Was feeling pretty good this morning, and was rather entrapped by a bunch of 18 wheelers;
Got on the pedal, hit 100Mph and pulling hard.
First time ever. 01 LE at 15,000 miles.
Loved it!
Bob
Now, in the rain, those brakes are terrible. If I'm driving in heavy rain on the highway the first time I hit the brakes nothing happens and I get alot of pedal resistance. I have to pump the pedal to get some braking effect. Not good.
I guess we have different ideas of fun. I kinda like a car to stick.
-juice
I'm down at my friends house right now. I was able to drive the whole way with the top down. It was so fun! I only got a minor sunburn on my nose and cheeks. The car rode smooth and was perfectly happy cruising at 80. I even briefly hit 95 and the wind buffeting wasn't bad at all. It didn't drink a drop of oil and the oil still looks clean, so this engine is in great condition still. My only gripe is the way too short 5th gear. 4200 rpms at 80??! Talk about sucking gas down, although 28 mpg isn't horrible. I would think the trannys wouldn't last real long with such high stress. I know my 84 GTI, which is also known for its short gearing (4000 at 80), blew the 5th gear right off the shaft doing 75. Of course, this tranny was known for this problem because VW, in its infinite wisdom, decided to save a few cents per car by deleting a clip that was supposed to keep the gear in place. The high rpms on the highway causes the gear to self destruct after 150-170k miles of wear. Any such known problems like this with the Miata? Oh, my friend absolutely loved the car. Now he wants one, hehehehe I finally trumped the Jones. Funny, it took buying a 10 year old used car to do it.
I was concerned about passing the NC inspection with e-codes, so I waited until after I got an inspection to install them. I asked the guy doing the inspection if he would have noticed that they weren't DOT legal. He said he had 2 miatas with e-codes on both of them, and that no one would look for that during an inspection (at least in NC).
It took all of about 20 minutes to remove the sealed beams and replace with the e-codes. Just make sure you don't touch the bulbs with your fingers, they say it significantly shortens their life if the oils from your skin get on them.
The sharp cutoff of the low beams makes the lights very easy to aim and the 80 watts don't seem to bother anyone, in the the year that they have been installed I haven't had anyone blink at me yet.
Looks like the 712 is not available in 14".
Ok, yo tengo una pregunta. Somebody posted here awhile back about a colored wax system that restores the paint to a natural shine. I can't find the post.
Can someone repost the name brand? My Mica Blue 92 still looks good, but the years are slowly catching up to her. The wind scratches are becoming more visible and the blue isn't as dark as I'd like it to be.
Hope all is well with everyone else. Keep the ideas coming. This is a great board...
Eddie
Steve summarized the E-code story very well. I used H4 bulbs with 55/60 wattage, same as stock. I'll go ahead and e-mail you a photo, you'll see how they are night-and-day better than the factory sealed beams of the same wattage.
I cannot even imagine what they'd be like with 80/100 watt bulbs. Though the E-codes are glass and metal, so I be they're better able to withstand the heat than other encasements.
-juice
BTW, it is great to be back in my car again, and coming from the Accent, I feel like I'm driving a Ferrari!
thx,
javadoc (hi malt, I see you're here)
You might want to look into getting a tonneau. It'll help keep you warmer when you drop the top on those balmy Alaskan Spring days.
That's exactly why I chose a '93. It was the last year with a single air bag, and I have a little tot that I'd eventually like to take with me.
If you want that 2nd air bag, the 94s also get bigger brakes, more chassis bracing, and the 1.8l engine. Mileage went from 25/30 to 22/27 on the EPA cycle, though, but they feel more torquey.
I added the chassis bracing to my '93, but I won't bother with the brakes because I don't autocross. Mine's been perfect for about the year and half I've owned it.
-juice
Also, what kind of horn did you install? Can you add a dual horn setup to the stock one horn wiring?
I'll have to keep my eyes peeled for a good car, thx!
/java
I want to say that the vibes at highway speeds have lessened, but it might be in my head.
I think the '99 and later models have a key to disable to air bag? Can anyone confirm? If I swap, that's what I would get.
-juice
I'll miss my barn doors, though.
-juice
/j
Java, are Candian spec cars "legal" up in Alaska? If so, the early cars don't have a driver's airbag either. Makes it easier to add a Momo/Nardi steering wheel :O)
-juice
/j
You'll only have bugs on your teeth if you're 6'7".
-juice
For those who don't know, the loctite fix consists of pulling off the crankshaft pulley, replacing the front oil seal, installing a new woodruff key, and loctiting it in place with 252 loctite (the red, "permanent" kind). You replace the pulley and install a new crank bolt, which you also loctite in place. If memory serves, there are people who have done this after the crank failed and have gone 100,000 trouble free miles. The repair works so well that now it is being done as a preventive.
thx,
java
http://www.miata.net/garage/crankshaft.html
Keep in mind that this document was written long ago. The loctite repair is mentioned only very briefly at the end, probably just recently added, but by all accounts, it works, and works well.
There's a guy on Miata.net (Jeff Anderson) that will fix the radio to function as intended, replace the little bulbs that tend to burn out, and send you directions to correctly phase the speaker wiring. I sent my radio to him and added the speakers and wiring harness from PBC. Now I can actually hear the music (and feel the bass) with the top down at highway speeds.
As for the battery, I'd make sure you had the gel type. You really don't want the liquid type, since its in the trunk. The original Panasonics have been known to last up to 8-10 years. When I bought my '92 it had the "wet cell" type. One of the first things I did was order a replacement Westco gel type. I think they are about $80 shipped. You might want to go to miata.net and do a search on "replacement battery" because I seem to remember that there is another replacement gel type that was getting positive reviews.
KBB or Edmunds can price it out. Both include a credit for low mileage. The credit is relatively high - you may have trouble selling it for as much as they say it's worth, actually.
I bought a '93 with 26k miles, the blue book at the time, with mileage credits, was $11,400, but I "stole it" for $7,800. That was full asking price, by the way, it was just low. But I doubt anyone would have paid the full $11,400, because at that price range they're looking for cars 4-5 years newer. Good luck.
-juice
When I was shopping for my Miata (the funnest car I have ever had), my husband tried his best to talk me out of buying as he calls it "a motorcycle on four wheels". I have not regretted purchasing my car and after my accident, I know I made the right choice.
Miatas don't need a lot of CCAs, so the small, light battery is fine. I wouldn't put one on a big V6 or V8, though.
Way to stick up for your wants and needs, Jamie. Glad to hear it held up well against a sport/brute.
-juice
Ingtonge - go ahead and replace your battery while you still have choice. I tried to milk my battery for the last 1000 miles and I had to settle for the wet replacement Mazda is currently selling - I had to jump my car to even get to the dealer. Since it's my daily driver, I couldn't wait around to have a gel shipped. I'll live with the wet cell until it starts getting flaky or leaky (which is a pain since I never had to think about the battery before).
