Engine's burning oil - how much longer will it last?
I have a '93 Tercel with about 125K miles. It had 89K when I bought it back in '02. The engine used a little oil when I bought it (I had to add about 1/2 qt every 750-1000 miles or so), but I believe the consumption has gotten worse. Now it'll go through 1/2 qt about every tank full of gas. It doesn't leak so I know it's burning the oil. The weird thing is that the engine still runs very well, has plenty of power, and still pulls over 40 MPG on the highway. In other words, the engine doesn't act like it's burning oil as badly as it is. Usually when an engine shows signs of wear to where it's burning oil this badly, you usually notice a definite drop in power and/or fuel economy. That's just not my case. I've always used good oil (Havoline) and filters (PureOnes), with frequent change intervals (about every 4K-5K). I guess my questions are these: How much longer before this sucker starts looking like a misqusito fogger going down the highway, and is there anything I can do differently to slow down this wearing out process? Also, I was hoping to get 200K out of this car. Is that no longer a feesable goal?
See Also: Troubleshooting Engine Oil Consumption
It doesn't sound like you'll get 200k out of the motor but you could get that out of the car if you want to put another motor in it.
At any rate, unless you run afoul of emissions testing (which generally doesn't care how much oil you burn) or unless your car's smoke becomes reallly obnoxious, you can keep it running for a long time. Eventually you will burn oil so badly that you'll foul the plugs a lot or destroy your catalytic converter and this will become quite a nuisance for you.
Or you will forget to add oil and then KABOOM.
The worst it got before I had to break down and fix it was maybe 200 miles/qt on the highway, I could double that in town. Smoke was awful at startup or when going up a steep hill...barely notioceable otherwise.
If you really like the Tercel...just have it looked at. A valve job couldn't cost too much on something like that...surely less than that fintail.
fintail, been to Burlington, WA lately? Anything new along the I-5 corridor there?
BTW-take a gander over towards Burlington as you're heading past town on I-5 next time and you should be able to spot Jerry Smith Kia there on old Highway 99. That's the dealer I bought both of my Kia's from. They're a solid and reliable dealer of Kia products there in the beautiful Skagit Valley region of Washington state. Over and out.
Best way to know what's up is to do a cylinder leakdown test, and then all will be revealed.
iluv - I now live in Bellevue, transferred to a better job. I'll actually be going through that area tomorrow though, to pick up the fintail (it is stored north of Bellingham) and bring it here.
Do a leakdown test for sure, as Shifty says. A valve job for that thing has to be well under a grand.
This is why you want to do a leakdown test....you might have both valve guide AND ring wear, in which case strengthening the top end will only cause more oil to escape past the oil rings into the combustion chambers.
Testing for bad valve guides shouldn't be too hard. First of all, if your valve guides are the culprit, usually...usually...you'll get a lot more blue smoke at start up, and it will gradually diminish; also, if you get blue smoke while ACCELERATING, that's usually rings...if you get huge clouds of blue smoke while DECELERATING, that could be guides. So when you get a high vacuum situation (closed throttle plate) you'll tend to suck oil past the guides, but in a low vacuum situation (throttle to floor) you'll tend to pump oil through the oil rings.
Another sign of bad rings is blow-by, which is that chimney smoking effect you get at idle, where you can see puffs of smoke coming through the oil cap on top of the engine---be careful about testing for this on OHC engines, as the camshaft can send a lot of oil through the open oil cap.
Lookee here---only $285 bucks. I couldn't buy even the valves alone for my engine for that.
http://www.adccylinderheads.com/site/792044/page/292968
PS: I have NO idea if these are any good---I just googled 'em.
brakes...... a bad vaccuum line to/or brake booster check valve !!!!
A cyl. leakdown test as others have posted will tell.......................
and such there is NO minor repair of the valve guides.
Major disassembly is required as well as machine shop work which
is quite spendy. Not to mention the added parts that may be required
since you already have a 100k mile engine. (Timing belt, cam seals,
water pump and on and on)
Run it till it blows up and save yer money !
Auto RX is IMO snake oil. Nothing in a bottle will ever cure engine wear. But you can be our own personal guinea pig on the matter and report back after extensive desert and arctic testing. We're counting on you.
The reason snake oil isn't sound scientifically is pretty simple---IF the engine is burning oil because there is cylinder bore wear or piston ring wear, and that wear is so great as to allow oil to pass through or combustion gasses to pass through, well now really, what liquid goop in a can is going to cure that?
All you end up doing is making the oil thick for a little while and gum things up until the engine reaches operating temperature and breaks it all down again.
If someone is counting on some goo in a can is going to stop 120 psi compression driven by exploding gasoline, well good luck to them.
If the problem is measurable engine wear, then all that stuff is a complete waste of money. But if the piston rings are just stuck or the engine is severly sludged up, then maybe maybe some strong addtives/cleaners and frequent oil changes can help, sure...
But after 100K++ miles, it's not likely to be sticking rings---a rather uncommon occurrence on modern engines.
