Ford Escape Hybrid Care and Maintenance
Discuss your Escape Hybrid's routine care and maintenance here.
I brought my own oil (Mobil 1 5w20) and asked them to use it. Since the capacity is 4.5 quarts, I brought 5 quarts. Technician apparently doesn't bother to check on the capacity so they dump all 5 quarts in. I'm going to have to drain the oil filter to get the level down below the "full" mark.
They were able to hear the squeak, but could not locate it. They want me to bring the car back when they can have it for a longer period of time. At least they were considerate of the fact I was waiting for them to finish...
Sorry this is so late. I'm a new member and just read your post.
Larry
It is certainly possible to overfill to the point that damage to the engine will occur. They put a "full" line on the dipstick for a reason!
I'm curious if anyone else was told the same or has experienced any problems with using the auto-shutoff AC mode?
It will be 115 and 99% No one ever mentiond this. I thnk its just like the mold scare that went through the housing industry.. Anyway You probably only need max when you are at a light for a for a minute or so. So if the blowers going full when you start back up and your back in the other mode I can't see a build up of mold in the vent tubes from condensation. I'm going to really check this out because that would really affect you milage during the summer months. It just sounds like a new self appointed expert out there. PS do you have mold in your AC ducts at home. You have a fan system there that shuts down and blows a while after the condesor has shut off, then the unit shuts down then when the stat calls for the condensor it starts up.
steelhme
And yes, mold does grow in my AC ducts at home and they are cleaned out periodically.
I don't understand what would be the motivation of my dealer to relay the warning about the mold unless he's had to deal with warranty claims or if he was asked to do so by Ford. I don't know why he did it, but it's what he told me. I agree that it kind of defeats the purpose of having a hybrid if you aren't able to use 'electric' mode as often because of AC issues. Personally, I just sweat it out as long as I can take the heat.
Also, I think the new federal energy bill this year gives 06 escapes a $2600 tax 'credit'. Anyone else substantiate this? Thanks.
You might want to start your research by reading through the main Ford Escape Hybrid topic.
Every Escape made has a place for a filter, but none are shipped with it. It's a easy DIY job, takes about 15 minutes. You should be able to google your way to a step-by-step procedure to install either the "correct" cabin filter or a much cheaper engine air filter that is a nearly perfect fit.
When you change the filter (I change mine every 6 months) just spray a shot of lysol spray down the hole before you put the new filter in.
I only put about 150 miles per week (max) on it, usually less.
Growing up I was taught to change the oil every 3K miles.
I have heard that number is obsolete, but I think the dealer is still using that figure.
When I went in for the first oil change at the dealer, the Escape computer console said "Oil 74%" (or a figure close to that).
Can anybody tell me if that computer display is reliable?
What oil change interval are you guys using?
I am interested in the location of the air filter that can be installed.
I asked my Ford Dealer but I am happy that they know how to spell Hybred.
Can you help a Northern Canuk out here?
I'll check it out tonight.
Might you know of any sites that list help with the Transmission Issues on the Hybred.?
:shades:
In short, make sure that your service center stocks the oil and filter (with appropriate gasket rings) and actually uses them before you loose your oil. Ask to see the oil filter to make sure it's the right one. Thanks for nothing Re***ker Ford! You just lost a customer and 5 maybe 10 others.
I have a FEH06- I believe the infamous rear squeak is related to the rear air vent for the E-motor, I am not sure how to get there to spray a bit of wd40. But I am very confident that is where it is originating from. The dealer has proven to be completely useless. Love the vehicle fit my wallet and lifestyle just find.
I can trough in two set of golf clubs, a bicyle, and my boxer- and I am off. Milage is holding at 32-34 mpg- BUT the SQUEAK is killing me... any updates or knoledge on how to get to the vents-
NOT the vent filters but the vent. Also- the rear air filter little guy about 4x4- dealer does not know where or how to get one... any body have a clue ? thanks
dsb1
I am ready to trade the car in on something else if they can't figure it out soon (the dealer keeps telling me there is no "fix" and it doesn't make any sense for me to bring it in until Ford figures something out.) Drowning the squeaks out is impossible. Somehow it is at just the right pitch that it can be heard over loud music.
Larry
The dealer is telling me there's nothing they can do about it except wait until the part is available (they claim the part is too new, so the manufacturer is not even making it yet so it could be months from now), and they have never seen an Escape Hybrid with this problem.
Has anyone else experienced this smart junction box or door lock problem? I'm very frustrated and wondering how to handle this issue.
In CA it is warranted for 10 years or 150,000 miles as part of the hybrid system. However, it is not a Lithium battery, it is a NiMh battery.
In most other states it is 8 years or 120,000, if I recall correctly. I live in CA, so those are the important numbers for me.
The replacement cost is one of the big unknowns in the whole hybrid purchase decision. Sure, it will last for your ownership (so long as you don't drive cars "forever"), but what about resale when the battery pack warranty is about to run out? There is a forum to discuss this issue.
If anyone else has had this problem and have had it fixed i would greatly appriciate some info.
The oil filter is front and center under the engine compartment in a hard plastic housing that is the closest thing that looks like an oil filter. (If you are lying on your back under the car with your feet out the front and you head between the axles - it is at 6 o'clock) The replaceable part of the oil filter is actually a paper element (like air filters have always been) and the filter housing is reused. Two o-rings need to be procured with the paper element and Ford dealers that are "with-it" know this and sell them with the filter as a kit (I think I paid $8.)
The bottom of the filter housing has a drain plug which takes a 6mm hex and uses one of the two o-rings. The hard plastic housing is removed next and is somewhat problematic if you don't have a good strap-style oil filter wrench, or an oil filter wrench that fits the large hex pattern molded into the housing. Even after the drain plug is removed, more used oil will appear when the housing (and the second o-ring) is removed.
Both O-rings fit tightly into their glands and be careful to use a dull tool (don't scratch the gland surface) to assist in prying them out. Likewise, it helps to lube and stretch the new O-rings slightly before installing.
Don't forget the regular oil pan drain plug located straight aft of the oil filter.
The manual calls for exactly 4.5 quarts if the filter is changed with the oil. Note: The 5W-20 oil that Ford sells is a "Premium Blend" of regular and synthetic oil. Probably as good as pure synthetic if you are going to change on a short mileage basis.
I would be hesitant to trust this job to a "Jiffy Lube" or the like unless they could really show they knew what they were doing.
Good Luck
Makes sense if it was the shock. Two people in the vehicle make the shocks ride differently.
Second, there are 2 different possible battery warranties. If you have the Federal Emissions that the battery is covered full replacement for 8 years or 80,000 miles. If you Hybrid has "california emissions" on the sticker than your battery is covered for 10 years or 150,000 miles. In either case, the Unique Hybrid Components are covered for 8 years or 80,000 miles.
Mark.
Other than this the darn thing has been bullet proof.
Cost of repair $0 dollars, Time spent 1.5 hours,
Wife satisfied: Priceless
