 miles on the car. It has been running fantastic since I bought it in 2007. This summer I had the transmission serviced with no noticeable changes. But the last time I had the oil changed, there was a dramatic drop in mpg. I mean A LOT. I now am getting 16 to 19 mpg. It was sudden - from one tank to the next, not a gradual drop.
I brought it back to TimeIt Lube, where they said the fuel system was due to be cleaned out, and they guaranteed that would improve the mileage. It didn't. So they said I needed spark plugs - got that done at Firestone. Still terrible mileage.
Is it possible it has the wrong kind of oil in it? Would that mess up the engine, or just cause a drop in performance?
Any feedback would be helpful.
ameliam,
Some of this post may seem like I'm preaching, or a "know it all", but maybe it will help! I had an '03 Pilot that got great mileage for it's size. So good that many didn't believe it. Your 04 is pretty much the same vehicle. So here are some helpful tips.
FWIW I traded the Pilot for an '09 Ridgeline that gets within a mile or two per gallon of the Pilot in small town driving, and 2-3 mpg less on the road. Not great but still better than my neighbors RL and most of the post I've seen on forums.
25 MPG in any type of local driving seems pretty high, unless there were a lot of straight shots from here to there with no traffic lights, stop signs and so forth, and involved at least 10+ miles each way.
Cold weather and the addition of just 1 or 2 forced stops can seriously affect mileage for short trips. With all that in mind here are some tips.
1. Do an ILP. For info on that, go to page 11 and post 201, of this thread for the information. As you will learn I got a lot of static concerning the ILP. But I was getting great mileage and the non believers were not! If your battery has been disconnected, replaced or discharged for any reason, the ILP should be done.
kipk, "Honda Pilot Real World MPG" #200, 27 Dec 2006 7:15 am
2. If you have "Climate Control" the AC compressor runs all the time and simply adds more or less warm air to control the temperature. Be sure the AC compressor is turned off if you don't need to cool.
3. Many of those quickie oil change places think that 10W-30W oil is good for everything. Not true! Honda requires 5W-20W for the early Pilots. Check your owners manual. Also the filter is important. Me thinks Honda knows more about the requirements of their engines than anyone else, Therefore I use their "HONDA" Brand oil filters. Realizing there are likely other filters that are just as good or better but Honda brand we can be sure of. If your engine is not lubricating properly, mileage will drop and engine damage will be done. Oil and the way it flows are the life blood of your engine, so do it correctly.
4. Transmission should have been serviced a couple of times by now. If your Pilot is 4WD the rear axle should be services also. Use Honda lubricants.
This is important. Old fluids and incorrect ones can cause real problems.
5. It is nearing time for a timing belt replacement. Get it done.
6. Use top tier gas, as it has considerably more cleaners than the government requires. Shell, Chevron, Texaco, ant QT are just a few. Cheap gas is cheap gas.
Read everything in this link to better understand the importance as well as who sells it. http://www.toptiergas.com/ .
7. We can spend fortunes trying to "Fix" things that went wrong because we tried to save a few bucks on oil changes and such.
Check your odometer against a Scan Gauge ll, a GPS, or Highway mile markers.
Hope this helps.
Kip
My understanding is that "Dino" oil in an engine tends to develop acids over time that are not particularly good for the engine. And that synthetic oil is more forgiving.
Is that 22+ mpg the average for all the miles you have put on the Pilot? Or is that for highway driving only.
Kip
during 8,000 miles. i average 20 mpg. mostly driven in the snow.
22.3 mpg is 300 miles driven. no snow. 60-65 mph. 99 % highway. didn't use cruise control.
after 8,000 miles, honda engine is better and stronger, more responsive. today I drove 100 mph for 10 seconds..
I have been use chevron 87 for last 5 fuel up.
I finally change oil on my pilot 4wd. total cost $29 for the castrol syn blend oil change and rotate tires. I told them to set tire pressure to 34 psi.
so whats your opinion on the psi? what psi give you better handling in the snow ??
maybe I am thinking 34 in the front, 32 in the rear?
I think I need to buy tire pressure guage ASAP. so I can monitor.
after 8900 miles. my tires are 10/32 and 7/32. maybe I was driving 26-30 psi all the time..
i finally bought tire pressure guage from sears. craftsman digital $14.99 plus tax. dealer set the pressure at 34 psi. I measured cold. it show 36 psi. I will set it to 34 psi.
so far so good with the guage.
So I am thinking 34 PSI Front/ 32 PSI Rear for the Pilot 4wd. so thats way it will have perfect even tire wear.
The car is just not very aerodynamic and the "ECO" cylinder deactivation doesn't seem to make a huge difference. Even on a long highway trip using the cruise set at 70 MPH (65 speed limit), we only averaged just over 20 MPG.
in the last 3 days, I have been driving in the snow ( mostly highway). I average about 20.9 mpg.. Speed is between 30-45 mph.
I moved from the country into the city during this time - and when I lived in the country, it was 12 miles home, no lights, no stop signs. Guess that's why I was getting such great mileage - trip averaged 50 mph straight shot home.
I was thinking of switching to synthetic but after reading up on it, I think I'll be better off just going back to the Honda dealership for service and let them put in what they think is appropriate. I am way past my warranty now, but I hated that every time I went in for an oil change - right on schedule - they had three to five hundred dollars worth of service they recommended in addition to the oil change. I imagine since I haven't been in for so long, it will be worse now. I don't think I had the timing belt changed, so I will have that done.
I'm off on a driving trip right now, and again, I could kick myself for having brought the car to time it lube for service only a few days ago. An example of their knowledge: the guy brought me out to look under the hood to show me what they'd done, and he told me my transmission fluid looked like dirty water and that I needed my transmission serviced. I reminded him that they had serviced my transmission only six months ago. Then he realized that he was looking at my new oil, not my transmission fluid. Ugh!
Live and learn. And when I get home I want to try that ILP you posted. My automatic driver side window won't go up automatically anymore and I hope that will fix it.
Thanks again!
I was intelligent enough to do that about once a week for 7 years. Recon some folks just never learn.
To "fix" it. Turn the key back on. ..Push and hold the down button until the window reaches the bottom, and continue holding the button down for a couple of seconds.
Then pull up and hold the button until the window reaches the top, and continue to hold it up for a couple of seconds.
That should "fix" the auto feature.
Kip
can you tell us whats year is your pilot ? AWD ? motor oil ? fuel brand ?
2009 Honda Pilot Touring 4x4
it is 2010 honda pilot ex-l AWD
11,000 miles on odo.
castrol synblend 5w20
chevron 87 octane
33 PSI ( cold )
one driver.
outside temp. ( 40 - 48 F )
speed ( 60-65 mph)
straight highway
so we can make a conclusion, pilot awd can get 23-25 mpg. I am impressed with this pilot.. if I drive 60-65 mph, I can get 24 mpg easy..
good luck to all the pilots owner.
A 1000+ mile trip in the pilot yielded 27+ mpg, without using cruise most of the time. But with the cruise activated, it got about the same. The best I've gotten with the Ridgeline is 26+ with Cruise activated.
These figures were calculated at the gas pump although the Ridgeline's dash meter is usually off one way or the other about 1 mpg.
Kip
Highway at 65-70 is typically 21mpg
Highway at 60-65 is typically 24mpg
City mileage runs between 17 and 19. I definitely had to change my driving behavior to get the City mileage up to this range, the first month of ownership I was at 15mpg and was wishing I had my old Suburban back.
No problems with the Pilot, the electronics are pretty nice.
