Visitor Agreement.
Not all of Chrysler's recent transmissions are bad either. Their smaller front-wheel drive 3-speed was pretty robust, its just that the transaxle wasn't. And I think the RE series is actually a good transmission, especially since the major upgrade to increase overdrive lubrication in '98.
They most certainly had problems with their first electronic 4-speed FWD transmission (can't remember the model designation for the moment).
Dusty
http://www.nhtsa.gov/NCAP/Cars/2002Pkup.html
Dusty
http://www.hwysafety.org/vehicle_ratings/ce/html/0128.htm
if you live in a snowy climate or play in the mud alot...i'd say get the posi rear. i live in the northern plains and always opt for the limited slip. most of the time i don't even have to put the truck into 4wd because of this.
think about this...even in a 4wd truck (without posi) you still really only have 2wd...one front and one rear tire. and if they are both spinning you ain't gettin far. at least with a posi rear end you've got 2 rear tires grabbing for whatever they can bite into...plus the front one. so in essence you sorta have 3wd vs 2wd.
i should have been more precise with my question. here is a cut and paste from car-truck.com. they are talking about the rear axle in the new '03 heavy duty dodges.
"The American Axle rear ends seem to be terrific. They include an interesting approach to limited slip: a torque-activated twisting worm gear rather than the Dana clutch packs."
i was just wondering if this axle and limited slip setup has made its way into the '03 1500? and can anyone verify that dodge is still using dana axles on the 1500? i was under the impression that they aren't...
Dealer is saying invoice includes ~$500 regional advertising fee?
Is this legit, getting quote for $26.4K with following options:
M9 Premium Seat-Cloth
AHC Trailer Tow
CVN Storage - Fold flat
24G Auto Transmission
DMH Axle Ratio: 3.92
DSA Limited Slip Rear Diff.
GXM Keyless Remote
SCV Leather Steering
WPG Wheel - 20" x 9"
Past Chrysler service manuals were very good about listing the manufacturer of the axle assembly. But I don't have mine yet.
I seem to recall reading that Chrysler returned to making their own 1/2 ton axles after seven years of getting bad units from American Gear. GM has used the American Gear axles in years past and they have also had a high failure rate (we've had two in our G20 and I know several others with pickups that failed).
I don't have any information on what Dodge is using in the RAM 3/4 and 1 ton units. I just did read something about this new "twisted worm drive" limited slip somewhere, but I thought it was identified with the new RAM heavy duties.
Dusty
The current 9 1/4 rear axle appears to be made by Chrysler.
Dusty
I go back and forth between ford or dodge, and I've not noticed much difference reliability wise. My father-in-laws '99 F-350 has been great except for a clutch glitch right at first. My neighbors '98 F-250 has been a disaster; needed new auto-tranny, transaxle, front axles, and other stuff. I just buy whichever one happens to be more comfortable/drive better at the time I'm buying. Thinking F-450 Western Hauler at this time.
I don't know anyone that plows commercially with an automatic.
check out this link...
http://dodgeram.org/tech/specs/Ramspecs.htm
I don't know.
Dusty
I'm being told that TRW, Dana, and more recently, American Gear has provided vendor-supplied versions of the Chrysler-designed 9 1/4 axle assembly. I've gotten conflicting information on years, but there appears to be agreement that American Gear was first engaged in the 1994 model year.
Dusty
the timeline for the 48re stretches from january '03 all the way to next summer. so, who knows?
Of course, that could work against you as far as getting a good price.
Good luck,
Dusty
Dusty
Mid way through their 2003 design schedule they then realized that the new NV design for the 5.7 hemi (also to be used on GM truck lines) had some deficiencies. It was then too late to try to modify the earlier existing candidate for early 2003 production.
The only other option was to take torque and horsepower away. However, that would have meant cam, timing and fuel revision and the comensurate emissions recertification. While building a new cam profile could've been done in time for 2003 launch, testing and certification could not. Also, somebody at Chrysler decided that producing a lower horsepower/torque version in manual transmission would not necessarily be a popular or marketing-smart thing to do anyways.
Dusty
i thought gm/chrysler came to splits on new venture gear and that now chrysler owns all of it...or vice versa...?
It's possible that -- like the old Rochester Products and Delco Rochester divisions that now make up Delphi, they've been sold off as independents.
Dusty
Craig!!
i think you are spot on with the mpg...especially highway. dodge claims a 10% improvement over the old 360. the 360 4x4 quad is 16 highway. so that would make the hemi either 17 or maybe 18 if you round up. makes one really wonder why anyone would want the 4.7l when it prolly doesn't get any better mileage than the hemi??
