Frontier vs Ranger - III
13»
  • volfyvolfy Member Posts: 274
    You probably know this already, but before you head for the tire shop, wash your car and shine up the tires with ArmorAll. It makes a great impression that you took care of the tires.
  • wdoyle9752wdoyle9752 Member Posts: 73
    >>Thanks for the tips guys,
    >>Doyle;
    >>How much did those cost? are they just as quiet?
    The Pirelli P400 Touring tires are $55 a piece at tirerack.com. They are just as quite if not quiter, but traction dry/wet is considerably better than the Firestone Wilderness HT.
    I kept the old firestones, figuring that they may be recalled one day.
  • consoleconsole Member Posts: 7
    I shopped between the Ranger and the Frontier very seriously, earlier this year (2000 models). I chose the Frontier. I'll offer my reasons here, in order of priority:
    1. Price. It came down to a 4th-of-July sale where I got my Frontier DR XE for about $500 below invoice minus the $500 rebate in effect at the time. Price was $13995 plus the $520 destination, plus a couple dealer add-ons like pinstriping. Under $15k before tax. The cheapest V6 Ranger I could find would have been over $15k, easily.
    2. Availability of configurations, and personal preferences. Every vehicle I have driven for the past 4 years (I'm only 24 years old, so basically every vehicle since I've been able to afford to pick and choose, that's 3 vehicles in 4 years) has been a V6 w/ manual trans. I am a power nut and don't mind shifting. Try finding the V6/stick combination in a Ranger. Virtually impossible.
    3. Reliability and performance. Very comparable between the 2. As someone mentioned in one of the early responses in this thread, the Frontier 3.3 has more HP and torque than the Ranger 3.0. The Ranger 4.0 would have been prohibitively expensive for my needs, and impossible to couple with a stick trans unless I custom-ordered from the factory. Consumer Reports indicates very comparable reliability.
    4. Bed size is probably very similar between all compact trucks and not worth arguing over, but it is true that Nissans have the *deepest* beds in their class, if that's important to you.
    Things I preferred about my 1990 Ranger 2WD Ext Cab XLT I had until 2 years ago, that I don't like as much about my 2000 Frontier DR XE:
    1. Leg room. The Ranger seemed to have a bit more of it. The Nissan's King Cab seats should slide a little farther back.
    2. Seat comfort. Granted, the Ranger was a split bench and the Frontier has buckets, so not as cut-and-dried a comparison, but the Frontier's seats seem to have very little back support and are too squishy. My trick shoulder joint acts up after a long drive in the Frontier. It's the left one, so it's not from shifting.
    Things I like better about my Frontier than the '90 Ranger:
    1. More power. Comes with the 3.3L Nissan vs. the 2.9L 1990 Ford engine.
    2. I have a Desert Runner, which means added ground clearance, tho I'm pissed that Nissan cheaped out and left the leaf springs BELOW the axle for the DR and apparently also on the 2WD Crew Cabs. WTF's up with that? If you're gonna raise the truck and sell it as an offroader, the leaf springs have no business being under the axle. Even so, it's a better riding and offroading truck than the Ranger was.
    3. Sliding rear window. OK, just a packaging item that existed on the Ranger as well, but it is very cool that for 2000, the Value Truck Package included sliding window, meaning virtually every Nissan truck had one since very few trucks were produced without the VTP. However, I've noticed a lot of the new 2001 Frontiers with solid rear windows -- especially the Crew Cabs. OK, maybe in a Crew Cab if the rear windows roll down you don't need a sliding rear window, but I want to see them remain standard (or almost so) on the King Cabs.
    To me, these things are only good for thieves to break into your truck. I cant think of anything I would want to put in the bed and retrieve through the sliding window. As far as for ventilation, it is typically either too hot or too cold to open a window anyways. Rear sliding windows are particularly useless in an ext cab.
    Is there some hidden function of the sliding window I am missing here?