Anything you can do with "engine magic" in a can I can do with 50 weight oil, because it is the same principle...the heavier and gooey-er it is, the slower it will work into the combustion chamber. But sooner or later it'll burn just the same.
And I've busted down engines that were doped with STP---it's not a pretty sight.
(if ohc), rocker arms (if not) to get access and remove the keepers
and valve springs.
Removal of spark plugs to put compressed air in the cylinders
to hold the valves in place.
Then ya gotta slip the valve spring compression tool in place to
release the "keepers". Remove valve springs. Replace O ring.
Reassemble......................
LOTS of work......Equals $$$$
There were several posts in the GM threads about high oil
consumption. GM issued a TSB to replace the PVC valve with
one with a smaller orifice...............
Must of worked..............No further complaints seen............
Bott...........Hopefully you will get lucky and a PVC valve will do the
trick!
If you have power brakes...Did you check the Vaccuum line to the
booster for oil residue ?
Lemko is also correct...........The old heavy straight weight oil will cut
oil consumption down. With that many miles it prob. won't make a
difference in the winter..............
Nah, popping off a camshaft on a Tercel isn't hard, especially considering the alternatives, which might be engine overhaul or the local government taking your car off the road. Couple hours shop time and that's it. Price it out let us know.
50 weight oil in winter is like jello---not recommended unless you use an engine heater.
The next year the rules were changed so a turbine car could not win.
Harry
My point which might have been muddy is that without a cylinder leakdown test we really don't know if your problem is engine wear or not, and so if I were in your shoes (I wear an 11) I would test first then try the remedy most likely to work.
Also I'm pretty adamant on the idea that reconditioning seals never works--now THAT part is voodoo. The engine cleaning part as a benefit I could buy that in some cases, certainly, but once a seal has lost its vibrancy, swelling it up like a raisin through chemicals is a short-term solution at best. Once you soften it, it loses its ability to remain resilient under all conditions.
Just nurse it along or spend big $$ to repair...................
Go with straight 40 weight and keep running it !
I do it with my ancient "winter rats". My 87 Escort never complains...LOL!
Yep, I kept it alive and had a rebuilt 6 cyl 200 c.i. engine thrown in the nice looking Stang. The next major failure was the transmission and the car was gone, making way for a 1970 Chevrolet Suburban. Ya wanna talk about beasts to drive. Probably achieved 8 miles to the gallon in that people mover!
Reminds me of the guy at work who seemed to be genuinely intrigued by the Ford Excursion when it first came out. Maybe he thought he could carry his Ford (Kia) Festiva inside it!
I have taken the car to the dealership on multiple occasion. There is no leaking, the underside is dry as a bone. There is no discernable smoke on start-up or in motion. Power and gas mileage is great. The compression is within norms.
The dealer conducted some form of test and removed / replace valve in the crankcase - they said it was out of spec and sucking up to much oil. This did not solve the problem. The dealership now has me using 10-60 M3 High Performance Motor Oil. They are trying to go the cheap route and not teardown the Engine.
I think I have a problem within the Engine -i.e. rings , valve guides, etc.
If what i believe is right - what can be fixed first without too much fuss and money, Or should I just have them tear the Engine down and put in new valve guides, rings, etc.
The car runs great otherwise - it's very annoying to put oil in the car every 1000 miles. If it was every 3000-5000 miles then I would have no problems, but this is a BMW - it's supposedly engineered to go 300K - having this happen at 117K is bothersome to say the least.
Looking forward to your help.
Regards
Manny Mateus :confuse:
Do you really think it's worth the expense?
For me, simply adding a quart of 1.50 oil once a month isn't a big deal.
And I don't like their reccomendation of using a heavyweight oil to mask the problem. 10-60?? Never heard of the stuff?
Just check it often to make sure it doesn't get worse.
I remember I once had a Chevy that used a quart every 700-1000 miles like clockwork. I kept that Chevy five years and it never changed. Ran like a top too!
Beautiful car that just liked a quart of oil once in awhile.
:W does not stand for weight, it stands for winter, meaning that an oil with a W is suitable for use in winter.
W does not stand for weight, it stands for winter, meaning that an oil with a W is suitable for use in winter."
Ummm, no. You have it exactly backwards. 10W-60 oil is a 10 weight oil ("W" does NOT stand for winter) that is stable enough that when hot it only thins out to the viscosity of a straight 60 weight oil. There are two methods of stabilizing thin oils (take your pick, 0W-30, 0W-40, 15W-50, 10W-60... it doesn't matter). The first is to add what are generally termed "Viscosity Improvers" (VIs), and the second is to produce an oil from a fully synthetic base. Most middle of the road oils (Motorcraft 5W-20 for instance) use some synthetic PAO and some VIs to achieve the desired result.
FWIW, while formulations are a tightly kept secret by all manufacturers, it is believed that some oils, Mobil 1 0W-40 for instance, are formulated with such a high quality PAO base that they need no VIs to achieve their classification.
Best Regards,
Shipo
