Miles on the car when we left was 876. Speeds were above the norm. Ran like a charm though. Did the return trip all in one day.
I filled up the tank and it only took 14 gallons! Owners manual says 17 or so total and this obviously would mean you would have a LOT more range left than indicated on the computer (at least 60 miles by my driving habits).
Does anybody know if the range indication has issues with accuracy? Is it "pessimistic" to keep the motorist out of trouble (stranded) and have a dumb factor built in or is it really accurate? Any techies know anything about it? It's an 06 TL and I always reset the trip computer at fill-ups.
Thanks....
This is the case for my '04 and I believe for every TL through '08.
Well.... I guess that's why my mechanic says "NEVER EVER run out of fuel with a fuel injected car!!!! Thanks for the answer, I've pretty much concluded that there is range left when the computer is showing 10 or so miles. I'm not in the routine of getting that close anyway but it's nice to know in case of an emergency...
Should the fact I mostly drive on city roads for short trips bring down my mileage so much?
Same trip in November we got 26.8.
First trip when we left had just 870 or so miles. This trip started with 3534 miles on car. Maybe it will continue to get better. Has a long way to go to match same trips in 00 3.2 TL where we got right at 30 MPG.
Speed was very fast as usual.
Before leaving I installed 3M clear protective covering myself and it worked great.
Miles: 389
Avg. Speed: 48mph
Avg. MPG: 28+
Per the OBC.
Skiing was great!
Got to love the car,will cry when lease is up next year.
Old Mike
Delighted! Can't imagine what the number will be when the engine is broken in. Gas used was 1/2 tank left over from the dealer and the rest Sunoco Premium (91). Yeah I know, while pumping I realized they had Ultra (93).
booya!!!! :shades:
or should I say Acura
We just returned from a 1941 mile trip and used 67.025 gallon. That calculates to 28.99 MPG. Tire pressure was 33 PSI before starting but I noticed it rose to 38 in the front (37 rear) on the trip.
Speeds were very high and I had many miles at 90 MPH and above.
By the way, I alternate tanks between mid grade and high grade gasoline, all BP gas. Total gas cost was $251.95 or $ 12.98 per hundred miles.
Love the car.
I recently purchased 2012 TL and have 1150+ miles on it. My average mileage is stuck on 18.5 MPG. One of the reason for selecting 2012 TL was gas mileage over other car ike infinity/bmw in the segment. I was expecting it to be in low 20's. My wife drives it. 70% highway/30% city. She is very conservative driver. Dealer told me that it will increase after 1000 miles but it hasn't. I have read somewhere it takes 3-4K miles before mileage reaches it's optimum value. I would love to hear any experiences/advice.
Midgrade gas, 100k
On OEM tires we were getting 27-29mpg, usually closer to 29 than 27. For the 1st 50k mi.
With Conti Extreme Contact tires we dropped to 25-27mpg, and even worse when the Conti's were brand new.
I've found that the sweet spot for good MPG is between 70-75mph. Taking it to 75-80mph can lose 1-2 mpg quickly ( maybe 3 over extended time?) You may think you're getting there quicker, but if you can make the trip w/ 1 less stop for gas, that prob. will save you 15 min, give or take
Keep the shifts close to 3,000 rpm
In addition to reduced mileage the reduced power due to the retarded timing can make a notable difference in performance. When I first tried regular on a highway trip I could tell it took a little longer to get up to highway speeds. But, once when I had to quickly accelerate from 65 MPH to avoid someone there wasn't much extra power available, in fact, I had to floor it to get even a moderate amount of acceleration from 65 MPH. When using premium the car will rapidly accelerate from 65 MPH even when the gas is not pressed all the way to the floor.
Here is the secret. Any acceleration at all yields poor mileage, it doesn't matter if you are ginger on the throttle or accelerate like I do. Your instantaneous mileage will be maybe 10-15 mpg. In your wife's case, lets say we have to drive 4 blocks to the next light. I will be doing the speed limit, or 10 above in about 200-300 feet. Your wife's conservative driving will cause her to spend maybe 3 or 4 times that distance accelerating, albeit slowly. As soon as I get to cruising speed I am getting 35-40 mpg, while she is still getting 15. This easily makes up for my more aggressive acceleration.
Also when I mean "aggressive" acceleration I am talking about moderate throttle and shifting below 4000 rpm. I usually shift 1-2-3-6 in this type of driving. I also drive a 1998 Ford Ranger with an EPA "19 City/ 21 Combined/ 24 Highway". I drive it the same way and get 21 combined.
There have been numerous tests to back up this theory, I am just amazed they don't disseminate it. Maybe because they don't want to give people the idea of aggressive driving. BMW did such a study once and concluded that "brisk acceleration" was the most economical. Try it, it works. At least it does with a manual, since I don't drive auto trans cars I can't vouch for them. :shades:
I recently got a new 2012 TL, I currently have just under 400 miles on it. EPA rates the car at 20mpg / 29mpg, combined 23 (so 1mph better on highway and the rest are the same as the TSX). I don't quite understand how a car with 80 more hp, another 300lbs and two more cylinders yields better gas mileage (comon that 6 speed auto isn't THAT great??!!) but that's what the EPA says! After a week with the new car,driving pretty much the same style / acceleration rates as my old car, I'm averaging at best 22mpg during my normal commute. Strictly city driving is definitely MUCH worse than my TSX even though they're rated at the same 20mpg.
My question... Are the EPA estimates THAT far off on my previous TSX (extremely underrated) or is the TL just not broken in quite yet? In my opinion there is noway that the larger, more powerful TL is going to achieve numbers like the TSX, even with the new 6 speed auto.
Since I achieved roughly 3 mpg above EPA combined in the TSX on my normal 13 mile commute shouldn't I also expect the same with the TL and not slightly BELOW the estimates? I cant vouch for the fuel that the dealer put in (still on my first tank) but I would assume it isn't going to make that much of a difference?? Anyone have any input??