  • cthompson21cthompson21 Member Posts: 1,102
    Just curious, but did you price any Rangers at a dealership or are you comparing MSRP off of Edmunds and the like?
    A dealer 2 miles down the street from me had a couple of Trailhead Rangers at 12.9K. The Trailhead is similar to the Desert Runner (it's 2wd with the looks of a 4wd). It came with A/C, a 5-speed, AM/FM/Cass, 3.73 gearing with the limited slip differential, and the 3L V6. It's no barnburner by any means, but it's good-looking, reliable, and very economical transportation at a price that's damn near a steal.
    For 15K you should be able to pick up a fully loaded 2wd Ranger if you buy a '00 and take the rebate ($1500 I believe) over the special financing. I got my almost fully loaded 4x4 Ranger (absolutely everything minus the LSD and ext-cab) for 18.5K a couple years ago with the 3.9% financing over 60 months to boot (could have taken the $1500 rebate if I so chose).
    Thanks for the honest observations. There's usually so much BS flying around these forums that it's annoying. No one will actually admit that their truck is not flawless or there are things they'd like to change about it.
    First, about sliding rear window... it's all about ventilation, especially in a king cab truck whose rear side windows don't crack open.
    In response to the Trailhead Rangers... at least for the 2000 year, they were only available in regular cab. I haven't checked for 2001, so I guess it's possible they've added an ext. cab to the Trailhead lineup. I simply won't drive a regular-cab, compact pickup. My legs are too long. Note my previous post about how even the Nissan KC's legroom seems an inch or so stingier than the '90 Ranger I used to have.
    Also, that $1500 rebate wasn't offered when I bought. It might've been $500, same as the rebate at the time on the Frontier DR.
    Money aside, my first choice within the genre was and remains the Toyota Tacoma PreRunner. (My other car's a Camry, and I'm definitely sold on Big Japanese 3 reliability overall -- Honda, Toyota, & Nissan.) Only reason I didn't buy one was the $6k to $7k higher price tag, and the fact that I intended the truck as a 2nd vehicle that wouldn't warrant that kind of spending. The Desert Runner's a good poor-man's alternative, but until there's an ext. cab Trailhead Ranger, not worth my consideration.
    Have you driven a '98 or later regular cab Ranger? They increased the cab length by 3 inches. It makes quite a difference. I'm still undecided whether extended cab or regular cab for my next truck. There are trade-offs either way.
    Those Trailhead Rangers I was talking about didn't have any rebates attached to them at the 12.9K price. In any case, it's easy to get a 2wd, ext-cab, V6 Ranger for under 15K (without even applying a rebate).
    I don't think they're offering a Trailhead package for '01. I think it's being replaced by the entry-level Edge package. The Edge is a few hundred dollars more but adds some additional features (CD, monochromatic treatment, 4-wheel ABS)
    I do agree that the Tacoma is overpriced. But, it also seems that you're comparing what you paid for your Frontier with both the Ranger's and Tacoma's MSRP (which to me is like oranges to apples). For a Ranger, it's easy to get a price at dealer invoice (base invoice + destination + allocation of ad fees). For a Tacoma, you're doing good if you can get $500 over dealer invoice.
    I love my sliding rear window. But, I also know first hand from locking the keys in the truck how easy it is to break into it.
  • mahimahimahimahi Member Posts: 497
    Hey CT,
    Shouldn't the first line of your response read? "Have you driven...A FORD LATELY?" j/k :)
    sorry...couldn't resist!!!
    Noticed that all of the '01 CC's I've seen on the road don't have the sliding rear window. I love mine. I wouldn't ever own a truck without it. I did that once my S-10 SS didn't have one and I missed it big time.
    That's a good one. A man without humor is a man who drives a Chevy! (JK to all GM fans, just bringing up the 'ole rivalry)
    Is the Sport Trac the one with the power sliding rear window that rolls down? You gotta love that.
  • cncmancncman Member Posts: 487
    You won't find a sliding rear window in the 01 frontier CC's because it has a rear defroster, gotta like that too!
