Mazda5 Owners: Problems & Solutions
I reported it to my dealer but they didn't pay much attention.
4 winter tires (from local Walmart) P205/55R16 + 4 steel wheels (from local merchant) = 650$ tx incl.
Tried them in Montreal area yesterday, work very well on snow, and very acceptable on ice.
Any help would be great. Thanks! :sick:
The tire warranty paper should be in the little book with the owners manual.
On a happier note, I got my check today! I guess you don't have to get it fixed to get one, it says for our "frustration".
HiFive
Brrrr.
I am still waiting for my check here in New York, has everyone who is on the east coast gotten it already?
Today though, my 'Check engine' light came on. I thought this was pretty odd since I barely have 1000 miles on my 5 at this point. I called the dealer, and they said the most common reason for the check engine light was either that the gas cap was not securely fastened, or the tank was overfilled. Either way, I'll have to bring the car in to have them check the diagnostic code and reset the light.
While on one hand, I hope its something as simple as a loose gas cap, on the other hand, I'm incensed that Mazda would cause the car to throw a code that can ONLY be reset by the DEALER for something as trivial as that. Or the overfilling of the tank, for that matter. What is the solution to an overfilled tank? Duhhh, drive it a couple miles, maybe? If a tank is 'over-full', doesnt that just mean its going to start spilling out on the ground?
In either scenario, I dont see a reason to throw a code that requires a service visit. While it may be paid for by the dealer while the car is under warrantee, its an inconvenience for me to have to drive to the dealer and lose the use of the car while they 'diagnose' it. What happens after the car is out of warrantee? Am I going to have to pay for a service visit every time I don't screw the gas cap on tightly enough? Great way to guarantee revenue for your dealer network, Mazda!
Also, while Im on my gripe box, is anyone else hitting curbs with the rims on these things? I didn't notice (until after I took a chunk out of one) how far the rim is offset from the actual rubber. It sticks out like 1/2", guaranteeing you'll always hit the rim before the tire if you get too close to a curb with the wheel turned. Maybe its just me, but I've owned two other vehicles at the house I currently occupied, and I've never bit the curb as many times as I have in the 5.
Anyone else throw a check engine light code? How long does it take them to diagnose/reset them?
This isn't unique to Mazda. Regulations for evaporative emissions have gotten really strict over the past few years and indeed the "check engine soon" light on all cars is intended to signal an open loop in the fuel system... the most common of which is a loose gas cap.
I dont have a problem with signaling a warning, but I don't see any reason to make something so trivial a persistent code that only the dealer can reset.
Whats next,you have to have the dealer reset your 'door ajar' light?
:confuse:
Our VW does the same thing. Emissions regulations.
Amazon. You may also find that your local autoparts franchise store offers a use-it-for-free-in-our-parking-lot tool.
For a little more money, there's a version that captures a couple days of detailed OBD data and then dumps it to your PC, so you can see a graph of your gas mileage and how far/fast your teenager drove the car last night.
pagetuner
http://pagetuner.com/mazda5/
A short cut is to refill the gas tank (without topping off) making sure the cap is placed correctly/tightly. Then, go home and disconnect the negative battery cable for at least a half hour. Though, be prepared to loose certain settings like your radio, clock, etc.
The light should be off when you reconnect the battery cable and turn on the car. However, if there is still an issue (whether gas or some other emission), the code will re-flash and the light will come on after several starts and/or several miles (approx. 150 miles).
I don't know what kind of people have the time to drive to the gas station, buy more gas when its not needed, filling up, making sure to put the gas cap on 'correctly'(just for the record, Im 36 years old and have owned about 15 vehicles in my lifetime. There was nothing wrong with the way the gas cap was put on. I know how to put a gas cap on), and then disconnect the battery just to reset the code. My gripe is that its a waste of time to take it to the dealer in the first place.
Why would I waste what in all likelihood would be even MORE time driving around and disconnecting batteries, if my gripe was that its a waste of time? I mean, I understand they're trying to help, but sheesh.
But yeah, I think all manufacturers have had to use OBDII diagnostics in the U.S., regardless of country of origin, so if theres a consumer device that can read/reset codes, it'll probably work on the Mazda. I'll let the group know how it goes.
Im just parking a mile away from it now to 'curb' further damage, but I feel like a little old lady every time I do it. Oh well.
I wish I could just fill the gas tank once and drive for the next 100,000 miles. What a waste of time having to fill up week after week. That's approx. 52 times a year. And what about oil changes every 5,000 miles? Why can't it be every 500,000 miles?
Hey, I was only trying to help. The battery cable trick got me past a couple of state inspections without having to take it to the dealer.
Now, about the wheels and the curb...Pretend u r driving a Ferrari, not a Hummer (or Pathfinder)
For the record, I went to my local Autozone, who have an OBDII codereader, but go figure, Mazdas OBDII port must have some extra pin in it so that aftermarket readers wont work with it, because they tried two of them and they wouldnt communicate with it.
So, whenever the dealer decides to 'fit me in', I can find out whether Im capable of screwing on a gas cap correctly or not.
If this doesn't work the dealer can reset the light. Both the Kia and the Suzuki could only be reset by the dealer so Mazda is not alone here. I believe all vehicles require the dealer only to do this. The reason is that, if there really is a problem, you could blow your warranty by not getting it fixed. If you could just keep resetting the light yourself, a real problem would continue until it cases damage to the car.
Hard to come by this NEW windshield. Sucks to have to deal with this... just wanted to share my pain... but I must say I love my Mazda5..
Have a nice day and happy holidays.
Oh Yeah.. I got my $500 check about two Fridays ago..
Any ideas? Am I just being picky?
I'm looking forward to taking a road trip with the MZ5.
Yes, I have tried any possible adjustment (bottom seat down, bottom seat on angle, reclining back seat one more position, etc.). As per Wuster's comment, for my wife is perfect as well, no complaints there.
I can live with it but I hope there is a way of tweaking it, otherwise I will have to use the Cruise Control more often
I am 6'3" and I don't have a big problem with the legroom. I haven't been on a long trip with it yet so we'll see how that works out. The only problem I have is that the gas and brake pedals are too close together and my size 12 foot can get caught on the bottom of the brake pedal when I'm going from the gas to the brake.
Yup, I married an itsy bitsy blonde. But I'm no towering giant either. So it works out fine for us.
I'm not having legroom problems either, and I've put roughly 3500 miles on the car so far (longest trip being 5 hours at a time).
I'm 5'11" and I'm most comfortable when the seat's roughly halfway back...not really anywhere near the furthest-back position. So I guess the comfort problems reported here have more to do with "leg length" than overall height...either that or it's just different notions of what's comfortable and what seating positions people prefer.
It's most noticeable at low speeds (1st/2nd gear). I think it only happens when the car is cold, but I can't be sure.
I've had the recall work done. Has anyone experienced something similar? Any ideas on what the cause could be?
