Thanks - that's how I needed it explained to understand!
So...if my peak accelleration occurs between 4 & 6,000 RPMs, my best gas mileage might be at the 3,000 RPM mark?
I know you can't give me a definite "yes" here, but please confirm I'm understanding your concept.
The engine does not use the least amount of gas running at the RPM where it produces its max torque. But is efficient at this level considering the amount of power it is generating - the more power the more work the engine can do in a given amount of time.
A few simple (silly even) examples -
If you are just sitting with the car in neutral - the higher the RPM the more gas it will use. No real work is getting done.
If you drive a car 100 miles at 90 MPH it will take more gas than if you drove the same 100 miles at 45 MPH. Same amount of work was done (you went 100 miles) - but the time is different.
These are some of the factors that make this stuff so darn complicated and hard to explain.
Not sure this is even technically correct - but imagine how hard your engine would need to work - going up a steep hill at 25 MPG in 5th gear.
Down shift into 3RD gear (keep going the same 25 MPH) your engine is at a higher RPM - but is not under as much strain - not working as hard to move the car up the same hill.
So the amount of gas you use going up the hill in 3rd gear is less - even though your engine was running at a higher RPM
From the standpoint of every day driving I don't think it will make a big difference - maybe 1-2 MPG who knows.
But when you are towing an RV a long distance getting 15 instead of 13 MPG seems to add up.
I generally meant when the car was on a flat, level surface with minimal traffic.
I think I will keep the RPMs up a little higher than I have been - even a 1-2 mog beneift is worthwhile when you factor in the other, even bigger benefit - I'm closer to the torque/hp "sweetspot" in case I need it!!!
Other things can also help determine your gas mileage.
Can you give better details?
What is your current mileage?
How long is your commute?
City or Highway?
What type of fuel are you using (Octane)?
If you're doing strictly city driving, the MPG average will suffer.
Short trips only add to the low numbers.
On the highway, that's where the TL's economy really shines!
I think you're right. They're playing it safe, but the manual shouldn't say there's only 1.5g left when the alert comes on when it is a lot more than that.
I filled it up this morning after driving with the 'low fuel' alert for 35-40 miles. It came out to 14.3 gallons, so it still had more than 2.5 gallons in the tank.
It's just a little annoying the light comes on so soon.
I sure hope that's not the type of driving you did during the break in period.
I know many Acura dealers are buffoons and will claim that it's really not necessary to properly break in the engine. But the advice I got for my Honda S2000 and Porsche 911 from several knowledgeable engineers and mechanics was identical: in addition to not over-revving and varying engine speeds, DO NOT start the car without driving it for at least 15-20 minutes so as to allow the oil (not just water) and all engine parts to reach full operating temperature. This enables the seals, gaskets, cylinders, etc. to seat properly.
That is what you should do for a high compression, tight tolerance, high performance engine. The TL-S might not be in the same league as the 9,000 rpm S2000 or the 911 engines, but I'd still consider it worthy of proper break in.
You meant "DO NOT stop the car without....", I suppose...
I am curious. What happens if the car's engine did not have a proper break in? And if someone is buying a used car, how would they know that engine was not properly handled in the beginning?
Just curious,
They wouldn't... that's the worst part about buying used.
Improper break-in doesn't really start to show it's affects until 40-50K miles. You'll start to see oil consumption, poor compression, loss of power, poor fuel economy, and the list can go on and on from there.
As scottm123 pointed out, lots of things can occur if the car is abused (intentionally or not) during break-in. Performance suffers. According to my Porsche dealer, a high percentage of "rear main seal" leaks that occured in the previous genration 911 could be linked to bad practices during the break in period when engine parts, gaskets, seals, etc. should be "seating" properly. It's so damn easy to properly break in a high performance engine that it should be put on the label over the airbag warning on the visor.
I traded in my 2.5 year old 2002 Honda S2000 on an Acura TL in May 2004. The Acura/Mercedes dealer owner is a car nut and would only agree to take the car after personally test driving and doing a compression test. It passed on both counts and I gave him the "right answer" relative to what I did during the break in period. He has been known to refuse cars - especially AMG models - that were not properly broken in by their original owners. It's a small town dealership and he doesn't want to have the second buyer of an SL65 pissed off at him as a result of the first owner's transgressions.
Maybe you are getting better mileage because your car might have broken in better than mine?
But I don't mash the pedal or rev the car. I will try to drive a bit more conservatively for the next 100 miles or so and see if it makes the difference.
* 2006 Auto TL, bought new, 18,500 miles to date
* 85-90% HWY driving, 80-mile round-trip work commute
* Typical cruising speed is 68-75 MPH, approx. 1900-2100 RPM
Thus far, the car has exceeded my mileage expectations.