    >inches.
    No. I did not know that. But I still have a fondness for king/ext. cabs in compact trucks. It's very useful for throwing the ice chests and sleeping bags back there and not worry about weather or theft from putting them in the bed.
    >12.9K price.
    I recall seeing a bit more, but it's not worth wracking my brain or squabbling over. As for your statement that "it's easy to get a 2wd, ext-cab, V6 Ranger for under 15K (without even applying a rebate)," I assure you that I tried. It would be possible to barely come in on one side of $15k with a stick shift, but none of the trucks that I saw on any Phoenix area Ford lots had the V6/stick combo, unless they were 4WD's with the 3L V6. All 2WD/3L and 4WD/4L trucks were sent from the factory with auto tranny, and that tacks on an extra $1k or $1100 I believe.
    The Ford dealer I most looked at, Earnhardt Ford in Tempe, AZ, also annoyed me because they have the hideous practice of tacking on a $3k "dealer markup" that no one expects to pay and nobody in their right mind ever WOULD pay. I punish such dealers by refusing to do business with them. Not many dealers in Phoenix put on markup, but every single dealer I looked at in Sacramento, where I lived up until a couple years ago, tacks on markup.
    Most dealers in my area have an agreement with my credit union where C.U. members have the option of purchasing thru the fleet dept. for a predetermined price of usually between $100 and $500 or 1% or 2% over invoice. There's no reason a savvy shopper should ever pay more than $200 over invoice, except maybe on a very popular SUV or luxury vehicle.
    I agree that the utility of an ext-cab truck is very nice. I'll probably get an ext-cab truck next time. In the meantime, I'll just settle with a lockable lid and a smaller cab.
    The Trailhead Rangers did sticker for more money, MSRP was something like 14K. That Ford dealer had a one price, no haggle policy similar to Saturn. That is what the dealer marked the price at.
    It really sounds like you've dealt with some terrible Ford dealerships. That's by far the problem with Ford.
    Did they even look into a possible dealer trade for you? My salesman did a dealer trade with a dealer in WI and personally drove there and back to get the exact truck I wanted.
    "There's no reason a savvy shopper should ever pay more than $200 over invoice, except maybe on a very popular SUV or luxury vehicle."
    Tell that to the Toyota, Nissan, or Mitsu dealer where their closest dealer of the same make is an hour drive away. I'd rather pay a couple extra hundred bucks than deal with that sort of headache. Plus, the revenue will filter into your local economy.
    In any case, have fun with your truck. That's what they're there for, right?
    Did this room die again?
    Recently, I saw the new Frontier commercials with the truck powersliding across some rough surface. To say the least, Nissan marketing should never have aired that commercial.
    I'm still here CT, I have seent he commercials you talk about, why should they have not aired it? I got my first SC yesterday, do yourself a favor and drive one if you can find one, it's a blast!
    The commercial showed a S/C Frontier doing a powerslide across a rough, muddy surface in slow motion. The body flex that you could see in slow motion was terrible. The truck was flexing and bending like jell-o. I'm not saying that all trucks don't exhibit this trait, though. It just didn't look good, and that's prolly why you haven't seen it (pulled off the air, I only saw it once or twice).
    It just doesn't have the appeal of the Max power-sliding across the desert (very cool, definately a top contender when replacing my SVTour in a coupla years especially with that new 260hp engine on the very near horizon).
    It looks like I'll have to get out and test drive some trucks soon to keep abreast of the current offerings.
    So, what do you think? The SOHC 4L versus the S/C 3.3L??? I haven't had the pleasure yet, waiting for the 5-speed manual tranny in the Ranger.