The truck handled about as you would expect going from half to three quarter ton. The engine moved it around effortlessly. The trans/engine combo was a bit of a let down though. The trans in my half ton seems to be programmed the same way that I am. It shifts when I think that it should and I don't even notice it any more. When you want to accelerate in a hurry, the downshifts are immediate and the motor is right there. The hemi, on the other hand, has a noticeable hesitation between the time that you stomp the accelerator the downshift occurs and the hemi takes over. When it does wake up, it goes rather well. It might have been a problem with the particular truck that I drove or maybe that add on package included a re programmed trans. Made me think that a half ton with a short throw 5 speed would be a lot of fun though.
I did run both my truck and the hemi on a measured course to check the mileage difference. It was about five miles in two directions that included some mild hills. Both trucks had 3.73 gears and similar sized tires I believe. I ran the course with the cruise set at 60 mph. My truck probably had 500 lbs of tools and equipment and possibly 30 lbs of dirt and mud added to it. Mine averaged a little better than 18 and the hemi around 14.5. Maybe the hemi would have done a little better after break in. I'm still waiting for mine to break in. It has 42,500 on it now. Same mileage now as when new.
My truck sits pretty high, but that 3/4 ton is up there. With the same size tires, it's at least four inches taller. You're really looking down at most of the world riding around in that truck. Might not fit in some garages.
I test drove one and noticed that it acted similar to what you noticed. It doesn't always feel like it's pulling as hard as it is. If you look at the speedo it seems to get up there pretty quick. I tested flooring it and it felt great when it got up into the higher rpm levels. Even squalled the tires on dry pavement without trying.
Anyway, It was enough to convince me. I've ordered one and can't wait to get it.
anyway, i also felt that the tranny was almost too smooth and syrupy and it kinda took away some of the urgency i expected while driving a 345 hp machine. hopefully the tranny would learn faster and snappier shifts overtime such that the hemi will feel awake!
The engines as far as I know are pretty much bullet proof. I've got two in ag tractors and 3 more powering irrigation wells. These engines are used in a myriad of ag, industrial, and marine applications that make powering a pickup seem like easy duty. I've never had any major failures in these engines and have never heard of any problems in the pickup trucks that I have been around. I think that you could use the same engine to wear out at least two trucks before you had major engine problems. Providing, of course, good maintenance practices were followed.
I checked with the local Dodge place's service manager on the repo I drove and he said the grinding third on the truck I was looking at was probably a synchronizer and fixing one of those plus putting a new clutch in it would run at least $2,000.00. Just the clutch for the diesel was $900.00+. He also knew this truck, a 1996 SLT with five speed, and said the only thing they had done to it was put a clutch in it, which means in some six years it had used up three clutches. Of course, he also knew the owner was rough on equipment, so that may well not have been the truck's fault.
What brand ag equipment are you using that has the Cummins in them? We will be needing a farm tractor before long and I am interested in the longevity of them, as well. We probably don't need tractors of over 65 horsepower, or so.
Thanks for your input, and I invite anyone else familiar with Dodge to provide yours, too.
THE BOX I HAD IN THE CARAVAN IS JUST TOO HIGH TO FIT UNDER THE BACK SEAT(THE HUMP)I NEED MY BOOM BOOM HAHAHA.GOT SOME OTHER IDEAS FROM THIS SIGHT ALREADY.
Case IH used these engines in their MX 100 thru MX 170 tractors. PTO horsepower ratings from 85 to around 145. I think they made them from the mid '90's thru '01. Their replacement series for this size tractor uses a different engine (maybe Perkins). Don't know if any other tractor maker used this engine or possibly the 4B Cummins. The 4B would be more in your HP range and is simply a 6B less two cylinders.
http://www.chevron.com/prodserv/nafl/auto/content/atf.shtm#atf34
"ATF+3® /ATF+4®
DaimlerChrysler has had their own ATF specifications for many years, but as of 1997, Chrysler owners' manuals no longer list DEXRON as an acceptable replacement. ATF+3 is a readily available mineral oil-based ATF that is suitable in any application calling for ATF PLUS® , ATF+2® , or a Type 7176® fluid. Vehicles manufactured after 1999 require ATF+4® , a synthetic-based ATF only available through DaimlerChrysler."
I have talked to one transmission shop that told me that Chrysler ATF+4 was used by them in Ford truck transmissions to cure torque converter shudder. Interestingly, a fellow worker told me the other day that his 2000 F150 had such a problem and that his Ford dealer installed Chrysler ATF!!!
The above seems to say that ATF+4 is a synthetic material, but I suspect that it also contains some sort of friction modifier. It also implies that ATF+4 is only available through Chrysler.
Dusty
