Visitor Agreement.
The new Chevy truck has a Cheap frame and so does the Ford truck. Dodge is the only truck that still has a good thick frame. So the new Ford and Chevy trucks are nice just cheap that is all I have to say. I am sorry Ford and Chevy but when you build cheap trucks you get poor quality trucks.
Ford & Chevy did You may get more power with these new V-8's but they were not designed and built like a 302-5.0 Ford or a 350-5.7 Chevy.
Dodge is still using old design engine because they are proven just like the 302-5.0 Ford & 350-5.7 Chevy.
Why was Chrysler bailed out by the government with these wonderful pushrod motors? Why was the vehicle that saved your quality company equipped with Japanese motors?
Please dodgeboy, if you're gonna' be a troll try not to pick the worst in class to argue with.
V-8's
I AM A FORD MECHANIC AND FORD HAS GONE DOWN HILL
IN TERMS OF QUALITY OF THEIR TRUCKS. SINCE THEY
CHANGED TO THE NEW BODY STYLE TRUCKS WITH SOHC
V-8's
Ya, and I'm the CEO of GM.
Picking up shop rags and fetching lunch does not make one a mechanic.
Hey BOY, you forgot the mayo.....
the 6.1l, which will have around 340-350hp, and over 400lbs torque. And If that doesn't get you going how about a hemi v10, that will surely be putting out 400 or so horsepower, and probably over 500lbs torque. So dodge in a year from now will be the king of the hill in gas engines, and I think there going be there for a long time, because chevy, nor ford has the hemi design, unless they copy it from dodge. Also just read december issue of truck trend where they compared the three new diesel trucks from chevy ford dodge.
First things first the new chev does win the competition, but I think only becasue of the hype around the new truck. Why Is say this is because they really gave the ram alot of good remarks , all the way from interior styling to brakes, to the engine. The ram and ford were both 6spd manuals while the gm was automatic. The dodge and gm were 4x4 crew, quadcab for the dodge, while the
ford was 2wd reg cab. Heres the jist of it. They said the dodge was king of torque, while the ford has it's loyaists, and gm comfort with power. Also they said the dodge was the best at pulling, while the gm was the fastest, (because of and automatic vs manual from the dodge, and ford), and the ford In this comparo just didn't matter.
Want a funny story?? Ray Evernham used Chevy motors while testing next years Dodge NASCAR bodies for aerodynamics.
'57 Plymouth Fury 318-4V motor is being discontinued along with the Plymouth Volare/Aspen
copp kar 360 motor.....love those magnum
383 and 440's also push button torqueflites....
and '68-69 Roadrunner horn sounds....
dem dodges aint fur the modern times
good luck
Chevy Desperado is Chuck Norris, the Dodge RAM
Pancho Villa and the '97-'01 FOMOCO F150 "BABY
HUEY"....My Chebby C2500 would then be Hulk Hogan
HEY!! CHECK OUT THE LATEST TRUCKIN MAG, on page
40 is a neat, cool, awesome, groovy, bodacious,
righteous and fine article on the pancho villa
diesel RAMBO pickup in HOOCHIE MAMA HOOKER RED
with skinny tires...strange this 4X4 is featured
in a mag devoted to lowered chebbies, fords and
other silly makes....LOVE DEM DERE DODGE HOOTCHIE
MAMA TRUCKS....
Ryan
Whats that I hear? Oh-o, sounds like most of your momies are calling you guys, probably time for a diaper change.
Wildman
Harry
Harry you from chicago???
Ryan
My son has a BS in Mechanical Engineering, and works as a design engineer in the chasis division of Caterpiller Agricultural Tractors in Dekalb and my daughter passed away from a disease similar to Lou Gehrigs disease in 1996 at age nineteen.
What field of engineering are you studying? and what do you want to work at?
Harry
I dont know exactly where i want to work as of yet. Still have about 2 yrs to decide i do have a nice internship right now though.
Rockford is nice my uncle lived there for awhile. We used to go up there all the time. All i remember about shopping up there was cherry valley mall.
Ryan
young buck ME's learn Pro/ENGINEER 3D SOLID
MODELING software at Caterpiller...I said NO..too cold out there in Ill. Caterpiller owns
Solar Turbines in San Diego, Ca about 95 mi
south...still too far....
MODVPTNL No balding chebbies here, still
have black hair, not using VIAGARA yet,
just driving a booty spanking pickup is all...
Dodge Vipers with their pushrod V10's were
designed for BABYBOOMERS not gen Xers who
crave DOHC Hondas, Acura's and Beemers...
and Toyota Tundra wussie pickups...
You arent lting about the cold weather in these parts either. Woke up this morning and the truck is covered with snow. I dont even want to go outside i know its friggin cold.
Ryan
truck and it was COOOOLD!! about 50 deg F..
Was in Montana in Air Force '64-'68 and the
nice arctic winds brought temp to -40 DEG F..
I think Dodge and Ford trucks have better
heaters...
Its (by my trucks temp gauge) 23 degrees. It is 3 degrees above zero with the windchill
I have no problems with my chevy heater. Works great take no time to warm the cab up
Ryan
(coldest ive been in is like minus 30 that wasnt cool)
Dodge has the best heaters and ford is tied with chevy in that department. The biggest problem is that there is to much aluminum on the new engines and it dissipates the heat to fast.
Another factor on heaters up her is # of cylinders if it has less than 8 of them you will not get much heat.
There is nothing like having to leave a manual transmission in neutral overnight so you can start your truck in the morning and then having to use 4WD to move,after that you can only drive 15 MPH until the tires get ride of the flat spot.
with 401 cu in, 325 HP, 445 lb-ft torque, 10:25:1
comp ratio, 3:23 axel ratio, 2 speed Dynaflow
tranny. I turned 86 mph in 16 sec, would do 0-60
in 8.8 secs. Smoked buddie's mom's '62 390 T-BIRD, Buick would burn 9' of rubber....
what did your MAMA (Mommy) drive??
Haven't we gone over this a few months ago?? Look, it's obvious that you are a little boy who has entirely too much time on the computer allowed by your mommy. Now turn the boob-screen off and run outside and play like normal kids.
It's no wonder why so many American kids are fat and lazy today.
My son uses that PRO E program at CAT, He learned it on his co-op job while in school, then took the course on it at school. The industrial instructor was good. Thomas showed the NIU instructor a few tricks he didn't know. That is an impressive CAD program.
Harry
Learned it in Dec 1992. Prior to that used
AutoCAD....hated it, like drawing with crayons...
regards
- Tim
BTW....Dodge will NEVER be the king in engines....period..
Ryan
Every 5.3 I drove had plenty of go .....for a truck.....
I'd put any 5.3/6.0 against any 5.9.......only reason they can stick a 360 in a dakota is cuz it's a dog!
...but we have had this discussion before....
I gove credit to Dodge for style and innovation....but in mechanical....I see no credit to give yet...
sorry
- Tim
Tim, I don't get it my truck is heavier with all kinds of old technology and it would still woop*** all over the above test vehicles. Do these engines need a long warmup or could it be that I happened to get some real dogs here? My wife's actual description of the 5.3 was " a real pooch". I was dissapointed because that Tahoe filled most of the requirements on her list.
As far as the replacement truck goes, I'm leaning heavily toward an f250 crewcab, v-10. Dodge don't make a crew cab and chevy is lacking in power and and styling (almost as bad as the f150).