  • scape2scape2 Member Posts: 4,123
    Hey cncman!! how are you doing?? I have test driven the SC 3.3 in the automatic and compared it to a Ford SOHC 4.0 automatic. To tell you the truth the acceleration was better in the Ford. The RAnger pulled harder in my experience. At the same time I asked to drive a new Pathfinder with the 3.5. Whew we!! this is an awesome engine! This engine seemed to have no end in pulling and pulling and going and going, revs were wonderful. The Pathfinder with its 3.5 would eat any 4-runner for lunch and would give a V8 Explorer one heck of a run. I'm telling you Nissan needs the 3.5 in the Frontier. This would put the Frontier on top of Toyota, Ford and Chevy hands down. And I am a Ford fan! Tell the Nissan group to write Nissan and pressure them for the 3.5 in the Frontier, at least as an option if nothing else. I believe people would pay the extra $$$ for this wonderful engineering..
    Nissan says it won't fit in the current frontier, they state it's too wide to fit the e bay. They also stated that they want to keep 3.5 in the high end nissan and infiniti cars/suv's.
    CT;
    it's been awhile since I have driven the 4.0l, so I can't tell right now without driving again. But I was very happy with the performance and it was very smooth acceleration, not alot of kickback when you floored, this may be why Vince and others may think that the 4.0l pulls more on acceleration. I am not sure, but I think the times would be similar, not enough to make a difference.
    Hey Vince, Just busy with work and school, trying to get ready for my trip in December, going to Italy! Of course business slows down alot when you really need to make the money! Last month was very slow for all dealers, not alot of traffic. What did you think of the SC vs. the regular 3.3? Wdoyle is right, the VQ won't fit in the frontier platform, I still would not be surprised to see in the next 1-2 years, a 3.5-4.0l version of the same engine now with an optional SC.
    The SC was an improvement now doubt. The styling of the new Frontier kind of grows on you too. Now that I have seen a few around in different colors. I just wish that Ford would put better tires on their Rangers. The Firestones just scream cost cutting and cheap....
    Hey Vinny, just wanted to also say it is very nice conversing with you now, sure beats all of the reasearch we had to do right?, The thing I have always noticed about Nissan is they come out with a new design, alot of people talk about what a mistake it was, blah, blah, blah, then it goes away after awhile and folks really start to like it, this happened with the 95-99 maxima and the 2000 maxima, the 98 on up altima and now the new Frontier is growing on folks, we have been doing alot better with the frontiers the last two montha than the first month or so they came out. I like the tires they have been putting on the Frontiers,
    our SC has Firestone firehawks, alot of folks tell me those are good, the 15&16" have either generals or BF goodrich longtrail TA's, both great tires.
    The BFG's say quality and workmanship in my book. I have a very sour taste for Firestone. I personally believe they tried to bring Ford down with them. I keep reading rumors around the net that Ford is going to dump Firestone as is main supplier. Ford has also had closed door talks with Goodyear and Michellin. I hope this is true, I pray it is true.
    Hey, I also hear that Nissan is going to have a full size truck? Have any pictures?
    I agree with Vince, I think the Frontier would be a better truck with the 3.5L. What they should have done a is redesign the frontier frontend in the same design as the new Pathfinder. To me in all of the compact "truck/SUV" class the 2001 Pathfinder has by far the best looking frontend. Maybe if they used that fronend the 3.5L would have fit. I still laugh at the 2001 frontier front, it's stupid to have a mono-color plastic bumper on a pick up. I mean to me one of the nice things of owning a truck is if I accidently back into something(at low speeds of course)...no damage. If I'm parked in a parking lot and a shopping cart gets away and hits my front bumper...no damage. But just as it happened in the suv market several years ago, the compact truck market is switching to a grocery-getter market with plastic front bumpers, leather seats(still trying to figure out why this is offered in any pick up) and power seats.
    Oh well, different strokes for different folks.
    mah, you nailed it on the head. Trucks are turning into grocery getters. Why would anyone want leather in a truck???? 6 disc CD changer.. ect.... Plastic, painted bumpers are a huge mistake if you do any type of offroading...