This weekend we did a 600 mile round trip to upstate New York. Drove mostly at around 80mph, but there were some slow spots (about 25% of the time) and some hills. Averaged 30 mpg one way and 31 mpg on the way back. I'm pleased with those numbers.
Finally took a longer drive - did a little over 300 highway miles with no stops - left early and was in no big rush - drove very conservative - no fast starts - slow and easy all the way - set the cruise on 76 MPH - got 35.5 MPG - filled up again for the return trip - drove - MUCH faster on the way home - jack rabbit starts - passing trucks and slow cars - the engine sure does sound sweet above 6,000 RPM - and even though traffic was jammed up in a few spots still got 32 MPG.
Although 35.5 is great mileage I will gladly sacrifice 3.5 MPG for the extra speed - and fun the TL can give. We have a Mazda3 with a 4 banger that does not get as good as MPG as the TL.
Average MPH: 60
Average MPG: 28
Whilst on the Mass Pike and 495, cruised mostly @ 80mph with bursts slightly higher and some traffic lowered into the 60s.
The westbound pike in Auburn was an absolute parking lot yesterday.
Then, every meathead in the world gets on the road and then slams on their brakes as soon as they see that weird glowing orb in the sky.
It's a sun people, buy some glasses!
Ugh. :sick:
I was passed by a black 'Slade on 495s Sunday. I was at 80, he was doing at least 100. Late for the Pats game, I guess... And he wasn't getting 28mpg (and probably didn't care)!
That result--8% off--accords with my less precise measurements done around town, where the trip computer usually read around 20 to maybe 21 MPG, and my calculations come in at 19.
I am not really very happy with these figures, but they are pretty close to the EPA estimates of 18 and 26. I suspect with more normal driving, my trip mileage would be down 1 or 2, to around 27 or 28.
The other potential error is the miles. I checked my odometer/tripometer a couple times, using the highway odometer checks, and it seemed almost exactly correct. Only other caveat is that my TL is just a couple months old and has 2500 miles on it. I expect mileage to improve a bit up to maybe 10,000 (?) miles.
(only about 55 miles in each direction) and seem to be getting ~ 20 mpg in my 9-day-old '08 TL.
The salesman says that mileage gets better after each of the three oil changes.
At today's premium gas prices I have a reason to want my '08 TL to stop being so new.
The worst was a winter week of -31F, total of 227 miles, stop starts in town of 5 minute drives then stop for 2 hours, avg speed 25 mph, got 11.7 mpg
BTW - I'm also a pilot and our club used to have a plane with a fuel totalizer and the technology was very accurate for computing mpg - in fact it was usually accurate to within 1% based on GPS miles flown / gallons used.
Please do check in. I'll be curious to see if your computer is 8% or so too high. That would give you an actual figure of 22 MPG. Sounds like your driving isn't great for mileage. Thanks for the comparison to the competition.
Just filled up today and I have confirmed your findings. My average was swaying between 23-24 on the computer and it calculated manually to just over 22 MPG. That's still slightly better than my 98 Maxima average, and I have less than 600 miles on the engine. Granted I would get better mileage if I drove less than an average 80 mph on the interstate and 10mph over the posted limited in town...plus didn't accelerate as briskly. But if I cared about mileage that much and could actually tolerate driving less than 75 mph (don't know how you guys can do it in a TL, let alone a TL-S) I would have bought something else.
I am still impressed that this car can get better mileage than my Maxima and weighs 450 more, and has 100 more HP. I am also happy that I have outscored Road and Track and the other magazine who got around 19-20 with the TL-S and 17 or so with the G35. I have 2 friends who drive like old ladies compared to me, one had a 03 G35X (he got 18 ave) and another friend with a 06 TL 6M who averages 22 on the trip computer. So I am really happy I am doing better than them, it also confirms that the TL-S was the right choice for me over the G35.
An interesting side note; on my first fill up the LOW FUEL warning went up on the way to the station, and I was able to cram no more than 13 gallons into the tank, the second fill up I drove to work and lunch after the warning and managed to just ladle in 13.9 Gallons. Clearly the low fuel warning is conservative. My Maxima gave me about 30 miles before it ran out when the car was newer, now it is practically dead in the water as soon as the light comes on. The tank is 18.5 gallons but you will be walking with 2 gallons left nowadays. :surprise:
For the manual trans people, I have to wonder if shifting technique plays a roll in otherwise similar driving. Typically I use 4 gears out of 6 when accelerating in town, possibly that is why I am getting better mileage than my slower driving friend.
How do the rest of you guys normally drive? (shift points and gears)?
