I can get 29-31mpg. I don't consider myself an aggressive driver.
As for the gas, I use regular and premium. Unfortunately, it's difficult to find 91 octane, so I have to use 93 octane. I don't see any noticeable difference in
MPG when using either grade of gas.
http://www.usatoday.com/money/autos/2003-07-30-premiumgas_x.htm
Essentially...it is USA Today which quotes a senior Chevron Exec to saying:
"I personally use regular even though my owner's manual says you'll get better performance with premium," says Lewis Gibbs, consulting engineer and 45-year veteran at Chevron oil company. He's chairman of Technical Committee 7 on Fuels, part of the Society of Automotive Engineers (SAE) Fuels & Lubricants Council. Gibbs knows gas.
I am still interested to learn if it could mess up the computer or other parts. I honestly don't know. One thing I do notice is that my MPG goes up by 1 or 2 mpg when I do a 50/50 mix....which I also don't know what causes that (please...someone help me to understand that one)
[I am still primarily a premium fuel user ...]
Anyway, according to the manual, this car supposedly has a 17 gallon capacity isn't it??... today I filled the tank with 13.95 gl. (and I mean filled it) @ $2.25/gl of 89 grade. Total gas pumped amounted to $32.15.
Last week filled up tank with 89 grade as well, and run the car for 335 miles (in city and highway traffic) before I ran out of gas today. Per computer, MPG was 25.
The car has been runing really well, and haven't noticed any problems due to gas being lower than required 91 grade...... I sort of wonder what grade of gas the dealer put in when they gave me the car when I bought it....
So nightcrawler...are you planning to do mid grade 89 going forward? 25mpg is pretty darn good in mixed traffic compared to a G35 that gets 25mpg pure highway.
If I had a buck for everytime you used either one.... :shades:
This may be a bad way to gauge this...but I have two points of evidence.
1) I reset the MPG computer multiple times when I started the engine and noticed what type of mileage.
2) I already had >100 miles on the MPG computer gauge...noted the MPG when I started the engine...the noticed how the MPG sank like a lead balloon.
I really believe the MPG computer is rather accurate when I test it against the number of miles driven on a gas tank fill-up (miles divided by gallons to fill the tank).
And as you can see...I fiddle with all the darn electronics in the car. I like that mpg computer.
What a fantastic car!
http://www.msnbc.msn.com/id/8844563/
Many variables.
Hey, at one time I could program a computer to show anything. For example, it would be easy for a computer to add 1.1 miles for every mile turned, very easy.
strickly in town and slight open road metered 19.6 mpg.
much better than Porsche or Explorer.
I am satisfied, of course not with +91 octane @ $1.60 +
Dude, where is 91+ $1.60!!! I'm moving there!
I've been getting 22-24mpg in mixed commute driving using 93 octane.
You mean when you were programming using Fortran on punched cards? :P :P
This is apples-to-apples driving. I'm driving the same routes, same season, with air conditioning on. If my volvo is rated for 18 and gets 18 then I should be getting the 21 city mpg in the TL, which it's rated at, not worse than the volvo.
I feel ripped off.
Is this typical in a "running-in" period?
So you feel ripped off because of mpg? Wow.
BTW, I'm using nothing but 91 octane.
Perhaps it does need time to break in and maybe there's a bit of aggressiveness to my driving because the novelty effect of having a new car.
But I'm telling you all, I drive my 236hp v70 t5 the same way and still get the promised 18 city mpg.
I forgot to mention, my sister just bought a TL as well this past weekend and drove it out here to OC from Phoenix and said she got 24 mpg. So that's a 5 mpg deficit, the same kind I'm seeing in my city driving. Maybe it is the break-in period.
I'll come back and let you all know if I see an improvement.
The car this TL replaced was a 1991 Mercedes 300E which never got less than 20MPG.
Unfortunately I'm often stuck in traffic at speeds of 40mph. When traffic conditions are good however, computer shows I'm making 25 or 26 mpg... but then on morning rush hour traffic it drops down to 23 or 24mpg.. I think I'm a careful driver and don't force the engine to much, and judging by traffic conditions here in Austin, I would never be able to use the full power of this car!!
But for those of you who are making less than 20mpg, you might consider the following: Check your tire presure, lighten up your car and get rid of all that garbage on your trunk, stick to the speed limit, maybe change your air filter (which makes a huge difference), and well maybe you and your passengers should get on a diet and loose weight for the sake of more gas savings!...or just charge a commuter premium to those passengers over 250lb to make up for the lost MPG due to excess weight you are hauling.
Oh...I tested out the concept of lower octane (87 when it recommended 91)....on my wife's TSX (wasn't going to hurt my baby tl). Results.... The car didn't have the pep and spunk that I knew the car to have. It didn't ping or anything like that...so figure no harm done. MPG was similar...no noticable difference. So conclusion? Well...mixed. Seems like no harm no foul....however stinks not to have the pep. Next step....try mid-grade...stay tuned.
Also...asked a buddy that is a hard core track racer that has a Porsche he carries on a flatbed with 600hp. He as saying that gas brands do differ. Some purer than others. For instance...he was recommending Chevron, Texaco, Shell, 76...because they are more 'refined'. He may stretch into Mobil...maybe. Arco, Costco, no namers....he wouldn't touch as the are hodge podge less refined gas brands.
LOL :P
I only buy Chevron because I have been told it's the best, but I will buy Shell in a pinch. But I will not put anything in my TL that Acura does not recommend.
However...I also prefer Chevron.
Another point my buddy (who installed a hydralic floor lift in one of his garages) has made about fuels. He mentioned that current cars are built to even tighter tolerance than in the past. High HP coming from higher compression engine. But bigger yet is that technology has advanced so much that cars are built mechanically with even tighter tolerances. So...he recommends really paying attention to oil types. For instance....follow the oil vicosity recommendation. For the TL...it is something like a 5w-20. Reason is that the thinner oil is required not for fuel mileage...but because the moving parts are so much more 'tighter fitting' and the cylinders have less 'gaps'...so the oil needs to flow that much more easily. The parts are engineered to have oil flowing at the indicated vicosity.
Also...my guess is that the TL's automatic shift logic is very optimized. So that I would believe that the car is a smarter shifter than most.
So when it comes to the TL's tiptronic transmission, one could say that you can not do better than the car's computer when it comes to properly deciding when to switch gears...while at the same time take into consideration that you want to achieve optimum mpg. So sounds like the manual feature of the tiptronic tranny is not the same as a regular manual tranny, although you use it the same way.
Well I just kind of wondered how different this was from a regular manual transmission. But if someone wondered why they would need the ability to switch into manual from auto, then try driving uphill one day.... this feature is useful because it allows you to select the gear you want to get the power you need to go uphill. This could be also used on freeways as an auto tranny could go back and forth from one gear to the other... but don't know what's the impact on mpg. Well what's your experience on this?? or you just have it there for decoration?