    I disagree, vince. Not all hardworking trucks are offroaders. A lot of the contractors I worked with bought 4X4 just so they can hop the curb at the job site and go that 50 ft up in the muck following a hard rain. These are majority of the work truck buyers, not the folks who treat their pickups as offroad toys. It makes little difference whether your bumpers are painted, black, or chrome.
    Also, more and more of the contractors are turning their pickups into their mobile offices. So why not a little more creature comfort to go with the work truck. I don't see how a CD changer makes an otherwise identical truck any less capable.
    As for fitting VQ in the Frontier, I think Nissan should eventually do it for those VERY FEW who want and are willing to pay for the extra ponies and refinement in a compact package. The Frontier line looks like it will continue to grow in popularity and the volume might soon justify an even more expanded trim range.
    For me however, I would much rather Nissan spend the R&D budget on refining the existing 3.3L V6 and 2.4L I4 - the bread and butter of the Frontier line. If I want that much power in a work truck, a 1/2-ton full-size would be a much more appropriate platform. Unless of course, I just want a little play truck that get fling big rooster tails. :-)
  • david6david6 Member Posts: 75
    You just described me to a T. I'm getting a 4x4 Ranger not to go off roading, but to jump the curb and get to the building site through the mud and snow. However, I also go into tight parking situations a lot, so I'd rather have a compact truck. And since I'm in my truck so much, it has to be comfortable and fun, so I got a lot of the goodies, and the big engine. That way I get acceleration, and when I have to haul or tow comething heavy, I don't have any concerns (mainly, though, for the acceleration). I've got a dump truck when I need big and powerful, although I have to plan for it - I will be caught in situations where I'm on one job site, and realize that I should move ladders and the break to another, and my truck will carry all that on the rack almost as well as a full size. So I want a loaded, maybe too loaded, compact.
    I did consider the Frontier seriously, but I was able to get more power for much less money in the Ford, and based on what I found I'm not taking much of a hit in quality. However, if Nissan had a more powerful engine in the lineup (like the supercharged engine) for a competitive price I might have gone that way. But the prices I got weren't close. I did like the Frontier's bed-size and locking tailgate quite a bit, but didn't like the handling much. And the 3.3L that was similar in price didn't even compare to the (newer) Ford 4.0L. Maybe for my next truck . . . especially if the 3.5L goes into it or the 3.3L has more power, but at a reasonable cost. Of course, that assumes that the Ford dealer stops cutting their profit to the bone to get my business, something the Nissan dealer (understandably) didn't want to do.
    Its funny, as much as people think, Ford is not loosing money on the Ranger. Its called mass production. Ford makes thousands upon thousands of Rangers every year and gets deep discounts for the mass produced parts. Ford is just able to build a nice compact truck for less $$$$$..... Dealers are not selling these to the public at a loss either, they make money otherwise they wouldn't be in business...
    Sorry I missed the question about the full sized truck photo. I put it up awhile back on the driveway.com site that mahi and others have set up, but it is just an artist's idea of what it might look like, no official pictures yet. Also have you been following Nissan's financial situation lately? Better than expected turnaround has driven stock prices up, Nissan posted I think about a $2billion profit, and is building the new plant in Mississippi for the full sized truck, new van and full sized SUV, also DCX was so impressed with Ghosn's turnaround for Nissan they adopted his model for mitsubishi! You gotta admit, things are chugging along! Hope every one had a good t-day.
    You guys the point is that the trucks are going more "plastic". Bringing up you're example of work trucks at work sites is perfect. A plastic bumper or fairing(under the bumper)with fog/driving lights is in no-way as durable as say a chrome bumper. I or vince really weren't saying that the truck is "less" capable just no as "durable" as a whole. I look at say the newer generation GM full-size trucks('94-'99) used by the county gov't here and compare them to some of their older GM's(pre-'87 models) and the newer trucks 'show' alot more use because of some of the features. True black painted bumpers are second best because you just spray paint those and they don't show the marks, given no dents are present. As far as the offroading truck(PreRunners, Desert Runners, Edge) since this is what they are marketed as we are saying anybody that knows about 4-wheeling that you are going to run over things, things are going to kick up and hit your front bumpers. If they are painted then you end up with unnecessary gouges in your paint. Leather seats though are another whole thing. If you're at that muddy work site tropping through the mud are you just going to jump in the truck? Are you going to worry if you're crew jumping in the back are going to scrape their muddy boots across the back of the seats? What about that screw driver you left in you're back pocket?(cloth gives alot more than stiffer leather)Since i'm not in constuction my extra cirricular activities played a big reason why I didn't get leather(plus it wasn't an option on the Frontier, but I was looking at the F-250). I do alot of offshore fishing, duck hunting and I work out at the gym(everyday). The signifigance of the activities is that I'm usually wet when I get in my truck. But most people that have truck are very active people and are usually involved in activities that take place with the 'elelments' whether it's somebody like Vince that's an avid offroader or maybe somebody that is a hunter or a construction worker or a farmer. I could never see a construction company pay for leather seating anyway, unless it was for the owner or foreman(and even then it's a status thing- they get the better model truck). Don't get me wrong though, some of the things are nice to have and help bring pick up truck ownership to a more comfortable level.
    I do agree that metal parts is more durable than equivalent plastic parts. Heck, I still hang on to my 15-20 yr old cameras & lenses because they are solidly constructed with metal bodies. Then again, while the plastic bumpers and aprons commonly used on cars and trucks nowaday may not be as tough and durable as the old chromed hunk of steel, but they also weigh less and cost less to manufacture. Which generally means they are less to replace as well.
    Also, if hit a boulder with typical urethane plastic bumper apron, it deforms and then bounces back. Do that with a steel one and you end up with a dent period.
    Bear in mind that there are still steel reinforment beams underneath the plastic bumper covers so that crashworthness is not compromised, if not enhanced. Instead of having to provide a cosmetic skin, all the steel is used in the structural member. Plastic bumper covers take up the cosmetic part.
    As far as leather vs. cloth seats goes. Having had both in my vehicles, I'd say leather is actually more abrasion resistant and cleans up easier than fabric. Granted, it depends on the particular leather since some are softer and thinner than others, but the same goes for fabric as well.
    One might have reservations about parking a mud-soaked, grease-stained butt on expensive leather, butI can guarantee ya leather seat will stand up to it far better than a cloth one.
    I've worked with upholstry-grade leather, and I can tell you that a screwdriver would have punctured through any automotive fabric long before it'll do damage to a leather seat.
    I think this issue is somewhat akin to those sports car purists who think having a cupholder in a Porsche is a sacrilege, and that the presence of a Big Gulp gripper somehow makes it less of a sports car.
    Plastic bumper covers ove steel beams may not be as tough and macho as an all steel one, but it is every bit as functional and in many ways superior.
    .....but explain to me how it's superior, especially in MANY ways. Not trying to start a war here but chrome bumper is going to be much cheaper if you bend/dent it(if you have to replace it) than a plastic one. Have you ever seen underneath one of those plastic bumpers? Yeah, there's some steel under there(enough to pass standards)along with some collapsible braces and some times there's even styrofoam in there. But my point wasn't really about the safety factor so much as the "cosmetic" durability. Let's use your exapmle of hitting a rock. In fact this actually happened in my friend's '99 Pathfinder. We were backing out of a parking space but ran out of room, so we had to pull forward a little bit(jockeying it out because of the idiots parked too close behind us). As he pulled forward with the wheels cut all the way to the right he bumped the decorative boulder. Because the bumper/facia was plastic it gave so much that we didn't even feel it until the facia was pushed all the way in and the truck just stopped moving. Once we got out of there(like you said) we popped it out but to no avail the bumper facia had huge gouges in it. Now had it been a steel bumper we would have felt the 'bump' right away because with the steel bumper there is no "give" at that slow speed.
    I'm not saying that the plastics are bad per say just not fitting in the 4x4 arena. Because usually those that pay the extra money for the 4 wheel drive usually take them offroad and when you're offroad there's a good chance that you're going to hit something even if you don't mean to.
    As for the interior being leather I've had both too. Alot of this will depend on several things such as miles, how well taken care of and the grade of materials used. But really take a look at some older leather interiors(you say you've worked with some of these leathers, well I used to detail cars-had my own business)like Cadies, Mustangs, Porches comparably the leather has always shown age more strongly than it's cloth counterpart. Leather, as it's supposed to do, stretches, gets softer with the more use therfore it begins to wrinkle/crease, which is always a different color than the rest of the leather. It does this because there is no dye after the leather "breaks" to crease, it's the true leather color. You might be right, the screwdriver might not punchure through the leather as easily as the cloth but, I promise you that it will take less effort to scratch/scuff that nice leather.
    Again it's got nothing to do with being "Macho" rather more resistant to element use.
    That "macho" statement probably didn't come out right. I merely meant to say that some folks may prefer the rugged and solid appearance of all steel bumpers, more so than the actual functionality.
    This won't be a flame war unless we make it one, and I have no intention of doing so. I actually agree with a lot of what you've said. My point is that the use of plastics is simply another engineering compromise that has its advantages and disadvantages.
    The question you raised is a philosophical one. Sure a steel apron would have sent a stronger protest to the inattentive driver immediately upon hitting the boulder, but the unyielding nature of the steel apron will ensure that more damage is done. Think about it. A 3500lbs vehicle rolling into a boulder - something's gotta yield. And it sure ain't gonna be that boulder.
    Urethane plastic has pathetic yield strength compared to steel, yes. But it'll sustain way more elastic deformation before permanent damage occurs.
    Your friend would have ended up with permanent scratches and dents on a steel bumper apron. More rugged? Yes. Cosmetically superior? Debatable.
    And to make a steel bumper apron strong enough to survive such an incident unscathed would incur a weight penalty that I find objectionable. Others may disagree, of course.
    BTW, you make it sound like styrofoam in bumper designs is a bad thing. Th styrofoam acts to protect the vehicle occupants the same way the styrofoam in a fibreglass helmet protects its the cranial content. Engineered in concert with the other parts of the bumper system, it'll abosrb a huge amount of energy - albeit only once.
    Unlike an all steep bumper, which is traditionally designed to abosrb energy by deformation, the composite bumpers of today is designed to absorb energy by failure. The carbon fibre chassis in Formula One cars is designed to absort crash energy in the same failure mode.
    Like the plastic aprons, the styrofoam may not appear as sustantial as good ol' steel, but its function is nothing to scuff at.
    Well,
    It was bound to happen, at 28,000 miles I finally had a warranty claim, my parking light burned out, had it replaced under warranty, I was actually expecting to pay for it! Take care everyone, Vinny, where ya been man? Keeping those tacoma guys in line? Happy holidays.
  • eharri3eharri3 Member Posts: 640
    gotta agree.... a painted plastic bumper is gonna get all nicked and scratched and start to look kinda ugly after a few years, from all the dirt and rocks that bounce up or fly back and hit it at highway speeds. This is usually where you see the first dents and scrapes on cars with monochromatic paint schemes that are over a few years old.
  • cygnusx1cygnusx1 Member Posts: 290
    MAn, I just went to this site for kicks since I like to check up on recalls, tsbs, etc every now and then. If you look in the CONUMER COMPLAINTS area and type in any recent model Ford Rager (like the 1998 POS I had that Ford bought back from me because it fell apart) the list of complaints is endless (and still growing). "No Boundaries (except reliabity)"
  • axle59axle59 Member Posts: 28
    I bought a 2001 XE king cab desert runner last night and one of the first things out of my buddies mouth when he saw it this morning was "man, nissan must have bought stock in rubbermaid huh"
